Troubleshooting unusually long restart time
I have to wait a long time every time I try to restart my PC. It’s the shutting down that’s slow not the boot up:
Startup finished in 1.615s (kernel) + 12.482s (userspace) = 14.097s
graphical.target reached after 4.973s in userspace.
System info:
  Kernel: 6.1.19-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    root=UUID=30b101f0-84c0-4963-8856-274804c75768 rw quiet splash
    resume=UUID=5d178c61-fac8-46ec-8b66-37f2b97fce07 udev.log_priority=3
  Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Desktop Mobo: ASUSTeK model: TUF Z270 MARK 2 v: Rev 1.xx
    serial: <superuser required> UEFI-[Legacy]: American Megatrends v: 1301
    date: 03/14/2018
  Device-1: hidpp_battery_0 model: Logitech G304 Lightspeed Wireless Gaming
    Mouse serial: <filter> charge: 100% (should be ignored) rechargeable: yes
    status: discharging
  RAM: total: 15.5 GiB used: 4.07 GiB (26.3%)
  Info: model: Intel Core i7-7700K bits: 64 type: MT MCP arch: Kaby Lake
    gen: core 7 level: v3 note: check built: 2018 process: Intel 14nm family: 6
    model-id: 0x9E (158) stepping: 9 microcode: 0xF0
    L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 800 min/max: 800/4600 scaling: driver: intel_pstate
    governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
    8: 800 bogomips: 67224
    intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
    movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
    pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
    rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
    vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
    vulnerable
  Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
    RSB filling, PBRSB-eIBRS: Not affected
  Device-1: Intel HD Graphics 630 vendor: ASUSTeK driver: i915 v: kernel
    arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: HDMI-A-1
    empty: HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:5912 class-ID: 0300
  Device-2: Logitech Webcam C310 type: USB driver: snd-usb-audio,uvcvideo
    bus-ID: 1-8:4 chip-ID: 046d:081b class-ID: 0102 serial: <filter>
  Display: x11 server: X.Org v: 21.1.7 compositor: kwin_x11 driver: X:
    loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0
    screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: HDMI-A-1 mapped: HDMI-1 model: Dell U2417H serial: <filter>
    built: 2018 res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2
    size: 527x296mm (20.75x11.65") diag: 604mm (23.8") ratio: 16:9 modes:
    max: 1920x1080 min: 720x400
  API: OpenGL v: 4.6 Mesa 22.3.5 renderer: Mesa Intel HD Graphics 630 (KBL
    GT2) direct-render: Yes
  Device-1: Intel 200 Series PCH HD Audio vendor: ASUSTeK driver: snd_hda_intel
    v: kernel bus-ID: 1-8:4 bus-ID: 00:1f.3 chip-ID: 046d:081b class-ID: 0102
    chip-ID: 8086:a2f0 serial: <filter> class-ID: 0403
  Sound API: ALSA v: k6.1.19-1-MANJARO running: yes
  Sound Server-1: JACK v: 1.9.22 running: no
  Sound Server-3: PipeWire v: 0.3.65 running: yes
  Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
  IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: docker0 state: down mac: <filter>
    driver: btusb v: 0.8 bus-ID: 1-13.4:8 chip-ID: 0a12:0001 class-ID: e001
  Local Storage: total: 6.6 TiB used: 4.31 TiB (65.4%)
    model: WDS100T3X0C-00SJG0 size: 931.51 GiB block-size: physical: 512 B
    rev: 111110WD temp: 46.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO M.2 250GB
    size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    type: SSD serial: <filter> rev: 1B6Q scheme: MBR
  ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital
    model: WD10EZEX-21WN4A0 size: 931.51 GiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter>
    rev: 1A01 scheme: GPT
  ID-4: /dev/sdc maj-min: 8:32 type: USB vendor: Seagate model: BUP Slim RD
    size: 931.51 GiB block-size: physical: 4096 B logical: 512 B type: N/A
    serial: <filter> rev: 0304 scheme: MBR
  ID-5: /dev/sdd maj-min: 8:48 type: USB vendor: Western Digital
    model: WD40NDZW-11MR8S1 size: 3.64 TiB block-size: physical: 4096 B
    logical: 512 B type: HDD rpm: 5400 serial: <filter> rev: 4008 scheme: GPT
  ID-1: / raw-size: 215.84 GiB size: 211.39 GiB (97.94%)
    used: 34.84 GiB (16.5%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: 30b101f0-84c0-4963-8856-274804c75768
  ID-2: /mnt/Lord Lance raw-size: 3.64 TiB size: 3.64 TiB (100.00%)
    used: 3.14 TiB (86.3%) fs: ntfs dev: /dev/sdd1 maj-min: 8:49
    label: Lord Lance uuid: A2F647BFF6479309
  ID-3: /mnt/Seagate Backup Plus raw-size: 931.51 GiB
    size: 931.51 GiB (100.00%) used: 449.02 GiB (48.2%) fs: ntfs dev: /dev/sdc1
    maj-min: 8:33 label: Seagate Backup uuid: 4E72C35E72C34983
  ID-4: /mnt/Western Digital HDD raw-size: 931.51 GiB
    size: 931.51 GiB (100.00%) used: 718.26 GiB (77.1%) fs: ntfs dev: /dev/sdb1
    maj-min: 8:17 label: Western Digital 1TB HDD uuid: 406096B36096AF62
  ID-1: swap-1 type: partition size: 17.05 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/sda2 maj-min: 8:2 label: swap
    uuid: 5d178c61-fac8-46ec-8b66-37f2b97fce07
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
    uuid: C4C9-FCA3
  ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 930.9 GiB fs: ntfs label: N/A
    uuid: 9E50D3D450D3B0EF
  ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 509 MiB fs: ntfs label: N/A
    uuid: BE04EE2204EDDE01
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
  Device-1: 1-1:2 info: Seagate RSS LLC Backup Plus Portable Drive
    type: Mass Storage driver: uas interfaces: 1 rev: 2.1 speed: 480 Mb/s
    power: 100mA chip-ID: 0bc2:ab24 class-ID: 0806 serial: <filter>
  Device-2: 1-3:3 info: Logitech Keyboard K120 type: Keyboard,HID
    driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 1.5 Mb/s power: 90mA
    chip-ID: 046d:c31c class-ID: 0300
  Device-3: 1-8:4 info: Logitech Webcam C310 type: Video,Audio
    power: 500mA chip-ID: 046d:081b class-ID: 0102 serial: <filter>
