Hopefully Ive done it right this time
Kernel: 6.3.8-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.3-x86_64
root=UUID=b08c96c4-a567-41f6-a4d9-30637f36df0f rw rootflags=subvol=@ quiet
resume=UUID=330b6883-99c7-48dc-b025-b7f010b238c4 udev.log_priority=3
Desktop: KDE Plasma v: 5.27.5 tk: Qt v: 5.15.10 wm: kwin_wayland vt: 2
Type: Desktop System: Gigabyte product: X570 AORUS ELITE v: -CF
serial: <superuser required>
Mobo: Gigabyte model: X570 AORUS ELITE v: x.x serial: <superuser required>
UEFI: American Megatrends v: F30 date: 09/15/2020
System RAM: available: 31.29 GiB used: 4.41 GiB (14.1%)
Info: model: AMD Ryzen 7 5800X3D bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 2 microcode: N/A
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 96 MiB
desc: 1x96 MiB
Speed (MHz): avg: 2199 high: 2200 min/max: 2200/3400 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 2200
3: 2200 4: 2200 5: 2200 6: 2200 7: 2191 8: 2200 9: 2200 10: 2200 11: 2200
12: 2200 13: 2200 14: 2200 15: 2195 16: 2200 bogomips: 108631
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] vendor: Sapphire
driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
active: DP-1,DP-3 empty: DP-2,HDMI-A-1 bus-ID: 0b:00.0 chip-ID: 1002:73bf
class-ID: 0300
Device-2: Logitech HD Webcam C525 driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-2.4:6
chip-ID: 046d:0826 class-ID: 0e02 serial: <filter>
Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.2
compositor: kwin_wayland driver: X: loaded: amdgpu
gpu: amdgpu d-rect: 3840x1080 display-ID: 0
Monitor-1: DP-1 pos: primary,left res: 1920x1080 size: N/A modes: N/A
Monitor-2: DP-3 pos: right res: 1920x1080 size: N/A modes: N/A
API: OpenGL v: 4.6 Mesa 23.1.2 renderer: AMD Radeon RX 6800 XT (navi21
LLVM 15.0.7 DRM 3.52 6.3.8-1-MANJARO) direct-render: Yes
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0b:00.1 chip-ID: 1002:ab28
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte
bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Logitech HD Webcam C525 driver: snd-usb-audio,uvcvideo type: USB
Device-4: Focusrite-Novation Scarlett 2i4 driver: snd-usb-audio type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-4.3:8
chip-ID: 1235:800a class-ID: fe01
API: ALSA v: k6.3.8-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.71 status: active with: 1: pipewire-media-session
status: active 2: pw-jack type: plugin tools: pw-cat,pw-cli
Server-3: PulseAudio v: 16.1 status: active with: 1: pulseaudio-alsa
type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl
Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 05:00.0
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3.4.4:9
chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 16.7 TiB used: 4.46 TiB (26.7%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Sabrent
model: SB-ROCKET-NVMe4-2TB size: 1.82 TiB block-size: physical: 512 B
fw-rev: RKT4B5.1 temp: 36.9 C scheme: MBR
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Sabrent model: N/A size: 1.86 TiB
block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
tech: SSD serial: <filter> fw-rev: RKT303.3 temp: 27.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 QVO 2TB
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 2B6Q scheme: MBR
ID-4: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD60EZAZ-00SF3B0 size: 5.46 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 5400 serial: <filter>
fw-rev: 0A80 scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: Western Digital
ID-6: /dev/sde maj-min: 8:64 vendor: SanDisk model: USB 3.2Gen1
size: 232.88 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
fw-rev: 1.00 scheme: MBR
ID-7: /dev/sdf maj-min: 8:80 vendor: Generic model: Flash Disk
