Hi,
I have the following device:
3b:00.0 Network controller: Intel Corporation Wi-Fi 6 AX200 (rev 1a)
And since the latest update I have sporadic trouble with Bluetooth.
Every second time I turn on my laptop, the Bluetooth seems not to be recognized by KDE.
When it does not work, I have to log out and login back again. After that the Bluetooth is recognized and it works normally.
The problem persist regardless if I use the 5.15 or 5.16 kernel, and before the KDE update it (the problem) was non-existent.
Has anyone any ides?
Under I quote my Journald log:
20. 02. 22 08:06 dbus-daemon [session uid=1000 pid=966] Successfully activated service ‘org.bluez.obex’ 20. 02. 22 08:06 systemd Started Bluetooth OBEX service. 20. 02. 22 08:06 dbus-daemon [session uid=1000 pid=966] Activating via systemd: service name=‘org.a11y.Bus’ unit=‘at-spi-dbus-bus.service’ requested by ‘:1.52’ (uid=1000 pid=1335 comm=/usr/bin/python /usr/bin/blueman-applet ) 20. 02. 22 08:06 kded5 bluedevil: ObexManager operational changed true 20. 02. 22 08:06 kded5 bluedevil: ObexAgent registered 20. 02. 22 08:06 dbus-daemon [system] Activating via systemd: service name=‘org.blueman.Mechanism’ unit=‘blueman-mechanism.service’ requested by ‘:1.52’ (uid=1000 pid=1335 comm=/usr/bin/python /usr/bin/blueman-applet ) 20. 02. 22 08:06 systemd Starting Bluetooth management mechanism… 20. 02. 22 08:06 dbus-daemon [system] Successfully activated service ‘org.blueman.Mechanism’ 20. 02. 22 08:06 systemd Started Bluetooth management mechanism. 20. 02. 22 08:06 audit SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=blueman-mechanism comm=systemd exe=/usr/lib/systemd/systemd hostname=? addr=? terminal=? res=success’ 20. 02. 22 08:06 kernel audit: type=1130 audit(1645340770.684:62): pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=blueman-mechanism comm=systemd exe=/usr/lib/systemd/systemd hostname=? addr=? terminal=? res=success’ 20. 02. 22 08:06 dbus-daemon [system] Failed to activate service ‘org.bluez’: timed out (service_start_timeout=25000ms) 20. 02. 22 08:06 kded5 kf.bluezqt: PendingCall Error: Failed to activate service ‘org.bluez’: timed out (service_start_timeout=25000ms) 20. 02. 22 08:06 kernel Bluetooth: Core ver 2.22 20. 02. 22 08:06 kernel NET: Registered PF_BLUETOOTH protocol family 20. 02. 22 08:06 kernel Bluetooth: HCI device and connection manager initialized 20. 02. 22 08:06 kernel Bluetooth: HCI socket layer initialized 20. 02. 22 08:06 kernel Bluetooth: L2CAP socket layer initialized 20. 02. 22 08:06 kernel Bluetooth: SCO socket layer initialized 20. 02. 22 08:06 kernel Bluetooth: hci0: Bootloader revision 0.3 build 0 week 24 2017 20. 02. 22 08:06 kernel Bluetooth: hci0: Device revision is 1 20. 02. 22 08:06 kernel Bluetooth: hci0: Secure boot is enabled 20. 02. 22 08:06 kernel Bluetooth: hci0: OTP lock is enabled 20. 02. 22 08:06 kernel Bluetooth: hci0: API lock is enabled 20. 02. 22 08:06 kernel Bluetooth: hci0: Debug lock is disabled 20. 02. 22 08:06 kernel Bluetooth: hci0: Minimum firmware build 1 week 10 2014 20. 02. 22 08:06 systemd Reached target Bluetooth. 20. 02. 22 08:06 kernel Bluetooth: hci0: Found device firmware: intel/ibt-20-1-3.sfi 20. 02. 22 08:06 systemd Starting Bluetooth service… 20. 02. 22 08:06 bluetoothd Bluetooth daemon 5.63 20. 02. 22 08:06 systemd Started Bluetooth service. 20. 02. 22 08:06 audit SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=bluetooth comm=systemd exe=/usr/lib/systemd/systemd hostname=? addr=? terminal=? res=success’ 20. 02. 22 08:06 systemd Reached target Bluetooth Support. 