this is in regards to electron 24 24.8.8-4
Preparing...
Refreshing extra.db...
Refreshing AUR...
Preparing...
Cloning electron24 build files...
Generating electron24 information...
Checking electron24 dependencies...
Resolving dependencies...
Checking inter-conflicts...
Building electron24...
==> Making package: electron24 24.8.8-4 (Fri 01 Mar 2024 04:39:26 PM PST)
==> Retrieving sources...
-> Updating electron git repo...
From https://github.com/electron/electron
- [deleted] (none) -> base-no-destructor
- [deleted] (none) -> clavin/session-clear-data-api
- [deleted] (none) -> miniak/remove-input-field-type
- [deleted] (none) -> quick-test
- [deleted] (none) -> refactor/27-x-y--backport-41253--inline-simple-getters
- [deleted] (none) -> trop/29-x-y-bp-feat-add-browserwindow-isoccluded--1707215463074
- [deleted] (none) -> trop/29-x-y-bp-feat-add-support-for-configuring-system-network-context-proxies-1708621727140
- [deleted] (none) -> trop/30-x-y-bp-build-update-appveyor-image-to-latest-version-e-123-0-6312-5-1708618264741
- [deleted] (none) -> trop/30-x-y-bp-feat-add-support-for-configuring-system-network-context-proxies-1708621727975
- [deleted] (none) -> refs/pull/33134/merge
- [deleted] (none) -> refs/pull/40983/merge
- [deleted] (none) -> refs/pull/41239/merge
- [deleted] (none) -> refs/pull/41249/merge
- [deleted] (none) -> refs/pull/41309/merge
- [deleted] (none) -> refs/pull/41338/merge
- [deleted] (none) -> refs/pull/41379/merge
- [deleted] (none) -> refs/pull/41400/merge
- [deleted] (none) -> refs/pull/41412/merge
- [deleted] (none) -> refs/pull/41413/merge
- [deleted] (none) -> refs/pull/41415/merge
- [deleted] (none) -> refs/pull/41416/merge
- [deleted] (none) -> refs/pull/41417/merge
3511eb1a8e..1da86c0fbf 27-x-y -> 27-x-y
6544cec686..945f1c7262 28-x-y -> 28-x-y
ffcccdcf37..fd2620bda4 29-x-y -> 29-x-y
532039ea2c..56dfcc5468 30-x-y -> 30-x-y
+ a300730954...2495207a2f app-node-preload -> app-node-preload (forced update)
* [new branch] cherry-pick/security/27-x-y/release-1-m122 -> cherry-pick/security/27-x-y/release-1-m122
* [new branch] cherry-pick/security/28-x-y/release-1-m122 -> cherry-pick/security/28-x-y/release-1-m122
+ cfd34fc91d...3ad52b7612 clavin/session-clear-data-api-enhanced-plus-plus -> clavin/session-clear-data-api-enhanced-plus-plus (forced update)
* [new branch] fix-process-internals -> fix-process-internals
* [new branch] fix-util-proc-crash -> fix-util-proc-crash
* [new branch] fixup-codespaces -> fixup-codespaces
aa66ce7963..36aa7236d5 hide-browserwindow-webcontentsview -> hide-browserwindow-webcontentsview
26131b23b8..cc9e21c260 main -> main
* [new branch] miniak/ipc-renderer-internal -> miniak/ipc-renderer-internal
+ 1cf273dd2a...2dd2753293 native-filesystem-permissions -> native-filesystem-permissions (forced update)
+ 5c2f6944f8...8f098eb3ab roller/chromium/30-x-y -> roller/chromium/30-x-y (forced update)
+ 4907b11051...f35dc072af roller/chromium/main -> roller/chromium/main (forced update)
* [new branch] same-party-patch -> same-party-patch
* [new branch] slow-same-party-revert -> slow-same-party-revert
* [new branch] trop/30-x-y-bp-fix-webcontents-print-options-should-be-optional-1709220005895 -> trop/30-x-y-bp-fix-webcontents-print-options-should-be-optional-1709220005895
e690567c84..5217dfef74 refs/pull/32769/head -> refs/pull/32769/head
+ 775cc04357...1cf356e44f refs/pull/34589/merge -> refs/pull/34589/merge (forced update)
+ 8ccd6d30db...8c0b1c1100 refs/pull/34698/merge -> refs/pull/34698/merge (forced update)
+ 6bf4f3873d...24837a1b4b refs/pull/35418/merge -> refs/pull/35418/merge (forced update)
+ 721f94af8a...3367cf765b refs/pull/37902/merge -> refs/pull/37902/merge (forced update)
+ 79cc1db61b...efbddac8cf refs/pull/38437/merge -> refs/pull/38437/merge (forced update)
+ 9f0304d7ae...31bb72f7d2 refs/pull/39706/merge -> refs/pull/39706/merge (forced update)
+ 1c0c0a5401...cef1751003 refs/pull/39817/merge -> refs/pull/39817/merge (forced update)
6d55f93cc2..5c80ed8487 refs/pull/40507/head -> refs/pull/40507/head
+ 8ccb162109...630f278cbe refs/pull/40569/merge -> refs/pull/40569/merge (forced update)
+ d60e703ad0...3c6297b39c refs/pull/40667/merge -> refs/pull/40667/merge (forced update)
+ 9b1a8b5f9d...1f1d555d97 refs/pull/40894/merge -> refs/pull/40894/merge (forced update)
+ 9c7557dec9...1237e65f0f refs/pull/41046/merge -> refs/pull/41046/merge (forced update)
+ caa452da9f...ba321c6ffb refs/pull/41122/merge -> refs/pull/41122/merge (forced update)
+ a300730954...2495207a2f refs/pull/41165/head -> refs/pull/41165/head (forced update)
+ 22bb0a50b0...9df600809d refs/pull/41165/merge -> refs/pull/41165/merge (forced update)
+ 016f6b461f...235079a8f8 refs/pull/41169/merge -> refs/pull/41169/merge (forced update)
+ bcd31f9302...d831d92dbc refs/pull/41205/merge -> refs/pull/41205/merge (forced update)
+ 8015ce9b46...6c1a278adc refs/pull/41211/merge -> refs/pull/41211/merge (forced update)
aa66ce7963..36aa7236d5 refs/pull/41256/head -> refs/pull/41256/head
+ e6b33c44c0...7359f7be9c refs/pull/41256/merge -> refs/pull/41256/merge (forced update)
+ 0f224ac0f1...964ca442aa refs/pull/41271/merge -> refs/pull/41271/merge (forced update)
+ f96ca0aeb9...b45c21fdc0 refs/pull/41281/merge -> refs/pull/41281/merge (forced update)
+ 08fd3c5d90...afde2b2cba refs/pull/41314/merge -> refs/pull/41314/merge (forced update)
+ a094dff7dd...b6eefe2aec refs/pull/41326/merge -> refs/pull/41326/merge (forced update)
+ cfd34fc91d...3ad52b7612 refs/pull/41355/head -> refs/pull/41355/head (forced update)
+ 36aebdfd07...572a63e001 refs/pull/41355/merge -> refs/pull/41355/merge (forced update)
+ c0dc3d1039...b4eb082ed3 refs/pull/41358/merge -> refs/pull/41358/merge (forced update)
+ bac53cdd14...a67a31ff60 refs/pull/41369/merge -> refs/pull/41369/merge (forced update)
+ 9518d62cc9...9ba4e58f6a refs/pull/41391/merge -> refs/pull/41391/merge (forced update)
+ 4907b11051...1bb9fe2aac refs/pull/41412/head -> refs/pull/41412/head (forced update)
+ 1cf273dd2a...2dd2753293 refs/pull/41419/head -> refs/pull/41419/head (forced update)
+ de1ea65b1c...44b3cbafd1 refs/pull/41419/merge -> refs/pull/41419/merge (forced update)
f70bb3986b..dd7fb3a80a refs/pull/41420/head -> refs/pull/41420/head
* [new ref] refs/pull/41423/head -> refs/pull/41423/head
* [new ref] refs/pull/41424/head -> refs/pull/41424/head
* [new ref] refs/pull/41425/head -> refs/pull/41425/head
* [new ref] refs/pull/41428/head -> refs/pull/41428/head
* [new ref] refs/pull/41428/merge -> refs/pull/41428/merge
* [new ref] refs/pull/41430/head -> refs/pull/41430/head
* [new ref] refs/pull/41432/head -> refs/pull/41432/head
* [new ref] refs/pull/41434/head -> refs/pull/41434/head
* [new ref] refs/pull/41435/head -> refs/pull/41435/head
* [new ref] refs/pull/41436/head -> refs/pull/41436/head
* [new ref] refs/pull/41437/head -> refs/pull/41437/head
* [new ref] refs/pull/41440/head -> refs/pull/41440/head
* [new ref] refs/pull/41441/head -> refs/pull/41441/head
* [new ref] refs/pull/41446/head -> refs/pull/41446/head
* [new ref] refs/pull/41447/head -> refs/pull/41447/head
* [new ref] refs/pull/41450/head -> refs/pull/41450/head
* [new ref] refs/pull/41450/merge -> refs/pull/41450/merge
* [new ref] refs/pull/41451/head -> refs/pull/41451/head
* [new ref] refs/pull/41452/head -> refs/pull/41452/head
* [new ref] refs/pull/41453/head -> refs/pull/41453/head
* [new ref] refs/pull/41454/head -> refs/pull/41454/head
* [new ref] refs/pull/41455/head -> refs/pull/41455/head
* [new ref] refs/pull/41456/head -> refs/pull/41456/head
* [new ref] refs/pull/41457/head -> refs/pull/41457/head
* [new ref] refs/pull/41458/head -> refs/pull/41458/head
* [new ref] refs/pull/41461/head -> refs/pull/41461/head
* [new ref] refs/pull/41467/head -> refs/pull/41467/head
* [new ref] refs/pull/41470/head -> refs/pull/41470/head
* [new ref] refs/pull/41474/head -> refs/pull/41474/head
* [new ref] refs/pull/41474/merge -> refs/pull/41474/merge
* [new ref] refs/pull/41475/head -> refs/pull/41475/head
* [new ref] refs/pull/41476/head -> refs/pull/41476/head
* [new ref] refs/pull/41476/merge -> refs/pull/41476/merge
* [new ref] refs/pull/41478/head -> refs/pull/41478/head
* [new ref] refs/pull/41479/head -> refs/pull/41479/head
* [new ref] refs/pull/41480/head -> refs/pull/41480/head
* [new ref] refs/pull/41480/merge -> refs/pull/41480/merge
* [new ref] refs/pull/41483/head -> refs/pull/41483/head
* [new ref] refs/pull/41485/head -> refs/pull/41485/head
* [new ref] refs/pull/41487/head -> refs/pull/41487/head
* [new ref] refs/pull/41487/merge -> refs/pull/41487/merge
* [new ref] refs/pull/41488/head -> refs/pull/41488/head
* [new ref] refs/pull/41488/merge -> refs/pull/41488/merge
* [new ref] refs/pull/41489/head -> refs/pull/41489/head
* [new ref] refs/pull/41490/head -> refs/pull/41490/head
* [new ref] refs/pull/41490/merge -> refs/pull/41490/merge
* [new ref] refs/pull/41491/head -> refs/pull/41491/head
* [new ref] refs/pull/41492/head -> refs/pull/41492/head
* [new tag] v27.3.4 -> v27.3.4
* [new tag] v28.2.5 -> v28.2.5
* [new tag] v29.1.0 -> v29.1.0
* [new tag] v30.0.0-alpha.2 -> v30.0.0-alpha.2
* [new tag] v30.0.0-alpha.3 -> v30.0.0-alpha.3
* [new tag] v31.0.0-nightly.20240223 -> v31.0.0-nightly.20240223
* [new tag] v31.0.0-nightly.20240226 -> v31.0.0-nightly.20240226
* [new tag] v31.0.0-nightly.20240227 -> v31.0.0-nightly.20240227
* [new tag] v31.0.0-nightly.20240228 -> v31.0.0-nightly.20240228
* [new tag] v31.0.0-nightly.20240229 -> v31.0.0-nightly.20240229
* [new tag] v31.0.0-nightly.20240301 -> v31.0.0-nightly.20240301
-> Updating depot_tools git repo...
