I’m having trouble resizing windows in KDE. I use Typora (flatpak) software. Accidentally, I maximized the window I was writing in, and now I can’t resize it anymore.
At the moment, the window occupies the entire screen of my monitor. I’ve tried many shortcuts, but I haven’t had success. What can I do?
You mean this shortcuts?
View
Function
Hotkey (Windows/Linux)
Hotkey (macOS)
Toggle Sidebar
Ctrl + Shift + L
Command + Shift + L
Outline
Ctrl + Shift + 1
Command + Control + 1
Articles
Ctrl + Shift + 2
Command + Control + 2
File Tree
Ctrl + Shift + 3
Command + Control + 3
Source Code Mode
Ctrl + /
Command + /
Focus Mode
F8
F8
Typewriter Mode
F9
F9
Toggler Fullscreen
F11
Command + Option + F
Actual Size
Ctrl + Shift + 0
(Not Supported)
Zoom In
Ctrl + Shift + =
(Not Supported)
Zoom Out
Ctrl + Shift + -
(Not Supported)
Switch Between Opened Documents
Ctrl + Tab
Command + `
Toggle DevTools
Ctrl + Shift + I
More here Shortcut Keys - Typora Support
anon89812132:
Toggler Fullscreen
Yeah! It is the command “Toggler Fullscreen (F11)”. Perfect! Thanks for your help and patience with such a basic question from a novice user like me.
victorhcardoso:
Perfect!
If that worked for you, then perfect, and no worries, we all started somewhere
Cheers!
