So far so good. ComfyUI seems to be properly installed. (See command output below.)
I started it with “sudo systemctl start comfyui” as suggested on the AUR page.
However, on invoking http://localhost:8188/ with Firefox there is this error message: Unable to connect
Firefox can’t connect to the server at localhost:8188
Using localhost:8188 as the AI Connector address in RapidRaw, the message is “connection failed”.
Any suggestions? Thank you.
❯ LANG=C pamac build comfyui
Preparing...
Cloning comfyui build files...
Generating comfyui information...
Checking comfyui dependencies...
Warning: comfyui-0.45.0-1 is up to date -- reinstalling
Resolving dependencies...
Checking inter-conflicts...
To build (1):
comfyui 0.45.0-1 AUR
Edit build files : [e]
Apply transaction ? [e/y/N] y
Authenticating as: Rudolf Fischer (rf)
Password:
Building comfyui...
==> Making package: comfyui 0.45.0-1 (Fr 20 Nov 2026 15:08:52)
==> Retrieving sources...
-> Found comfyui-0.45.0.tar.gz
-> Found comfyui.install
-> Found comfyui.sh
-> Found comfyui.service
-> Found comfyui.sysusers
-> Found comfyui.tmpfiles
comfyui-0.45.0.tar.gz ... Passed
comfyui.install ... Skipped
comfyui.sh ... Skipped
comfyui.service ... Skipped
comfyui.sysusers ... Skipped
comfyui.tmpfiles ... Skipped
==> Extracting sources...
-> Extracting comfyui-0.45.0.tar.gz with bsdtar
==> Starting build()...
==> Entering fakeroot environment...
==> Starting package()...
==> Tidying install...
-> Removing libtool files...
-> Removing static library files...
-> Purging unwanted files...
-> Compressing man and info pages...
==> Checking for packaging issues...
==> Creating package "comfyui"...
-> Generating .PKGINFO file...
-> Generating .BUILDINFO file...
-> Adding install file...
-> Generating .MTREE file...
-> Compressing package...
==> Leaving fakeroot environment.
==> Finished making: comfyui 0.45.0-1 (Fr 20 Nov 2026 15:08:56)
==> Cleaning up...
Überprüfe Schlüsselring... [1/1]
Integrität wird überprüft... [1/1]
Paketdateien werden geladen... [1/1]
Dateikonflikte werden überprüft... [1/1]
Überprüfe verfügbaren Speicherplatz... [1/1]
Using system disk as snapshot device for creating snapshots in BTRFS mode
Mounted '/dev/sdc1' (subvolid=0) at '/run/timeshift/15344/backup'
btrfs: Quotas are not enabled
Creating new backup...(BTRFS)
Saving to device: /dev/sdc1, mounted at path: /run/timeshift/15344/backup
Created directory: /run/timeshift/15344/backup/timeshift-btrfs/snapshots/2026-11-20_15-08-57
Created subvolume snapshot: /run/timeshift/15344/backup/timeshift-btrfs/snapshots/2026-11-20_15-08-57/@
Created subvolume snapshot: /run/timeshift/15344/backup/timeshift-btrfs/snapshots/2026-11-20_15-08-57/@home
Created control file: /run/timeshift/15344/backup/timeshift-btrfs/snapshots/2026-11-20_15-08-57/info.json
BTRFS Snapshot saved successfully (0s)
Tagged snapshot '2026-11-20_15-08-57': ondemand
Failed to show notification: Cannot autolaunch D-Bus without X11 $DISPLAY
Mounted '/dev/sdc1' (subvolid=0) at '/run/timeshift/15422/backup'
Removing snapshot: 2026-11-04_19-36-09
Deleting subvolume: @home (Id:366)
Deleted subvolume: @home (Id:366)
Deleting subvolume: @ (Id:365)
Deleted subvolume: @ (Id:365)
Deleted directory: /run/timeshift/15422/backup/timeshift-btrfs/snapshots/2026-11-04_19-36-09
Removed snapshot: 2026-11-04_19-36-09
Detecting snapshots ...