From https://chromium.googlesource.com/chromium/tools/depot_tools
* [new ref] refs/changes/03/5324203/1 -> refs/changes/03/5324203/1
* [new ref] refs/changes/03/5324203/2 -> refs/changes/03/5324203/2
* [new ref] refs/changes/03/5324203/meta -> refs/changes/03/5324203/meta
17dc5332c..853a38922 refs/changes/06/4793206/meta -> refs/changes/06/4793206/meta
* [new ref] refs/changes/07/5325207/1 -> refs/changes/07/5325207/1
* [new ref] refs/changes/07/5325207/2 -> refs/changes/07/5325207/2
* [new ref] refs/changes/07/5325207/3 -> refs/changes/07/5325207/3
* [new ref] refs/changes/07/5325207/meta -> refs/changes/07/5325207/meta
a3c10d6e6..2e0c7d920 refs/changes/09/5320109/meta -> refs/changes/09/5320109/meta
* [new ref] refs/changes/09/5328609/1 -> refs/changes/09/5328609/1
* [new ref] refs/changes/09/5328609/2 -> refs/changes/09/5328609/2
* [new ref] refs/changes/09/5328609/meta -> refs/changes/09/5328609/meta
* [new ref] refs/changes/12/5321212/1 -> refs/changes/12/5321212/1
* [new ref] refs/changes/12/5321212/meta -> refs/changes/12/5321212/meta
* [new ref] refs/changes/15/5332415/1 -> refs/changes/15/5332415/1
* [new ref] refs/changes/15/5332415/meta -> refs/changes/15/5332415/meta
* [new ref] refs/changes/22/5299722/22 -> refs/changes/22/5299722/22
* [new ref] refs/changes/22/5299722/23 -> refs/changes/22/5299722/23
* [new ref] refs/changes/22/5299722/24 -> refs/changes/22/5299722/24
* [new ref] refs/changes/22/5299722/25 -> refs/changes/22/5299722/25
* [new ref] refs/changes/22/5299722/26 -> refs/changes/22/5299722/26
* [new ref] refs/changes/22/5299722/27 -> refs/changes/22/5299722/27
* [new ref] refs/changes/22/5299722/28 -> refs/changes/22/5299722/28
* [new ref] refs/changes/22/5299722/29 -> refs/changes/22/5299722/29
* [new ref] refs/changes/22/5299722/30 -> refs/changes/22/5299722/30
* [new ref] refs/changes/22/5299722/31 -> refs/changes/22/5299722/31
1d188ffcb..608c69b06 refs/changes/22/5299722/meta -> refs/changes/22/5299722/meta
2bbc7783f..bef519364 refs/changes/34/731834/meta -> refs/changes/34/731834/meta
* [new ref] refs/changes/37/5326137/1 -> refs/changes/37/5326137/1
* [new ref] refs/changes/37/5326137/2 -> refs/changes/37/5326137/2
* [new ref] refs/changes/37/5326137/meta -> refs/changes/37/5326137/meta
fdc8e7aa8..e43ae2e15 refs/changes/38/5300838/meta -> refs/changes/38/5300838/meta
* [new ref] refs/changes/40/5336640/1 -> refs/changes/40/5336640/1
* [new ref] refs/changes/40/5336640/2 -> refs/changes/40/5336640/2
* [new ref] refs/changes/40/5336640/meta -> refs/changes/40/5336640/meta
* [new ref] refs/changes/41/5324941/1 -> refs/changes/41/5324941/1
* [new ref] refs/changes/41/5324941/2 -> refs/changes/41/5324941/2
* [new ref] refs/changes/41/5324941/meta -> refs/changes/41/5324941/meta
* [new ref] refs/changes/44/5332644/1 -> refs/changes/44/5332644/1
* [new ref] refs/changes/44/5332644/2 -> refs/changes/44/5332644/2
* [new ref] refs/changes/44/5332644/meta -> refs/changes/44/5332644/meta
* [new ref] refs/changes/46/5320246/1 -> refs/changes/46/5320246/1
* [new ref] refs/changes/46/5320246/2 -> refs/changes/46/5320246/2
* [new ref] refs/changes/46/5320246/meta -> refs/changes/46/5320246/meta
c690c7b53..246c1475d refs/changes/50/4517650/meta -> refs/changes/50/4517650/meta
61a1b111d..103227f32 refs/changes/58/4128758/meta -> refs/changes/58/4128758/meta
* [new ref] refs/changes/60/5325460/1 -> refs/changes/60/5325460/1
* [new ref] refs/changes/60/5325460/meta -> refs/changes/60/5325460/meta
9011cecaf..645329730 refs/changes/62/1147362/meta -> refs/changes/62/1147362/meta
916649aed..37200e40d refs/changes/63/527663/meta -> refs/changes/63/527663/meta
0763399f0..c689c94b7 refs/changes/65/3899165/meta -> refs/changes/65/3899165/meta
* [new ref] refs/changes/67/5325567/1 -> refs/changes/67/5325567/1
* [new ref] refs/changes/67/5325567/2 -> refs/changes/67/5325567/2
* [new ref] refs/changes/67/5325567/meta -> refs/changes/67/5325567/meta
* [new ref] refs/changes/67/5328667/1 -> refs/changes/67/5328667/1
* [new ref] refs/changes/67/5328667/2 -> refs/changes/67/5328667/2
* [new ref] refs/changes/67/5328667/meta -> refs/changes/67/5328667/meta
* [new ref] refs/changes/67/5329167/1 -> refs/changes/67/5329167/1
* [new ref] refs/changes/67/5329167/2 -> refs/changes/67/5329167/2
* [new ref] refs/changes/67/5329167/3 -> refs/changes/67/5329167/3
* [new ref] refs/changes/67/5329167/meta -> refs/changes/67/5329167/meta
* [new ref] refs/changes/71/5321571/1 -> refs/changes/71/5321571/1
* [new ref] refs/changes/71/5321571/2 -> refs/changes/71/5321571/2
* [new ref] refs/changes/71/5321571/meta -> refs/changes/71/5321571/meta
* [new ref] refs/changes/72/5328672/1 -> refs/changes/72/5328672/1
* [new ref] refs/changes/72/5328672/2 -> refs/changes/72/5328672/2
* [new ref] refs/changes/72/5328672/meta -> refs/changes/72/5328672/meta
* [new ref] refs/changes/73/5332873/1 -> refs/changes/73/5332873/1
* [new ref] refs/changes/73/5332873/2 -> refs/changes/73/5332873/2
* [new ref] refs/changes/73/5332873/3 -> refs/changes/73/5332873/3
* [new ref] refs/changes/73/5332873/4 -> refs/changes/73/5332873/4
* [new ref] refs/changes/73/5332873/meta -> refs/changes/73/5332873/meta
* [new ref] refs/changes/74/5318974/1 -> refs/changes/74/5318974/1
* [new ref] refs/changes/74/5318974/2 -> refs/changes/74/5318974/2
* [new ref] refs/changes/74/5318974/meta -> refs/changes/74/5318974/meta
* [new ref] refs/changes/74/5332374/1 -> refs/changes/74/5332374/1
* [new ref] refs/changes/74/5332374/meta -> refs/changes/74/5332374/meta
* [new ref] refs/changes/76/5333176/1 -> refs/changes/76/5333176/1
* [new ref] refs/changes/76/5333176/2 -> refs/changes/76/5333176/2
* [new ref] refs/changes/76/5333176/meta -> refs/changes/76/5333176/meta
5960fed18..6ffee294c refs/changes/78/4864378/meta -> refs/changes/78/4864378/meta
* [new ref] refs/changes/79/5332879/1 -> refs/changes/79/5332879/1
* [new ref] refs/changes/79/5332879/2 -> refs/changes/79/5332879/2
* [new ref] refs/changes/79/5332879/meta -> refs/changes/79/5332879/meta
* [new ref] refs/changes/79/5336079/1 -> refs/changes/79/5336079/1
* [new ref] refs/changes/79/5336079/2 -> refs/changes/79/5336079/2
* [new ref] refs/changes/79/5336079/meta -> refs/changes/79/5336079/meta
bfad701f5..c6af0af39 refs/changes/80/5262880/meta -> refs/changes/80/5262880/meta
* [new ref] refs/changes/87/5328187/1 -> refs/changes/87/5328187/1
* [new ref] refs/changes/87/5328187/2 -> refs/changes/87/5328187/2
* [new ref] refs/changes/87/5328187/meta -> refs/changes/87/5328187/meta
* [new ref] refs/changes/91/5334791/1 -> refs/changes/91/5334791/1
* [new ref] refs/changes/91/5334791/2 -> refs/changes/91/5334791/2
* [new ref] refs/changes/91/5334791/meta -> refs/changes/91/5334791/meta
* [new ref] refs/changes/94/5332294/1 -> refs/changes/94/5332294/1
* [new ref] refs/changes/94/5332294/meta -> refs/changes/94/5332294/meta
8783a386f..5452981b5 refs/changes/95/5320195/meta -> refs/changes/95/5320195/meta
* [new ref] refs/changes/96/5304396/11 -> refs/changes/96/5304396/11
* [new ref] refs/changes/96/5304396/12 -> refs/changes/96/5304396/12
* [new ref] refs/changes/96/5304396/13 -> refs/changes/96/5304396/13
* [new ref] refs/changes/96/5304396/14 -> refs/changes/96/5304396/14
53ed099ab..44aeba613 refs/changes/96/5304396/meta -> refs/changes/96/5304396/meta
* [new ref] refs/changes/96/5333896/1 -> refs/changes/96/5333896/1
* [new ref] refs/changes/96/5333896/2 -> refs/changes/96/5333896/2
* [new ref] refs/changes/96/5333896/meta -> refs/changes/96/5333896/meta
9d64acede..fbb0301f1 main -> main
de6c8ed0b..4922f84d6 refs/meta/config -> refs/meta/config
-> Found electron-launcher.sh
-> Found electron.desktop
-> Found default_app-icon.patch
-> Found jinja-python-3.10.patch
-> Found use-system-libraries-in-node.patch
-> Found std-vector-non-const.patch
-> Found sql-relax-constraints-on-VirtualCursor-layout.patch
-> Found swiftshader-add-cstdint-for-uint64_t.patch
-> Found dawn-iwyu-add-cstdint-for-uint8_t.patch
-> Found iwyu-add-stdint.h-for-various-int-types-in-base.patch
-> Found iwyu-add-cstdint-for-uintptr_t-in-device.patch
-> Found iwyu-add-stdint.h-for-uint32_t-in-chrome_pdf.patch
-> Found iwyu-add-stdint.h-for-uint64_t-in-EncounteredSurface.patch
-> Found iwyu-add-stdint.h-for-integer-types-in-ui.patch
-> Found openscreen-iwyu-add-stdint.h.patch
-> Found pdfium-iwyu-add-stdint.h-for-uint32_t.patch
-> Found iwyu-add-stdint.h-for-uint32_t-in-cc.patch
-> Found add-missing-includes-causing-build-errors.patch
-> Found iwyu-add-stdint.h-for-int-types-in-gpu_feature_info.patch
-> Found iwyu-add-stdint.h-for-various-int-types-in-comp.patch
-> Found iwyu-add-stdint.h-for-various-integer-types-in-net.patch
-> Found iwyu-add-cstdint-for-int-types-in-s2cellid.patch
-> Found random-fixes-for-gcc13.patch
-> Found more-fixes-for-gcc13.patch
-> Found libxml2-2.12.patch
-> Found icu-74.patch
electron ... Skipped
depot_tools ... Skipped
electron-launcher.sh ... Passed
electron.desktop ... Passed
default_app-icon.patch ... Passed
jinja-python-3.10.patch ... Passed
use-system-libraries-in-node.patch ... Passed
std-vector-non-const.patch ... Passed
sql-relax-constraints-on-VirtualCursor-layout.patch ... Passed
swiftshader-add-cstdint-for-uint64_t.patch ... Passed
dawn-iwyu-add-cstdint-for-uint8_t.patch ... Passed
iwyu-add-stdint.h-for-various-int-types-in-base.patch ... Passed
iwyu-add-cstdint-for-uintptr_t-in-device.patch ... Passed
iwyu-add-stdint.h-for-uint32_t-in-chrome_pdf.patch ... Passed
iwyu-add-stdint.h-for-uint64_t-in-EncounteredSurface.patch ... Passed
iwyu-add-stdint.h-for-integer-types-in-ui.patch ... Passed
openscreen-iwyu-add-stdint.h.patch ... Passed
pdfium-iwyu-add-stdint.h-for-uint32_t.patch ... Passed
iwyu-add-stdint.h-for-uint32_t-in-cc.patch ... Passed
add-missing-includes-causing-build-errors.patch ... Passed
iwyu-add-stdint.h-for-int-types-in-gpu_feature_info.patch ... Passed
iwyu-add-stdint.h-for-various-int-types-in-comp.patch ... Passed
iwyu-add-stdint.h-for-various-integer-types-in-net.patch ... Passed
iwyu-add-cstdint-for-int-types-in-s2cellid.patch ... Passed
random-fixes-for-gcc13.patch ... Passed
more-fixes-for-gcc13.patch ... Passed
libxml2-2.12.patch ... Passed
icu-74.patch ... Passed
==> Extracting sources...
-> Creating working copy of electron git repo...
Cloning into 'electron'...
done.
Switched to a new branch 'makepkg'
-> Creating working copy of depot_tools git repo...
Cloning into 'depot_tools'...
done.
==> Starting prepare()...
Linking chromium from sources...
WARNING: Your metrics.cfg file was invalid or nonexistent. A new one will be created.
________ running 'git -c core.deltaBaseCacheLimit=2g clone --no-checkout --progress file:///var/tmp/pamac-build-dnf/electron24/src/electron /var/tmp/pamac-build-dnf/electron24/src/src/_gclient_electron_8b5vm2nh' in '/var/tmp/pamac-build-dnf/electron24/src'
Cloning into '/var/tmp/pamac-build-dnf/electron24/src/src/_gclient_electron_8b5vm2nh'...
remote: Enumerating objects: 273948
remote: Enumerating objects: 290732, done.
