Hi
When I restart the system, this message appears on the screen and the system does not turn off
[ 102.534102] nv_tco: Unexpected close, not stopping watchdog!
Thank you for your help
The system does not shut down
Hi
First step, you can add nowatchdog
to your kernel boot parameters. See here:
https://wiki.archlinux.org/index.php/Improving_performance#Watchdogs
If that doesn’t work, check what watchdogs are used on your system:
lsmod | grep -e dog -e wdt
and then blacklist the modules in /etc/modeprobe.d/blacklist.conf
(you can create this file if your installation doesn’t have a blacklist.conf file).
https://wiki.archlinux.org/index.php/Kernel_module#Blacklisting
I’m sorry for the short answers, but I’m just about to leave the house. If this isn’t enough information for you to proceed, I will be back online in a few hours and can explain things better, or someone else will probably come along and help out sooner.
I try
thank you
Hi
The system does not shut downk
Hi
My PC won’t shut/power off completely unless I manually press the
There are a lot of threads about shut-down issues already, you can participate there.
To shutdown immediately you can type shutdown now
in a terminal.
Posts merged. Please do not create new topics for the same issue
Thanks for the terminal method, tell me what code to use
shutdown now
This is what should work
However, you can use:
shutdown -h now
It halts the system before shutting down. This might work better
if you are in plasma, did you check out Settings > Power Manager in KDE Settings ? on how the power button should behave when pressed etc
if everything is fine then you can even use systemctl shutdown
Did you add the nowatchdog parameter to your grub?
Did you blacklist the appropriate kernel modules?
