Trouble updating
This testing update breaks here:
sudo pacman -S pacman
Abhängigkeiten werden aufgelöst …
Nach in Konflikt stehenden Paketen wird gesucht …
Fehler: Vorgang konnte nicht vorbereitet werden (Kann Abhängigkeiten nicht erfüllen)
:: Installation von gpgme (2.0.0-1) verletzt Abhängigkeit »libgpgme.so=11-64«, benötigt von ostree
I have ostree installed as a dependecy of flatpak, which is needed for an app only available in this container format. The whole thing seems to break down at the new version of gpgme, which won’t install.
Kind regards
Stefan
That is not an update command (and why are you trying to install pacman? You already have it installed). You need to sync the local databases with the mirrors and do your update in one go:
sudo pacman -Syu
If that fails, please post the full output here. If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C sudo pacman -Syu
This may be potentially informative;
Dieselbe Meldung hatte jemand anderes vor ein paar Tagen.
ach menno, Deine Fehlermeldung war auf deutsch, der Rest des Posts aber in englisch - ich hatte schon angefangen, auf deutsch zu antworten deshalb :grin:
Someone else encountered what appears to be the same problem a few days ago.
Usually I’d recommend removing ostree, as that is preventing the update.
It’ll take flatpak down along with it, but so be it - reinstall it after the update …
But it is a normal repo package and this should not have occurred.
And this is apparently not the way to the solution here.
What he ended up doing was refreshing the mirrors - something I do regularly anyway
sudo pacman-mirrors -c germany
But what somehow fixed it for him was removing pacman’s sync databases
sudo rm -R /var/lib/pacman/sync
link to that thread:
Kann das System nicht updaten, weil Abhängigkeiten verletzt werden - #7 by Nachlese
After that:
sudo pacman -Syu
and they are recreated
and apparently, the problem was fixed … however it came about in the first place :man_shrugging:
Warning: When installing packages in Arch, avoid refreshing the package list without upgrading the system (for example, when a package is no longer found in the official repositories). In practice, do not run pacman -Sy package_name instead of pacman -Syu package_name , as this could lead to dependency issues. See System maintenance#Partial upgrades are unsupported and BBS#89328.
– pacman - ArchWiki
You may have created a partial sync state by updating the metadata.
The command sudo pacman -S pacman may create a partial sync state.
Please use
sudo pacman -Syu <pkgname>
Also see this comment in [Unstable Update] June 2025 - #31 by Yochanan and the preceeding comment.