size: 58.59 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 3.2
spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: SSD serial: <filter>
fw-rev: 8.01 scheme: MBR
ID-1: / raw-size: 1.85 TiB size: 1.21 TiB (65.60%) used: 550.2 GiB (44.4%)
fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:5 label: MANJAROLD
uuid: b08c96c4-a567-41f6-a4d9-30637f36df0f
used: 612 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:4
label: NO_LABEL uuid: 368E-359E
ID-3: /home raw-size: 1.85 TiB size: 1.21 TiB (65.60%)
used: 550.2 GiB (44.4%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:5
label: MANJAROLD uuid: b08c96c4-a567-41f6-a4d9-30637f36df0f
ID-4: /run/media/thedatabug/DOCUMENTS raw-size: 5.46 TiB
size: 5.46 TiB (100.00%) used: 2.1 TiB (38.5%) fs: ntfs dev: /dev/sdc1
maj-min: 8:33 label: DOCUMENTS uuid: 01D69E68678D01D0
ID-5: /run/media/thedatabug/ENTERTAINMENT raw-size: 5.46 TiB
size: 5.46 TiB (100.00%) used: 1.82 TiB (33.4%) fs: ntfs dev: /dev/sdb1
maj-min: 8:17 label: ENTERTAINMENT uuid: 01D69E856214FD30
ID-6: /var/cache raw-size: 1.85 TiB size: 1.21 TiB (65.60%)
ID-7: /var/log raw-size: 1.85 TiB size: 1.21 TiB (65.60%)
ID-1: swap-1 type: partition size: 17.12 GiB used: 20.2 MiB (0.1%)
priority: -2 dev: /dev/nvme1n1p3 maj-min: 259:6 label: N/A
uuid: 330b6883-99c7-48dc-b025-b7f010b238c4
ID-1: /dev/nvme0n1p1 maj-min: 259:2 size: 1.81 TiB fs: btrfs label: MANJARO
uuid: 5d4ba93c-6239-4b42-b587-c9cbc08d78cc
ID-2: /dev/nvme0n1p2 maj-min: 259:3 size: 8.8 GiB fs: swap label: swap
uuid: b6f424ae-1978-4547-87be-dfabe587f19d
ID-3: /dev/sda1 maj-min: 8:1 size: 1.79 TiB fs: btrfs label: GARUDA
uuid: 6ed18e1f-c722-471d-81c3-e3d110173347
ID-4: /dev/sda2 maj-min: 8:2 size: 34.41 GiB fs: swap label: swap
uuid: 5c408958-88ef-49ca-8fbd-6ca48b5905ce
ID-5: /dev/sde1 maj-min: 8:65 size: 232.87 GiB fs: vfat label: APP STICK
uuid: 1D57-6408
ID-6: /dev/sdf1 maj-min: 8:81 size: 58.56 GiB fs: exfat label: Ventoy
uuid: 8676-3B3D
ID-7: /dev/sdf2 maj-min: 8:82 size: 32 MiB fs: vfat label: VTOYEFI
uuid: 7CDB-00D9
Hub-2: 1-3:2 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 1-3.1:4 info: Razer USA Naga Trinity type: mouse,keyboard
driver: razermouse,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1532:0067 class-ID: 0300
serial: <filter>
Device-2: 1-3.2:6 info: Microdia Backlit Gaming Keyboard
type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 400mA
chip-ID: 0c45:652f class-ID: 0301
Device-3: 1-3.3:7 info: HP Photosmart 6520 series
type: printer,mass storage driver: usb-storage,usblp interfaces: 4 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 2mA
chip-ID: 03f0:af11 class-ID: 0806 serial: <filter>
Hub-3: 1-3.4:8 info: VIA Labs VL812 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2812
Device-1: 1-3.4.4:9 info: Cambridge Silicon Radio Bluetooth Dongle (HCI
mode) type: bluetooth driver: btusb interfaces: 2 rev: 2.0
Device-2: 1-4:3 info: Integrated Express IT8297 RGB LED Controller
type: keyboard driver: hid-generic,usbhid interfaces: 1 rev: 2.0
chip-ID: 048d:8297 class-ID: 0301
Device-3: 1-5:5 info: Google Nexus/Pixel Device (MTP) type: still imaging
driver: N/A interfaces: 1 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 18d1:4ee1 class-ID: 0601 serial: <filter>
Hub-4: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
Hub-6: 3-6:2 info: Genesys Logic Hub ports: 4 rev: 2.0
Hub-7: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-8: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Hub-9: 5-2:2 info: Genesys Logic Hub ports: 4 rev: 2.1
Device-1: 5-2.3:4 info: SHARKOON GmbH 2.4GHz Wireless rechargeable
vertical mouse [More&Better] type: mouse driver: hid-generic,usbhid