  Device-4: 1-9:5 info: Corsair H100iRGBPROXT type: Keyboard
    driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
    chip-ID: 1b1c:0c20 class-ID: 0300
  Hub-2: 1-13:6 info: Microchip (formerly SMSC) USB2137B ports: 7 rev: 2.1
    speed: 480 Mb/s chip-ID: 0424:2137 class-ID: 0900
  Device-1: 1-13.3:7 info: Logitech USB Receiver type: Keyboard,Mouse,HID
    power: 98mA chip-ID: 046d:c53f class-ID: 0300
  Device-2: 1-13.4:8 info: Cambridge Silicon Radio Bluetooth Dongle (HCI
    mode) type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
    power: 100mA chip-ID: 0a12:0001 class-ID: e001
  Device-3: 1-13.5:9 info: Microchip U2417H_0B29_15083001 type: HID
    chip-ID: 04d8:0b29 class-ID: 0300
  Hub-3: 2-0:1 info: Super-speed hub ports: 10 rev: 3.0 speed: 5 Gb/s
  Device-1: 2-2:2 info: Western Digital My Passport 2627 type: Mass Storage
    driver: usb-storage interfaces: 1 rev: 3.1 speed: 5 Gb/s power: 896mA
    chip-ID: 1058:2627 class-ID: 0806 serial: <filter>
  Hub-4: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-5: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 52.0 C mobo: N/A
  Processes: 284 Uptime: 3m wakeups: 2 Init: systemd v: 252 default: graphical
  tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman
  pkgs: 1339 libs: 336 tools: pamac,yay pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
  default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.25
System Control if it matters:
  UNIT        LOAD   ACTIVE SUB       DESCRIPTION
  proc-sys-fs-binfmt_misc.automount        loaded active waiting   Arbitrary Executable File Formats File System Automount Point
  sys-devices-pci0000:00-0000:00:14.0-usb1-1\x2d1-1\x2d1:1.0-host7-target7:0:0-7:0:0:0-block-sdc-sdc1.device loaded active plugged   BUP_Slim_RD Seagate_Backup
  sys-devices-pci0000:00-0000:00:14.0-usb1-1\x2d1-1\x2d1:1.0-host7-target7:0:0-7:0:0:0-block-sdc.device      loaded active plugged   BUP_Slim_RD
  sys-devices-pci0000:00-0000:00:14.0-usb1-1\x2d13-1\x2d13.4-1\x2d13.4:1.0-bluetooth-hci0.device             loaded active plugged   /sys/devices/pci0000:00/0000:00:14.0/usb1/1-13/1-13.4/1-13.4:1.0/bluetooth/hci0
  sys-devices-pci0000:00-0000:00:14.0-usb1-1\x2d8-1\x2d8:1.2-sound-card1-controlC1.device                    loaded active plugged   081b
  sys-devices-pci0000:00-0000:00:14.0-usb2-2\x2d2-2\x2d2:1.0-host6-target6:0:0-6:0:0:0-block-sdd-sdd1.device loaded active plugged   WDC_WD40NDZW-11MR8S1 Lord_Lance
  sys-devices-pci0000:00-0000:00:14.0-usb2-2\x2d2-2\x2d2:1.0-host6-target6:0:0-6:0:0:0-block-sdd.device      loaded active plugged   WDC_WD40NDZW-11MR8S1
  sys-devices-pci0000:00-0000:00:17.0-ata1-host0-target0:0:0-0:0:0:0-block-sda-sda1.device                   loaded active plugged   Samsung_SSD_850_EVO_M.2_250GB 1
  sys-devices-pci0000:00-0000:00:17.0-ata1-host0-target0:0:0-0:0:0:0-block-sda-sda2.device                   loaded active plugged   Samsung_SSD_850_EVO_M.2_250GB swap
  sys-devices-pci0000:00-0000:00:17.0-ata1-host0-target0:0:0-0:0:0:0-block-sda.device                        loaded active plugged   Samsung_SSD_850_EVO_M.2_250GB
  sys-devices-pci0000:00-0000:00:17.0-ata4-host3-target3:0:0-3:0:0:0-block-sdb-sdb1.device                   loaded active plugged   WDC_WD10EZEX-21WN4A0 Western_Digital_1TB_HDD
  sys-devices-pci0000:00-0000:00:17.0-ata4-host3-target3:0:0-3:0:0:0-block-sdb.device                        loaded active plugged   WDC_WD10EZEX-21WN4A0
  sys-devices-pci0000:00-0000:00:1b.4-0000:02:00.0-nvme-nvme0-nvme0n1-nvme0n1p1.device                       loaded active plugged   WDS100T3X0C-00SJG0 EFI\x20system\x20partition
  sys-devices-pci0000:00-0000:00:1b.4-0000:02:00.0-nvme-nvme0-nvme0n1-nvme0n1p2.device                       loaded active plugged   WDS100T3X0C-00SJG0 Microsoft\x20reserved\x20partition
  sys-devices-pci0000:00-0000:00:1b.4-0000:02:00.0-nvme-nvme0-nvme0n1-nvme0n1p3.device                       loaded active plugged   WDS100T3X0C-00SJG0 Basic\x20data\x20partition
  sys-devices-pci0000:00-0000:00:1b.4-0000:02:00.0-nvme-nvme0-nvme0n1-nvme0n1p4.device                       loaded active plugged   WDS100T3X0C-00SJG0 4
  sys-devices-pci0000:00-0000:00:1b.4-0000:02:00.0-nvme-nvme0-nvme0n1.device                                 loaded active plugged   WDS100T3X0C-00SJG0
  sys-devices-pci0000:00-0000:00:1f.3-sound-card0-controlC0.device                                           loaded active plugged   /sys/devices/pci0000:00/0000:00:1f.3/sound/card0/controlC0
  sys-devices-pci0000:00-0000:00:1f.6-net-enp0s31f6.device                                                   loaded active plugged   Ethernet Connection (2) I219-V
  sys-devices-platform-serial8250-tty-ttyS1.device                                                           loaded active plugged   /sys/devices/platform/serial8250/tty/ttyS1
  sys-devices-platform-serial8250-tty-ttyS10.device                                                          loaded active plugged   /sys/devices/platform/serial8250/tty/ttyS10
  sys-devices-platform-serial8250-tty-ttyS11.device                                                          loaded active plugged   /sys/devices/platform/serial8250/tty/ttyS11
  sys-devices-platform-serial8250-tty-ttyS12.device                                                          loaded active plugged   /sys/devices/platform/serial8250/tty/ttyS12
  sys-devices-platform-serial8250-tty-ttyS13.device                                                          loaded active plugged   /sys/devices/platform/serial8250/tty/ttyS13
  sys-devices-platform-serial8250-tty-ttyS14.device                                                          loaded active plugged   /sys/devices/platform/serial8250/tty/ttyS14
  sys-devices-platform-serial8250-tty-ttyS15.device                                                          loaded active plugged   /sys/devices/platform/serial8250/tty/ttyS15
  sys-devices-platform-serial8250-tty-ttyS16.device                                                          loaded active plugged   /sys/devices/platform/serial8250/tty/ttyS16