Found snapshot: 2026-11-20 15:08:57 | timeshift-btrfs/snapshots/2026-11-20_15-08-57/@ | ondemand | {timeshift-autosnap} {created before upgrade} |
Found snapshot: 2026-11-19 15:57:40 | timeshift-btrfs/snapshots/2026-11-19_15-57-40/@ | ondemand | {timeshift-autosnap} {created before upgrade} |
Found snapshot: 2026-11-15 12:00:00 | timeshift-btrfs/snapshots/2026-11-15_12-00-00/@ | weekly | N/A |
Found snapshot: 2026-11-12 17:38:51 | timeshift-btrfs/snapshots/2026-11-12_17-38-51/@ | ondemand | {timeshift-autosnap} {created before upgrade} |
Found snapshot: 2026-11-05 23:00:01 | timeshift-btrfs/snapshots/2026-11-05_23-00-01/@ | weekly | N/A |
Found snapshot: 2026-09-26 21:00:00 | timeshift-btrfs/snapshots/2026-09-26_21-00-00/@ | weekly | N/A |
Found snapshot: 2026-01-06 22:24:33 | timeshift-btrfs/snapshots/2026-01-06_22-24-33/@ | ondemand | N/A |
Found snapshot: 2025-12-22 23:18:34 | timeshift-btrfs/snapshots/2025-12-22_23-18-34/@ | ondemand | N/A |
Found snapshot: 2025-12-20 20:55:14 | timeshift-btrfs/snapshots/2025-12-20_20-55-14/@ | ondemand | N/A |
Found snapshot: 2025-12-18 23:02:21 | timeshift-btrfs/snapshots/2025-12-18_23-02-21/@ | ondemand | N/A |
Found snapshot: 2025-12-16 21:06:27 | timeshift-btrfs/snapshots/2025-12-16_21-06-27/@ | ondemand | N/A |
if [ ! -e "${prefix}/grub-btrfs.cfg" ]; then
echo ""
else
submenu 'Manjaro Linux snapshots' {
configfile "${prefix}/grub-btrfs.cfg"
fi
Found 11 snapshot(s)
Unmount /tmp/grub-btrfs.4c02KUucrD .. Success
Reinstalliere comfyui (0.45.0-1)... [1/1]
:: Existing Python venv found, reusing it.
:: Installing PyTorch with ROCm 7.2 support.
:: This may take a while (several GB to download).
Looking in indexes: https://download.pytorch.org/whl/rocm7.2
Collecting torch
Downloading torch-2.14.1%2Brocm7.2-cp314-cp314-manylinux_2_28_x86_64.whl (6224.9 MB)
━━━━━━ 1.0/6.2 GB 11.5 MB/s eta 0:07:36
WARNING: Connection interrupted while downloading.
WARNING: Attempting to resume incomplete download (993.2 MB/6224.9 MB, attempt 1)
Resuming download torch-2.14.1%2Brocm7.2-cp314-cp314-manylinux_2_28_x86_64.whl (993.2 MB/6224.9 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━╸ 4.6/6.2 GB 11.5 MB/s eta 0:02:20
WARNING: Attempting to resume incomplete download (4618.3 MB/6224.9 MB, attempt 2)
Resuming download torch-2.14.1%2Brocm7.2-cp314-cp314-manylinux_2_28_x86_64.whl (4618.3 MB/6224.9 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 6.2/6.2 GB 11.5 MB/s 0:02:19
Collecting torchvision
Downloading torchvision-0.29.1%2Brocm7.2-cp314-cp314-manylinux_2_28_x86_64.whl.metadata (5.7 kB)
Collecting torchaudio
Downloading torchaudio-2.11.0%2Brocm7.2-cp314-cp314-manylinux_2_28_x86_64.whl.metadata (6.9 kB)
Collecting filelock (from torch)
Downloading filelock-4.2.4-py3-none-any.whl.metadata (2.0 kB)
Collecting typing-extensions>=4.10.0 (from torch)
Downloading typing_extensions-4.16.0-py3-none-any.whl.metadata (3.3 kB)
Collecting setuptools>=77.0.3 (from torch)
Downloading setuptools-78.1.0-py3-none-any.whl.metadata (6.6 kB)
Collecting sympy>=1.13.3 (from torch)
Downloading sympy-1.14.0-py3-none-any.whl.metadata (12 kB)
