Troubleshotting with drivers
Hello,
Some time ago started to “crash” my computer it happens to often when I use skype but without too.
When it crash my main screen goes black and stop detecting it and the second monitor frezzes and show the last thing it was showing. The music, skype audio keeps working but keyboard stop too. I’ve ask for help in reddit and It looks like it’s problem with drivers.
inxi -Fazy result
Kernel: 5.8.6-1-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=819b66c2-eccf-43ad-99f0-26e212acc03a rw quiet apparmor=1
security=apparmor resume=UUID=4685883e-7682-4292-b29d-3125cbad0951
udev.log_priority=3
Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.0 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Desktop Mobo: Gigabyte model: B85M-HD3 v: x.x serial: <filter>
UEFI: American Megatrends v: FF date: 06/19/2014
Topology: Quad Core model: Intel Core i5-4590 bits: 64 type: MCP
arch: Haswell family: 6 model-id: 3C (60) stepping: 3 microcode: 28
L2 cache: 6144 KiB
bogomips: 26349
Speed: 3668 MHz min/max: 800/3700 MHz Core speeds (MHz): 1: 2686 2: 2750
3: 3060 4: 1791
Type: l1tf
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
vendor: Gigabyte driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:0412
Device-2: NVIDIA GK104 [GeForce GTX 770] vendor: Gigabyte driver: nvidia
v: 450.66 alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:1184
Display: x11 server: X.Org 1.20.8 compositor: kwin_x11
driver: modesetting,nvidia alternate: fbdev,intel,nouveau,nv,vesa
display ID: :0 screens: 1
Screen-1: 0 s-res: 3200x1080 s-dpi: 91 s-size: 891x301mm (35.1x11.9")
s-diag: 940mm (37")
Monitor-1: DVI-D-0 res: 1920x1080 dpi: 92 size: 531x298mm (20.9x11.7")
diag: 609mm (24")
Monitor-2: VGA-1-1 res: 1280x1024 dpi: 96 size: 338x270mm (13.3x10.6")
diag: 433mm (17")
OpenGL: renderer: GeForce GTX 770/PCIe/SSE2 v: 4.6.0 NVIDIA 450.66
direct render: Yes
Audio ... skyped
vendor: Gigabyte driver: r8169 v: kernel port: d000 bus ID: 03:00.0
chip ID: 10ec:8168
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 1.49 TiB used: 115.40 GiB (7.6%)
ID-1: /dev/sda vendor: Seagate model: ST3500412AS size: 465.76 GiB
block size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
rotation: 5900 rpm serial: <filter> rev: CC32 scheme: MBR
ID-2: /dev/sdb vendor: Western Digital model: WD6400AAKS-22A7B0
size: 596.17 GiB block size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
serial: <filter> rev: 3B01 scheme: GPT
ID-3: /dev/sdc vendor: Samsung model: SSD 860 EVO 500GB size: 465.76 GiB
block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter>
rev: 1B6Q scheme: GPT
ID-1: / raw size: 448.38 GiB size: 440.34 GiB (98.21%)
used: 115.40 GiB (26.2%) fs: ext4 dev: /dev/sdc2
ID-1: swap-1 type: partition size: 17.09 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sdc3
System Temperatures: cpu: 34.0 C mobo: N/A gpu: nvidia temp: 39 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 18%
Processes: 190 Uptime: 1h 16m Memory: 15.53 GiB used: 2.73 GiB (17.5%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: 1391 pacman: 1383
lib: 418 flatpak: 0 snap: 8 Shell: Bash v: 5.0.18 running in: konsole
inxi: 3.1.05
These are my drivers currently installed:
  • video-hybrid-intel-nvidia-450xx-prime
  • video-nvidia-450xx
  • video-modesetting
I don’t know how to choose which one to use or to remove. I tried to remove the prime one(i think it’s the one giving problems) but without success.
I tried removing them by manjaro hardware software and manualy with the guide on the wiki( Configure NVIDIA (non-free) settings and load them on Startup) and this is the result:
I can’t upload embed images but it shows that the comands
  • sudo mhwd -r pci video-nvidia
    doesn’t work it shows it doesn’t exist.
What can i do now?
You have 2 GPUs … its the nvidia alone one you need to remove.
Prime you need because of your hybrid system.
Because it doesnt.
As shown by your output above video-nvidia-450xx does exist though.
So … remove that, and to be safe reinstall prime again:
sudo mhwd -r pci video-nvidia-450xx
sudo mhwd -f -i pci video-hybrid-intel-nvidia-450xx-prime
This don’t work to me
$ sudo mhwd -r pci video-nvidia-450xx
Removing video-nvidia-450xx…
Sourcing /etc/mhwd-x86_64.conf
Has lib32 support: true
Sourcing /var/lib/mhwd/local/pci/video-nvidia-450xx/MHWDCONFIG
Processing classid: 0300
Sourcing /var/lib/mhwd/scripts/include/0300
Processing classid: 0302
comprobando dependencias…
error: no se pudo preparar la operación (no se pudieron satisfacer las dependencias)
:: quitando nvidia-450xx-utils se rompe la dependencia con «nvidia-utils», necesaria para el paquete nvidia-prime
Error: pacman failed!
Error: script failed!
Then I realized to try to remove nvidia-utils but before I need to remove nvidia-prime. And after this finally I can remove it. And It leaves this packages installed .What are this?
$ sudo pacman -Q |grep nvidia
mhwd-nvidia-340xx 340.108-1
mhwd-nvidia-390xx 390.132-1
mhwd-nvidia-418xx 418.113-1
mhwd-nvidia-430xx 430.64-1.0
mhwd-nvidia-435xx 435.21-1.0
mhwd-nvidia-440xx 440.100-1
mhwd-nvidia-450xx 450.66-1
By the moment I hasn’t crash. God bless you.
Edit: It keeps crashing at least using skype.
Maybe I should create another post on “Software” or keep the thread here.?
Edit 2 : It happens the same using zoom . I am realising It could be problem of the webcam or the sharing window.
Edit 3 : I think it’s problem of the webcam driver but I don’t find which one is using.
I found in an arch guide that a module of webcam should be added to /etc/modules-load.d/webcam.conf but It doesn’t exist in my computer. Does it matter?
https://wiki.archlinux.org/index.php/Webcam_setup_(Español)
Looks like a case of this:
It could also likely be your drivers. Maybe get that fixed first.