  sys-devices-platform-serial8250-tty-ttyS17.device                                                          loaded active plugged   /sys/devices/platform/serial8250/tty/ttyS17
  sys-devices-platform-serial8250-tty-ttyS18.device                                                          loaded active plugged   /sys/devices/platform/serial8250/tty/ttyS18
  sys-devices-platform-serial8250-tty-ttyS19.device                                                          loaded active plugged   /sys/devices/platform/serial8250/tty/ttyS19
  sys-devices-platform-serial8250-tty-ttyS2.device                                                           loaded active plugged   /sys/devices/platform/serial8250/tty/ttyS2
  sys-devices-platform-serial8250-tty-ttyS20.device                                                          loaded active plugged   /sys/devices/platform/serial8250/tty/ttyS20
  sys-devices-platform-serial8250-tty-ttyS21.device                                                          loaded active plugged   /sys/devices/platform/serial8250/tty/ttyS21
  sys-devices-platform-serial8250-tty-ttyS22.device                                                          loaded active plugged   /sys/devices/platform/serial8250/tty/ttyS22
  sys-devices-platform-serial8250-tty-ttyS23.device                                                          loaded active plugged   /sys/devices/platform/serial8250/tty/ttyS23
  sys-devices-platform-serial8250-tty-ttyS24.device                                                          loaded active plugged   /sys/devices/platform/serial8250/tty/ttyS24
  sys-devices-platform-serial8250-tty-ttyS25.device                                                          loaded active plugged   /sys/devices/platform/serial8250/tty/ttyS25
  sys-devices-platform-serial8250-tty-ttyS26.device                                                          loaded active plugged   /sys/devices/platform/serial8250/tty/ttyS26
  sys-devices-platform-serial8250-tty-ttyS27.device                                                          loaded active plugged   /sys/devices/platform/serial8250/tty/ttyS27
  sys-devices-platform-serial8250-tty-ttyS28.device                                                          loaded active plugged   /sys/devices/platform/serial8250/tty/ttyS28
  sys-devices-platform-serial8250-tty-ttyS29.device                                                          loaded active plugged   /sys/devices/platform/serial8250/tty/ttyS29
  sys-devices-platform-serial8250-tty-ttyS3.device                                                           loaded active plugged   /sys/devices/platform/serial8250/tty/ttyS3
  sys-devices-platform-serial8250-tty-ttyS30.device                                                          loaded active plugged   /sys/devices/platform/serial8250/tty/ttyS30
  sys-devices-platform-serial8250-tty-ttyS31.device                                                          loaded active plugged   /sys/devices/platform/serial8250/tty/ttyS31
  sys-devices-platform-serial8250-tty-ttyS4.device                                                           loaded active plugged   /sys/devices/platform/serial8250/tty/ttyS4
  sys-devices-platform-serial8250-tty-ttyS5.device                                                           loaded active plugged   /sys/devices/platform/serial8250/tty/ttyS5
  sys-devices-platform-serial8250-tty-ttyS6.device                                                           loaded active plugged   /sys/devices/platform/serial8250/tty/ttyS6
  sys-devices-platform-serial8250-tty-ttyS7.device                                                           loaded active plugged   /sys/devices/platform/serial8250/tty/ttyS7
  sys-devices-platform-serial8250-tty-ttyS8.device                                                           loaded active plugged   /sys/devices/platform/serial8250/tty/ttyS8
  sys-devices-platform-serial8250-tty-ttyS9.device                                                           loaded active plugged   /sys/devices/platform/serial8250/tty/ttyS9
  sys-devices-pnp0-00:01-tty-ttyS0.device        loaded active plugged   /sys/devices/pnp0/00:01/tty/ttyS0
  sys-devices-virtual-misc-rfkill.device        loaded active plugged   /sys/devices/virtual/misc/rfkill
  sys-devices-virtual-net-docker0.device        loaded active plugged   /sys/devices/virtual/net/docker0
  sys-module-configfs.device        loaded active plugged   /sys/module/configfs
  sys-module-fuse.device        loaded active plugged   /sys/module/fuse
  sys-subsystem-bluetooth-devices-hci0.device        loaded active plugged   /sys/subsystem/bluetooth/devices/hci0
  sys-subsystem-net-devices-docker0.device        loaded active plugged   /sys/subsystem/net/devices/docker0
  sys-subsystem-net-devices-enp0s31f6.device        loaded active plugged   Ethernet Connection (2) I219-V
  -.mount        loaded active mounted   Root Mount
  dev-hugepages.mount        loaded active mounted   Huge Pages File System
  dev-mqueue.mount        loaded active mounted   POSIX Message Queue File System
  mnt-Lord\x20Lance.mount        loaded active mounted   /mnt/Lord Lance
  mnt-Seagate\x20Backup\x20Plus.mount        loaded active mounted   /mnt/Seagate Backup Plus
  mnt-Western\x20Digital\x20HDD.mount        loaded active mounted   /mnt/Western Digital HDD
  run-credentials-systemd\x2dsysctl.service.mount                                                            loaded active mounted   /run/credentials/systemd-sysctl.service
  run-credentials-systemd\x2dtmpfiles\x2dsetup.service.mount                                                 loaded active mounted   /run/credentials/systemd-tmpfiles-setup.service
  run-credentials-systemd\x2dtmpfiles\x2dsetup\x2ddev.service.mount                                          loaded active mounted   /run/credentials/systemd-tmpfiles-setup-dev.service