remote: Counting objects: 0% (1/290732)
remote: Counting objects: 1% (2908/290732)
remote: Counting objects: 2% (5815/290732)
remote: Counting objects: 3% (8722/290732)
remote: Counting objects: 4% (11630/290732)
remote: Counting objects: 5% (14537/290732)
remote: Counting objects: 6% (17444/290732)
remote: Counting objects: 7% (20352/290732)
remote: Counting objects: 8% (23259/290732)
remote: Counting objects: 9% (26166/290732)
remote: Counting objects: 10% (29074/290732)
remote: Counting objects: 11% (31981/290732)
remote: Counting objects: 12% (34888/290732)
remote: Counting objects: 13% (37796/290732)
remote: Counting objects: 14% (40703/290732)
remote: Counting objects: 15% (43610/290732)
remote: Counting objects: 16% (46518/290732)
remote: Counting objects: 17% (49425/290732)
remote: Counting objects: 18% (52332/290732)
remote: Counting objects: 19% (55240/290732)
remote: Counting objects: 20% (58147/290732)
remote: Counting objects: 21% (61054/290732)
remote: Counting objects: 22% (63962/290732)
remote: Counting objects: 23% (66869/290732)
remote: Counting objects: 24% (69776/290732)
remote: Counting objects: 25% (72683/290732)
remote: Counting objects: 26% (75591/290732)
remote: Counting objects: 27% (78498/290732)
remote: Counting objects: 28% (81405/290732)
remote: Counting objects: 29% (84313/290732)
remote: Counting objects: 30% (87220/290732)
remote: Counting objects: 31% (90127/290732)
remote: Counting objects: 32% (93035/290732)
remote: Counting objects: 33% (95942/290732)
remote: Counting objects: 34% (98849/290732)
remote: Counting objects: 35% (101757/290732)
remote: Counting objects: 36% (104664/290732)
remote: Counting objects: 37% (107571/290732)
remote: Counting objects: 38% (110479/290732)
remote: Counting objects: 39% (113386/290732)
remote: Counting objects: 40% (116293/290732)
remote: Counting objects: 41% (119201/290732)
remote: Counting objects: 42% (122108/290732)
remote: Counting objects: 43% (125015/290732)
remote: Counting objects: 44% (127923/290732)
remote: Counting objects: 45% (130830/290732)
remote: Counting objects: 46% (133737/290732)
remote: Counting objects: 47% (136645/290732)
remote: Counting objects: 48% (139552/290732)
remote: Counting objects: 49% (142459/290732)
remote: Counting objects: 50% (145366/290732)
remote: Counting objects: 51% (148274/290732)
remote: Counting objects: 52% (151181/290732)
remote: Counting objects: 53% (154088/290732)
remote: Counting objects: 54% (156996/290732)
remote: Counting objects: 55% (159903/290732)
remote: Counting objects: 56% (162810/290732)
remote: Counting objects: 57% (165718/290732)
remote: Counting objects: 58% (168625/290732)
remote: Counting objects: 59% (171532/290732)
remote: Counting objects: 60% (174440/290732)
remote: Counting objects: 61% (177347/290732)
remote: Counting objects: 62% (180254/290732)
remote: Counting objects: 63% (183162/290732)
remote: Counting objects: 64% (186069/290732)
remote: Counting objects: 65% (188976/290732)
remote: Counting objects: 66% (191884/290732)
remote: Counting objects: 67% (194791/290732)
remote: Counting objects: 68% (197698/290732)
remote: Counting objects: 69% (200606/290732)
remote: Counting objects: 70% (203513/290732)
remote: Counting objects: 71% (206420/290732)
remote: Counting objects: 72% (209328/290732)
remote: Counting objects: 73% (212235/290732)
remote: Counting objects: 74% (215142/290732)
remote: Counting objects: 75% (218049/290732)
remote: Counting objects: 76% (220957/290732)
remote: Counting objects: 77% (223864/290732)
remote: Counting objects: 78% (226771/290732)
remote: Counting objects: 79% (229679/290732)
remote: Counting objects: 80% (232586/290732)
remote: Counting objects: 81% (235493/290732)
remote: Counting objects: 82% (238401/290732)
remote: Counting objects: 83% (241308/290732)
remote: Counting objects: 84% (244215/290732)
remote: Counting objects: 85% (247123/290732)
remote: Counting objects: 86% (250030/290732)
remote: Counting objects: 87% (252937/290732)
remote: Counting objects: 88% (255845/290732)
remote: Counting objects: 89% (258752/290732)
remote: Counting objects: 90% (261659/290732)
remote: Counting objects: 91% (264567/290732)
remote: Counting objects: 92% (267474/290732)
remote: Counting objects: 93% (270381/290732)
remote: Counting objects: 94% (273289/290732)
remote: Counting objects: 95% (276196/290732)
remote: Counting objects: 96% (279103/290732)
remote: Counting objects: 97% (282011/290732)
remote: Counting objects: 98% (284918/290732)
remote: Counting objects: 99% (287825/290732)
remote: Counting objects: 100% (290732/290732)
remote: Counting objects: 100% (290732/290732), done.
remote: Compressing objects: 0% (1/69204)
remote: Compressing objects: 1% (693/69204)
remote: Compressing objects: 2% (1385/69204)
remote: Compressing objects: 3% (2077/69204)
remote: Compressing objects: 4% (2769/69204)
remote: Compressing objects: 5% (3461/69204)
remote: Compressing objects: 6% (4153/69204)
remote: Compressing objects: 7% (4845/69204)
remote: Compressing objects: 8% (5537/69204)
remote: Compressing objects: 9% (6229/69204)
remote: Compressing objects: 10% (6921/69204)
remote: Compressing objects: 11% (7613/69204)
remote: Compressing objects: 12% (8305/69204)
remote: Compressing objects: 13% (8997/69204)
remote: Compressing objects: 14% (9689/69204)
remote: Compressing objects: 15% (10381/69204)
remote: Compressing objects: 16% (11073/69204)
remote: Compressing objects: 17% (11765/69204)
remote: Compressing objects: 18% (12457/69204)
remote: Compressing objects: 19% (13149/69204)
remote: Compressing objects: 20% (13841/69204)
remote: Compressing objects: 21% (14533/69204)
remote: Compressing objects: 22% (15225/69204)
remote: Compressing objects: 23% (15917/69204)
remote: Compressing objects: 24% (16609/69204)
remote: Compressing objects: 25% (17301/69204)
remote: Compressing objects: 26% (17994/69204)
remote: Compressing objects: 27% (18686/69204)
remote: Compressing objects: 28% (19378/69204)
remote: Compressing objects: 29% (20070/69204)
remote: Compressing objects: 30% (20762/69204)
remote: Compressing objects: 31% (21454/69204)
remote: Compressing objects: 32% (22146/69204)
remote: Compressing objects: 33% (22838/69204)
remote: Compressing objects: 34% (23530/69204)
remote: Compressing objects: 35% (24222/69204)
remote: Compressing objects: 36% (24914/69204)
remote: Compressing objects: 37% (25606/69204)
remote: Compressing objects: 38% (26298/69204)
remote: Compressing objects: 39% (26990/69204)
remote: Compressing objects: 40% (27682/69204)
remote: Compressing objects: 41% (28374/69204)
remote: Compressing objects: 42% (29066/69204)
remote: Compressing objects: 43% (29758/69204)
remote: Compressing objects: 44% (30450/69204)
remote: Compressing objects: 45% (31142/69204)
remote: Compressing objects: 46% (31834/69204)
remote: Compressing objects: 47% (32526/69204)
remote: Compressing objects: 48% (33218/69204)
remote: Compressing objects: 49% (33910/69204)
remote: Compressing objects: 50% (34602/69204)
remote: Compressing objects: 51% (35295/69204)
remote: Compressing objects: 52% (35987/69204)
remote: Compressing objects: 53% (36679/69204)
remote: Compressing objects: 54% (37371/69204)
remote: Compressing objects: 55% (38063/69204)
remote: Compressing objects: 56% (38755/69204)
remote: Compressing objects: 57% (39447/69204)
remote: Compressing objects: 58% (40139/69204)
remote: Compressing objects: 59% (40831/69204)
remote: Compressing objects: 60% (41523/69204)
remote: Compressing objects: 61% (42215/69204)
remote: Compressing objects: 62% (42907/69204)
remote: Compressing objects: 63% (43599/69204)
remote: Compressing objects: 64% (44291/69204)
remote: Compressing objects: 65% (44983/69204)
remote: Compressing objects: 66% (45675/69204)
remote: Compressing objects: 67% (46367/69204)
remote: Compressing objects: 68% (47059/69204)
remote: Compressing objects: 69% (47751/69204)
remote: Compressing objects: 70% (48443/69204)
remote: Compressing objects: 71% (49135/69204)
remote: Compressing objects: 72% (49827/69204)
remote: Compressing objects: 73% (50519/69204)
remote: Compressing objects: 74% (51211/69204)
remote: Compressing objects: 75% (51903/69204)
remote: Compressing objects: 76% (52596/69204)
remote: Compressing objects: 77% (53288/69204)
remote: Compressing objects: 78% (53980/69204)
remote: Compressing objects: 79% (54672/69204)
remote: Compressing objects: 80% (55364/69204)
remote: Compressing objects: 81% (56056/69204)
remote: Compressing objects: 82% (56748/69204)
remote: Compressing objects: 83% (57440/69204)
remote: Compressing objects: 84% (58132/69204)
remote: Compressing objects: 85% (58824/69204)
remote: Compressing objects: 86% (59516/69204)
remote: Compressing objects: 87% (60208/69204)
remote: Compressing objects: 88% (60900/69204)
remote: Compressing objects: 89% (61592/69204)
remote: Compressing objects: 90% (62284/69204)
remote: Compressing objects: 91% (62976/69204)
remote: Compressing objects: 92% (63668/69204)
remote: Compressing objects: 93% (64360/69204)
remote: Compressing objects: 94% (65052/69204)
remote: Compressing objects: 95% (65744/69204)
remote: Compressing objects: 96% (66436/69204)
remote: Compressing objects: 97% (67128/69204)
remote: Compressing objects: 98% (67820/69204)
remote: Compressing objects: 99% (68512/69204)
remote: Compressing objects: 100% (69204/69204)
remote: Compressing objects: 100% (69204/69204), done.
Receiving objects: 0% (1/290732)
Receiving objects: 1% (2908/290732)
Receiving objects: 2% (5815/290732)
Receiving objects: 3% (8722/290732)
Receiving objects: 4% (11630/290732)
Receiving objects: 5% (14537/290732)
Receiving objects: 6% (17444/290732)
Receiving objects: 7% (20352/290732)
Receiving objects: 8% (23259/290732)
Receiving objects: 9% (26166/290732)
Receiving objects: 10% (29074/290732)
Receiving objects: 11% (31981/290732)
Receiving objects: 12% (34888/290732)
Receiving objects: 13% (37796/290732)
Receiving objects: 14% (40703/290732)
Receiving objects: 15% (43610/290732)
Receiving objects: 16% (46518/290732)
Receiving objects: 17% (49425/290732)
Receiving objects: 18% (52332/290732)
Receiving objects: 19% (55240/290732)
Receiving objects: 20% (58147/290732)
Receiving objects: 21% (61054/290732)
Receiving objects: 22% (63962/290732)
Receiving objects: 23% (66869/290732)
Receiving objects: 24% (69776/290732), 28.89 MiB | 57.76 MiB/s
Receiving objects: 25% (72683/290732), 28.89 MiB | 57.76 MiB/s
Receiving objects: 26% (75591/290732), 28.89 MiB | 57.76 MiB/s
Receiving objects: 27% (78498/290732), 28.89 MiB | 57.76 MiB/s
Receiving objects: 28% (81405/290732), 28.89 MiB | 57.76 MiB/s
Receiving objects: 29% (84313/290732), 28.89 MiB | 57.76 MiB/s
Receiving objects: 30% (87220/290732), 28.89 MiB | 57.76 MiB/s
Receiving objects: 31% (90127/290732), 28.89 MiB | 57.76 MiB/s
Receiving objects: 32% (93035/290732), 28.89 MiB | 57.76 MiB/s
Receiving objects: 33% (95942/290732), 28.89 MiB | 57.76 MiB/s
Receiving objects: 34% (98849/290732), 28.89 MiB | 57.76 MiB/s
Receiving objects: 35% (101757/290732), 28.89 MiB | 57.76 MiB/s
Receiving objects: 36% (104664/290732), 28.89 MiB | 57.76 MiB/s
Receiving objects: 37% (107571/290732), 28.89 MiB | 57.76 MiB/s
Receiving objects: 38% (110479/290732), 28.89 MiB | 57.76 MiB/s
Receiving objects: 38% (110843/290732), 28.89 MiB | 57.76 MiB/s
Receiving objects: 39% (113386/290732), 66.03 MiB | 66.09 MiB/s
Receiving objects: 40% (116293/290732), 66.03 MiB | 66.09 MiB/s
Receiving objects: 41% (119201/290732), 66.03 MiB | 66.09 MiB/s
Receiving objects: 42% (122108/290732), 66.03 MiB | 66.09 MiB/s
Receiving objects: 43% (125015/290732), 66.03 MiB | 66.09 MiB/s
Receiving objects: 44% (127923/290732), 66.03 MiB | 66.09 MiB/s
Receiving objects: 45% (130830/290732), 66.03 MiB | 66.09 MiB/s
Receiving objects: 46% (133737/290732), 66.03 MiB | 66.09 MiB/s
Receiving objects: 47% (136645/290732), 66.03 MiB | 66.09 MiB/s
Receiving objects: 48% (139552/290732), 66.03 MiB | 66.09 MiB/s
Receiving objects: 49% (142459/290732), 66.03 MiB | 66.09 MiB/s
Receiving objects: 50% (145366/290732), 66.03 MiB | 66.09 MiB/s
Receiving objects: 51% (148274/290732), 66.03 MiB | 66.09 MiB/s
Receiving objects: 52% (151181/290732), 66.03 MiB | 66.09 MiB/s
Receiving objects: 53% (154088/290732), 66.03 MiB | 66.09 MiB/s
Receiving objects: 54% (156996/290732), 66.03 MiB | 66.09 MiB/s
Receiving objects: 55% (159903/290732), 66.03 MiB | 66.09 MiB/s
Receiving objects: 56% (162810/290732), 66.03 MiB | 66.09 MiB/s
Receiving objects: 57% (165718/290732), 66.03 MiB | 66.09 MiB/s
Receiving objects: 58% (168625/290732), 66.03 MiB | 66.09 MiB/s
Receiving objects: 59% (171532/290732), 66.03 MiB | 66.09 MiB/s
Receiving objects: 60% (174440/290732), 66.03 MiB | 66.09 MiB/s
Receiving objects: 61% (177347/290732), 66.03 MiB | 66.09 MiB/s
Receiving objects: 62% (180254/290732), 66.03 MiB | 66.09 MiB/s
Receiving objects: 63% (183162/290732), 66.03 MiB | 66.09 MiB/s
Receiving objects: 64% (186069/290732), 66.03 MiB | 66.09 MiB/s
Receiving objects: 65% (188976/290732), 104.29 MiB | 69.61 MiB/s
Receiving objects: 66% (191884/290732), 104.29 MiB | 69.61 MiB/s
Receiving objects: 67% (194791/290732), 104.29 MiB | 69.61 MiB/s
Receiving objects: 68% (197698/290732), 104.29 MiB | 69.61 MiB/s
Receiving objects: 69% (200606/290732), 104.29 MiB | 69.61 MiB/s
Receiving objects: 70% (203513/290732), 104.29 MiB | 69.61 MiB/s
Receiving objects: 71% (206420/290732), 104.29 MiB | 69.61 MiB/s
Receiving objects: 72% (209328/290732), 104.29 MiB | 69.61 MiB/s
Receiving objects: 73% (212235/290732), 104.29 MiB | 69.61 MiB/s
Receiving objects: 74% (215142/290732), 104.29 MiB | 69.61 MiB/s
Receiving objects: 75% (218049/290732), 104.29 MiB | 69.61 MiB/s
Receiving objects: 76% (220957/290732), 104.29 MiB | 69.61 MiB/s
Receiving objects: 77% (223864/290732), 104.29 MiB | 69.61 MiB/s
Receiving objects: 78% (226771/290732), 104.29 MiB | 69.61 MiB/s
Receiving objects: 79% (229679/290732), 104.29 MiB | 69.61 MiB/s
Receiving objects: 80% (232586/290732), 104.29 MiB | 69.61 MiB/s
Receiving objects: 81% (235493/290732), 104.29 MiB | 69.61 MiB/s
Receiving objects: 82% (238401/290732), 104.29 MiB | 69.61 MiB/s
Receiving objects: 83% (241308/290732), 104.29 MiB | 69.61 MiB/s
Receiving objects: 84% (244215/290732), 104.29 MiB | 69.61 MiB/s
Receiving objects: 85% (247123/290732), 104.29 MiB | 69.61 MiB/s
Receiving objects: 86% (250030/290732), 104.29 MiB | 69.61 MiB/s
Receiving objects: 87% (252937/290732), 104.29 MiB | 69.61 MiB/s
Receiving objects: 88% (255845/290732), 104.29 MiB | 69.61 MiB/s
Receiving objects: 89% (258752/290732), 104.29 MiB | 69.61 MiB/s
Receiving objects: 90% (261659/290732), 104.29 MiB | 69.61 MiB/s
Receiving objects: 91% (264567/290732), 104.29 MiB | 69.61 MiB/s
Receiving objects: 92% (267474/290732), 104.29 MiB | 69.61 MiB/s
Receiving objects: 93% (270381/290732), 104.29 MiB | 69.61 MiB/s
Receiving objects: 94% (273289/290732), 104.29 MiB | 69.61 MiB/s
Receiving objects: 95% (276196/290732), 104.29 MiB | 69.61 MiB/s
Receiving objects: 96% (279103/290732), 104.29 MiB | 69.61 MiB/s
Receiving objects: 97% (282011/290732), 104.29 MiB | 69.61 MiB/s
Receiving objects: 98% (284918/290732), 104.29 MiB | 69.61 MiB/s
Receiving objects: 99% (287825/290732), 104.29 MiB | 69.61 MiB/s
remote: Total 290732 (delta 217822), reused 290179 (delta 217325), pack-reused 0
Receiving objects: 100% (290732/290732), 104.29 MiB | 69.61 MiB/s
Receiving objects: 100% (290732/290732), 137.91 MiB | 70.82 MiB/s, done.
