sudo pacman -U pyrenamer-0.6.0-1-any.pkg.tar.zst
loading packages…
resolving dependencies…
warning: cannot resolve “python27”, a dependency of “pyrenamer”
:: The following package cannot be upgraded due to unresolvable dependencies:
pyrenamer
:: Do you want to skip the above package for this upgrade? [y/N] N
:: unable to satisfy dependency ‘python27’ required by pyrenamer
You probably can edit the
DEBIAN/control
file (inside your downloaded Debian package)
and adjust the required python version from 2.7 to just 2
so it matches the name of what is now installed
debtap uses the information in that DEBIAN/control file
Perhaps you get prompted to edit it before running debtap on the package?
Otherwise, you can unpack the Debian package
and either move the files “by hand”
or edit and then re-create the package after having edited that file.
Or just force install the package - it should work.
I tried to do it manually but it seems that pyrenamer doesn’t “see” python2 env. but only python3.
/usr/bin/pyrenamer
File “/usr/bin/pyrenamer”, line 28
print “PyGtk 2.0 or later required for this app to run”
SyntaxError: Missing parentheses in call to ‘print’. Did you mean print(“PyGtk 2.0 or later required for this app to run”)?
This could (probably) be resolved in a similar way - I don’t know.
I have no experience in setting up and using two different python major versions simultaneously.
What @Yochanan said is probably applicable and the way to go.
I’d choose a different tool - one that is current.
But I don’t know what it is about this one that is so special that you want to keep using it.
