Trouble with starting Apps
Hello,
I’m having trouble launching some apps in Manjaro. If I want to start the app (e.g. Add/Remove Software, Disk, System Monitor, Terminal), the app opens immediately but in the “Dash to Dock” the app only appears after about 30 seconds. They also take longer to appear in the overview of “Switch Application” (Super + Tab) but they are immediately visible in the overview of “Activities” (Super).
I also created a virtual machine with Manjaro to check if the same problems occur there but the problem is not on the VM.
When starting other apps, such as Nautilus or Firefox, I don’t have such problems.
Does anyone else have the same problems as me?
kind regards.
I also tried different kernel versions but it didn’t help.
Welcome to the forum :partying_face:
The lack of response leads me to believe you are experiencing this alone at the time. Could you give some more info and post system information, see link below, and check if you are fully up to date.
Thanks for the nice welcome. :slightly_smiling_face: :+1:
I’m a beginner in the Manjaro/Gnome world so please be patient with me. :relieved:
I hope the following information is sufficient for the start.
Thank you for trying to help me.
  Kernel: 6.1.19-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    root=UUID=75854fed-81cf-489e-8f29-df1898ae34ac rw apparmor=1
  Desktop: GNOME v: 43.3 tk: GTK v: 3.24.36 wm: gnome-shell dm: GDM v: 43.0
  Type: Desktop System: Gigabyte product: B560M AORUS PRO AX v: -CF
    serial: <superuser required>
  Mobo: Gigabyte model: B560M AORUS PRO AX serial: <superuser required>
    UEFI: American Megatrends LLC. v: F11b date: 05/24/2022
  RAM: total: 15.42 GiB used: 6.55 GiB (42.5%)
  Info: model: 11th Gen Intel Core i5-11400 bits: 64 type: MT MCP
    arch: Rocket Lake gen: core 11 level: v4 note: check built: 2021+
    process: Intel 14nm family: 6 model-id: 0xA7 (167) stepping: 1
    microcode: 0x56
    L1: 480 KiB desc: d-6x48 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 12 MiB
    desc: 1x12 MiB
  Speed (MHz): avg: 1250 high: 2600 min/max: 800/4400 scaling:
    driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 800
    5: 2600 6: 2600 7: 801 8: 800 9: 2600 10: 800 11: 800 12: 800
    bogomips: 62232
    arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f avx512ifma
    avx512vbmi avx512vl bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
    cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est
    f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp
    hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida
    intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
    movbe mpx msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq
    pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed
    rdtscp rep_good sdbg sep sha_ni smap smep ss ssbd sse sse2 sse4_1 sse4_2
    ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
    tsc_known_freq umip vaes vme vmx vnmi vpclmulqdq vpid x2apic xgetbv1 xsave
    xsavec xsaveopt xsaves xtopology xtpr
  Type: retbleed mitigation: Enhanced IBRS
  Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
    filling, PBRSB-eIBRS: SW sequence
  Device-1: Intel RocketLake-S GT1 [UHD Graphics 730] vendor: Gigabyte
    driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
    ports: active: HDMI-A-2 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0
    chip-ID: 8086:4c8b class-ID: 0300
  Display: wayland server: X.org v: 1.21.1.7 with: Xwayland v: 22.1.8
    compositor: gnome-shell driver: X: loaded: vesa gpu: i915 display-ID: 0
  Monitor-1: HDMI-A-2 model: Samsung serial: <filter> built: 2010
    res: 1920x1080 dpi: 48 gamma: 1.2 size: 160x90mm (6.3x3.54")
    diag: 1168mm (46") ratio: 16:9 modes: max: 1920x1080 min: 720x400
  API: OpenGL v: 4.6 Mesa 22.3.5 renderer: Mesa Intel Graphics (RKL GT1)
    direct-render: Yes
  Device-1: Intel Tiger Lake-H HD Audio vendor: Gigabyte driver: snd_hda_intel
    v: kernel alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:43c8
    class-ID: 0403
  Sound API: ALSA v: k6.1.19-1-MANJARO running: yes
  Sound Server-1: JACK v: 1.9.22 running: no
  Sound Server-3: PipeWire v: 0.3.65 running: yes
  Device-1: Intel Ethernet I225-V vendor: Gigabyte driver: igc v: kernel pcie:
    gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 03:00.0 chip-ID: 8086:15f3
    class-ID: 0200
  Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
  IF: wlp4s0 state: down mac: <filter>
  Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-14:7
  Device-1: Storage maj-min: 254:0 type: LUKS dm: dm-0 size: 465.76 GiB
  Components:
  p-1: sda1 maj-min: 8:1 size: 465.76 GiB
  Local Storage: total: 937.12 GiB used: 285.37 GiB (30.5%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 250GB
    size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 type: SSD serial: <filter> rev: 2B2QGXA7 temp: 43.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
    model: WD5000AAKX-001CA0 size: 465.76 GiB block-size: physical: 512 B
    logical: 512 B speed: 6.0 Gb/s type: N/A serial: <filter> rev: 1H15
    scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: Sabrent model: SABRENT
    size: 238.47 GiB block-size: physical: 4096 B logical: 512 B type: N/A
    serial: <filter> rev: 0204
  ID-1: / raw-size: 232.59 GiB size: 227.88 GiB (97.98%)
    used: 50.42 GiB (22.1%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: 75854fed-81cf-489e-8f29-df1898ae34ac
    used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 00A4-406A
  ID-3: /home/<filter>/Share raw-size: N/A size: 937.81 GiB
    used: 251.64 GiB (26.8%) fs: cifs dev: /dev/share
  ID-4: /mnt/Storage raw-size: 465.76 GiB size: 457.38 GiB (98.20%)
    used: 234.95 GiB (51.4%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
    mapped: Storage label: N/A uuid: N/A
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
  Hub-2: 1-4:2 info: Realtek RTS5411 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
    power: 100mA chip-ID: 0bda:5411 class-ID: 0900
  Hub-3: 1-9:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
  Device-1: 1-9.1:5 info: Microsoft Wireless keyboard (All-in-One-Media)
    type: Keyboard,Mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
    speed: 12 Mb/s power: 100mA chip-ID: 045e:0800 class-ID: 0300
  Hub-4: 1-10:4 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
  Device-1: 1-11:8 info: Integrated Express ITE Device type: HID
    driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
    chip-ID: 048d:5702 class-ID: 0300
  Device-2: 1-14:7 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
    class-ID: e001
  Hub-5: 2-0:1 info: Super-speed hub ports: 5 rev: 3.1 speed: 20 Gb/s
  Hub-6: 2-3:2 info: Realtek Hub ports: 4 rev: 3.2 speed: 5 Gb/s power: 96mA
    chip-ID: 0bda:0411 class-ID: 0900
  Device-1: 2-3.1:3 info: JMicron / USA JMS561U two ports SATA 6Gb/s bridge
    type: Mass Storage driver: uas interfaces: 1 rev: 3.0 speed: 5 Gb/s
    power: 896mA chip-ID: 152d:1561 class-ID: 0806 serial: <filter>
  System Temperatures: cpu: 31.0 C mobo: N/A
  Processes: 371 Uptime: 44m wakeups: 0 Init: systemd v: 252 default: graphical
  tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman
  pkgs: 1410 libs: 346 tools: gnome-software,pamac pm: flatpak pkgs: 0
  Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.25
  RAM: total: 15.42 GiB used: 6.57 GiB (42.6%)
    microcode: 0x56
    desc: 1x12 MiB
  Speed (MHz): avg: 2300 high: 2600 min/max: 800/4400 scaling:
    driver: intel_pstate governor: powersave cores: 1: 2600 2: 2600 3: 2600
    4: 2600 5: 801 6: 2600 7: 2600 8: 800 9: 2600 10: 2600 11: 2600 12: 2600
    bogomips: 62232
    direct-render: Yes
    class-ID: 0403
    class-ID: 0200
  Components:
    lanes: 4 type: SSD serial: <filter> rev: 2B2QGXA7 temp: 42.9 C scheme: GPT
    scheme: GPT
    uuid: 00A4-406A
    class-ID: e001
  System Temperatures: cpu: 33.0 C mobo: N/A
  Processes: 367 Uptime: 50m wakeups: 0 Init: systemd v: 252 default: graphical
  pkgs: 1411 libs: 346 tools: gnome-software,pamac pm: flatpak pkgs: 0
The system should be up to date.
It’s German, but it says that everything is up to date.
sudo pacman -Syu         ✔  4s 
:: Paketdatenbanken werden synchronisiert …
 core ist aktuell
 extra ist aktuell
 community ist aktuell
 multilib ist aktuell
:: Vollständige Systemaktualisierung wird gestartet …
 Es gibt nichts zu tun
The problem solved itself.
That is good to know, unsatisfactory tho to have problems mysteriously start and go away.
Reading the system info something strikes me as odd:
I hope someone has some thoughts about this, to me it seems the home drive is not correctly mounted.
Some Swap is essential, you appear to have none.
I have noticed that there were another gnome update (new 43.4) and also a new kernel version: 6.2.8-1, maybe this have solved the problem.
At the moment i am happy that everything is working fine. :blush:
cat /etc/lsb-release         ✔
DISTRIB_ID=ManjaroLinux
DISTRIB_RELEASE=22.1.0
DISTRIB_CODENAME=Talos
DISTRIB_DESCRIPTION="Manjaro Linux"
uname -a         ✔
Linux home 6.2.8-1-MANJARO #1 SMP PREEMPT_DYNAMIC Wed Mar 22 21:14:50 UTC 2023 x86_64 GNU/Linux
I have mounted a samba share to my home directory using cifs. It works fine why are you having the thoughts that it is not correctly mounted. How should be the right output if it where mounted correctly?
I am using a SSD (NVMe PCIe M.2) and i have read that if you are using a SSD, you don’t need Swap necessarily?
Can you confirm it also.
SSD does not mean you dont need SWAP. Maybe some argue you should avoid it to avoid r/w on the SSD … but I wouldnt worry about wearing it out if I were you.
You definitely want SWAP unless you have 16+ GB of RAM, and I might argue you should always have some available, whether its a swapfile or partition or otherwise.
I have 16GB RAM, but i am going to active swap soon.
At my end the output looks like this:
ID-3: /home raw-size: 74.22 GiB size: 74.22 GiB (100.00%)
    used: 27.32 GiB (36.8%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
I would assume the home drive would not be /home/<filter>/Share but this might just be something visual and not a cause for concern.
