It is always returned to install button whenever i have tried to install this app , and it said that Error: A failure occured in build().
I tried this installation on manjaro kde and failed even though my pc spec is not lower than the requirements of manjaro installation. please help me, guys!
Iām having trouble installing Etcher and Ape on my Manjaro system. Whenever I try to build Etcher from the AUR, I get an error message saying āError: cannot find the fakeroot binary.ā Hereās some additional information:
Details:
Iāve enabled both AUR and Flatpak repositories.
Iāve tried reinstalling Manjaro KDE three times to rule out any mistakes on my part.
Interestingly, while I can somewhat install Etcher on Manjaro KDE, the process is more challenging on Manjaro GNOME.
Here are some screenshots which should be concluded , I think.
Iām fairly certain that checking āEnable AUR Supportā does not suffice.
A precondition to using it is to have the package group base-devel installed.
All the programs in it.
It contains all the programs needed for building AUR packages - fakeroot among them.
Balena Etcher has Appimages ready for download on their site. In that case i would recommend this, but this is an exception.
And i would not recommend the use of aur for absolute beginnersā¦you have not even started with it and you had a problem, imagine if something is not working or an update breaks because of it.
As for etcher - I donāt know I wouldnāt dream of installing it - bad reputation - I donāt know if that is true for today - in any case use something else - like mintstick - or even better ventoy.
Your duplicate post has been merged into your original, which very much appears to be the same āissueā.
Please review the AUR wiki page linked above.
Actually I only need Ape ape. whenever i install with terminal or add/remove app, it is not working because tclkit and sdx are missing. I did update but it is not working. I am still hopeless to use. Could you find me a easy way to solve this problem?
Thank you so much bro.
even though the commands are perfect, I have downloaded tcl manually in browser because there is still error to download fully.
By the way, This community is so helpful.
I almost go to window again if it doesnāt work properly.
