Trying to connect AverMedia capture card
I’m trying to get my GC551 capture card to work in Linux. I have V4L2 installed, but OBS does not seem to be reading it. Am I missing something?
Hi @thecrimsoneye :wink:
Maybe this capture card has just no driver support for linux?
Here is a list supported cards of avermedia: AVerMedia - LinuxTVWiki
Could you post this output when the card is connected via usb?
lsusb -t -v
This says enough
https://www.reddit.com/r/AverMedia/comments/gftbe5/cg551_on_linux/
Quote
CG551 on Linux
Is it possible to install a CG551 on Linux to use with OBS or any other capturing software? Are there any drivers?
Technical Support
Hi mizfih,
No. Our gaming capture card doesn’t support Linux. -DSS