  run-user-1000-doc.mount        loaded active mounted   /run/user/1000/doc
  run-user-1000.mount        loaded active mounted   /run/user/1000
  sys-fs-fuse-connections.mount        loaded active mounted   FUSE Control File System
  sys-kernel-config.mount        loaded active mounted   Kernel Configuration File System
  sys-kernel-debug.mount        loaded active mounted   Kernel Debug File System
  sys-kernel-tracing.mount        loaded active mounted   Kernel Trace File System
  tmp.mount        loaded active mounted   /tmp
  cups.path        loaded active running   CUPS Scheduler
  systemd-ask-password-plymouth.path        loaded active waiting   Forward Password Requests to Plymouth Directory Watch
  systemd-ask-password-wall.path        loaded active waiting   Forward Password Requests to Wall Directory Watch
  init.scope        loaded active running   System and Service Manager
  session-1.scope        loaded active running   Session 1 of User lance
  alsa-restore.service        loaded active exited    Save/Restore Sound Card State
  bluetooth.service        loaded active running   Bluetooth service
  containerd.service        loaded active running   containerd container runtime
  cronie.service        loaded active running   Periodic Command Scheduler
  cups.service        loaded active running   CUPS Scheduler
  dbus.service        loaded active running   D-Bus System Message Bus
  docker.service        loaded active running   Docker Application Container Engine
  emby-server.service        loaded active running   Emby brings together your videos, music, photos, and live television.
  kmod-static-nodes.service        loaded active exited    Create List of Static Device Nodes
  lvm2-monitor.service        loaded active exited    Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling
  ModemManager.service        loaded active running   Modem Manager
  NetworkManager-wait-online.service        loaded active exited    Network Manager Wait Online
  NetworkManager.service        loaded active running   Network Manager
  packagekit.service        loaded active running   PackageKit Daemon
  plymouth-quit-wait.service        loaded active exited    Hold until boot process finishes up
  plymouth-quit.service        loaded active exited    Terminate Plymouth Boot Screen
  plymouth-read-write.service        loaded active exited    Tell Plymouth To Write Out Runtime Data
  plymouth-start.service        loaded active exited    Show Plymouth Boot Screen
  polkit.service        loaded active running   Authorization Manager
  rtkit-daemon.service        loaded active running   RealtimeKit Scheduling Policy Service
  sabnzbd.service        loaded active running   SABnzbd binary newsreader
  sddm.service        loaded active running   Simple Desktop Display Manager
  systemd-journal-flush.service        loaded active exited    Flush Journal to Persistent Storage
  systemd-journald.service        loaded active running   Journal Service
  systemd-logind.service        loaded active running   User Login Management
  systemd-modules-load.service        loaded active exited    Load Kernel Modules
  systemd-random-seed.service        loaded active exited    Load/Save Random Seed
  systemd-remount-fs.service        loaded active exited    Remount Root and Kernel File Systems
  systemd-sysctl.service        loaded active exited    Apply Kernel Variables
  systemd-timesyncd.service        loaded active running   Network Time Synchronization
  systemd-tmpfiles-setup-dev.service        loaded active exited    Create Static Device Nodes in /dev
  systemd-tmpfiles-setup.service        loaded active exited    Create Volatile Files and Directories
  systemd-udev-trigger.service        loaded active exited    Coldplug All udev Devices
  systemd-udevd.service        loaded active running   Rule-based Manager for Device Events and Files
  systemd-update-utmp.service        loaded active exited    Record System Boot/Shutdown in UTMP
  systemd-user-sessions.service        loaded active exited    Permit User Sessions
  systemd-vconsole-setup.service        loaded active exited    Setup Virtual Console
  teamviewerd.service        loaded active running   TeamViewer remote control daemon
  udisks2.service        loaded active running   Disk Manager
  upower.service        loaded active running   Daemon for power management
  user-runtime-dir@1000.service        loaded active exited    User Runtime Directory /run/user/1000
  user@1000.service        loaded active running   User Manager for UID 1000
  -.slice        loaded active active    Root Slice
  system-getty.slice        loaded active active    Slice /system/getty
  system-modprobe.slice        loaded active active    Slice /system/modprobe
  system.slice        loaded active active    System Slice
  user-1000.slice        loaded active active    User Slice of UID 1000
  user.slice        loaded active active    User and Session Slice
  cups.socket        loaded active running   CUPS Scheduler
  dbus.socket        loaded active running   D-Bus System Message Bus Socket
  dm-event.socket        loaded active listening Device-mapper event daemon FIFOs
  docker.socket        loaded active running   Docker Socket for the API
  lvm2-lvmpolld.socket        loaded active listening LVM2 poll daemon socket
  systemd-coredump.socket        loaded active listening Process Core Dump Socket
  systemd-journald-audit.socket        loaded active running   Journal Audit Socket
  systemd-journald-dev-log.socket        loaded active running   Journal Socket (/dev/log)
  systemd-journald.socket        loaded active running   Journal Socket
  systemd-rfkill.socket        loaded active listening Load/Save RF Kill Switch Status /dev/rfkill Watch
  systemd-udevd-control.socket        loaded active running   udev Control Socket
  systemd-udevd-kernel.socket        loaded active running   udev Kernel Socket