Collecting networkx>=2.5.1 (from torch)
Downloading networkx-3.7-py3-none-any.whl.metadata (6.7 kB)
Collecting jinja2 (from torch)
Downloading jinja2-3.1.6-py3-none-any.whl.metadata (2.9 kB)
Collecting fsspec>=0.8.5 (from torch)
Downloading fsspec-2026.9.0-py3-none-any.whl.metadata (10 kB)
Collecting triton-rocm~=3.8.0 (from torch)
Downloading triton_rocm-3.8.0-cp314-cp314-linux_x86_64.whl.metadata (983 bytes)
Collecting numpy (from torchvision)
Downloading numpy-2.5.4-cp314-cp314-manylinux_2_27_x86_64.manylinux_2_28_x86_64.whl.metadata (6.6 kB)
Collecting pillow!=8.3.*,>=5.3.0 (from torchvision)
Downloading pillow-13.0.0-cp314-cp314-manylinux_2_27_x86_64.manylinux_2_28_x86_64.whl.metadata (9.1 kB)
Collecting mpmath<1.4,>=1.1.0 (from sympy>=1.13.3->torch)
Downloading mpmath-1.3.0-py3-none-any.whl.metadata (8.6 kB)
Collecting MarkupSafe>=2.0 (from jinja2->torch)
Downloading markupsafe-3.0.3-cp314-cp314-manylinux2014_x86_64.manylinux_2_17_x86_64.manylinux_2_28_x86_64.whl.metadata (2.7 kB)
Downloading triton_rocm-3.8.0-cp314-cp314-linux_x86_64.whl (361.6 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 361.6/361.6 MB 10.7 MB/s 0:00:33
Downloading torchvision-0.29.1%2Brocm7.2-cp314-cp314-manylinux_2_28_x86_64.whl (3.7 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 3.7/3.7 MB 11.4 MB/s 0:00:00
Downloading torchaudio-2.11.0%2Brocm7.2-cp314-cp314-manylinux_2_28_x86_64.whl (337 kB)
Downloading fsspec-2026.9.0-py3-none-any.whl (221 kB)
Downloading networkx-3.7-py3-none-any.whl (2.1 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 2.1/2.1 MB 11.6 MB/s 0:00:00
Downloading pillow-13.0.0-cp314-cp314-manylinux_2_27_x86_64.manylinux_2_28_x86_64.whl (7.1 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 7.1/7.1 MB 11.2 MB/s 0:00:00
Downloading setuptools-78.1.0-py3-none-any.whl (1.3 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 1.3/1.3 MB 11.6 MB/s 0:00:00
Downloading sympy-1.14.0-py3-none-any.whl (6.3 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 6.3/6.3 MB 11.1 MB/s 0:00:00
Downloading mpmath-1.3.0-py3-none-any.whl (536 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 536.2/536.2 kB 10.4 MB/s 0:00:00
Downloading typing_extensions-4.16.0-py3-none-any.whl (45 kB)
Downloading filelock-4.2.4-py3-none-any.whl (162 kB)
Downloading jinja2-3.1.6-py3-none-any.whl (134 kB)
Downloading markupsafe-3.0.3-cp314-cp314-manylinux2014_x86_64.manylinux_2_17_x86_64.manylinux_2_28_x86_64.whl (23 kB)
Downloading numpy-2.5.4-cp314-cp314-manylinux_2_27_x86_64.manylinux_2_28_x86_64.whl (16.7 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 16.7/16.7 MB 11.1 MB/s 0:00:01
Installing collected packages: torchaudio, mpmath, typing-extensions, triton-rocm, sympy, setuptools, pillow, numpy, networkx, MarkupSafe, fsspec, filelock, jinja2, torch, torchvision
Successfully installed MarkupSafe-3.0.3 filelock-4.2.4 fsspec-2026.9.0 jinja2-3.1.6 mpmath-1.3.0 networkx-3.7 numpy-2.5.4 pillow-13.0.0 setuptools-78.1.0 sympy-1.14.0 torch-2.14.1+rocm7.2 torchaudio-2.11.0+rocm7.2 torchvision-0.29.1+rocm7.2 triton-rocm-3.8.0 typing-extensions-4.16.0
:: Installing ComfyUI dependencies...
