Hello, I’m trying to get a custom docker container that worked on Ubuntu. The command first command I need to get fails:
wget -qO- *| sudo sh &&
sudo usermod -a -G docker $USER &&
sudo shutdown -r 0
*instead of this it’s a link as get.docker … etc. (can’t post links).
with the error:
*# Executing docker install script, commit: 7cae5f8b0decc17d6571f9f52eb840fbc13b2737
You’ll have to install the docker package from the community repo first, then pull the container with docker pull as you normally would do.
Be aware that there’s currently an issue reported with docker on the stable branch, so it might not work either, at least until the issue gets resolved.
You may want to try the package podman-docker as well.
we not have container in git{lab,hub} ! we have scripts for create local container with docker or docker-compose
without your gitlab url , not possible to answer you , use </> btn
https://gitlab.com/url
generally : sudo systemctl start docker; git clone url ; cd directory; sudo docker run (read docker doc…)
Ah indeed, I didn’t post the link since I registered recently.
Also, manage to open the link and found docker pull..
and wget ..
commands and I am currently executing them so I will see if it will work.
I installed docker using via pacman and started it as systemctl start docker
Currently waiting for it all to download, then I will try to launch it with: sudo -E start_container
Btw, thanks a lot!
EDIT:
There was a #!bin/bash command before the docker pull registry .., but I skipped that since it didn’t want to run with that.
