This using a USB connection btw. NOT bluetooth. Gamepad works fine but the headset isnt being seen by anything. Mute button light doesnt even light up when i hit it.
I should also mention that I want the computer audio like games and stuff to use the 5.1 surround that I have, I just want comms to use headset/mic.
Kernel: 5.15.21-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=356e0855-8f86-4587-b1ae-782feb433691 rw quiet splash apparmor=1
Desktop: GNOME 41.3 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.3
Type: Desktop Mobo: Micro-Star model: B450 GAMING PRO CARBON AC (MS-7B85)
v: 1.0 serial: <superuser required> UEFI: American Megatrends v: 1.C0
date: 06/11/2020
RAM: total: 31.36 GiB used: 6.31 GiB (20.1%)
RAM Report:
Info: model: AMD Ryzen 7 2700X bits: 64 type: MT MCP arch: Zen+
family: 0x17 (23) model-id: 8 stepping: 2 microcode: 0x800820D
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 768 KiB desc: d-8x32 KiB; i-8x64 KiB L2: 4 MiB desc: 8x512 KiB
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 2888 high: 4201 min/max: 2200/3700 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 4052 2: 2283
3: 2100 4: 2123 5: 4201 6: 3953 7: 2099 8: 2099 9: 4187 10: 2104 11: 2401
12: 2096 13: 4118 14: 4186 15: 2107 16: 2109 bogomips: 118437
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm
mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
pse36 rapl rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap
smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock
syscall tce topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme
vmmcall wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
disabled, RSB filling
Device-1: NVIDIA TU106 [GeForce RTX 2070] vendor: Micro-Star MSI
driver: nvidia v: 510.47.03 alternate: nouveau,nvidia_drm bus-ID: 26:00.0
chip-ID: 10de:1f02 class-ID: 0300
Display: x11 server: X.org 1.21.1.3 compositor: gnome-shell driver:
loaded: nvidia resolution: <missing: xdpyinfo>
OpenGL: renderer: NVIDIA GeForce RTX 2070/PCIe/SSE2
v: 4.6.0 NVIDIA 510.47.03 direct render: Yes
Device-1: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 26:00.1 chip-ID: 10de:10f9
class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 28:00.3 chip-ID: 1022:1457
class-ID: 0403
Sound Server-1: ALSA v: k5.15.21-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.45 running: no
Device-1: Intel I211 Gigabit Network vendor: Micro-Star MSI driver: igb
v: kernel port: f000 bus-ID: 22:00.0 chip-ID: 8086:1539 class-ID: 0200
IF: enp34s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Intel Wireless-AC 9260 Bluetooth Adapter type: USB driver: btusb
v: 0.8 bus-ID: 5-4:3 chip-ID: 8087:0025 class-ID: e001
Local Storage: total: 14.1 TiB used: 7.16 TiB (50.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 2B6Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 840 EVO 250GB
type: SSD serial: <filter> rev: BB6Q scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 860 EVO 1TB
type: SSD serial: <filter> rev: 3B6Q scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 vendor: Seagate model: ST2000DL004 HD204UI
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 5400 serial: <filter> rev: 0001 scheme: MBR
ID-5: /dev/sde maj-min: 8:64 type: USB vendor: Western Digital
model: WD60 01FZWX-00A2VA0 size: 5.46 TiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: 0004 scheme: GPT
ID-6: /dev/sdf maj-min: 8:80 type: USB vendor: Western Digital
model: WD60EZAZ-00ZGHB0 size: 5.46 TiB block-size: physical: 512 B
logical: 512 B type: HDD rpm: 5400 serial: <filter> rev: 0102 scheme: GPT
Optical-1: /dev/sr0 vendor: PIONEER model: BD-RW BDR-209D rev: 1.51
dev-links: cdrom
Features: speed: 125 multisession: yes audio: yes dvd: yes
rw: cd-r,cd-rw,dvd-r state: running
ID-1: / raw-size: 48.83 GiB size: 47.76 GiB (97.81%) used: 23.49 GiB (49.2%)
fs: ext4 dev: /dev/sda5 maj-min: 8:5 label: N/A
uuid: 356e0855-8f86-4587-b1ae-782feb433691
used: 25.2 MiB (26.3%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 9C87-C8B2
ID-3: /mnt/1tb raw-size: 931.5 GiB size: 931.5 GiB (100.00%)