Collecting comfyui-frontend-package==1.58.5 (from -r /opt/comfyui/requirements.txt (line 1))
Downloading comfyui_frontend_package-1.58.5-py3-none-any.whl.metadata (117 bytes)
Collecting comfyui-workflow-templates==0.11.105 (from -r /opt/comfyui/requirements.txt (line 2))
Downloading comfyui_workflow_templates-0.11.105-py3-none-any.whl.metadata (25 kB)
Collecting comfyui-embedded-docs==0.5.16 (from -r /opt/comfyui/requirements.txt (line 3))
Downloading comfyui_embedded_docs-0.5.16-py3-none-any.whl.metadata (5.3 kB)
Requirement already satisfied: torch in ./opt/comfyui/venv/lib/python3.14/site-packages (from -r /opt/comfyui/requirements.txt (line 4)) (2.14.1+rocm7.2)
Collecting torchsde (from -r /opt/comfyui/requirements.txt (line 5))
Downloading torchsde-0.2.6-py3-none-any.whl.metadata (5.3 kB)
Requirement already satisfied: torchvision in ./opt/comfyui/venv/lib/python3.14/site-packages (from -r /opt/comfyui/requirements.txt (line 6)) (0.29.1+rocm7.2)
Requirement already satisfied: numpy>=1.25.0 in ./opt/comfyui/venv/lib/python3.14/site-packages (from -r /opt/comfyui/requirements.txt (line 7)) (2.5.4)
Collecting einops (from -r /opt/comfyui/requirements.txt (line 8))
Downloading einops-0.8.2-py3-none-any.whl.metadata (13 kB)
Collecting transformers>=4.50.3 (from -r /opt/comfyui/requirements.txt (line 9))
Downloading transformers-5.23.0-py3-none-any.whl.metadata (31 kB)
Collecting tokenizers>=0.13.3 (from -r /opt/comfyui/requirements.txt (line 10))
Downloading tokenizers-0.23.3-cp310-abi3-manylinux_2_17_x86_64.manylinux2014_x86_64.whl.metadata (9.8 kB)
Collecting sentencepiece (from -r /opt/comfyui/requirements.txt (line 11))
Downloading sentencepiece-0.2.3-cp314-cp314-manylinux_2_27_x86_64.manylinux_2_28_x86_64.whl.metadata (34 kB)
Collecting safetensors>=0.4.2 (from -r /opt/comfyui/requirements.txt (line 12))
Downloading safetensors-0.8.0-cp310-abi3-manylinux_2_17_x86_64.manylinux2014_x86_64.whl.metadata (4.2 kB)
Collecting aiohttp>=3.11.8 (from -r /opt/comfyui/requirements.txt (line 13))
Downloading aiohttp-3.14.5-cp314-cp314-manylinux2014_x86_64.manylinux_2_17_x86_64.manylinux_2_28_x86_64.whl.metadata (8.3 kB)
Collecting yarl>=1.18.0 (from -r /opt/comfyui/requirements.txt (line 14))
Downloading yarl-1.25.1-cp314-cp314-manylinux2014_x86_64.manylinux_2_17_x86_64.manylinux_2_28_x86_64.whl.metadata (111 kB)
Collecting pyyaml (from -r /opt/comfyui/requirements.txt (line 15))
Downloading pyyaml-6.0.3-cp314-cp314-manylinux2014_x86_64.manylinux_2_17_x86_64.manylinux_2_28_x86_64.whl.metadata (2.4 kB)
Requirement already satisfied: Pillow>=10.1.0 in ./opt/comfyui/venv/lib/python3.14/site-packages (from -r /opt/comfyui/requirements.txt (line 16)) (13.0.0)
Collecting scipy (from -r /opt/comfyui/requirements.txt (line 17))
Downloading scipy-1.18.1-cp314-cp314-manylinux_2_27_x86_64.manylinux_2_28_x86_64.whl.metadata (62 kB)
Collecting tqdm (from -r /opt/comfyui/requirements.txt (line 18))
Downloading tqdm-4.70.1-py3-none-any.whl.metadata (57 kB)