20. 02. 22 08:06 kernel audit: type=1130 audit(1645340795.381:76): pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=bluetooth comm=systemd exe=/usr/lib/systemd/systemd hostname=? addr=? terminal=? res=success’ 20. 02. 22 08:06 bluetoothd Starting SDP server 20. 02. 22 08:06 dbus-daemon [system] Activating via systemd: service name=‘org.freedesktop.hostname1’ unit=‘dbus-org.freedesktop.hostname1.service’ requested by ‘:1.86’ (uid=0 pid=2580 comm=/usr/lib/bluetooth/bluetoothd ) 20. 02. 22 08:06 bluetoothd Bluetooth management interface 1.21 initialized 20. 02. 22 08:06 kernel Bluetooth: BNEP (Ethernet Emulation) ver 1.3 20. 02. 22 08:06 kernel Bluetooth: BNEP filters: protocol multicast 20. 02. 22 08:06 kernel Bluetooth: BNEP socket layer initialized 20. 02. 22 08:06 kded5 bluedevil: Bluetooth operational changed true 20. 02. 22 08:06 kded5 bluedevil: Agent registered 20. 02. 22 08:06 kded5 bluedevil: Requested default Agent 20. 02. 22 08:06 kded5 Registering :1.111/org/ayatana/NotificationItem/blueman to system tray 20. 02. 22 08:06 kernel Bluetooth: hci0: Waiting for firmware download to complete 20. 02. 22 08:06 kernel Bluetooth: hci0: Firmware loaded in 1854439 usecs 20. 02. 22 08:06 kernel Bluetooth: hci0: Waiting for device to boot 20. 02. 22 08:06 kernel Bluetooth: hci0: Device booted in 14691 usecs 20. 02. 22 08:06 kernel Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-20-1-3.ddc 20. 02. 22 08:06 kernel Bluetooth: hci0: Applying Intel DDC parameters completed 20. 02. 22 08:06 kernel Bluetooth: hci0: Firmware revision 0.3 build 235 week 51 2021 20. 02. 22 08:06 kernel Bluetooth: RFCOMM TTY layer initialized 20. 02. 22 08:06 kernel Bluetooth: RFCOMM socket layer initialized 20. 02. 22 08:06 kernel Bluetooth: RFCOMM ver 1.11 20. 02. 22 08:06 pulseaudio Device /org/bluez/hci0/dev_EC_83_50_6A_7D_91 points to a nonexistent adapter /org/bluez/hci0. 20. 02. 22 08:06 pulseaudio Device /org/bluez/hci0/dev_00_16_94_2F_4B_00 points to a nonexistent adapter /org/bluez/hci0. 20. 02. 22 08:06 pulseaudio Device /org/bluez/hci0/dev_A0_AB_51_B6_DA_0D points to a nonexistent adapter /org/bluez/hci0. 20. 02. 22 08:06 pulseaudio Device /org/bluez/hci0/dev_D8_37_3B_19_D4_4F points to a nonexistent adapter /org/bluez/hci0. 20. 02. 22 08:06 bluetoothd Endpoint registered: sender=:1.37 path=/MediaEndpoint/A2DPSink/sbc 20. 02. 22 08:06 bluetoothd Endpoint registered: sender=:1.37 path=/MediaEndpoint/A2DPSource/sbc 20. 02. 22 08:06 bluetoothd Endpoint registered: sender=:1.37 path=/MediaEndpoint/A2DPSink/sbc_xq_453 20. 02. 22 08:06 bluetoothd Endpoint registered: sender=:1.37 path=/MediaEndpoint/A2DPSource/sbc_xq_453 20. 02. 22 08:06 bluetoothd Endpoint registered: sender=:1.37 path=/MediaEndpoint/A2DPSink/sbc_xq_512 20. 02. 22 08:06 bluetoothd Endpoint registered: sender=:1.37 path=/MediaEndpoint/A2DPSource/sbc_xq_512 20. 02. 22 08:06 bluetoothd Endpoint registered: sender=:1.37 path=/MediaEndpoint/A2DPSink/sbc_xq_552 20. 02. 22 08:06 bluetoothd Endpoint registered: sender=:1.37 path=/MediaEndpoint/A2DPSource/sbc_xq_552 20. 02. 22 08:07 systemd blueman-mechanism.service: Deactivated successfully. 20. 02. 22 08:07 audit SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=blueman-mechanism comm=systemd exe=/usr/lib/systemd/systemd hostname=? addr=? terminal=? res=success’ 20. 02. 22 08:07 kernel audit: type=1131 audit(1645340825.707:89): pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=blueman-mechanism comm=systemd exe=/usr/lib/systemd/systemd hostname=? addr=? terminal=? res=success’
