Trouble using Chaotic-AUR. Garuda keys fail to import
I use manjaro build iso , after I built the manjaro iso, I tried to install it with ext4 file system and got this error
How to use ? Please
Moderaotor edit: Please copy and paste text here, not screenshots of text
Welcome to the forum! :wave:
Please see:
Where can I go with a question about building an ISO image?
I built the Manjaro iso image and added the Chaotic-aur repository, but after installing the system from the iso image, I got an error with the Chaotic-aur repository keys
Please do not create duplicate threads.
Also…
I understand that you have moved my topic to the support thread?
resolving dependencies…
:: ananicy-cpp and ananicy-cpp-git are in conflict. Remove ananicy-cpp-git? [y/N] y
Package (2) Old Version New Version Net Change Download Size
ananicy-cpp-git 1.1.1.r5.g097d79f-1 -0.55 MiB
chaotic-aur/ananicy-cpp 1.1.1-1 0.55 MiB 0.24 MiB
Total Download Size: 0.24 MiB
Total Installed Size: 0.55 MiB
Net Upgrade Size: 0.00 MiB
:: Proceed with installation? [Y/n] Y
:: Retrieving packages…
ananicy-cpp-1.1.1-1-x86_64 249.2 KiB 193 KiB/s 00:01 [--------------------------------------------------------------] 100%
(1/1) checking keys in keyring [--------------------------------------------------------------] 100%
downloading required keys…
:: Import PGP key 349BC7808577C592, “Garuda Builder team@garudalinux.org”? [Y/n] Y
(1/1) checking package integrity [--------------------------------------------------------------] 100%
error: ananicy-cpp: signature from “TNE tne@garudalinux.org” is unknown trust
:: File /var/cache/pacman/pkg/ananicy-cpp-1.1.1-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
Do you want to delete it? [Y/n] Y
error: failed to commit transaction (invalid or corrupted package (PGP signature))
I don’t think that you will get support for using the chaotic-aur repo here - only recommendations to not use it.
From what I know: all the stuff in there is also available from AUR or normal repos.
What is contained in it seems to trigger a PGP signature error.
Usually easy to resolve (unlike the mess you get yourself into when mixing normal repo, AUR and this chaotic repo).
Look / search for how keyring errors are resolved and apply this to the chaotic repo.
They may even have instructions on the topic.
Like the AUR, this repo is likely built under the assumption that you use Arch.
Manjaro - especially the stable branch - is … not the same and will give you grief.
This topic title is misleading.
It has nothing to do with Manjaro Linux as adding thrid party repositories is unsupported.
Manjaro build tools work as they are expected to.
