Hello,
I have recently bought a “Razer Huntsman V2 Analog” keyboard and have gotten the Openrazer software. Unfortunately the only thing I can really do with that software is change the RGB on the keyboard and I cannot find any other software where I could change the actuation point and configure profiles. Going into Windows and using Razer Synapse to create profiles with joystick or gamepad functions or change actuation points changes it for Windows only and switching to Manjaro and selecting the profiles does not actually work.
Any recommendation on any software other than Openrazer to configure either the profiles or the actuation point of the keys?
Here is my inxi output:
Kernel: 5.18.12-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.18-x86_64
root=UUID=2b82ac00-133f-4626-aa79-6e9ce377c7d4 rw quiet apparmor=1
security=apparmor resume=UUID=1add82b5-b81a-4bd2-ad9a-ff2a10e7d0a9
udev.log_priority=3
Desktop: KDE Plasma v: 5.24.6 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Micro-Star product: MS-7C95 v: 1.0
serial: <superuser required>
Mobo: Micro-Star model: B550M PRO-VDH (MS-7C95) v: 1.0
serial: <superuser required> UEFI: American Megatrends LLC. v: 2.A0
date: 03/16/2022
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 3
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
RAM: total: 31.27 GiB used: 5.48 GiB (17.5%)
RAM Report:
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3 gen: 4
built: 2021-22 process: TSMC n7 (7nm) family: 0x19 (25) model-id: 0x21 (33)
stepping: 0 microcode: 0xA201016
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 2979 high: 3710 min/max: 2200/4850 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3513 2: 3309
3: 3038 4: 2644 5: 2773 6: 3135 7: 2549 8: 3311 9: 3132 10: 2943 11: 3710
12: 2879 13: 2880 14: 2580 15: 2831 16: 2445 bogomips: 121641
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
STIBP: always-on, RSB filling
Device-1: AMD Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
driver: amdgpu v: kernel arch: RDNA 1 process: TSMC n7 (7nm) built: 2019-20
pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-1,DP-3
empty: DP-2,HDMI-A-1 bus-ID: 2d:00.0 chip-ID: 1002:731f class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.3
compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting,radeon
alternate: fbdev,vesa gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 5360x1440 s-dpi: 96 s-size: 1418x381mm (55.83x15.00")
s-diag: 1468mm (57.81")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,top-right
model: Idek Iiyama PL3466WQ serial: <filter> built: 2019 res: 3440x1440
dpi: 110 gamma: 1.2 size: 797x334mm (31.38x13.15") diag: 869mm (34.2")
modes: max: 3440x1440 min: 720x400
Monitor-2: DP-3 mapped: DisplayPort-2 pos: bottom-l
model: Philips PHL 328E8Q serial: <filter> built: 2017 res: 1920x1080
dpi: 70 gamma: 1.2 size: 698x393mm (27.48x15.47") diag: 801mm (31.5")
ratio: 16:9 modes: max: 1920x1080 min: 720x400
OpenGL: renderer: AMD Radeon RX 5700 XT (navi10 LLVM 14.0.6 DRM 3.46
5.18.12-3-MANJARO)
v: 4.6 Mesa 22.1.3 direct render: Yes
Device-1: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel
bus-ID: 1-6:2 pcie: chip-ID: 146b:0e03 gen: 4 speed: 16 GT/s class-ID: 0300
serial: <filter> lanes: 16 bus-ID: 2d:00.1 chip-ID: 1002:ab38
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
bus-ID: 2f:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: BigBen Interactive Nacon Streaming Microphone type: USB
driver: hid-generic,snd-usb-audio,usbhid
Sound Server-1: ALSA v: k5.18.12-3-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.56 running: yes
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: e000 bus-ID: 2a:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp42s0 state: up speed: 100 Mbps duplex: full mac: <filter>
driver: btusb v: 0.8 bus-ID: 1-7.4:6 chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 2.26 TiB used: 1 TiB (44.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 type: SSD serial: <filter> rev: 3B2QGXA7 temp: 43.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT480BX500SSD1
size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: R022 scheme: GPT
ID-1: / raw-size: 58.59 GiB size: 57.37 GiB (97.92%) used: 39.03 GiB (68.0%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: Root
uuid: 2b82ac00-133f-4626-aa79-6e9ce377c7d4
ID-2: /boot/efi raw-size: 1000 MiB size: 998 MiB (99.80%)
used: 288 KiB (0.0%) fs: vfat dev: /dev/nvme0n1p4 maj-min: 259:4
label: NO_LABEL uuid: BBA7-013A
ID-3: /home raw-size: 1.75 TiB size: 1.72 TiB (98.37%)
used: 990.06 GiB (56.1%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
label: home uuid: 4e583d88-a810-4979-a3cb-028247cbdd9d
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p1 maj-min: 259:1 label: Swap
uuid: 1add82b5-b81a-4bd2-ad9a-ff2a10e7d0a9
ID-1: /dev/sda1 maj-min: 8:1 size: 100 MiB fs: vfat label: N/A
uuid: 8CC1-2480
ID-2: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/sda3 maj-min: 8:3 size: 446.23 GiB fs: ntfs label: N/A
uuid: 01D7ACAF35658960
ID-4: /dev/sda4 maj-min: 8:4 size: 800.8 MiB fs: vfat label: BOOT
uuid: 6FA3-D144
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 1-6:2 info: BigBen Interactive Nacon Streaming Microphone
type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 3
rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 146b:0e03 class-ID: 0300
serial: <filter>
Hub-2: 1-7:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-7.3:5 info: Logitech Unifying Receiver
type: Keyboard,Mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-2: 1-7.4:6
info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) type: Bluetooth
Device-3: 1-8:4 info: Micro Star MYSTIC LIGHT type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
power: 500mA chip-ID: 1462:7c95 class-ID: 0300 serial: <filter>
Hub-3: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-4: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-3:2 info: Razer USA Huntsman V2 Analog
type: Keyboard,Mouse,HID driver: razerkbd,usbhid interfaces: 5 rev: 2.0
speed: 12 Mb/s power: 500mA chip-ID: 1532:0266 class-ID: 0300
Hub-5: 3-4:3 info: Realtek RTS5411 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 0bda:5411 class-ID: 0900
Hub-6: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-7: 4-4:2 info: Realtek Hub ports: 4 rev: 3.0 speed: 5 Gb/s
chip-ID: 0bda:0411 class-ID: 0900
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 56.0 C mem: 62.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1163
Processes: 354 Uptime: 3h 14m wakeups: 15 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.0 clang: 14.0.6
Packages: 1639 pacman: 1631 lib: 467 flatpak: 8 Shell: Zsh v: 5.9
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.19