Resolving deltas: 0% (0/217822)
Resolving deltas: 1% (2179/217822)
Resolving deltas: 2% (4357/217822)
Resolving deltas: 3% (6535/217822)
Resolving deltas: 4% (8713/217822)
Resolving deltas: 5% (10892/217822)
Resolving deltas: 6% (13070/217822)
Resolving deltas: 7% (15248/217822)
Resolving deltas: 8% (17426/217822)
Resolving deltas: 9% (19604/217822)
Resolving deltas: 10% (21783/217822)
Resolving deltas: 11% (23961/217822)
Resolving deltas: 12% (26140/217822)
Resolving deltas: 13% (28317/217822)
Resolving deltas: 14% (30496/217822)
Resolving deltas: 15% (32674/217822)
Resolving deltas: 16% (34856/217822)
Resolving deltas: 17% (37030/217822)
Resolving deltas: 18% (39208/217822)
Resolving deltas: 19% (41387/217822)
Resolving deltas: 20% (43565/217822)
Resolving deltas: 21% (45743/217822)
Resolving deltas: 22% (47921/217822)
Resolving deltas: 23% (50101/217822)
Resolving deltas: 24% (52278/217822)
Resolving deltas: 25% (54456/217822)
Resolving deltas: 26% (56634/217822)
Resolving deltas: 27% (58812/217822)
Resolving deltas: 28% (60991/217822)
Resolving deltas: 29% (63170/217822)
Resolving deltas: 30% (65347/217822)
Resolving deltas: 31% (67525/217822)
Resolving deltas: 32% (69705/217822)
Resolving deltas: 33% (71882/217822)
Resolving deltas: 34% (74060/217822)
Resolving deltas: 35% (76239/217822)
Resolving deltas: 36% (78416/217822)
Resolving deltas: 37% (80596/217822)
Resolving deltas: 38% (82773/217822)
Resolving deltas: 39% (84951/217822)
Resolving deltas: 40% (87130/217822)
Resolving deltas: 41% (89308/217822)
Resolving deltas: 42% (91487/217822)
Resolving deltas: 43% (93664/217822)
Resolving deltas: 44% (95842/217822)
Resolving deltas: 45% (98020/217822)
Resolving deltas: 46% (100199/217822)
Resolving deltas: 47% (102379/217822)
Resolving deltas: 48% (104555/217822)
Resolving deltas: 49% (106733/217822)
Resolving deltas: 50% (108911/217822)
Resolving deltas: 51% (111091/217822)
Resolving deltas: 52% (113268/217822)
Resolving deltas: 53% (115447/217822)
Resolving deltas: 54% (117624/217822)
Resolving deltas: 55% (119803/217822)
Resolving deltas: 56% (121981/217822)
Resolving deltas: 57% (124159/217822)
Resolving deltas: 58% (126337/217822)
Resolving deltas: 59% (128515/217822)
Resolving deltas: 60% (130694/217822)
Resolving deltas: 61% (132872/217822)
Resolving deltas: 62% (135051/217822)
Resolving deltas: 63% (137230/217822)
Resolving deltas: 64% (139407/217822)
Resolving deltas: 65% (141585/217822)
Resolving deltas: 66% (143763/217822)
Resolving deltas: 67% (145941/217822)
Resolving deltas: 68% (148119/217822)
Resolving deltas: 69% (150298/217822)
Resolving deltas: 70% (152478/217822)
Resolving deltas: 71% (154654/217822)
Resolving deltas: 72% (156832/217822)
Resolving deltas: 73% (159011/217822)
Resolving deltas: 74% (161189/217822)
Resolving deltas: 75% (163367/217822)
Resolving deltas: 76% (165545/217822)
Resolving deltas: 76% (165677/217822)
Resolving deltas: 77% (167724/217822)
Resolving deltas: 78% (169902/217822)
Resolving deltas: 79% (172080/217822)
Resolving deltas: 80% (174258/217822)
Resolving deltas: 81% (176436/217822)
Resolving deltas: 82% (178615/217822)
Resolving deltas: 83% (180793/217822)
Resolving deltas: 84% (182971/217822)
Resolving deltas: 85% (185149/217822)
Resolving deltas: 86% (187327/217822)
Resolving deltas: 87% (189506/217822)
Resolving deltas: 88% (191685/217822)
Resolving deltas: 89% (193863/217822)
Resolving deltas: 90% (196040/217822)
Resolving deltas: 91% (198219/217822)
Resolving deltas: 92% (200398/217822)
Resolving deltas: 93% (202575/217822)
Resolving deltas: 94% (204753/217822)
Resolving deltas: 95% (206931/217822)
Resolving deltas: 96% (209110/217822)
Resolving deltas: 97% (211288/217822)
Resolving deltas: 98% (213466/217822)
Resolving deltas: 99% (215645/217822)
Resolving deltas: 100% (217822/217822)
Resolving deltas: 100% (217822/217822), done.
________ running 'python3 src/electron/script/patches-mtime-cache.py generate --cache-file src/electron/patches/mtime-cache.json --patches-config src/electron/patches/config.json' in '/var/tmp/pamac-build-dnf/electron24/src'
Skipping non-existent file: src/build/config/BUILDCONFIG.gn
Skipping non-existent file: src/ui/base/clipboard/clipboard_win.cc
Skipping non-existent file: src/ui/base/accelerators/accelerator.cc
Skipping non-existent file: src/ui/base/accelerators/accelerator.h
Skipping non-existent file: src/third_party/blink/renderer/core/fileapi/file.h
Skipping non-existent file: src/third_party/blink/renderer/core/fileapi/file.idl
Skipping non-existent file: src/third_party/blink/renderer/core/frame/frame.cc
Skipping non-existent file: src/third_party/blink/renderer/core/frame/local_frame.cc
Skipping non-existent file: src/content/browser/renderer_host/render_frame_host_impl.cc
Skipping non-existent file: src/content/browser/web_contents/web_contents_impl.cc
Skipping non-existent file: src/content/common/frame.mojom
Skipping non-existent file: src/content/public/browser/content_browser_client.cc
Skipping non-existent file: src/content/public/browser/content_browser_client.h
Skipping non-existent file: src/content/public/browser/web_contents_delegate.cc
Skipping non-existent file: src/content/public/browser/web_contents_delegate.h
Skipping non-existent file: src/content/renderer/render_frame_impl.cc
Skipping non-existent file: src/content/web_test/browser/web_test_content_browser_client.cc
Skipping non-existent file: src/content/web_test/browser/web_test_content_browser_client.h
Skipping non-existent file: src/third_party/blink/public/web/web_window_features.h
Skipping non-existent file: src/third_party/blink/renderer/core/frame/local_dom_window.cc
Skipping non-existent file: src/content/browser/renderer_host/render_widget_host_impl.cc
Skipping non-existent file: src/content/browser/renderer_host/render_widget_host_impl.h
Skipping non-existent file: src/content/browser/renderer_host/render_widget_host_view_aura.cc
Skipping non-existent file: src/components/services/storage/dom_storage/dom_storage_constants.cc
Skipping non-existent file: src/third_party/blink/public/mojom/dom_storage/storage_area.mojom
Skipping non-existent file: src/content/browser/renderer_host/render_widget_host_view_base.cc
Skipping non-existent file: src/content/browser/renderer_host/render_widget_host_view_base.h
Skipping non-existent file: src/content/app_shim_remote_cocoa/render_widget_host_view_cocoa.mm
Skipping non-existent file: src/content/browser/web_contents/web_contents_view_aura.cc
Skipping non-existent file: src/content/browser/web_contents/web_drag_dest_mac.mm
Skipping non-existent file: src/gin/isolate_holder.cc
Skipping non-existent file: src/gin/public/isolate_holder.h
Skipping non-existent file: src/gin/v8_initializer.cc
Skipping non-existent file: src/gin/v8_initializer.h
Skipping non-existent file: src/ui/views/widget/desktop_aura/desktop_window_tree_host_win.cc
Skipping non-existent file: src/ui/views/win/hwnd_message_handler.cc
Skipping non-existent file: src/third_party/boringssl/BUILD.gn
Skipping non-existent file: src/chrome/browser/renderer_host/pepper/pepper_isolated_file_system_message_filter.cc
Skipping non-existent file: src/chrome/browser/renderer_host/pepper/pepper_isolated_file_system_message_filter.h
Skipping non-existent file: src/chrome/renderer/pepper/chrome_renderer_pepper_host_factory.cc
Skipping non-existent file: src/chrome/renderer/pepper/pepper_helper.h
Skipping non-existent file: src/build/config/linux/gtk/BUILD.gn
Skipping non-existent file: src/ui/ozone/platform/x11/BUILD.gn
Skipping non-existent file: src/build/linux/sysroot_scripts/install-sysroot.py
Skipping non-existent file: src/chrome/BUILD.gn
Skipping non-existent file: src/content/renderer/render_thread_impl.cc
Skipping non-existent file: src/third_party/blink/renderer/core/editing/kill_ring_mac.mm
Skipping non-existent file: src/base/process/process_info_mac.cc
Skipping non-existent file: src/content/renderer/renderer_main_platform_delegate_mac.mm
Skipping non-existent file: src/content/renderer/theme_helper_mac.mm
Skipping non-existent file: src/device/bluetooth/bluetooth_adapter_mac.mm
Skipping non-existent file: src/media/audio/BUILD.gn
Skipping non-existent file: src/media/audio/mac/audio_manager_mac.cc
Skipping non-existent file: src/net/dns/dns_config_service_posix.cc
Skipping non-existent file: src/sandbox/mac/sandbox_compiler.cc
Skipping non-existent file: src/sandbox/mac/seatbelt.cc
Skipping non-existent file: src/sandbox/mac/seatbelt_extension.cc
Skipping non-existent file: src/ui/accessibility/platform/inspect/ax_transform_mac.mm
Skipping non-existent file: src/ui/display/mac/screen_mac.mm
Skipping non-existent file: src/gpu/ipc/service/image_transport_surface_overlay_mac.h
Skipping non-existent file: src/gpu/ipc/service/image_transport_surface_overlay_mac.mm
Skipping non-existent file: src/ui/accelerated_widget_mac/display_ca_layer_tree.mm
Skipping non-existent file: src/ui/base/cocoa/remote_layer_api.h
Skipping non-existent file: src/ui/base/cocoa/remote_layer_api.mm
Skipping non-existent file: src/components/remote_cocoa/app_shim/application_bridge.mm
Skipping non-existent file: src/components/remote_cocoa/app_shim/native_widget_ns_window_bridge.mm
Skipping non-existent file: src/content/app_shim_remote_cocoa/ns_view_bridge_factory_impl.mm
Skipping non-existent file: src/content/browser/accessibility/browser_accessibility_manager_mac.mm
Skipping non-existent file: src/content/browser/renderer_host/render_widget_host_view_mac.h
Skipping non-existent file: src/content/browser/renderer_host/render_widget_host_view_mac.mm
Skipping non-existent file: src/ui/base/BUILD.gn
Skipping non-existent file: src/ui/base/cocoa/remote_accessibility_api.h
Skipping non-existent file: src/ui/views/cocoa/native_widget_mac_ns_window_host.h
Skipping non-existent file: src/ui/views/cocoa/native_widget_mac_ns_window_host.mm
Skipping non-existent file: src/components/remote_cocoa/app_shim/browser_native_widget_window_mac.mm
Skipping non-existent file: src/components/remote_cocoa/app_shim/native_widget_mac_frameless_nswindow.mm
Skipping non-existent file: src/components/remote_cocoa/app_shim/native_widget_mac_nswindow.h
Skipping non-existent file: src/components/remote_cocoa/app_shim/native_widget_mac_nswindow.mm
Skipping non-existent file: src/base/enterprise_util_mac.mm
Skipping non-existent file: src/base/mac/foundation_util.mm
Skipping non-existent file: src/base/process/launch_mac.cc
Skipping non-existent file: src/media/audio/mac/audio_low_latency_input_mac.cc
Skipping non-existent file: src/sandbox/mac/sandbox_logging.cc
Skipping non-existent file: src/sandbox/mac/system_services.cc
Skipping non-existent file: src/ui/gfx/platform_font_mac.mm
Skipping non-existent file: src/content/public/renderer/render_frame_observer.h
Skipping non-existent file: src/content/renderer/render_frame_impl.h
Skipping non-existent file: src/third_party/blink/public/web/web_local_frame_client.h
Skipping non-existent file: src/third_party/blink/renderer/bindings/core/v8/local_window_proxy.cc
Skipping non-existent file: src/third_party/blink/renderer/core/frame/local_frame_client.h
Skipping non-existent file: src/third_party/blink/renderer/core/frame/local_frame_client_impl.cc
Skipping non-existent file: src/third_party/blink/renderer/core/frame/local_frame_client_impl.h
Skipping non-existent file: src/third_party/blink/renderer/core/loader/empty_clients.h
Skipping non-existent file: src/chrome/browser/media/webrtc/desktop_media_list.h
Skipping non-existent file: src/chrome/browser/media/webrtc/desktop_media_list_base.cc
Skipping non-existent file: src/chrome/browser/media/webrtc/desktop_media_list_base.h
Skipping non-existent file: src/chrome/browser/media/webrtc/fake_desktop_media_list.cc
Skipping non-existent file: src/chrome/browser/media/webrtc/fake_desktop_media_list.h
Skipping non-existent file: src/chrome/browser/media/webrtc/native_desktop_media_list.cc
Skipping non-existent file: src/chrome/browser/net/proxy_config_monitor.cc
Skipping non-existent file: src/chrome/browser/net/proxy_config_monitor.h
Skipping non-existent file: src/tools/gritsettings/resource_ids.spec
Skipping non-existent file: src/chrome/browser/notifications/platform_notification_service_impl.cc
Skipping non-existent file: src/chrome/browser/notifications/platform_notification_service_impl.h
Skipping non-existent file: src/content/browser/notifications/blink_notification_service_impl.cc
Skipping non-existent file: src/content/browser/notifications/blink_notification_service_impl.h
Skipping non-existent file: src/content/browser/notifications/blink_notification_service_impl_unittest.cc
Skipping non-existent file: src/content/browser/notifications/platform_notification_context_impl.cc
Skipping non-existent file: src/content/browser/notifications/platform_notification_context_impl.h