Collecting psutil (from -r /opt/comfyui/requirements.txt (line 19))
Downloading psutil-7.2.2-cp36-abi3-manylinux2010_x86_64.manylinux_2_12_x86_64.manylinux_2_28_x86_64.whl.metadata (22 kB)
Collecting alembic (from -r /opt/comfyui/requirements.txt (line 20))
Downloading alembic-1.20.1-py3-none-any.whl.metadata (7.3 kB)
Collecting SQLAlchemy>=2.0.0 (from -r /opt/comfyui/requirements.txt (line 21))
Downloading sqlalchemy-2.1.9-cp314-cp314-manylinux2014_x86_64.manylinux_2_17_x86_64.manylinux_2_28_x86_64.whl.metadata (9.7 kB)
Requirement already satisfied: filelock in ./opt/comfyui/venv/lib/python3.14/site-packages (from -r /opt/comfyui/requirements.txt (line 22)) (4.2.4)
Collecting av>=17.0.0 (from -r /opt/comfyui/requirements.txt (line 23))
Downloading av-19.0.2-cp312-abi3-manylinux_2_28_x86_64.whl.metadata (5.0 kB)
Collecting comfy-aimdo==0.6.0 (from -r /opt/comfyui/requirements.txt (line 24))
Downloading comfy_aimdo-0.6.0-cp39-abi3-manylinux2014_x86_64.manylinux_2_17_x86_64.whl.metadata (4.4 kB)
Collecting comfy-kitchen==0.2.41 (from -r /opt/comfyui/requirements.txt (line 25))
Downloading comfy_kitchen-0.2.41-cp312-abi3-manylinux_2_27_x86_64.manylinux_2_28_x86_64.whl.metadata (19 kB)
Collecting requests (from -r /opt/comfyui/requirements.txt (line 26))
Downloading requests-2.34.2-py3-none-any.whl.metadata (4.8 kB)
Collecting simpleeval>=1.0.0 (from -r /opt/comfyui/requirements.txt (line 27))
Downloading simpleeval-1.0.8-py3-none-any.whl.metadata (20 kB)
Collecting blake3 (from -r /opt/comfyui/requirements.txt (line 28))
Downloading blake3-1.0.11-cp314-cp314-manylinux_2_17_x86_64.manylinux2014_x86_64.whl.metadata (4.9 kB)
Collecting kornia>=0.7.1 (from -r /opt/comfyui/requirements.txt (line 31))
Downloading kornia-0.9.2-py3-none-any.whl.metadata (25 kB)
Collecting spandrel (from -r /opt/comfyui/requirements.txt (line 32))
Downloading spandrel-0.4.2-py3-none-any.whl.metadata (15 kB)
Collecting pydantic~=2.0 (from -r /opt/comfyui/requirements.txt (line 33))
Downloading pydantic-2.14.4-py3-none-any.whl.metadata (143 kB)
Collecting pydantic-settings~=2.0 (from -r /opt/comfyui/requirements.txt (line 34))
Downloading pydantic_settings-2.16.3-py3-none-any.whl.metadata (4.0 kB)
Collecting PyOpenGL>=3.1.8 (from -r /opt/comfyui/requirements.txt (line 35))
Downloading pyopengl-3.1.10-py3-none-any.whl.metadata (3.3 kB)
Collecting comfy-angle (from -r /opt/comfyui/requirements.txt (line 36))
Downloading comfy_angle-0.1.1-py3-none-manylinux_2_28_x86_64.whl.metadata (2.2 kB)
Collecting comfyui-workflow-templates-core==0.3.396 (from comfyui-workflow-templates==0.11.105->-r /opt/comfyui/requirements.txt (line 2))
Downloading comfyui_workflow_templates_core-0.3.396-py3-none-any.whl.metadata (260 bytes)
Collecting comfyui-workflow-templates-json==0.1.131 (from comfyui-workflow-templates==0.11.105->-r /opt/comfyui/requirements.txt (line 2))
Downloading comfyui_workflow_templates_json-0.1.131-py3-none-any.whl.metadata (266 bytes)
