Trouble Switching Between Nvidia and AMD Graphics
About a month ago, I open a topic about how to use one system on both a computer with Nvidia Graphic Card and a computer with AMD Integrated Graphic Card.
https://forum.manjaro.org/t/how-to-disable-nvidia-drivers
Huge thanks to @megavolt for solving the previous problems.
However, after a month of usage, I discovered that there`s still something incorrect.
  • The desktop environment (KDE Plasma) is often stuck tore
  • Steam Proton is not working (failed to run any game, but I can do so if I only install Nvidia Drivers)
  • i can successfully run osu! smoothly with wine, but not Proton (that`s wired)
When I run nvidia-smi, it shows
| NVIDIA-SMI 470.141.03   Driver Version: 470.141.03   CUDA Version: 11.4     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|                               |                      |               MIG M. |
|   0  NVIDIA GeForce ...  Off  | 00000000:08:00.0 N/A |                  N/A |
| 42%   43C    P8    N/A /  N/A |    843MiB /  1966MiB |     N/A      Default |
|                               |                      |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                  GPU Memory |
|        ID   ID                                                   Usage      |
|  No running processes found                                                 |
Something must went wrong, right?
Could you guys help me again? Thanks a lot!!!
When I try to run basemark, it shows:
Gtk-Message: 09:45:37.971: Failed to load module "appmenu-gtk-module"
(node:26980) electron: The default of contextIsolation is deprecated and will be changing from false to true in a future release of Electron.  See https://github.com/electron/electron/issues/23506 for more information
(Use `basemarkgpu --trace-warnings ...` to show where the warning was created)
[26980:1013/094540.113437:FATAL:gpu_data_manager_impl_private.cc(407)] GPU process isn't usable. Goodbye.