Skipping non-existent file: src/content/browser/renderer_host/render_process_host_impl.cc
Skipping non-existent file: src/content/public/browser/platform_notification_service.h
Skipping non-existent file: src/content/test/mock_platform_notification_service.cc
Skipping non-existent file: src/content/test/mock_platform_notification_service.h
Skipping non-existent file: src/components/crash/content/tools/generate_breakpad_symbols.py
Skipping non-existent file: src/chrome/browser/extensions/global_shortcut_listener_ozone.cc
Skipping non-existent file: src/chrome/browser/extensions/global_shortcut_listener_ozone.h
Skipping non-existent file: src/chrome/browser/extensions/global_shortcut_listener_win.cc
Skipping non-existent file: src/content/browser/media/media_keys_listener_manager_impl.cc
Skipping non-existent file: src/ui/base/accelerators/media_keys_listener.cc
Skipping non-existent file: src/ui/base/accelerators/media_keys_listener_mac.mm
Skipping non-existent file: src/ui/base/x/x11_global_shortcut_listener.cc
Skipping non-existent file: src/ui/base/x/x11_global_shortcut_listener.h
Skipping non-existent file: src/ui/ozone/platform/x11/x11_global_shortcut_listener_ozone.cc
Skipping non-existent file: src/ui/ozone/platform/x11/x11_global_shortcut_listener_ozone.h
Skipping non-existent file: src/ui/ozone/public/platform_global_shortcut_listener.h
Skipping non-existent file: src/BUILD.gn
Skipping non-existent file: src/chrome/browser/printing/print_job.cc
Skipping non-existent file: src/chrome/browser/printing/print_view_manager_base.cc
Skipping non-existent file: src/chrome/browser/printing/print_view_manager_base.h
Skipping non-existent file: src/chrome/browser/printing/printer_query.cc
Skipping non-existent file: src/chrome/browser/ui/webui/print_preview/fake_print_render_frame.cc
Skipping non-existent file: src/chrome/browser/ui/webui/print_preview/fake_print_render_frame.h
Skipping non-existent file: src/components/printing/browser/print_manager.cc
Skipping non-existent file: src/components/printing/browser/print_manager.h
Skipping non-existent file: src/components/printing/common/print.mojom
Skipping non-existent file: src/components/printing/renderer/print_render_frame_helper.cc
Skipping non-existent file: src/components/printing/renderer/print_render_frame_helper.h
Skipping non-existent file: src/content/browser/BUILD.gn
Skipping non-existent file: src/printing/printing_context.cc
Skipping non-existent file: src/printing/printing_context.h
Skipping non-existent file: src/sandbox/policy/mac/sandbox_mac.mm
Skipping non-existent file: src/content/browser/renderer_host/renderer_sandboxed_process_launcher_delegate.cc
Skipping non-existent file: src/content/browser/renderer_host/renderer_sandboxed_process_launcher_delegate.h
Skipping non-existent file: src/content/browser/ppapi_plugin_sandboxed_process_launcher_delegate.cc
Skipping non-existent file: src/base/trace_event/builtin_categories.h
Skipping non-existent file: src/content/public/renderer/content_renderer_client.h
Skipping non-existent file: src/content/renderer/renderer_blink_platform_impl.cc
Skipping non-existent file: src/content/renderer/renderer_blink_platform_impl.h
Skipping non-existent file: src/third_party/blink/public/platform/platform.h
Skipping non-existent file: src/third_party/blink/renderer/core/workers/worker_thread.cc
Skipping non-existent file: src/content/browser/renderer_host/render_frame_host_manager.cc
Skipping non-existent file: src/third_party/crashpad/crashpad/util/win/exception_handler_server.cc
Skipping non-existent file: src/services/network/network_context.cc
Skipping non-existent file: src/services/network/network_context.h
Skipping non-existent file: src/services/network/public/mojom/network_context.mojom
Skipping non-existent file: src/cc/trees/layer_tree_host_impl.cc
Skipping non-existent file: src/cc/trees/layer_tree_settings.h
Skipping non-existent file: src/components/viz/common/display/renderer_settings.h
Skipping non-existent file: src/components/viz/host/renderer_settings_creation.cc
Skipping non-existent file: src/content/browser/gpu/gpu_process_host.cc
Skipping non-existent file: src/third_party/blink/renderer/platform/graphics/canvas_color_params.cc
Skipping non-existent file: src/third_party/blink/renderer/platform/widget/compositing/layer_tree_settings.cc
Skipping non-existent file: src/ui/gfx/mac/io_surface.cc
Skipping non-existent file: src/ui/gfx/switches.cc
Skipping non-existent file: src/ui/gfx/switches.h
Skipping non-existent file: src/content/gpu/gpu_main.cc
Skipping non-existent file: src/content/public/gpu/content_gpu_client.h
Skipping non-existent file: src/chrome/browser/ui/views/overlay/video_overlay_window_views.cc
Skipping non-existent file: src/content/browser/child_process_launcher_helper_linux.cc
Skipping non-existent file: src/net/url_request/static_http_user_agent_settings.h
Skipping non-existent file: src/services/network/test/test_network_context.h
Skipping non-existent file: src/ui/native_theme/native_theme.cc
Skipping non-existent file: src/ui/native_theme/native_theme.h
Skipping non-existent file: src/ui/native_theme/native_theme_win.cc
Skipping non-existent file: src/third_party/blink/public/web/web_message_port_converter.h
Skipping non-existent file: src/third_party/blink/renderer/core/exported/web_message_port_converter.cc
Skipping non-existent file: src/build/toolchain/win/rc/rc.py
Skipping non-existent file: src/chrome/browser/profiles/profile_keyed_service_factory.cc
Skipping non-existent file: src/chrome/browser/profiles/profile_selections.cc
Skipping non-existent file: src/content/browser/renderer_host/render_view_host_impl.cc
Skipping non-existent file: src/content/browser/renderer_host/render_view_host_impl.h
Skipping non-existent file: src/content/public/browser/render_view_host.h
Skipping non-existent file: src/third_party/blink/public/mojom/page/page.mojom
Skipping non-existent file: src/third_party/blink/public/web/web_view.h
Skipping non-existent file: src/third_party/blink/renderer/core/exported/web_view_impl.cc
Skipping non-existent file: src/third_party/blink/renderer/core/exported/web_view_impl.h
Skipping non-existent file: src/chrome/browser/plugins/plugin_response_interceptor_url_loader_throttle.cc
Skipping non-existent file: src/chrome/browser/spellchecker/spellcheck_hunspell_dictionary.cc
Skipping non-existent file: src/chrome/browser/spellchecker/spellcheck_hunspell_dictionary.h
Skipping non-existent file: src/components/viz/host/host_display_client.cc
Skipping non-existent file: src/components/viz/host/host_display_client.h
Skipping non-existent file: src/components/viz/host/layered_window_updater_impl.cc
Skipping non-existent file: src/components/viz/host/layered_window_updater_impl.h
Skipping non-existent file: src/components/viz/service/BUILD.gn
Skipping non-existent file: src/components/viz/service/display_embedder/output_surface_provider.h
Skipping non-existent file: src/components/viz/service/display_embedder/output_surface_provider_impl.cc
Skipping non-existent file: src/components/viz/service/display_embedder/output_surface_provider_impl.h
Skipping non-existent file: src/components/viz/service/display_embedder/software_output_device_mac.cc
Skipping non-existent file: src/components/viz/service/display_embedder/software_output_device_mac.h
Skipping non-existent file: src/components/viz/service/display_embedder/software_output_device_proxy.cc
Skipping non-existent file: src/components/viz/service/display_embedder/software_output_device_proxy.h
Skipping non-existent file: src/components/viz/service/display_embedder/software_output_device_win.cc
Skipping non-existent file: src/components/viz/service/frame_sinks/root_compositor_frame_sink_impl.cc
Skipping non-existent file: src/content/browser/compositor/viz_process_transport_factory.cc
Skipping non-existent file: src/services/viz/privileged/mojom/compositing/display_private.mojom
Skipping non-existent file: src/services/viz/privileged/mojom/compositing/frame_sink_manager.mojom
Skipping non-existent file: src/services/viz/privileged/mojom/compositing/layered_window_updater.mojom
Skipping non-existent file: src/ui/compositor/compositor.h
Skipping non-existent file: src/ui/gfx/ca_layer_params.h
Skipping non-existent file: src/ui/gfx/mojom/ca_layer_params.mojom
Skipping non-existent file: src/ui/gfx/mojom/ca_layer_params_mojom_traits.cc
Skipping non-existent file: src/ui/gfx/mojom/ca_layer_params_mojom_traits.h
Skipping non-existent file: src/content/browser/gpu/gpu_data_manager_impl.cc
Skipping non-existent file: src/content/browser/gpu/gpu_data_manager_impl.h
Skipping non-existent file: src/content/browser/gpu/gpu_data_manager_impl_private.cc
Skipping non-existent file: src/content/browser/gpu/gpu_data_manager_impl_private.h
Skipping non-existent file: src/chrome/browser/spellchecker/spellcheck_service.cc
Skipping non-existent file: src/chrome/browser/spellchecker/spellcheck_service.h
Skipping non-existent file: src/third_party/blink/renderer/core/messaging/message_port.cc
Skipping non-existent file: src/third_party/blink/renderer/core/messaging/message_port.h
Skipping non-existent file: src/third_party/blink/renderer/core/messaging/message_port.idl
Skipping non-existent file: src/third_party/blink/common/web_preferences/web_preferences.cc
Skipping non-existent file: src/third_party/blink/common/web_preferences/web_preferences_mojom_traits.cc
Skipping non-existent file: src/third_party/blink/public/common/web_preferences/web_preferences.h
Skipping non-existent file: src/third_party/blink/public/common/web_preferences/web_preferences_mojom_traits.h
Skipping non-existent file: src/third_party/blink/public/mojom/webpreferences/web_preferences.mojom
Skipping non-existent file: src/content/browser/renderer_host/render_widget_host_delegate.h
Skipping non-existent file: src/content/browser/web_contents/web_contents_impl.h
Skipping non-existent file: src/content/public/browser/web_contents_observer.h
Skipping non-existent file: src/components/crash/core/app/crash_reporter_client.cc
Skipping non-existent file: src/components/crash/core/app/crash_reporter_client.h
Skipping non-existent file: src/components/crash/core/app/crashpad_linux.cc
Skipping non-existent file: src/components/crash/core/app/crashpad_mac.mm
Skipping non-existent file: src/components/crash/core/app/crashpad_win.cc
Skipping non-existent file: src/components/upload_list/upload_list.cc
Skipping non-existent file: src/components/upload_list/upload_list.h
Skipping non-existent file: src/ui/base/models/simple_menu_model.cc
Skipping non-existent file: src/ui/base/models/simple_menu_model.h
Skipping non-existent file: src/third_party/blink/renderer/platform/media/multi_buffer_data_source.cc
Skipping non-existent file: src/third_party/blink/renderer/platform/media/multi_buffer_data_source.h
Skipping non-existent file: src/chrome/browser/accessibility/accessibility_ui.cc
Skipping non-existent file: src/chrome/browser/accessibility/accessibility_ui.h
Skipping non-existent file: src/build/config/linux/atk/BUILD.gn
Skipping non-existent file: src/build/config/linux/atspi2/BUILD.gn
Skipping non-existent file: src/third_party/blink/renderer/bindings/core/v8/worker_or_worklet_script_controller.cc
Skipping non-existent file: src/chrome/browser/media/offscreen_tab.cc
Skipping non-existent file: src/chrome/browser/media/offscreen_tab.h
Skipping non-existent file: src/chrome/browser/ui/ash/ash_web_view_impl.cc
Skipping non-existent file: src/chrome/browser/ui/ash/ash_web_view_impl.h
Skipping non-existent file: src/chrome/browser/ui/ash/keyboard/chrome_keyboard_web_contents.cc
Skipping non-existent file: src/chrome/browser/ui/browser.cc
Skipping non-existent file: src/chrome/browser/ui/browser.h
Skipping non-existent file: src/chrome/browser/ui/media_router/presentation_receiver_window_controller.cc
Skipping non-existent file: src/chrome/browser/ui/media_router/presentation_receiver_window_controller.h
Skipping non-existent file: src/chrome/browser/ui/views/hats/hats_next_web_dialog.cc
Skipping non-existent file: src/components/embedder_support/android/delegate/web_contents_delegate_android.cc
Skipping non-existent file: src/components/embedder_support/android/delegate/web_contents_delegate_android.h
Skipping non-existent file: src/components/offline_pages/content/background_loader/background_loader_contents.cc
Skipping non-existent file: src/components/offline_pages/content/background_loader/background_loader_contents.h
Skipping non-existent file: src/extensions/browser/guest_view/extension_options/extension_options_guest.cc
Skipping non-existent file: src/extensions/browser/guest_view/extension_options/extension_options_guest.h
Skipping non-existent file: src/extensions/browser/guest_view/mime_handler_view/mime_handler_view_guest.cc