  dev-disk-by\x2duuid-5d178c61\x2dfac8\x2d46ec\x2d8b66\x2d37f2b97fce07.swap                                  loaded active active    /dev/disk/by-uuid/5d178c61-fac8-46ec-8b66-37f2b97fce07
  basic.target        loaded active active    Basic System
  bluetooth.target        loaded active active    Bluetooth Support
  cryptsetup.target        loaded active active    Local Encrypted Volumes
  getty.target        loaded active active    Login Prompts
  graphical.target        loaded active active    Graphical Interface
  integritysetup.target        loaded active active    Local Integrity Protected Volumes
  local-fs-pre.target        loaded active active    Preparation for Local File Systems
  local-fs.target        loaded active active    Local File Systems
  multi-user.target        loaded active active    Multi-User System
  network-online.target        loaded active active    Network is Online
  network.target        loaded active active    Network
  paths.target        loaded active active    Path Units
  remote-fs.target        loaded active active    Remote File Systems
  slices.target        loaded active active    Slice Units
  sockets.target        loaded active active    Socket Units
  sound.target        loaded active active    Sound Card
  swap.target        loaded active active    Swaps
  sysinit.target        loaded active active    System Initialization
  time-set.target        loaded active active    System Time Set
  timers.target        loaded active active    Timer Units
  veritysetup.target        loaded active active    Local Verity Protected Volumes
  archlinux-keyring-wkd-sync.timer        loaded active waiting   Refresh existing PGP keys of archlinux-keyring regularly
  fstrim.timer        loaded active waiting   Discard unused blocks once a week
  logrotate.timer        loaded active waiting   Daily rotation of log files
  man-db.timer        loaded active waiting   Daily man-db regeneration
  pamac-cleancache.timer        loaded active waiting   Monthly clean packages cache
  pamac-mirrorlist.timer        loaded active waiting   Generate mirrorlist weekly
  pkgfile-update.timer        loaded active waiting   pkgfile database update timer
  shadow.timer        loaded active waiting   Daily verification of password and group files
  systemd-tmpfiles-clean.timer        loaded active waiting   Daily Cleanup of Temporary Directories
LOAD   = Reflects whether the unit definition was properly loaded.
ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
SUB    = The low-level unit activation state, values depend on unit type.
170 loaded units listed. Pass --all to see loaded but inactive units, too.
To show all installed unit files use 'systemctl list-unit-files'.
And when it’s restarting this is what seems to be taking time:
Hi @lordlance,
Please provide the output for:
journalctl --boot=-1 --priority=4 --no-pager
Where:
  • --boot=-1 is the reference to the previous boot. Since we’re looking for shutdown problems, it is at the end of the previous boot;
  • --priority=4 just limits the output to warnings and error messages only;
  • --no-pager formats the output so that it is usable here, on the forum.
Hope you manage!
Edit:
Please also provide the output of:
sudo dmesg | grep -i Fail
Edit #2:
Also, see:
https://www.linuxquestions.org/questions/linux-software-2/identifying-a-stop-job-running-into-timeout-during-shutdown-4175705665/#post6313976
So, check your /etc/fstab:
So I suggest that you go through /etc/fstab and check that every UUID listed in fstab is the same as the one listed on the corresponding partition UUID.
Mar 21 19:56:42 home kernel: x86/cpu: SGX disabled by BIOS.
Mar 21 19:56:42 home kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
Mar 21 19:56:42 home kernel: MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
Mar 21 19:56:42 home kernel:  #5 #6 #7
Mar 21 19:56:42 home kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Mar 21 19:56:42 home kernel: resource sanity check: requesting [mem 0xfdffe800-0xfe0007ff], which spans more than pnp 00:07 [mem 0xfdb00000-0xfdffffff]
Mar 21 19:56:42 home kernel: caller pmc_core_probe+0xb7/0x6b0 mapping multiple BARs
Mar 21 19:56:42 home kernel: ata1.00: supports DRM functions and may not be fully accessible
Mar 21 19:56:44 home kernel: sd 6:0:0:0: [sdd] No Caching mode page found
Mar 21 19:56:44 home kernel: sd 6:0:0:0: [sdd] Assuming drive cache: write through
Mar 21 19:56:45 home kernel: sd 7:0:0:0: [sdc] Optimal transfer size 33553920 bytes not a multiple of preferred minimum block size (4096 bytes)
Mar 21 19:56:46 home kernel: scsi 6:0:0:1: Wrong diagnostic page; asked for 1 got 8
Mar 21 19:56:46 home kernel: scsi 6:0:0:1: Failed to get diagnostic page 0x1
Mar 21 19:56:46 home kernel: scsi 6:0:0:1: Failed to bind enclosure -19
Mar 21 19:56:46 home kernel: kauditd_printk_skb: 24 callbacks suppressed
Mar 21 19:56:46 home bluetoothd[595]: profiles/audio/vcp.c:vcp_init() D-Bus experimental not enabled
Mar 21 19:56:46 home bluetoothd[595]: src/plugin.c:plugin_init() Failed to init vcp plugin
Mar 21 19:56:46 home bluetoothd[595]: profiles/audio/mcp.c:mcp_init() D-Bus experimental not enabled
Mar 21 19:56:46 home bluetoothd[595]: src/plugin.c:plugin_init() Failed to init mcp plugin
Mar 21 19:56:46 home bluetoothd[595]: profiles/audio/bap.c:bap_init() D-Bus experimental not enabled
Mar 21 19:56:46 home bluetoothd[595]: src/plugin.c:plugin_init() Failed to init bap plugin
Mar 21 19:56:49 home ksplashqml[859]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath.desktop/contents/splash/Splash.qml:49: ReferenceError: maxWidth is not defined
Mar 21 19:56:49 home ksplashqml[859]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath.desktop/contents/splash/Splash.qml:81:29: Unable to assign int to QEasingCurve
Mar 21 19:56:49 home udisksd[917]: Error probing device: Error sending ATA command IDENTIFY DEVICE to '/dev/sdd': Unexpected sense data returned:
                                   0000: f0 00 01 00  50 00 01 0a  80 00 00 00  00 1d 00 00    ....P...........
