Troubleshooting Nvidia RTX 5060
Hi Manjaro-Mates,
for some reason SDDM (KDE/Wayland) produces a black screen on RTX 5060 cards (means: no graphical login). My workaround currently is to use COSMIC’s login screen (cosmic-greeter) which just works fine.
This affects TUXEDO InfinityBook Max 15 - Gen10 (possibly RTX 5060 in general?). Also tried with the older 570xx driver - didn’t make any obvious difference.
I would try the plasma-login-manager. Pretty easy to switch:
$ sudo pacman -Syu plasma-login-manager
$ systemctl disable sddm
$ systemctl enable plasmalogin
$ sudo pacman -R sddm-kcm sddm
If you are not using SDDM already, disable the COSMIC login manager instead of sddm.
I will try with plasma-login-manager thank you for suggesting!
Please note that Manjaro KDE ISO still ships SDDM by default - likely resulting in a broken installation for many users. (Actually invested about 1.5 days to figure that out - unideal…)
EDIT: Yep, plasma-login-manager also works thanks!