Skipping non-existent file: src/extensions/browser/guest_view/mime_handler_view/mime_handler_view_guest.h
Skipping non-existent file: src/fuchsia_web/webengine/browser/frame_impl.cc
Skipping non-existent file: src/fuchsia_web/webengine/browser/frame_impl.h
Skipping non-existent file: src/headless/lib/browser/headless_web_contents_impl.cc
Skipping non-existent file: src/ui/views/controls/webview/web_dialog_view.cc
Skipping non-existent file: src/ui/views/controls/webview/web_dialog_view.h
Skipping non-existent file: src/printing/printing_context_mac.h
Skipping non-existent file: src/printing/printing_context_mac.mm
Skipping non-existent file: src/printing/printing_context_system_dialog_win.cc
Skipping non-existent file: src/ui/gtk/printing/print_dialog_gtk.cc
Skipping non-existent file: src/gin/public/v8_platform.h
Skipping non-existent file: src/gin/v8_platform.cc
Skipping non-existent file: src/third_party/zlib/BUILD.gn
Skipping non-existent file: src/content/public/browser/web_contents.h
Skipping non-existent file: src/content/browser/renderer_host/navigator.cc
Skipping non-existent file: src/sandbox/linux/bpf_dsl/bpf_dsl.cc
Skipping non-existent file: src/buildtools/third_party/libc++/BUILD.gn
Skipping non-existent file: src/buildtools/third_party/libc++abi/BUILD.gn
Skipping non-existent file: src/chrome/browser/BUILD.gn
Skipping non-existent file: src/chrome/test/BUILD.gn
Skipping non-existent file: src/base/functional/callback_helpers.h
Skipping non-existent file: src/tools/clang/scripts/update.py
Skipping non-existent file: src/content/app/content_main.cc
Skipping non-existent file: src/chrome/browser/extensions/global_shortcut_listener.cc
Skipping non-existent file: src/chrome/browser/extensions/global_shortcut_listener.h
Skipping non-existent file: src/services/network/public/cpp/resource_request.cc
Skipping non-existent file: src/services/network/public/cpp/resource_request.h
Skipping non-existent file: src/services/network/public/cpp/url_request_mojom_traits.cc
Skipping non-existent file: src/services/network/public/cpp/url_request_mojom_traits.h
Skipping non-existent file: src/services/network/public/mojom/url_request.mojom
Skipping non-existent file: src/services/network/public/mojom/url_response_head.mojom
Skipping non-existent file: src/services/network/url_loader.cc
Skipping non-existent file: src/services/network/url_loader.h
Skipping non-existent file: src/chrome/browser/process_singleton.h
Skipping non-existent file: src/chrome/browser/process_singleton_posix.cc
Skipping non-existent file: src/chrome/browser/process_singleton_win.cc
Skipping non-existent file: src/ui/base/clipboard/scoped_clipboard_writer.cc
Skipping non-existent file: src/ui/base/clipboard/scoped_clipboard_writer.h
Skipping non-existent file: src/chrome/browser/win/chrome_process_finder.cc
Skipping non-existent file: src/chrome/browser/win/chrome_process_finder.h
Skipping non-existent file: src/content/app/content_main_runner_impl.cc
Skipping non-existent file: src/chrome/browser/ui/exclusive_access/fullscreen_controller.cc
Skipping non-existent file: src/chrome/browser/ui/exclusive_access/fullscreen_controller.h
Skipping non-existent file: src/services/device/device_service.cc
Skipping non-existent file: src/chrome/browser/resources/pdf/pdf_viewer.ts
Skipping non-existent file: src/ui/color/color_id.h
Skipping non-existent file: src/ui/color/ui_color_mixer.cc
Skipping non-existent file: src/ui/color/win/native_color_mixers_win.cc
Skipping non-existent file: src/build_overrides/partition_alloc.gni
Skipping non-existent file: src/content/browser/renderer_host/legacy_render_widget_host_win.cc
Skipping non-existent file: src/content/browser/renderer_host/legacy_render_widget_host_win.h
Skipping non-existent file: src/buildtools/third_party/libc++/__config_site
Skipping non-existent file: src/ui/ozone/platform/x11/ozone_platform_x11.cc
Skipping non-existent file: src/ui/ozone/public/ozone_platform.h
Skipping non-existent file: src/ui/gtk/gtk_compat.cc
Skipping non-existent file: src/ui/gtk/gtk_compat.h
Skipping non-existent file: src/printing/buildflags/buildflags.gni
Skipping non-existent file: src/content/browser/service_worker/service_worker_context_wrapper.cc
Skipping non-existent file: src/content/browser/media/capture/screen_capture_kit_device_mac.mm
Skipping non-existent file: src/content/renderer/render_process_impl.cc
Skipping non-existent file: src/components/webrtc/media_stream_devices_controller.cc
Skipping non-existent file: src/components/webrtc/media_stream_devices_controller.h
Skipping non-existent file: src/.gitignore
Skipping non-existent file: src/third_party/.gitignore
Skipping non-existent file: src/ui/views/widget/desktop_aura/desktop_window_tree_host_win.h
Skipping non-existent file: src/ui/views/win/hwnd_message_handler_delegate.h
Skipping non-existent file: src/ui/gtk/gtk_ui.cc
Skipping non-existent file: src/ui/gtk/gtk_ui.h
Skipping non-existent file: src/ui/gtk/window_frame_provider_gtk.cc
Skipping non-existent file: src/ui/gtk/window_frame_provider_gtk.h
Skipping non-existent file: src/ui/linux/fallback_linux_ui.cc
Skipping non-existent file: src/ui/linux/fallback_linux_ui.h
Skipping non-existent file: src/ui/linux/linux_ui.h
Skipping non-existent file: src/chrome/browser/extensions/api/language_settings_private/language_settings_private_api_unittest.cc
Skipping non-existent file: src/chrome/browser/spellchecker/spellcheck_service_unittest.cc
Skipping non-existent file: src/components/spellcheck/common/spellcheck_features.cc
Skipping non-existent file: src/tools/licenses/licenses.py
Skipping non-existent file: src/content/browser/renderer_host/navigation_request.cc
Skipping non-existent file: src/content/browser/renderer_host/render_frame_host_impl.h
Skipping non-existent file: src/extensions/renderer/script_injection.cc
Skipping non-existent file: src/third_party/blink/public/web/web_local_frame.h
Skipping non-existent file: src/third_party/blink/public/web/web_script_execution_callback.h
Skipping non-existent file: src/third_party/blink/renderer/core/frame/local_frame.h
Skipping non-existent file: src/third_party/blink/renderer/core/frame/local_frame_mojo_handler.cc
Skipping non-existent file: src/third_party/blink/renderer/core/frame/pausable_script_executor.cc
Skipping non-existent file: src/third_party/blink/renderer/core/frame/pausable_script_executor.h
Skipping non-existent file: src/third_party/blink/renderer/core/frame/web_local_frame_impl.cc
Skipping non-existent file: src/third_party/blink/renderer/core/frame/web_local_frame_impl.h
Skipping non-existent file: src/content/public/app/content_main_delegate.cc
Skipping non-existent file: src/content/public/app/content_main_delegate.h
Skipping non-existent file: src/content/browser/child_process_launcher.h
Skipping non-existent file: src/content/browser/child_process_launcher_helper_mac.cc
Skipping non-existent file: src/content/browser/child_process_launcher_helper_win.cc
Skipping non-existent file: src/content/browser/service_process_host_impl.cc
Skipping non-existent file: src/content/browser/utility_process_host.cc
Skipping non-existent file: src/content/browser/utility_process_host.h
Skipping non-existent file: src/content/browser/utility_sandbox_delegate.cc
Skipping non-existent file: src/content/browser/utility_sandbox_delegate.h
Skipping non-existent file: src/content/common/sandbox_init_win.cc
Skipping non-existent file: src/content/public/browser/service_process_host.cc
Skipping non-existent file: src/content/public/browser/service_process_host.h
Skipping non-existent file: src/content/public/common/sandbox_init_win.h
Skipping non-existent file: src/content/public/common/sandboxed_process_launcher_delegate.cc
Skipping non-existent file: src/content/public/common/sandboxed_process_launcher_delegate.h
Skipping non-existent file: src/sandbox/policy/win/sandbox_win.cc
Skipping non-existent file: src/sandbox/policy/win/sandbox_win.h
Skipping non-existent file: src/components/os_crypt/keychain_password_mac.mm
Skipping non-existent file: src/content/browser/renderer_host/render_widget_host_view_child_frame.cc
Skipping non-existent file: src/content/browser/renderer_host/render_widget_host_view_child_frame.h
Skipping non-existent file: src/chrome/browser/predictors/preconnect_manager.cc
Skipping non-existent file: src/chrome/browser/predictors/preconnect_manager.h
Skipping non-existent file: src/.gn
Skipping non-existent file: src/base/BUILD.gn
Skipping non-existent file: src/components/os_crypt/BUILD.gn
Skipping non-existent file: src/components/remote_cocoa/app_shim/BUILD.gn
Skipping non-existent file: src/content/common/BUILD.gn
Skipping non-existent file: src/content/renderer/BUILD.gn
Skipping non-existent file: src/device/bluetooth/BUILD.gn
Skipping non-existent file: src/gpu/ipc/service/BUILD.gn
Skipping non-existent file: src/net/dns/BUILD.gn
Skipping non-existent file: src/sandbox/mac/BUILD.gn
Skipping non-existent file: src/third_party/blink/renderer/core/BUILD.gn
Skipping non-existent file: src/ui/accelerated_widget_mac/BUILD.gn
Skipping non-existent file: src/ui/accessibility/platform/BUILD.gn
Skipping non-existent file: src/ui/display/BUILD.gn
Skipping non-existent file: src/ui/gfx/BUILD.gn
Skipping non-existent file: src/ui/views/BUILD.gn
Skipping non-existent file: src/ui/views/controls/webview/BUILD.gn
Skipping non-existent file: src/chrome/browser/ui/views/status_icons/status_icon_linux_dbus.cc
Skipping non-existent file: src/chrome/browser/ui/views/status_icons/status_icon_linux_dbus.h
Skipping non-existent file: src/base/threading/thread_restrictions.h
Skipping non-existent file: src/content/browser/site_instance_impl.cc
Skipping non-existent file: src/third_party/blink/renderer/bindings/core/v8/v8_initializer.cc
Skipping non-existent file: src/third_party/blink/renderer/bindings/core/v8/v8_initializer.h
Skipping non-existent file: src/ui/ozone/platform/x11/x11_window.cc
Skipping non-existent file: src/services/device/usb/usb_service_impl.cc
Skipping non-existent file: src/ui/base/x/x11_whole_screen_move_loop.cc
Skipping non-existent file: src/ui/gfx/x/window_cache.cc
Skipping non-existent file: src/ui/gfx/x/window_cache.h
Skipping non-existent file: src/ui/gfx/x/window_cache_unittest.cc
Skipping non-existent file: src/DEPS
Skipping non-existent file: src/ui/ozone/platform/wayland/host/zwp_text_input_wrapper_v1.cc
Skipping non-existent file: src/chrome/browser/apps/guest_view/web_view_browsertest.cc
Skipping non-existent file: src/chrome/test/data/extensions/platform_apps/web_view/shim/main.js
Skipping non-existent file: src/extensions/browser/guest_view/web_view/web_view_find_helper.cc
Skipping non-existent file: src/ui/gl/swap_chain_presenter.cc
Skipping non-existent file: src/mojo/core/ipcz_driver/mojo_message.cc
Skipping non-existent file: src/base/allocator/partition_allocator/shim/allocator_shim_override_linker_wrapped_symbols.h
Skipping non-existent file: src/base/allocator/partition_allocator/shim/allocator_shim_unittest.cc
Skipping non-existent file: src/chrome/test/data/extensions/platform_apps/web_view/newwindow/embedder.js
Skipping non-existent file: src/chrome/test/data/extensions/platform_apps/web_view/newwindow/guest_opener_open_on_load.html
Skipping non-existent file: src/components/guest_view/browser/guest_view_manager.cc
Skipping non-existent file: src/components/guest_view/browser/test_guest_view_manager.cc
Skipping non-existent file: src/components/guest_view/browser/test_guest_view_manager.h
Skipping non-existent file: src/media/video/av1_video_encoder.cc
Skipping non-existent file: src/media/video/software_video_encoder_test.cc
Skipping non-existent file: src/third_party/ipcz/src/BUILD.gn
Skipping non-existent file: src/third_party/ipcz/src/ipcz/block_allocator_pool.cc
Skipping non-existent file: src/third_party/ipcz/src/ipcz/buffer_pool.cc
Skipping non-existent file: src/third_party/ipcz/src/ipcz/buffer_pool_test.cc
Skipping non-existent file: src/third_party/ipcz/src/ipcz/fragment.cc
Skipping non-existent file: src/third_party/ipcz/src/ipcz/fragment.h
Skipping non-existent file: src/third_party/ipcz/src/ipcz/fragment_descriptor.h
Skipping non-existent file: src/third_party/ipcz/src/ipcz/fragment_test.cc
Skipping non-existent file: src/third_party/ipcz/src/ipcz/node_link_memory.cc
Skipping non-existent file: src/third_party/ipcz/src/ipcz/ref_counted_fragment_test.cc
Skipping non-existent file: src/third_party/blink/renderer/modules/peerconnection/rtc_data_channel.cc
Skipping non-existent file: src/third_party/blink/renderer/modules/peerconnection/rtc_data_channel.h
Skipping non-existent file: src/chrome/browser/ui/views/tabs/fake_tab_slot_controller.cc
Skipping non-existent file: src/chrome/browser/ui/views/tabs/fake_tab_slot_controller.h