                                   0010: 00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00    ................
                                    (g-io-error-quark, 0)
Mar 21 19:56:49 home ksmserver[926]: Qt: Session management error: networkIdsList argument is NULL
Mar 21 19:56:49 home kglobalaccel5[1002]: kf.globalaccel.kglobalacceld: No desktop file found for service  "org.kde.spectacle.desktop"
Mar 21 19:56:49 home kwin_x11[929]: kwin_xkbcommon: XKB: couldn't find a Compose file for locale "en_IN" (mapped to "en_IN.ISO8859-1")
Mar 21 19:56:49 home kwin_x11[929]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
Mar 21 19:56:49 home kwin_x11[929]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
Mar 21 19:56:49 home ksmserver[926]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.17'
Mar 21 19:56:50 home baloo_file[882]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.25'
Mar 21 19:56:50 home plasmashell[1048]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Mar 21 19:56:50 home plasmashell[1048]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Mar 21 19:56:50 home backlighthelper[1157]: org.kde.powerdevil: no kernel backlight interface found
Mar 21 19:56:50 home org_kde_powerdevil[1095]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Mar 21 19:56:50 home pipewire[1168]: mod.rt: Can't find org.freedesktop.portal.Desktop. Is xdg-desktop-portal running?
Mar 21 19:56:50 home pipewire[1168]: mod.rt: found session bus but no portal
Mar 21 19:56:50 home org_kde_powerdevil[1095]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
Mar 21 19:56:50 home com.teamviewer.TeamViewer[921]: qrc:/ui/MainWindow/Meeting/MeetingJoinPanel.qml:69: TypeError: Cannot read property 'participantName' of null
Mar 21 19:56:50 home com.teamviewer.TeamViewer[921]: qrc:/ui/MainWindow/Meeting/MeetingJoinPanel.qml:17: TypeError: Cannot read property 'joinEnabled' of null
Mar 21 19:56:50 home com.teamviewer.TeamViewer[921]: qrc:/ui/MainWindow/Meeting/MeetingJoinPanel.qml:18: TypeError: Cannot read property 'joining' of null
Mar 21 19:56:50 home com.teamviewer.TeamViewer[921]: file:///opt/teamviewer/tv_bin/RTlib/qt/qml/QtQuick/Controls/Private/Style.qml:52: ReferenceError: __control is not defined
Mar 21 19:56:50 home com.teamviewer.TeamViewer[921]: file:///opt/teamviewer/tv_bin/RTlib/qt/qml/QtQuick/Controls/Styles/Base/ScrollViewStyle.qml:56: ReferenceError: __control is not defined
Mar 21 19:56:50 home com.teamviewer.TeamViewer[921]: qrc:/ui/MainWindow/Onboarding/OnboardingTab.qml:80: TypeError: Cannot read property 'headline' of null
Mar 21 19:56:50 home com.teamviewer.TeamViewer[921]: qrc:/ui/MainWindow/Onboarding/OnboardingTab.qml:95: TypeError: Cannot read property 'image' of null
Mar 21 19:56:50 home com.teamviewer.TeamViewer[921]: qrc:/ui/MainWindow/Onboarding/OnboardingTab.qml:101: TypeError: Cannot read property 'text' of null
Mar 21 19:56:50 home wireplumber[1169]: Failed to set scheduler settings: Operation not permitted
Mar 21 19:56:50 home kded5[928]: kscreen.kded: PowerDevil SuspendSession action not available!
Mar 21 19:56:50 home plasmashell[1048]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Mar 21 19:56:50 home org_kde_powerdevil[1095]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Mar 21 19:56:50 home org_kde_powerdevil[1095]: org.kde.powerdevil: The profile  "AC" tried to activate "DimDisplay" a non-existent action. This is usually due to an installation problem, a configuration problem, or because the action is not supported
Mar 21 19:56:50 home plasmashell[1048]: libpng warning: iCCP: known incorrect sRGB profile
Mar 21 19:56:51 home kernel: kauditd_printk_skb: 141 callbacks suppressed
Mar 21 19:56:51 home kdeconnectd[1233]: kdeconnect.core: Warning: KDE Connect private key file has too open permissions  "/home/lance/.config/kdeconnect/privateKey.pem"
Mar 21 19:56:51 home kdeconnectd[1233]: kdeconnect.core: Warning: KDE Connect certificate file has too open permissions  "/home/lance/.config/kdeconnect/certificate.pem"
Mar 21 19:56:51 home plasmashell[1048]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:534:9: QML Label: Binding loop detected for property "height"
Mar 21 19:56:51 home plasmashell[1048]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:499:13: QML Label: Binding loop detected for property "height"
Mar 21 19:56:51 home wireplumber[1169]: <WpPortalPermissionStorePlugin:0x55894f1cd120> Failed to call Lookup: GDBus.Error:org.freedesktop.portal.Error.NotFound: No entry for camera
Mar 21 19:56:51 home plasmashell[1048]: Trying to use rootObject before initialization is completed, whilst using setInitializationDelayed. Forcing completion
Mar 21 19:56:51 home plasmashell[1048]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:556:5: QML Label: Binding loop detected for property "height"
Mar 21 19:56:51 home kdeconnectd[1233]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Mar 21 19:56:51 home kdeconnectd[1233]: kdeconnect.plugin.battery: No Primary Battery detected on this system. This may be a bug.
