I am trying to set default resolution for my webcam to 1920x1080 with v4l2 so I am typing v4l2-ctl --get-fmt-video and I am getting this:
Format Video Capture:
Width/Height : 640/480
Pixel Format : 'YUYV' (YUYV 4:2:2)
Field : None
Bytes per Line : 1280
Size Image : 614400
Colorspace : sRGB
Transfer Function : Default (maps to sRGB)
YCbCr/HSV Encoding: Default (maps to ITU-R 601)
Quantization : Default (maps to Limited Range)
Flags :
Then I am changing it to 1920x1080 and H264 with v4l2-ctl -v width=1920,height=1080,pixelformat=H264, then I am checking again if it applied changes and output is:
Width/Height : 1920/1080
Pixel Format : 'H264' (H.264)
Field : None
Bytes per Line : 3840
Size Image : 655360
Colorspace : sRGB
Quantization : Default (maps to Full Range)
Flags :
Everything is looking nice but then when I am going to Discord or checking it with vlc v4l2:// :v4l-vdev="/dev/video0" it changes back to default options.
I have Razer Kiyo btw.
If needed here is an output of v4l2-ctl --all
Driver Info:
Driver name : uvcvideo
Card type : Razer Kiyo
Bus info : usb-0000:01:00.0-5
Driver version : 5.8.3
Capabilities : 0x84a00001
Video Capture
Metadata Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04200001
Video Capture
Streaming
Extended Pix Format
Priority: 2
Video input : 0 (Camera 1: ok)
Field : None
Size Image : 655360
Colorspace : sRGB
Flags :
Crop Capability Video Capture:
Bounds : Left 0, Top 0, Width 1920, Height 1080
Default : Left 0, Top 0, Width 1920, Height 1080
Pixel Aspect: 1/1
Selection Video Capture: crop_default, Left 0, Top 0, Width 1920, Height 1080, Flags:
Selection Video Capture: crop_bounds, Left 0, Top 0, Width 1920, Height 1080, Flags:
Streaming Parameters Video Capture:
Capabilities : timeperframe
Frames per second: 30.000 (30/1)
Read buffers : 0
brightness 0x00980900 (int) : min=0 max=255 step=1 default=128 value=128
contrast 0x00980901 (int) : min=0 max=255 step=1 default=128 value=118
saturation 0x00980902 (int) : min=0 max=255 step=1 default=128 value=136
white_balance_temperature_auto 0x0098090c (bool) : default=1 value=1
gain 0x00980913 (int) : min=0 max=255 step=1 default=0 value=63
power_line_frequency 0x00980918 (menu) : min=0 max=2 default=2 value=2
0: Disabled
1: 50 Hz
2: 60 Hz
white_balance_temperature 0x0098091a (int) : min=2000 max=7500 step=10 default=4000 value=4350 flags=inactive
sharpness 0x0098091b (int) : min=0 max=255 step=1 default=128 value=128
backlight_compensation 0x0098091c (int) : min=0 max=1 step=1 default=0 value=1
exposure_auto 0x009a0901 (menu) : min=0 max=3 default=3 value=1
1: Manual Mode
3: Aperture Priority Mode
exposure_absolute 0x009a0902 (int) : min=3 max=2047 step=1 default=127 value=3
exposure_auto_priority 0x009a0903 (bool) : default=0 value=1
pan_absolute 0x009a0908 (int) : min=-36000 max=36000 step=3600 default=0 value=0
tilt_absolute 0x009a0909 (int) : min=-36000 max=36000 step=3600 default=0 value=0
focus_absolute 0x009a090a (int) : min=0 max=255 step=1 default=0 value=46 flags=inactive
focus_auto 0x009a090c (bool) : default=1 value=1
zoom_absolute 0x009a090d (int) : min=100 max=140 step=10 default=100 value=100