Skipping non-existent file: src/chrome/browser/ui/views/tabs/tab_slot_controller.h
Skipping non-existent file: src/chrome/browser/ui/views/tabs/tab_strip.cc
Skipping non-existent file: src/chrome/browser/ui/views/tabs/tab_strip.h
Skipping non-existent file: src/content/browser/site_instance_impl.h
Skipping non-existent file: src/content/browser/site_instance_impl_unittest.cc
Skipping non-existent file: src/third_party/blink/renderer/core/css/rule_feature_set.cc
Skipping non-existent file: src/third_party/blink/web_tests/external/wpt/css/selectors/has-sibling-chrome-crash.html
Skipping non-existent file: src/third_party/blink/renderer/modules/mediastream/media_stream_device_observer.cc
Skipping non-existent file: src/third_party/blink/renderer/modules/mediastream/media_stream_device_observer.h
Skipping non-existent file: src/third_party/blink/renderer/platform/exported/mediastream/web_platform_media_stream_source.cc
Skipping non-existent file: src/third_party/blink/renderer/platform/network/network_state_notifier.cc
Skipping non-existent file: src/content/browser/webid/federated_auth_request_impl.cc
Skipping non-existent file: src/content/browser/media/capture/desktop_capture_device.cc
Skipping non-existent file: src/pdf/pdf_view_web_plugin.cc
Skipping non-existent file: src/third_party/angle/src/libANGLE/renderer/gl/cgl/WindowSurfaceCGL.h
Skipping non-existent file: src/third_party/angle/src/libANGLE/renderer/gl/cgl/WindowSurfaceCGL.mm
Skipping non-existent file: src/third_party/angle/src/libANGLE/formatutils.cpp
Skipping non-existent file: src/third_party/angle/src/libANGLE/renderer/vulkan/BufferVk.cpp
Skipping non-existent file: src/third_party/angle/src/libANGLE/renderer/vulkan/Suballocation.h
Skipping non-existent file: src/third_party/angle/src/libANGLE/renderer/vulkan/TextureVk.cpp
Skipping non-existent file: src/third_party/angle/src/libANGLE/renderer/vulkan/vk_cache_utils.cpp
Skipping non-existent file: src/third_party/angle/src/libANGLE/renderer/vulkan/vk_cache_utils.h
Skipping non-existent file: src/third_party/angle/src/libANGLE/renderer/vulkan/vk_helpers.cpp
Skipping non-existent file: src/third_party/angle/src/libANGLE/renderer/vulkan/vk_helpers.h
Skipping non-existent file: src/third_party/angle/src/tests/gl_tests/TransformFeedbackTest.cpp
Skipping non-existent file: src/third_party/angle/src/tests/gl_tests/UniformBufferTest.cpp
Skipping non-existent file: src/third_party/boringssl/src/crypto/digest_extra/digest_extra.c
Skipping non-existent file: src/third_party/boringssl/src/crypto/fipsmodule/digest/digests.c
Skipping non-existent file: src/third_party/boringssl/src/decrepit/evp/evp_do_all.c
Skipping non-existent file: src/third_party/boringssl/src/include/openssl/digest.h
Skipping non-existent file: src/third_party/boringssl/src/ssl/ssl_buffer.cc
Skipping non-existent file: src/third_party/boringssl/src/ssl/ssl_lib.cc
Skipping non-existent file: src/third_party/boringssl/src/ssl/ssl_test.cc
Skipping non-existent file: src/third_party/boringssl/src/crypto/cipher_extra/cipher_extra.c
Skipping non-existent file: src/third_party/boringssl/src/include/openssl/cipher.h
Skipping non-existent file: src/third_party/devtools-frontend/src/front_end/entrypoints/shell/BUILD.gn
Skipping non-existent file: src/third_party/devtools-frontend/src/front_end/entrypoints/shell/shell.ts
Skipping non-existent file: src/third_party/devtools-frontend/src/front_end/ui/legacy/BUILD.gn
Skipping non-existent file: src/third_party/ffmpeg/BUILD.gn
Skipping non-existent file: src/v8/BUILD.gn
Skipping non-existent file: src/v8/src/api/api.cc
Skipping non-existent file: src/v8/src/objects/objects.h
Skipping non-existent file: src/v8/src/objects/ordered-hash-table.h
Skipping non-existent file: src/v8/src/codegen/arm64/assembler-arm64.cc
Skipping non-existent file: src/v8/src/codegen/arm64/assembler-arm64.h
Skipping non-existent file: src/v8/src/base/macros.h
Skipping non-existent file: src/v8/include/v8config.h
Skipping non-existent file: src/v8/src/objects/js-array-buffer.cc
Skipping non-existent file: src/v8/include/v8-cppgc.h
Skipping non-existent file: src/v8/include/v8-microtask-queue.h
Skipping non-existent file: src/v8/src/execution/microtask-queue.h
Skipping non-existent file: src/v8/AUTHORS
Skipping non-existent file: src/v8/BUILD.bazel
Skipping non-existent file: src/v8/src/base/platform/platform-aix.cc
Skipping non-existent file: src/v8/src/base/platform/platform-darwin.cc
Skipping non-existent file: src/v8/src/base/platform/platform-freebsd.cc
Skipping non-existent file: src/v8/src/base/platform/platform-posix.cc
Skipping non-existent file: src/v8/src/base/platform/platform-solaris.cc
Skipping non-existent file: src/v8/src/base/platform/platform-win32.cc
Skipping non-existent file: src/v8/src/base/platform/platform.cc
Skipping non-existent file: src/v8/src/base/platform/platform.h
Skipping non-existent file: src/v8/src/ic/ic.cc
Skipping non-existent file: src/v8/src/objects/js-objects.cc
Skipping non-existent file: src/v8/src/objects/js-objects.h
Skipping non-existent file: src/v8/src/objects/lookup-inl.h
Skipping non-existent file: src/v8/src/objects/lookup.h
Skipping non-existent file: src/v8/src/objects/objects.cc
Skipping non-existent file: src/v8/test/unittests/api/interceptor-unittest.cc
Skipping non-existent file: src/v8/src/objects/lookup.cc
Skipping non-existent file: src/v8/test/mjsunit/regress/regress-crbug-1447430.js
Skipping non-existent file: src/v8/src/diagnostics/objects-printer.cc
Skipping non-existent file: src/v8/src/ic/handler-configuration.cc
Skipping non-existent file: src/v8/src/objects/map-inl.h
Skipping non-existent file: src/v8/src/objects/map.h
Skipping non-existent file: src/v8/src/strings/string-builder.cc
Skipping non-existent file: src/v8/src/objects/js-function.cc
Skipping non-existent file: src/v8/src/compiler/js-operator.cc
Skipping non-existent file: src/v8/src/builtins/promise-all-element-closure.tq
Skipping non-existent file: src/v8/src/builtins/promise-all.tq
Skipping non-existent file: src/v8/src/builtins/promise-any.tq
Skipping non-existent file: src/v8/src/compiler/access-info.cc
Skipping non-existent file: src/v8/src/objects/map-updater.cc
Skipping non-existent file: src/v8/src/compiler/js-native-context-specialization.cc
Skipping non-existent file: src/third_party/electron_node/lib/child_process.js
Skipping non-existent file: src/third_party/electron_node/lib/internal/process/pre_execution.js
Skipping non-existent file: src/third_party/electron_node/src/node_binding.cc
Skipping non-existent file: src/third_party/electron_node/src/node_binding.h
Skipping non-existent file: src/third_party/electron_node/BUILD.gn
Skipping non-existent file: src/third_party/electron_node/deps/base64/BUILD.gn
Skipping non-existent file: src/third_party/electron_node/deps/cares/BUILD.gn
Skipping non-existent file: src/third_party/electron_node/deps/googletest/BUILD.gn
Skipping non-existent file: src/third_party/electron_node/deps/histogram/BUILD.gn
Skipping non-existent file: src/third_party/electron_node/deps/llhttp/BUILD.gn
Skipping non-existent file: src/third_party/electron_node/deps/nghttp2/BUILD.gn
Skipping non-existent file: src/third_party/electron_node/deps/simdutf/BUILD.gn
Skipping non-existent file: src/third_party/electron_node/deps/uv/BUILD.gn
Skipping non-existent file: src/third_party/electron_node/deps/uvwasi/BUILD.gn
Skipping non-existent file: src/third_party/electron_node/filenames.json
Skipping non-existent file: src/third_party/electron_node/node.gni
Skipping non-existent file: src/third_party/electron_node/src/inspector/BUILD.gn
Skipping non-existent file: src/third_party/electron_node/src/node_version.h
Skipping non-existent file: src/third_party/electron_node/tools/generate_gn_filenames_json.py
Skipping non-existent file: src/third_party/electron_node/tools/generate_node_version_header.py
Skipping non-existent file: src/third_party/electron_node/tools/install.py
Skipping non-existent file: src/third_party/electron_node/tools/js2c.py
Skipping non-existent file: src/third_party/electron_node/tools/tar.py
Skipping non-existent file: src/third_party/electron_node/common.gypi
Skipping non-existent file: src/third_party/electron_node/src/api/environment.cc
Skipping non-existent file: src/third_party/electron_node/src/node.h
Skipping non-existent file: src/third_party/electron_node/lib/internal/modules/cjs/loader.js
Skipping non-existent file: src/third_party/electron_node/lib/internal/fs/watchers.js
Skipping non-existent file: src/third_party/electron_node/src/node_builtins.cc
Skipping non-existent file: src/third_party/electron_node/src/node_builtins.h
Skipping non-existent file: src/third_party/electron_node/lib/internal/bootstrap/node.js
Skipping non-existent file: src/third_party/electron_node/lib/internal/modules/package_json_reader.js
Skipping non-existent file: src/third_party/electron_node/src/crypto/crypto_cipher.cc
Skipping non-existent file: src/third_party/electron_node/src/crypto/crypto_common.cc
Skipping non-existent file: src/third_party/electron_node/src/crypto/crypto_dh.cc
Skipping non-existent file: src/third_party/electron_node/src/crypto/crypto_dsa.cc
Skipping non-existent file: src/third_party/electron_node/src/crypto/crypto_random.cc
Skipping non-existent file: src/third_party/electron_node/src/crypto/crypto_rsa.cc
Skipping non-existent file: src/third_party/electron_node/src/crypto/crypto_util.cc
Skipping non-existent file: src/third_party/electron_node/src/crypto/crypto_util.h
Skipping non-existent file: src/third_party/electron_node/src/node_metadata.cc
Skipping non-existent file: src/third_party/electron_node/src/node_metadata.h
Skipping non-existent file: src/third_party/electron_node/src/node_options.cc
Skipping non-existent file: src/third_party/electron_node/src/node_options.h
Skipping non-existent file: src/third_party/electron_node/test/parallel/test-crypto-async-sign-verify.js
Skipping non-existent file: src/third_party/electron_node/test/parallel/test-crypto-authenticated.js
Skipping non-existent file: src/third_party/electron_node/test/parallel/test-crypto-binary-default.js
Skipping non-existent file: src/third_party/electron_node/test/parallel/test-crypto-certificate.js
Skipping non-existent file: src/third_party/electron_node/test/parallel/test-crypto-cipher-decipher.js
Skipping non-existent file: src/third_party/electron_node/test/parallel/test-crypto-cipheriv-decipheriv.js
Skipping non-existent file: src/third_party/electron_node/test/parallel/test-crypto-classes.js
Skipping non-existent file: src/third_party/electron_node/test/parallel/test-crypto-dh.js
Skipping non-existent file: src/third_party/electron_node/test/parallel/test-crypto-getcipherinfo.js
Skipping non-existent file: src/third_party/electron_node/test/parallel/test-crypto-hash-stream-pipe.js
Skipping non-existent file: src/third_party/electron_node/test/parallel/test-crypto-hash.js
Skipping non-existent file: src/third_party/electron_node/test/parallel/test-crypto-hkdf.js
Skipping non-existent file: src/third_party/electron_node/test/parallel/test-crypto-padding.js
Skipping non-existent file: src/third_party/electron_node/test/parallel/test-crypto-private-decrypt-gh32240.js
Skipping non-existent file: src/third_party/electron_node/test/parallel/test-crypto-rsa-dsa.js
Skipping non-existent file: src/third_party/electron_node/test/parallel/test-crypto-sign-verify.js
Skipping non-existent file: src/third_party/electron_node/test/parallel/test-crypto-stream.js
Skipping non-existent file: src/third_party/electron_node/test/parallel/test-crypto-x509.js
Skipping non-existent file: src/third_party/electron_node/test/parallel/test-crypto.js
Skipping non-existent file: src/third_party/electron_node/test/parallel/test-https-agent-additional-options.js
Skipping non-existent file: src/third_party/electron_node/test/parallel/test-https-agent-session-eviction.js
Skipping non-existent file: src/third_party/electron_node/test/parallel/test-tls-getcertificate-x509.js
Skipping non-existent file: src/third_party/electron_node/test/parallel/test-tls-getprotocol.js
Skipping non-existent file: src/third_party/electron_node/test/parallel/test-tls-write-error.js
Skipping non-existent file: src/third_party/electron_node/test/parallel/test-webcrypto-derivebits.js
Skipping non-existent file: src/third_party/electron_node/test/parallel/test-webcrypto-derivekey.js
Skipping non-existent file: src/third_party/electron_node/test/parallel/test-webcrypto-sign-verify.js
Skipping non-existent file: src/third_party/electron_node/test/parallel/test-webcrypto-wrap-unwrap.js
Skipping non-existent file: src/third_party/electron_node/test/parallel/test-x509-escaping.js
Skipping non-existent file: src/third_party/electron_node/test/parallel/test-debugger-address.mjs