Mar 21 19:56:51 home kdeconnectd[1233]: kdeconnect.plugin.battery: Total quantity of batteries found:  0
Mar 21 19:56:51 home plasmashell[1048]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
Mar 21 19:56:51 home plasmashell[1048]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/ThumbnailStrip.qml"
Mar 21 19:56:52 home plasmashell[1048]: file:///usr/lib/qt/qml/org/kde/plasma/workspace/calendar/InfiniteList.qml:43:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Mar 21 19:56:52 home plasmashell[1048]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Mar 21 19:56:52 home plasmashell[1048]: file:///usr/lib/qt/qml/org/kde/plasma/workspace/calendar/MonthView.qml:381: TypeError: Cannot read property 'cellHeight' of null
Mar 21 19:56:52 home plasmashell[1048]: file:///usr/share/plasma/plasmoids/org.kde.plasma.mediacontroller/contents/ui/CompactRepresentation.qml:77: TypeError: Cannot read property 'implicitWidth' of null
Mar 21 19:56:53 home pulseaudio[1370]: stat('/etc/pulse/default.pa.d'): No such file or directory
Mar 21 19:56:54 home com.teamviewer.TeamViewer[921]: qrc:/ui/MainWindow/Partnerlist/Partnerlist.qml:24: TypeError: Cannot read property 'itemModel' of null
Mar 21 19:56:55 home plasmashell[1048]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Mar 21 19:58:28 home birdtray[1223]: QThread::wait: Thread tried to wait on itself
Mar 21 19:58:28 home birdtray[1223]: QSocketNotifier: Socket notifiers cannot be enabled or disabled from another thread
Mar 21 19:58:28 home birdtray[1223]: QThread: Destroyed while thread is still running
Mar 21 19:58:28 home kdeconnectd[1233]: org.kde.pulseaudio: No object for name "alsa_output.pci-0000_00_1f.3.analog-stereo"
Mar 21 19:58:28 home kdeconnectd[1233]: org.kde.pulseaudio: No object for name "alsa_input.usb-046d_081b_E878AD50-02.mono-fallback"
Mar 21 19:58:28 home plasmashell[1048]: file:///usr/share/plasma/plasmoids/org.kde.kdeconnect/contents/ui/FullRepresentation.qml:37:23: QML DeviceDelegate: Binding loop detected for property "width"
Mar 21 19:58:29 home ksmserver[926]: org.kde.kf5.ksmserver: Connection rejected: ksmserver is shutting down
Mar 21 19:58:29 home kdeconnectd[2475]: Qt: Session management error: Protocol Setup Failed, reason : Connection rejected: ksmserver is shutting down
Mar 21 19:58:29 home kded5[928]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
Mar 21 19:58:29 home kdeconnectd[2475]: kdeconnect.core: Warning: KDE Connect private key file has too open permissions  "/home/lance/.config/kdeconnect/privateKey.pem"
Mar 21 19:58:29 home kdeconnectd[2475]: kdeconnect.core: Warning: KDE Connect certificate file has too open permissions  "/home/lance/.config/kdeconnect/certificate.pem"
Mar 21 19:58:29 home org.kde.kdeconnect[2475]: dbus[2475]: arguments to dbus_pending_call_block() were incorrect, assertion "pending != NULL" failed in file dbus-pending-call.c line 766.
Mar 21 19:58:29 home org.kde.kdeconnect[2475]: This is normally a bug in some application using the D-Bus library.
Mar 21 19:58:29 home sddm[772]: Authentication error: "Process crashed"
Mar 21 19:58:29 home sddm[772]: Auth: sddm-helper crashed (exit code 15)
Mar 21 19:58:29 home sddm[772]: Auth: sddm-helper exited with 15
Mar 21 19:58:29 home com.teamviewer.TeamViewer[921]: The X11 connection broke (error 1). Did the X11 server die?
Mar 21 19:58:29 home com.teamviewer.TeamViewer[921]: The X11 connection broke: I/O error (code 1)
Mar 21 19:58:29 home com.teamviewer.TeamViewer[921]: X connection to :0 broken (explicit kill or server shutdown).
Mar 21 19:58:29 home kdeconnectd[2475]: The X11 connection broke (error 1). Did the X11 server die?
Mar 21 19:58:29 home kactivitymanagerd[1087]: The X11 connection broke (error 1). Did the X11 server die?
Mar 21 19:58:29 home com.teamviewer.TeamViewer[921]: malloc(): unsorted double linked list corrupted
Mar 21 19:58:29 home systemd[829]: plasma-kactivitymanagerd.service: Failed with result 'exit-code'.
Mar 21 19:58:29 home systemd[829]: app-com.ulduzsoft.Birdtray@autostart.service: Main process exited, code=dumped, status=6/ABRT
Mar 21 19:58:29 home systemd[829]: app-com.ulduzsoft.Birdtray@autostart.service: Failed with result 'core-dump'.
Mar 21 19:58:30 home systemd[1]: udisks2.service: Main process exited, code=dumped, status=6/ABRT
Mar 21 19:58:30 home systemd[1]: udisks2.service: Failed with result 'core-dump'.