Collecting comfyui-workflow-templates-media-api==0.3.84 (from comfyui-workflow-templates==0.11.105->-r /opt/comfyui/requirements.txt (line 2))
Downloading comfyui_workflow_templates_media_api-0.3.84-py3-none-any.whl.metadata (290 bytes)
Collecting comfyui-workflow-templates-media-video==0.3.101 (from comfyui-workflow-templates==0.11.105->-r /opt/comfyui/requirements.txt (line 2))
Downloading comfyui_workflow_templates_media_video-0.3.101-py3-none-any.whl.metadata (283 bytes)
Collecting comfyui-workflow-templates-media-image==0.3.160 (from comfyui-workflow-templates==0.11.105->-r /opt/comfyui/requirements.txt (line 2))
Downloading comfyui_workflow_templates_media_image-0.3.160-py3-none-any.whl.metadata (283 bytes)
Collecting comfyui-workflow-templates-media-other==0.3.229 (from comfyui-workflow-templates==0.11.105->-r /opt/comfyui/requirements.txt (line 2))
Downloading comfyui_workflow_templates_media_other-0.3.229-py3-none-any.whl.metadata (306 bytes)
Collecting comfyui-workflow-templates-media-assets-01==0.1.48 (from comfyui-workflow-templates==0.11.105->-r /opt/comfyui/requirements.txt (line 2))
Downloading comfyui_workflow_templates_media_assets_01-0.1.48-py3-none-any.whl.metadata (290 bytes)
Collecting comfyui-workflow-templates-media-assets-02==0.1.30 (from comfyui-workflow-templates==0.11.105->-r /opt/comfyui/requirements.txt (line 2))
Downloading comfyui_workflow_templates_media_assets_02-0.1.30-py3-none-any.whl.metadata (290 bytes)
Collecting annotated-types>=0.6.0 (from pydantic~=2.0->-r /opt/comfyui/requirements.txt (line 33))
Downloading annotated_types-0.8.0-py3-none-any.whl.metadata (15 kB)
Collecting pydantic-core==2.50.5 (from pydantic~=2.0->-r /opt/comfyui/requirements.txt (line 33))
Downloading pydantic_core-2.50.5-cp314-cp314-manylinux2014_x86_64.manylinux_2_17_x86_64.whl.metadata (6.6 kB)
Requirement already satisfied: typing-extensions>=4.16.0 in ./opt/comfyui/venv/lib/python3.14/site-packages (from pydantic~=2.0->-r /opt/comfyui/requirements.txt (line 33)) (4.16.0)
Collecting typing-inspection>=0.4.4 (from pydantic~=2.0->-r /opt/comfyui/requirements.txt (line 33))
Downloading typing_inspection-0.4.5-py3-none-any.whl.metadata (2.6 kB)
Collecting python-dotenv>=1.2.2 (from pydantic-settings~=2.0->-r /opt/comfyui/requirements.txt (line 34))
Downloading python_dotenv-1.2.4-py3-none-any.whl.metadata (29 kB)
Requirement already satisfied: setuptools>=77.0.3 in ./opt/comfyui/venv/lib/python3.14/site-packages (from torch->-r /opt/comfyui/requirements.txt (line 4)) (78.1.0)
Requirement already satisfied: sympy>=1.13.3 in ./opt/comfyui/venv/lib/python3.14/site-packages (from torch->-r /opt/comfyui/requirements.txt (line 4)) (1.14.0)
Requirement already satisfied: networkx>=2.5.1 in ./opt/comfyui/venv/lib/python3.14/site-packages (from torch->-r /opt/comfyui/requirements.txt (line 4)) (3.7)
Requirement already satisfied: jinja2 in ./opt/comfyui/venv/lib/python3.14/site-packages (from torch->-r /opt/comfyui/requirements.txt (line 4)) (3.1.6)