Skipping non-existent file: src/third_party/electron_node/test/sequential/test-debugger-pid.js
Skipping non-existent file: src/third_party/electron_node/benchmark/worker/atomics-wait.js
Skipping non-existent file: src/third_party/electron_node/lib/internal/main/worker_thread.js
Skipping non-existent file: src/third_party/electron_node/lib/internal/worker.js
Skipping non-existent file: src/third_party/electron_node/deps/histogram/src/hdr_atomic.h
Skipping non-existent file: src/third_party/electron_node/deps/uv/src/win/util.c
Skipping non-existent file: src/third_party/electron_node/test/parallel/test-v8-serdes.js
Skipping non-existent file: src/third_party/electron_node/src/env-inl.h
Skipping non-existent file: src/third_party/electron_node/src/env.h
Skipping non-existent file: src/third_party/electron_node/src/inspector_agent.cc
Skipping non-existent file: src/third_party/electron_node/deps/uv/docs/src/loop.rst
Skipping non-existent file: src/third_party/electron_node/deps/uv/include/uv.h
Skipping non-existent file: src/third_party/electron_node/deps/uv/src/unix/async.c
Skipping non-existent file: src/third_party/electron_node/deps/uv/src/unix/core.c
Skipping non-existent file: src/third_party/electron_node/deps/uv/src/unix/loop.c
Skipping non-existent file: src/third_party/electron_node/deps/uv/src/uv-common.h
Skipping non-existent file: src/third_party/electron_node/deps/uv/src/win/core.c
Skipping non-existent file: src/third_party/electron_node/deps/uv/test/test-embed.c
Skipping non-existent file: src/third_party/electron_node/deps/uv/test/test-list.h
Skipping non-existent file: src/third_party/electron_node/test/es-module/test-esm-data-urls.js
Skipping non-existent file: src/third_party/electron_node/test/es-module/test-esm-invalid-pjson.js
Skipping non-existent file: src/third_party/electron_node/src/node_i18n.cc
Skipping non-existent file: src/third_party/electron_node/src/node_internals.h
Skipping non-existent file: src/third_party/electron_node/src/node_serdes.cc
Skipping non-existent file: src/third_party/electron_node/test/parallel/test-v8-serialize-leak.js
Skipping non-existent file: src/third_party/electron_node/configure.py
Skipping non-existent file: src/third_party/electron_node/src/node_platform.cc
Skipping non-existent file: src/third_party/electron_node/src/node_platform.h
Skipping non-existent file: src/third_party/electron_node/src/node_options-inl.h
Skipping non-existent file: src/third_party/electron_node/test/parallel/test-v8-stats.js
Skipping non-existent file: src/third_party/electron_node/lib/internal/modules/esm/get_format.js
Skipping non-existent file: src/third_party/electron_node/lib/internal/modules/esm/resolve.js
Skipping non-existent file: src/third_party/electron_node/lib/internal/modules/esm/translators.js
Skipping non-existent file: src/third_party/electron_node/lib/internal/url.js
Skipping non-existent file: src/third_party/electron_node/src/node_errors.cc
Skipping non-existent file: src/third_party/electron_node/src/node_errors.h
Skipping non-existent file: src/third_party/electron_node/src/histogram.cc
Skipping non-existent file: src/third_party/electron_node/src/node_messaging.cc
Skipping non-existent file: src/third_party/electron_node/src/env.cc
Skipping non-existent file: src/third_party/electron_node/src/node.cc
Skipping non-existent file: src/third_party/electron_node/test/sequential/sequential.status
Skipping non-existent file: src/third_party/electron_node/lib/internal/bootstrap/browser.js
Skipping non-existent file: src/third_party/electron_node/test/parallel/test-intl.js
Skipping non-existent file: src/third_party/electron_node/lib/internal/modules/run_main.js
Skipping non-existent file: src/third_party/electron_node/lib/assert.js
Skipping non-existent file: src/third_party/nan/test/cpp/news.cpp
Skipping non-existent file: src/third_party/nan/nan.h
Skipping non-existent file: src/third_party/nan/nan_callbacks.h
Skipping non-existent file: src/third_party/perfetto/include/perfetto/ext/base/sys_types.h
Skipping non-existent file: src/third_party/squirrel.mac/.gitignore
Skipping non-existent file: src/third_party/squirrel.mac/BUILD.gn
Skipping non-existent file: src/third_party/squirrel.mac/Squirrel/RACSignal+SQRLTransactionExtensions.h
Skipping non-existent file: src/third_party/squirrel.mac/Squirrel/RACSignal+SQRLTransactionExtensions.m
Skipping non-existent file: src/third_party/squirrel.mac/Squirrel/SQRLCodeSignature.m
Skipping non-existent file: src/third_party/squirrel.mac/Squirrel/SQRLDirectoryManager.m
Skipping non-existent file: src/third_party/squirrel.mac/Squirrel/SQRLDownloadedUpdate.m
Skipping non-existent file: src/third_party/squirrel.mac/Squirrel/SQRLInstaller.m
Skipping non-existent file: src/third_party/squirrel.mac/Squirrel/SQRLShipItLauncher.m
Skipping non-existent file: src/third_party/squirrel.mac/Squirrel/SQRLShipItRequest.m
Skipping non-existent file: src/third_party/squirrel.mac/Squirrel/SQRLTerminationListener.m
Skipping non-existent file: src/third_party/squirrel.mac/Squirrel/SQRLUpdate.m
Skipping non-existent file: src/third_party/squirrel.mac/Squirrel/SQRLUpdater.h
Skipping non-existent file: src/third_party/squirrel.mac/Squirrel/SQRLUpdater.m
Skipping non-existent file: src/third_party/squirrel.mac/Squirrel/SQRLZipArchiver.m
Skipping non-existent file: src/third_party/squirrel.mac/Squirrel/ShipIt-main.m
Skipping non-existent file: src/third_party/squirrel.mac/build/xcrun.gni
Skipping non-existent file: src/third_party/squirrel.mac/build/xcrun.py
Skipping non-existent file: src/third_party/squirrel.mac/filenames.gni
Skipping non-existent file: src/third_party/squirrel.mac/Squirrel/SQRLInstaller.h
Skipping non-existent file: src/third_party/squirrel.mac/vendor/Mantle/Mantle/Mantle.h
Skipping non-existent file: src/third_party/squirrel.mac/vendor/ReactiveObjC/ReactiveObjC/NSControl+RACTextSignalSupport.m
Skipping non-existent file: src/third_party/squirrel.mac/vendor/ReactiveObjC/ReactiveObjC/NSNotificationCenter+RACSupport.m
Skipping non-existent file: src/third_party/squirrel.mac/vendor/ReactiveObjC/ReactiveObjC/NSObject+RACAppKitBindings.m
Skipping non-existent file: src/third_party/squirrel.mac/vendor/ReactiveObjC/ReactiveObjC/NSObject+RACKVOWrapper.m
Skipping non-existent file: src/third_party/squirrel.mac/vendor/ReactiveObjC/ReactiveObjC/NSObject+RACLifting.m
Skipping non-existent file: src/third_party/squirrel.mac/vendor/ReactiveObjC/ReactiveObjC/NSObject+RACPropertySubscribing.h
Skipping non-existent file: src/third_party/squirrel.mac/vendor/ReactiveObjC/ReactiveObjC/NSObject+RACPropertySubscribing.m
Skipping non-existent file: src/third_party/squirrel.mac/vendor/ReactiveObjC/ReactiveObjC/NSObject+RACSelectorSignal.m
Skipping non-existent file: src/third_party/squirrel.mac/vendor/ReactiveObjC/ReactiveObjC/NSText+RACSignalSupport.m
Skipping non-existent file: src/third_party/squirrel.mac/vendor/ReactiveObjC/ReactiveObjC/NSUserDefaults+RACSupport.m
Skipping non-existent file: src/third_party/squirrel.mac/vendor/ReactiveObjC/ReactiveObjC/RACCommand.m
Skipping non-existent file: src/third_party/squirrel.mac/vendor/ReactiveObjC/ReactiveObjC/RACDynamicSignal.m
Skipping non-existent file: src/third_party/squirrel.mac/vendor/ReactiveObjC/ReactiveObjC/RACKVOChannel.h
Skipping non-existent file: src/third_party/squirrel.mac/vendor/ReactiveObjC/ReactiveObjC/RACKVOChannel.m
Skipping non-existent file: src/third_party/squirrel.mac/vendor/ReactiveObjC/ReactiveObjC/RACSubject.m
Skipping non-existent file: src/third_party/squirrel.mac/vendor/ReactiveObjC/ReactiveObjC/RACSubscriber.m
Skipping non-existent file: src/third_party/squirrel.mac/vendor/ReactiveObjC/ReactiveObjC/RACSubscriptingAssignmentTrampoline.h
Skipping non-existent file: src/third_party/squirrel.mac/vendor/ReactiveObjC/ReactiveObjC/RACTestScheduler.m
Skipping non-existent file: src/third_party/squirrel.mac/vendor/ReactiveObjC/ReactiveObjC/RACTuple.m
Skipping non-existent file: src/third_party/squirrel.mac/vendor/ReactiveObjC/ReactiveObjC/RACUnarySequence.m
Skipping non-existent file: src/third_party/squirrel.mac/vendor/ReactiveObjC/ReactiveObjC/UIBarButtonItem+RACCommandSupport.m
Skipping non-existent file: src/third_party/squirrel.mac/vendor/ReactiveObjC/ReactiveObjC/UIButton+RACCommandSupport.m
Skipping non-existent file: src/third_party/squirrel.mac/vendor/ReactiveObjC/ReactiveObjC/UIControl+RACSignalSupport.m
Skipping non-existent file: src/third_party/squirrel.mac/vendor/ReactiveObjC/ReactiveObjC/UIDatePicker+RACSignalSupport.m
Skipping non-existent file: src/third_party/squirrel.mac/vendor/ReactiveObjC/ReactiveObjC/UIGestureRecognizer+RACSignalSupport.m
Skipping non-existent file: src/third_party/squirrel.mac/vendor/ReactiveObjC/ReactiveObjC/UIRefreshControl+RACCommandSupport.m
Skipping non-existent file: src/third_party/squirrel.mac/vendor/ReactiveObjC/ReactiveObjC/UISegmentedControl+RACSignalSupport.m
Skipping non-existent file: src/third_party/squirrel.mac/vendor/ReactiveObjC/ReactiveObjC/UISlider+RACSignalSupport.m
Skipping non-existent file: src/third_party/squirrel.mac/vendor/ReactiveObjC/ReactiveObjC/UIStepper+RACSignalSupport.m
Skipping non-existent file: src/third_party/squirrel.mac/vendor/ReactiveObjC/ReactiveObjC/UISwitch+RACSignalSupport.m
Skipping non-existent file: src/third_party/squirrel.mac/vendor/ReactiveObjC/ReactiveObjC/UITextField+RACSignalSupport.m
Skipping non-existent file: src/third_party/squirrel.mac/vendor/ReactiveObjC/ReactiveObjC/UITextView+RACSignalSupport.m
Skipping non-existent file: src/third_party/squirrel.mac/vendor/ReactiveObjC/ReactiveObjC/RACQueueScheduler.m
Skipping non-existent file: src/third_party/webrtc/modules/desktop_capture/screen_capturer_linux.cc
Skipping non-existent file: src/third_party/webrtc/modules/desktop_capture/window_capturer_linux.cc
Skipping non-existent file: src/third_party/webrtc/pc/peer_connection.cc
Skipping non-existent file: src/third_party/webrtc/pc/peer_connection.h
Skipping non-existent file: src/third_party/webrtc/pc/peer_connection_integrationtest.cc
Skipping non-existent file: src/third_party/webrtc/pc/webrtc_sdp.cc
Skipping non-existent file: src/third_party/webrtc/pc/webrtc_sdp_unittest.cc
Skipping non-existent file: src/third_party/webrtc/modules/desktop_capture/linux/wayland/shared_screencast_stream.cc
Skipping non-existent file: src/third_party/webrtc/modules/desktop_capture/desktop_capture_types.h
Skipping non-existent file: src/third_party/webrtc/modules/desktop_capture/desktop_capturer.cc
Skipping non-existent file: src/third_party/webrtc/modules/desktop_capture/desktop_capturer.h
Skipping non-existent file: src/third_party/webrtc/modules/desktop_capture/linux/wayland/screencast_portal.cc
Skipping non-existent file: src/third_party/pdfium/fpdfsdk/pwl/cpwl_combo_box.cpp
Skipping non-existent file: src/third_party/pdfium/testing/resources/javascript/bug_1445426.evt
Skipping non-existent file: src/third_party/pdfium/testing/resources/javascript/bug_1445426.in
Skipping non-existent file: src/third_party/pdfium/fpdfsdk/formfiller/cffl_listbox.cpp
Skipping non-existent file: src/third_party/pdfium/fpdfsdk/pwl/cpwl_combo_box.h
Skipping non-existent file: src/third_party/pdfium/testing/resources/javascript/xfa_specific/bug_1444238.evt
Skipping non-existent file: src/third_party/pdfium/testing/resources/javascript/xfa_specific/bug_1444238.in
Skipping non-existent file: src/third_party/skia/relnotes/path_715M.md
Skipping non-existent file: src/third_party/skia/src/core/SkPath.cpp
Skipping non-existent file: src/third_party/libwebp/src/src/dec/vp8l_dec.c
Skipping non-existent file: src/third_party/libwebp/src/src/dec/vp8li_dec.h
Skipping non-existent file: src/third_party/libwebp/src/src/utils/huffman_utils.c
Skipping non-existent file: src/third_party/libwebp/src/src/utils/huffman_utils.h
Skipping non-existent file: src/third_party/libvpx/source/libvpx/vp8/encoder/onyx_if.c
[0:01:40] Still working on:
[0:01:40] src/third_party/electron_node
[0:01:50] Still working on:
[0:01:50] src/third_party/electron_node
[0:02:00] Still working on:
[0:02:00] src/third_party/electron_node
[0:02:10] Still working on:
[0:02:10] src/third_party/electron_node
[0:02:20] Still working on:
[0:02:20] src/third_party/electron_node
[0:02:23] Still working on:
[0:02:23] src/third_party/electron_node
patching file patches/chromium/feat_add_data_parameter_to_processsingleton.patch
patching file shell/browser/api/electron_api_app.cc
Hunk #1 succeeded at 512 (offset -11 lines).
Hunk #2 succeeded at 1091 (offset -11 lines).
patching file shell/browser/api/electron_api_app.h
Running hooks...
/var/tmp/pamac-build-dnf/electron24/PKGBUILD: line 187: src/build/landmines.py: No such file or directory
==> ERROR: A failure occurred in prepare().
Aborting...
is there something wrong with the build script or something else?