used: 667.4 GiB (71.6%) fs: ntfs dev: /dev/sdc2 maj-min: 8:34
label: 1TB Games uuid: F47C94387C93F418
ID-4: /mnt/ssd raw-size: 232.88 GiB size: 232.88 GiB (100.00%)
used: 128.38 GiB (55.1%) fs: ntfs dev: /dev/sdb1 maj-min: 8:17
label: 250GSSD uuid: 6CCA16C8CA168F08
ID-5: /run/media/valdarious/ACB08A1FB089F05E raw-size: 183.45 GiB
size: 183.45 GiB (100.00%) used: 83.11 GiB (45.3%) fs: ntfs dev: /dev/sda3
maj-min: 8:3 label: N/A uuid: ACB08A1FB089F05E
ID-6: /run/media/valdarious/MediaBackup raw-size: 5.46 TiB
size: 5.46 TiB (100.00%) used: 4.86 TiB (89.1%) fs: ntfs dev: /dev/sde2
maj-min: 8:66 label: MediaBackup uuid: 96EE0B81EE0B58BF
ID-7: /run/media/valdarious/Mediabackup2 raw-size: 5.46 TiB
size: 5.46 TiB (100.00%) used: 207.23 GiB (3.7%) fs: ntfs dev: /dev/sdf2
maj-min: 8:82 label: Mediabackup2 uuid: CCACCD39ACCD1EB8
ID-8: /run/media/valdarious/VideoPool raw-size: 1.82 TiB
size: 1.82 TiB (100.00%) used: 1.21 TiB (66.7%) fs: ntfs dev: /dev/sdd1
maj-min: 8:49 label: VideoPool uuid: 309C2B1E9C2ADDDA
ID-1: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/sda4 maj-min: 8:4 size: 498 MiB fs: ntfs label: N/A
uuid: 6EA2A257A2A22415
ID-3: /dev/sdc1 maj-min: 8:33 size: 16 MiB fs: <superuser required>
ID-4: /dev/sde1 maj-min: 8:65 size: 128 MiB fs: <superuser required>
ID-5: /dev/sdf1 maj-min: 8:81 size: 16 MiB fs: <superuser required>
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Hub-2: 1-2:2 info: Hitachi ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 045b:0209 class-ID: 0900
Hub-3: 1-2.1:4 info: Hitachi ports: 4 rev: 2.1 speed: 480 Mb/s
Device-1: 1-3:3 info: Microsoft Controller type: <vendor specific>
driver: xpad interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 500mA
chip-ID: 045e:0b00 class-ID: ff00 serial: <filter>
Device-2: 1-4:5 info: N/A type: Abstract (modem),CDC-Data driver: cdc_acm
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 11f1:2514
class-ID: 0a00 serial: <filter>
Device-3: 1-7:6 info: Cooler Master AMD SR4 lamplight Control
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 2516:0051 class-ID: 0300
Device-4: 1-8:7 info: Corsair Gaming K68 Keyboard type: Keyboard,HID
power: 500mA chip-ID: 1b1c:1b3f class-ID: 0300 serial: <filter>
Device-5: 1-9:8 info: Logitech G403 HERO Gaming Mouse type: Mouse,HID
power: 300mA chip-ID: 046d:c08f class-ID: 0300 serial: <filter>
Hub-4: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-5: 2-2:2 info: Hitachi ports: 4 rev: 3.0 speed: 5 Gb/s
chip-ID: 045b:0210 class-ID: 0900
Hub-6: 2-2.1:3 info: Hitachi ports: 4 rev: 3.0 speed: 5 Gb/s
Device-1: 2-2.2:4 info: JMicron USB to ATA/ATAPI Bridge type: Mass Storage
driver: uas interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 8mA
chip-ID: 8882:009d class-ID: 0806 serial: <filter>
Device-2: 2-2.3:5 info: JMicron / JMicron USA USB to ATA/ATAPI Bridge
type: Mass Storage driver: uas interfaces: 1 rev: 3.1 speed: 5 Gb/s
power: 8mA chip-ID: 152d:9561 class-ID: 0806 serial: <filter>
Hub-7: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-8: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-9: 5-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 5-3:2 info: Micro Star PRO CARBON 12 type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
power: 500mA chip-ID: 1462:7b85 class-ID: 0300 serial: <filter>
Device-2: 5-4:3 info: Intel Wireless-AC 9260 Bluetooth Adapter
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0025 class-ID: e001
Hub-10: 6-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
Device-1: 6-1:3 info: JMicron / JMicron USA JMS567 SATA 6Gb/s bridge
type: Mass Storage driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s
power: 896mA chip-ID: 152d:0567 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 57.4 C mobo: N/A gpu: nvidia temp: 48 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 17%
Processes: 385 Uptime: 1h 28m wakeups: 0 Init: systemd v: 250
tool: systemctl Compilers: gcc: N/A Packages: pacman: 1301 lib: 428
flatpak: 0 Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.12
