there is a trouble on choice keyboard langage ,
on boot iso USB manjaro
i choose fr_FR , but in Grub2 Mode with Ventoy , twice parameters appears on boot kernel command
no change seems to be applied ( checked after gui with inxi -Fza )
lang=en_US keytable=us tz=UTC ...
lang=fr_FR keytable=fr ....
i cant edit lines commands ( UEFI or Grub2) from iso USB
You always get two unless setting en_US, I set en_GB and get two. You can fix this after install in Manjaro Settings Manager Local Settings just delete en_US and apply fr_FR.
here the trouble , if i use iso USB live manjaro , i cant change Settings language ,
i tried with adding new layout keyboard with or without system , it stays in qwerty , even after i recreate a terminal.
You can’t do it on a live system the iso’s by default are read only.