interfaces: 1 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 100mA chip-ID: 1ea7:0064 class-ID: 0301
Device-2: 5-2.4:6 info: Logitech HD Webcam C525 type: audio,video
Hub-10: 5-3:3 info: Genesys Logic Hub ports: 4 rev: 2.1
Hub-11: 5-4:5 info: Genesys Logic Hub ports: 4 rev: 2.1
Device-1: 5-4.2:7 info: Holtek USB Gaming Keyboard type: keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 04d9:a0f8 class-ID: 0300
Device-2: 5-4.3:8 info: Focusrite-Novation Scarlett 2i4 type: audio
driver: snd-usb-audio interfaces: 6 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 500mA chip-ID: 1235:800a class-ID: fe01
Hub-12: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-13: 6-2:2 info: Genesys Logic Hub ports: 4 rev: 3.1
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0626
Hub-14: 6-3:3 info: Genesys Logic Hub ports: 4 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0612
Device-1: 6-3.3:5 info: SanDisk Ultra Flair type: mass storage
driver: usb-storage interfaces: 1 rev: 3.2 speed: 5 Gb/s (596.0 MiB/s)
lanes: 1 mode: 3.2 gen-1x1 power: 896mA chip-ID: 0781:5591 class-ID: 0806
serial: <filter>
Device-2: 6-3.4:6 info: Alcor Micro Flash Drive type: mass storage
lanes: 1 mode: 3.2 gen-1x1 power: 800mA chip-ID: 058f:6387 class-ID: 0806
serial: <filter>
Hub-15: 6-4:4 info: Genesys Logic Hub ports: 4 rev: 3.0
System Temperatures: cpu: 35.0 C mobo: 29.0 C gpu: amdgpu temp: 35.0 C
mem: 42.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
Processes: 462 Uptime: 15m wakeups: 0 Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: 1932 pm: dpkg
pkgs: 0 pm: pacman pkgs: 1870 libs: 486 tools: pamac,paru,yay pm: flatpak
pkgs: 62 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.27
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
sda 8:0 1 1.8T 0 disk
├─sda1 8:1 1 1.8T 0 part
└─sda2 8:2 1 34.4G 0 part
sdb 8:16 1 5.5T 0 disk
└─sdb1 8:17 1 5.5T 0 part /run/media/thedatabug/ENTERTAINMENT
sdc 8:32 1 5.5T 0 disk
└─sdc1 8:33 1 5.5T 0 part /run/media/thedatabug/DOCUMENTS
sdd 8:48 1 0B 0 disk
sde 8:64 1 232.9G 0 disk
└─sde1 8:65 1 232.9G 0 part
sdf 8:80 1 58.6G 0 disk
├─sdf1 8:81 1 58.6G 0 part
└─sdf2 8:82 1 32M 0 part
nvme1n1 259:0 0 1.9T 0 disk
├─nvme1n1p1 259:4 0 300M 0 part /boot/efi
├─nvme1n1p2 259:5 0 1.8T 0 part /var/log
│ /var/cache
│ /home
└─nvme1n1p3 259:6 0 17.1G 0 part [SWAP]
nvme0n1 259:1 0 1.8T 0 disk
├─nvme0n1p1 259:2 0 1.8T 0 part
└─nvme0n1p2 259:3 0 8.8G 0 part
Filesystem Size Used Avail Use% Mounted on
dev 16G 0 16G 0% /dev
run 16G 2.2M 16G 1% /run
/dev/nvme1n1p2 1.3T 551G 676G 45% /
tmpfs 16G 71M 16G 1% /dev/shm
/dev/nvme1n1p2 1.3T 551G 676G 45% /home
/dev/nvme1n1p2 1.3T 551G 676G 45% /var/cache
/dev/nvme1n1p2 1.3T 551G 676G 45% /var/log
tmpfs 16G 6.0M 16G 1% /tmp
/dev/nvme1n1p1 300M 612K 299M 1% /boot/efi
tmpfs 3.2G 13M 3.2G 1% /run/user/1000
/dev/sdc1 5.5T 2.2T 3.4T 39% /run/media/thedatabug/DOCUMENTS
/dev/sdb1 5.5T 1.9T 3.7T 34% /run/media/thedatabug/ENTERTAINMENT
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=368E-359E /boot/efi vfat umask=0077 0 2
UUID=b08c96c4-a567-41f6-a4d9-30637f36df0f / btrfs subvol=/@,defaults,discard=async,ssd 0 0
UUID=b08c96c4-a567-41f6-a4d9-30637f36df0f /home btrfs subvol=/@home,defaults,discard=async,ssd 0 0
UUID=b08c96c4-a567-41f6-a4d9-30637f36df0f /var/cache btrfs subvol=/@cache,defaults,discard=async,ssd 0 0
UUID=b08c96c4-a567-41f6-a4d9-30637f36df0f /var/log btrfs subvol=/@log,defaults,discard=async,ssd 0 0
UUID=330b6883-99c7-48dc-b025-b7f010b238c4 swap swap defaults,noatime 0 0
tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0
ID 258 gen 382284 top level 5 path @cache
ID 259 gen 382314 top level 5 path @log
ID 487 gen 382318 top level 5 path @home
ID 565 gen 382318 top level 5 path @