Mar 21 19:58:30 home sddm[772]: Signal received: SIGTERM
Mar 21 19:58:31 home sddm[772]: QProcess: Destroyed while process ("/usr/lib/sddm/sddm-helper") is still running.
Mar 21 19:58:34 home kernel: kauditd_printk_skb: 26 callbacks suppressed
Mar 21 20:00:00 home systemd[829]: dbus.service: State 'final-sigterm' timed out. Killing.
Mar 21 20:00:00 home systemd[829]: dbus.service: Failed with result 'timeout'.
Mar 21 20:00:01 home systemd[1]: run-credentials-systemd\x2dtmpfiles\x2dsetup.service.mount: Failed with result 'exit-code'.
Mar 21 20:00:01 home kernel: watchdog: watchdog0: watchdog did not stop!
[    5.727799] scsi 6:0:0:1: Failed to get diagnostic page 0x1
[    5.727801] scsi 6:0:0:1: Failed to bind enclosure -19
[  289.921820] audit: type=1100 audit(1679409338.833:104): pid=3142 uid=1000 auid=1000 ses=2 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="lance" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
[  302.642386] audit: type=1100 audit(1679409351.556:107): pid=3200 uid=1000 auid=1000 ses=2 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="lance" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[  302.643147] audit: type=1110 audit(1679409351.556:109): pid=3200 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[  304.827370] audit: type=1104 audit(1679409353.739:113): pid=3200 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[  310.377323] audit: type=1110 audit(1679409359.289:115): pid=3351 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[  310.437261] audit: type=1104 audit(1679409359.349:118): pid=3351 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[  886.568544] audit: type=1100 audit(1679409935.476:119): pid=4483 uid=1000 auid=1000 ses=2 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="lance" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[  886.569151] audit: type=1110 audit(1679409935.479:121): pid=4483 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[  889.642501] audit: type=1104 audit(1679409938.552:124): pid=4483 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 1435.730719] audit: type=1100 audit(1679410484.635:127): pid=5459 uid=1000 auid=1000 ses=2 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="lance" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[ 1435.734073] audit: type=1110 audit(1679410484.639:129): pid=5459 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[ 1436.974423] audit: type=1104 audit(1679410485.879:132): pid=5459 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[ 1472.904072] audit: type=1110 audit(1679410521.808:134): pid=5520 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[ 1473.153322] audit: type=1104 audit(1679410522.058:137): pid=5520 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[ 3128.205455] audit: type=1100 audit(1679412177.100:138): pid=6984 uid=1000 auid=1000 ses=2 msg='op=PAM:authentication grantors=? acct="lance" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=failed'
[ 3141.229189] audit: type=1100 audit(1679412190.123:139): pid=7019 uid=1000 auid=1000 ses=2 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="lance" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 3141.232903] audit: type=1110 audit(1679412190.127:141): pid=7019 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 3141.482011] audit: type=1104 audit(1679412190.377:144): pid=7019 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 3148.495129] audit: type=1110 audit(1679412197.390:146): pid=7033 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 3150.954077] audit: type=1104 audit(1679412199.850:149): pid=7033 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 3267.037704] audit: type=1100 audit(1679412315.929:150): pid=7284 uid=1000 auid=1000 ses=2 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="lance" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[ 3267.041800] audit: type=1110 audit(1679412315.936:152): pid=7284 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Based on what I see, they do match:
blkid output:
/dev/nvme0n1p3: BLOCK_SIZE="512" UUID="9E50D3D450D3B0EF" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="b235f35d-c964-474e-b17e-4b4ba2f39e67"
/dev/nvme0n1p1: UUID="C4C9-FCA3" BLOCK_SIZE="512" TYPE="vfat" PARTLABEL="EFI system partition" PARTUUID="d924536f-9837-4ec6-8954-4f5c3f63ef5a"
/dev/nvme0n1p4: BLOCK_SIZE="512" UUID="BE04EE2204EDDE01" TYPE="ntfs" PARTUUID="3d1b2855-b6de-4953-b21b-ed5dfb881489"
/dev/sdd1: LABEL="Lord Lance" BLOCK_SIZE="512" UUID="A2F647BFF6479309" TYPE="ntfs" PARTLABEL="My Passport" PARTUUID="a40a9105-51ae-470c-9171-32af509e4622"
/dev/sdb1: LABEL="Western Digital 1TB HDD" BLOCK_SIZE="512" UUID="406096B36096AF62" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="31dce5fc-96f4-4f62-b351-2bd8fad58291"
/dev/sdc1: LABEL="Seagate Backup" BLOCK_SIZE="512" UUID="4E72C35E72C34983" TYPE="ntfs" PARTUUID="23613b02-01"
/dev/sda2: LABEL="swap" UUID="5d178c61-fac8-46ec-8b66-37f2b97fce07" TYPE="swap" PARTUUID="f983cb0d-02"
/dev/sda1: UUID="30b101f0-84c0-4963-8856-274804c75768" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="f983cb0d-01"
/dev/nvme0n1p2: PARTLABEL="Microsoft reserved partition" PARTUUID="9ed6b9b4-7f76-4ef2-a1ec-b2e54cdf5a58"
etc/fstab
UUID=30b101f0-84c0-4963-8856-274804c75768 /              ext4    defaults,noatime 0 1
UUID=5d178c61-fac8-46ec-8b66-37f2b97fce07 swap           swap    defaults,noatime 0 0
tmpfs                                     /tmp           tmpfs   defaults,noatime,mode=1777 0 0
Been looking at this again, obviously I know, and just saw this :point_down:
… and those two calls are about 2 minutes apart, and the one it got stuck on is plasmashell. But this makes no sense as I also use it and don’t have it.
So that’s making me think it’s some kind of customization. So I say test if it’s not a theme. Either Plasma shell or SDDM.
I don’t know what else it can be, so I hope it helps!
