Hello,
I’ve recently got my hands on a free Samsung LE26R73BD, and am currently testing it. It has a resolution of 1366x768.
In the manual it says that the HDMI connection shouldn’t be connected to a PC, as it will result in a blank display, however, it does give an output despite that. This output is however not scaled properly, and the initial issue seems to be that manjaro only lets me maximally use 1280x720p output for the TV. It does say that it can connect consoles to the TV though, giving a list of supported resolutions (presumably from the console): (1080i, 720p, 480p)@60hz, (1080i, 720p, 576p, 480p)@50hz, (1080i, 720p, 576p, 576i, 480p, 480i)@component
Otherwise regarding PC, it says it can do VGA, maximally at 1360x768, and supports a bunch of other resolutions.
I’m not exactly sure what to do to get this TV to work properly, or if it is even entirely possible, via HDMI. I don’t have a VGA adapter or VGA card available at the moment, and ideally I would want HDMI anyways. I have read through some of the arch wiki, and some forum posts on both the manjaro and arch forums, but I don’t feel confident enough in my linux abilities to entirely understand all of it. I have tried to manually add and force an output via xrandr however, but again, I’m not sure if I am doing this correctly.
cvt 1360 768
outputs
# 1366x768 59.80 Hz (CVT) hsync: 47.72 kHz; pclk: 84.75 MHz
Modeline "1360x768_60.00" 84.75 1366 1431 1567 1776 768 771 781 798 -hsync +vsync
Following that, i tried xrandr --newmode, xrandr --addmode, and xrandr --output with the relevant resolution information. In xrandr it says it has the 1360 resolution, but in the KDE display configuration it says it is 1366 instead. When selecting them in either terminal or gui, it produces a black screen on the TV with the message “mode not supported”.
I have also get and parsed the EDID of the TV, but I don’t know how to interpret it.
Section "Monitor"
Identifier "SAMSUNG"
ModelName "SAMSUNG"
VendorName "SAM"
# Monitor Manufactured week 47 of 2006
# EDID version 1.3
# Digital Display
DisplaySize 160 90
Gamma 2.40
Option "DPMS" "false"
Horizsync 15-46
VertRefresh 50-61
# Maximum pixel clock is 80MHz
#Extension block found. Parsing...
Modeline "Mode 8" +hsync +vsync interlace
Modeline "Mode 0" +hsync +vsync
Modeline "Mode 1" +hsync +vsync
Modeline "Mode 2" 74.250 1280 1390 1420 1650 720 725 730 750 +hsync +vsync
Modeline "Mode 3" 74.250 1280 1720 1760 1980 720 725 730 750 +hsync +vsync
Modeline "Mode 4" 74.250 1920 2008 2052 2200 1080 1082 1087 1125 +hsync +vsync interlace
Modeline "Mode 5" 74.250 1920 2448 2492 2640 1080 1082 1089 1125 +hsync +vsync interlace
Modeline "Mode 6" 27.027 720 736 798 858 480 489 495 525 -hsync -vsync
Modeline "Mode 7" 27.000 720 732 796 864 576 581 586 625 -hsync -vsync
Modeline "Mode 9" +hsync +vsync interlace
Modeline "Mode 10" -hsync -vsync
Modeline "Mode 11" -hsync -vsync
Option "PreferredMode" "Mode 8"
EndSection
Some possibly relevant inxi -Fxxn information:
Kernel: 6.10.13-3-MANJARO arch: x86_64 bits: 64
compiler: gcc v: 14.2.1
Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A wm: kwin_x11 dm: SDDM
Info: 8-core model: AMD Ryzen 7 5700U with Radeon Graphics bits: 64
type: MT MCP arch: Zen 2 rev: 1
Device-1: Advanced Micro Devices [AMD/ATI] Lucienne vendor: Lenovo
driver: amdgpu v: kernel arch: GCN-5 pcie: speed: 8 GT/s lanes: 16 ports:
active: HDMI-A-1,eDP-1 empty: DP-1 bus-ID: 04:00.0 chip-ID: 1002:164c
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 3200x1080 s-dpi: 96
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 pos: bottom-l model: Samsung
res: 1280x720 dpi: 203 diag: 184mm (7.2")
