Hello everyone, I’m trying to install pyenv on Manjaro because I need to work with different python versions, I did install pyenv from the official repositories and I followed the instructions here but pyenv wasn’t able to change the Python version when I did pyenv install -v 3.9.11 to install version 3.9.11 of Python in my system and then pyenv global 3.9.11, when I did python -V the python version remained the same 3.10.4.
I checked with which python command and paths remained the same /usr/bin/python.
So I followed the instructions here, so I did
echo 'export PYENV_ROOT="$HOME/.pyenv"' >> ~/.zprofile
echo 'export PATH="$PYENV_ROOT/bin:$PATH"' >> ~/.zprofile
echo 'eval "$(pyenv init --path)"' >> ~/.zprofile
echo 'export PYENV_ROOT="$HOME/.pyenv"' >> ~/.profile
echo 'export PATH="$PYENV_ROOT/bin:$PATH"' >> ~/.profile
echo 'eval "$(pyenv init --path)"' >> ~/.profile
echo 'eval "$(pyenv init -)"' >> ~/.zshrc
Note that I’m using zsh, however after restarting the shell, it didn’t work, repeating the pyenv global commands, etcetera.
So I tried using pyenv-installer and I followed the instructions however it prompts me to install again pyenv from the official repos as:
The application pyenv is not installed. It may be found in the following packages:
community/pyenv 2.2.5-1 /usr/bin/pyenv
Do you want to Install package pyenv? (y/N)
And it doesn’t work.
I post here my inxi -Faxi if this is of any help
Host: asdru Kernel: 5.16.18-1-MANJARO arch: x86_64 bits: 64 compiler: gcc
v: 11.2.0 parameters: BOOT_IMAGE=/boot/vmlinuz-5.16-x86_64
root=UUID=b7ccff9c-3ed2-4871-9171-b63a484b3dc9 rw quiet splash apparmor=1
security=apparmor resume=UUID=796ccbcb-530d-434a-8efd-c4a8a7338c8b
udev.log_priority=3
Desktop: GNOME v: 41.5 tk: GTK v: 3.24.33 wm: gnome-shell dm: GDM v: 41.3
Type: Laptop System: LENOVO product: 81UH v: Lenovo Legion Y740-15IRHg
serial: <superuser required> Chassis: type: 10 v: Lenovo Legion Y740-15IRHg
Mobo: LENOVO model: LNVNB161216 v: SDK0R32862 WIN
serial: <superuser required> UEFI-[Legacy]: LENOVO v: BVCN11WW(V1.07)
date: 07/04/2019
ID-1: BAT1 charge: 34.5 Wh (69.4%) condition: 49.7/52.4 Wh (94.9%)
volts: 11.6 min: 11.6 model: Celxpert L17L3PG1 type: Li-ion serial: 190
status: discharging
Info: model: Intel Core i7-9750H bits: 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xEC
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 922 high: 1000 min/max: 800/4500 scaling:
driver: intel_pstate governor: powersave cores: 1: 900 2: 900 3: 900 4: 900
5: 900 6: 900 7: 973 8: 1000 9: 1000 10: 900 11: 900 12: 900
bogomips: 62431
Type: l1tf
Device-1: NVIDIA TU106BM [GeForce RTX 2060 Mobile] vendor: Lenovo
driver: nvidia v: 510.60.02 alternate: nouveau,nvidia_drm pcie: gen: 1
speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0
chip-ID: 10de:1f51 class-ID: 0300
Device-2: Chicony Integrated Camera (1280x720@30) type: USB
driver: uvcvideo bus-ID: 1-7:4 chip-ID: 04f2:b604 class-ID: 0e02
serial: 0001
Display: x11 server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.1
compositor: gnome-shell driver: X: loaded: nvidia gpu: nvidia
display-ID: :1 screens: 1
Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
Monitor-1: DP-4 res: 1920x1080 hz: 144 dpi: 142
size: 344x194mm (13.54x7.64") diag: 395mm (15.55") modes: N/A
OpenGL: renderer: NVIDIA GeForce RTX 2060/PCIe/SSE2
v: 4.6.0 NVIDIA 510.60.02 direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel
Device-2: NVIDIA TU106 High Definition Audio vendor: Lenovo
bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
Sound Server-1: ALSA v: k5.16.18-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.49 running: yes
Device-1: Intel Cannon Lake PCH CNVi WiFi
vendor: Rivet Networks Killer Wireless-AC 1550i Wireless driver: iwlwifi
v: kernel bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
IF: wlp0s20f3 state: up mac: 24:ee:9a:ee:76:b8
IP v4: 192.168.0.162/24 type: dynamic noprefixroute scope: global
broadcast: 192.168.0.255
IP v6: fe80::3174:62e7:cfef:d096/64 type: noprefixroute scope: link
vendor: Lenovo driver: r8169 v: kernel pcie: speed: Unknown lanes: 63
link-max: gen: 6 speed: 64 GT/s port: 3000 bus-ID: 3f:00.0
IF: enp63s0 state: down mac: 7c:8a:e1:20:86:b4
IF-ID-1: br-3c1e6988777b state: down mac: 02:42:a2:24:94:7c
IP v4: 172.21.0.1/16 scope: global broadcast: 172.21.255.255
IF-ID-2: docker0 state: down mac: 02:42:30:40:da:14
IP v4: 172.17.0.1/16 scope: global broadcast: 172.17.255.255
WAN IP: 206.62.162.126
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-14:5 chip-ID: 8087:0aaa class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 3 state: down
bt-service: enabled,running rfk-block: hardware: no software: yes
address: 24:EE:9A:EE:76:BC
Local Storage: total: 953.87 GiB used: 177.8 GiB (18.6%)
model: MZVLB1T0HALR-000L2 size: 953.87 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: S3RSNX0M903911
rev: 5L1QEXA7 temp: 36.9 C scheme: MBR
ID-1: / raw-size: 919.45 GiB size: 903.95 GiB (98.31%)
used: 177.8 GiB (19.7%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: partition size: 34.41 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p2 maj-min: 259:2
System Temperatures: cpu: 54.0 C pch: 54.0 C mobo: N/A gpu: nvidia
temp: 55 C
Processes: 358 Uptime: 3h 51m wakeups: 21 Memory: 31.27 GiB
used: 8.66 GiB (27.7%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: 1489 pacman: 1474 lib: 367 flatpak: 0
snap: 15 Shell: Zsh v: 5.8.1 running-in: electron inxi: 3.3.15
Any help is appreciated ![]()
