Hi, I ran into the fact that in tty and during boot I have a problem with the screen resolution (apparently it is 1024x768), however on Fedora I did not have such problems (I also used proprietary drivers), I tried to find out how Fedora defines the screen resolution. I was told that Kernel mode setting (KMS) is being used.
I followed the archwiki and I tried late KMS start , specified nvidia-drm.modeset=1
kernel parameter, but it did not help me.
Then I tried Early KMS start, it also did not help me, but it fixed plymouth , now it is displayed correctly during boot, but if you press esc it goes back to the incorrect resolution after a couple of seconds and vice versa to normal if you return to plymouth screen.
What can be done to fix the resolution in the tty and at boot time?
inxi -v7azy
Kernel: 5.17.0-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.17-x86_64
root=UUID=44bb182f-f8d0-4fcc-99c0-ed01074ebcf1 rw quiet splash apparmor=1
security=apparmor udev.log_priority=3 nvidia-drm.modeset=1
Desktop: GNOME v: 41.4 tk: GTK v: 3.24.33 wm: gnome-shell dm: GDM v: 41.3
Type: Desktop System: ASUS product: All Series v: N/A
serial: <superuser required>
Mobo: ASUSTeK model: B85M-G v: Rev X.0x serial: <superuser required>
UEFI: American Megatrends v: 2501 date: 07/22/2015
RAM: total: 7.7 GiB used: 2.43 GiB (31.6%)
RAM Report:
Info: model: Intel Celeron G1840 bits: 64 type: MCP arch: Haswell family: 6
model-id: 0x3C (60) stepping: 3 microcode: 0x28
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 128 KiB
desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB desc: 2x256 KiB L3: 2 MiB
desc: 1x2 MiB
Speed (MHz): avg: 2465 high: 2605 min/max: 800/2800 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 2605 2: 2325
bogomips: 11178
Flags: abm acpi aperfmperf apic arat arch_perfmon bts clflush cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept
ept_ad erms est flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs
invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe msr
pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good sdbg sep ss ssbd
sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer vme vmx vnmi vpid xsave xsaveopt xtopology
xtpr
Type: l1tf
Device-1: NVIDIA GF108 [GeForce GT 730] driver: nvidia v: 390.147
alternate: nouveau,nvidia_drm pcie: gen: 2 speed: 5 GT/s lanes: 16 ports:
active: none off: VGA-1 empty: DVI-I-1,HDMI-A-1 bus-ID: 01:00.0
chip-ID: 10de:0f02 class-ID: 0300
Display: x11 server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.0
compositor: gnome-shell driver: X: loaded: nvidia gpu: nvidia display-ID: :1
screens: 1
Screen-1: 0 s-res: 1600x900 s-size: <missing: xdpyinfo>
Monitor-1: VGA-1 mapped: VGA-0 note: disabled model: LG (GoldStar) W2043
serial: <filter> built: 2009 res: 1600x900 hz: 60 dpi: 92 gamma: 1.2
size: 443x249mm (17.44x9.8") diag: 515mm (20.3") ratio: 16:9 modes:
max: 1600x900 min: 640x480
OpenGL: renderer: GeForce GT 730/PCIe/SSE2 v: 4.6.0 NVIDIA 390.147
direct render: Yes
mhwd -li
Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-nvidia-390xx 2021.12.18 false PCI
/etc/mkinitcpio.conf
# vim:set ft=sh
# MODULES
# The following modules are loaded before any boot hooks are
# run. Advanced users may wish to specify all system modules
# in this array. For instance:
# MODULES=(piix ide_disk reiserfs)
MODULES=(nvidia nvidia_modeset nvidia_uvm nvidia_drm)
# BINARIES
# This setting includes any additional binaries a given user may
# wish into the CPIO image. This is run last, so it may be used to
# override the actual binaries included by a given hook
# BINARIES are dependency parsed, so you may safely ignore libraries
BINARIES=()
# FILES
# This setting is similar to BINARIES above, however, files are added
# as-is and are not parsed in any way. This is useful for config files.
FILES=""
# HOOKS
# This is the most important setting in this file. The HOOKS control the
# modules and scripts added to the image, and what happens at boot time.
# Order is important, and it is recommended that you do not change the
# order in which HOOKS are added. Run 'mkinitcpio -H <hook name>' for
# help on a given hook.
# 'base' is _required_ unless you know precisely what you are doing.
# 'udev' is _required_ in order to automatically load modules
# 'filesystems' is _required_ unless you specify your fs modules in MODULES
# Examples:
## This setup specifies all modules in the MODULES setting above.
## No raid, lvm2, or encrypted root is needed.
# HOOKS=(base)
## This setup will autodetect all modules for your system and should
## work as a sane default
# HOOKS=(base udev autodetect block filesystems)
## This setup will generate a 'full' image which supports most systems.
## No autodetection is done.
# HOOKS=(base udev block filesystems)
## This setup assembles a pata mdadm array with an encrypted root FS.
## Note: See 'mkinitcpio -H mdadm' for more information on raid devices.
# HOOKS=(base udev block mdadm encrypt filesystems)
## This setup loads an lvm2 volume group on a usb device.
# HOOKS=(base udev block lvm2 filesystems)
## NOTE: If you have /usr on a separate partition, you MUST include the
# usr, fsck and shutdown hooks.
HOOKS="base udev autodetect modconf block keyboard keymap consolefont plymouth filesystems fsck"
# COMPRESSION
# Use this to compress the initramfs image. By default, gzip compression
# is used. Use 'cat' to create an uncompressed image.
#COMPRESSION="gzip"
#COMPRESSION="bzip2"
#COMPRESSION="lzma"
#COMPRESSION="xz"
#COMPRESSION="lzop"
#COMPRESSION="lz4"
#COMPRESSION="zstd"
# COMPRESSION_OPTIONS
# Additional options for the compressor
#COMPRESSION_OPTIONS=()
/etc/default/grub
GRUB_DEFAULT=saved
GRUB_TIMEOUT=15
GRUB_TIMEOUT_STYLE=hidden
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash apparmor=1 security=apparmor udev.log_priority=3 nvidia-drm.modeset=1"
GRUB_CMDLINE_LINUX=""
# If you want to enable the save default function, uncomment the following
# line, and set GRUB_DEFAULT to saved.
GRUB_SAVEDEFAULT=true
#GRUB_ENABLE_CRYPTODISK=y
GRUB_TERMINAL_INPUT=console
#GRUB_TERMINAL_OUTPUT=console
GRUB_GFXMODE=1600x900
GRUB_GFXPAYLOAD_LINUX=keep
#GRUB_DISABLE_LINUX_UUID=true
GRUB_DISABLE_RECOVERY=true
GRUB_DISABLE_OS_PROBER=false
# Uncomment and set to the desired menu colors. Used by normal and wallpaper
# modes only. Entries specified as foreground/background.
#GRUB_INIT_TUNE="480 440 1"
# Uncomment to ensure that the root filesystem is mounted read-only so that
# systemd-fsck can run the check automatically. We use 'fsck' by default, which
# needs 'rw' as boot parameter, to avoid delay in boot-time. 'fsck' needs to be
# removed from 'mkinitcpio.conf' to make 'systemd-fsck' work.
# See also Arch-Wiki: https://wiki.archlinux.org/index.php/Fsck#Boot_time_checking
#GRUB_ROOT_FS_RO=true
GRUB_THEME="/usr/share/grub/themes/Tela/theme.txt"
