Hi all, need a bit of help here, and haven’t posted before so not sure if I’m in the right spot lol.
I’m trying to connect two Xbox One S controllers to my Manjaro laptop, it has a Realtek Rtl8723ae wifi/bluetooth 4.0 controller built-in.
I’ve installed xpadneo, and I’m using bluetoothctl command, along with the included bluetooth manager gui. I’m pretty green with this command, so not sure if I’m using it right.
It looks like ertm was disabled by default in my manjaro install, so I don’t think that’s an issue, but I put the bluetooth.disable_ertm=1 command in the default grub file anyway.
I can get the first one connected without issue, it’s when I try to connect the second one.
The second one can pair and trust, and will partially connect. What I mean by partially is bluetoothctl says Connected: yes at first but the light on the controller still blinks. After about a minute it drops and bluetoothctl says Connected: no. Here is the output:
[bluetooth]# connect EC:83:50:71:83:70
Attempting to connect to EC:83:50:71:83:70
[CHG] Device EC:83:50:71:83:70 Connected: yes
[CHG] Device EC:83:50:71:83:70 Modalias: usb:v045Ep02E0d0903
[CHG] Device EC:83:50:71:83:70 Modalias: usb:v045Ep02FDd0903
[CHG] Device EC:83:50:71:83:70 UUIDs: 00001124-0000-1000-8000-00805f9b34fb
[CHG] Device EC:83:50:71:83:70 UUIDs: 00001200-0000-1000-8000-00805f9b34fb
[CHG] Device EC:83:50:71:83:70 ServicesResolved: yes
[CHG] Device EC:83:50:71:83:70 Paired: yes
Connection successful
[Xbox Wireless Controller]# connect 9C:AA:1B:98:FB:13
Attempting to connect to 9C:AA:1B:98:FB:13
[CHG] Device 9C:AA:1B:98:FB:13 Connected: yes
[CHG] Device 9C:AA:1B:98:FB:13 Modalias: usb:v045Ep02E0d0903
[CHG] Device 9C:AA:1B:98:FB:13 Modalias: usb:v045Ep02FDd0903
[CHG] Device 9C:AA:1B:98:FB:13 UUIDs: 00001124-0000-1000-8000-00805f9b34fb
[CHG] Device 9C:AA:1B:98:FB:13 UUIDs: 00001200-0000-1000-8000-00805f9b34fb
[CHG] Device 9C:AA:1B:98:FB:13 ServicesResolved: yes
[CHG] Device 9C:AA:1B:98:FB:13 Paired: yes
[CHG] Device 9C:AA:1B:98:FB:13 Modalias: usb:v045Ep02E0d0408
Failed to connect: org.bluez.Error.Failed
[CHG] Device 9C:AA:1B:98:FB:13 ServicesResolved: no
[CHG] Device 9C:AA:1B:98:FB:13 Paired: no
[CHG] Device 9C:AA:1B:98:FB:13 Connected: no
I started thinking that maybe my hardware is old and limited and I can only have one xbox controller per bluetooth controller. With that thought, I bought a TP-link bluetooth 4.0 dongle. Bluetoothctl picks it up, but when I try to connect, it’s doing something similar - connecting then dropping. I can’t remember the output (I can post it later if needed).
As I said earlier, I’m not very familiar with bluetoothctl’s interface and maybe I’m doing it wrong - At first, the prompt says [Bluetooth], and after I connect the first controller successfully, it says [Xbox Wireless Controller] as the prompt and if I type info, it gives me the xbox controller’s device info. So my simple mind is questioning that if I’m running the pair and connect commands from this prompt, is that actually trying to connect my first xbox controller to the second one instead of the bluetooth controller? So I think I have to get out of the [Xbox Wireless Controller] prompt, back to my [Bluetooth] prompt and attempt running the pair/connect commands from there. And it should work… but how do I change my prompt back to [Bluetooth]?
So maybe someone can let me know if I’m thinking along the right lines, or maybe there’s something deeper I’m unaware of.
Cheers
Edit-added bluetoothctl output