Requirement already satisfied: fsspec>=0.8.5 in ./opt/comfyui/venv/lib/python3.14/site-packages (from torch->-r /opt/comfyui/requirements.txt (line 4)) (2026.9.0)
Requirement already satisfied: triton-rocm~=3.8.0 in ./opt/comfyui/venv/lib/python3.14/site-packages (from torch->-r /opt/comfyui/requirements.txt (line 4)) (3.8.0)
Collecting trampoline>=0.1.2 (from torchsde->-r /opt/comfyui/requirements.txt (line 5))
Downloading trampoline-0.1.2-py3-none-any.whl.metadata (10 kB)
Collecting huggingface-hub<3.0,>=1.31.0 (from transformers>=4.50.3->-r /opt/comfyui/requirements.txt (line 9))
Downloading huggingface_hub-2.4.0-py3-none-any.whl.metadata (16 kB)
Collecting packaging>=20.0 (from transformers>=4.50.3->-r /opt/comfyui/requirements.txt (line 9))
Downloading packaging-26.3-py3-none-any.whl.metadata (3.5 kB)
Collecting regex>=2025.10.22 (from transformers>=4.50.3->-r /opt/comfyui/requirements.txt (line 9))
Downloading regex-2026.11.19-cp314-cp314-manylinux2014_x86_64.manylinux_2_17_x86_64.manylinux_2_28_x86_64.whl.metadata (40 kB)
Collecting typer (from transformers>=4.50.3->-r /opt/comfyui/requirements.txt (line 9))
Downloading typer-0.29.2-py3-none-any.whl.metadata (16 kB)
Collecting click<9.0.0,>=8.4.2 (from huggingface-hub<3.0,>=1.31.0->transformers>=4.50.3->-r /opt/comfyui/requirements.txt (line 9))
Downloading click-8.5.1-py3-none-any.whl.metadata (2.6 kB)
Collecting hf-xet<2.0.0,>=1.6.0 (from huggingface-hub<3.0,>=1.31.0->transformers>=4.50.3->-r /opt/comfyui/requirements.txt (line 9))
Downloading hf_xet-1.8.0-cp38-abi3-manylinux2014_x86_64.manylinux_2_17_x86_64.whl.metadata (4.9 kB)
Collecting httpx2<3,>=2.0.0 (from huggingface-hub<3.0,>=1.31.0->transformers>=4.50.3->-r /opt/comfyui/requirements.txt (line 9))
Downloading httpx2-2.16.2-py3-none-any.whl.metadata (10.0 kB)
Collecting anyio>=4.10 (from httpx2<3,>=2.0.0->huggingface-hub<3.0,>=1.31.0->transformers>=4.50.3->-r /opt/comfyui/requirements.txt (line 9))
Downloading anyio-4.16.0-py3-none-any.whl.metadata (4.7 kB)
Collecting httpcore2==2.16.2 (from httpx2<3,>=2.0.0->huggingface-hub<3.0,>=1.31.0->transformers>=4.50.3->-r /opt/comfyui/requirements.txt (line 9))
Downloading httpcore2-2.16.2-py3-none-any.whl.metadata (28 kB)
Collecting idna>=3.18 (from httpx2<3,>=2.0.0->huggingface-hub<3.0,>=1.31.0->transformers>=4.50.3->-r /opt/comfyui/requirements.txt (line 9))
Downloading idna-3.20-py3-none-any.whl.metadata (7.2 kB)
Collecting truststore>=0.10 (from httpx2<3,>=2.0.0->huggingface-hub<3.0,>=1.31.0->transformers>=4.50.3->-r /opt/comfyui/requirements.txt (line 9))
Downloading truststore-0.10.5-py3-none-any.whl.metadata (4.5 kB)
Collecting h11>=0.16 (from httpcore2==2.16.2->httpx2<3,>=2.0.0->huggingface-hub<3.0,>=1.31.0->transformers>=4.50.3->-r /opt/comfyui/requirements.txt (line 9))
Downloading h11-0.16.0-py3-none-any.whl.metadata (8.3 kB)
Collecting aiohappyeyeballs>=2.5.0 (from aiohttp>=3.11.8->-r /opt/comfyui/requirements.txt (line 13))
Downloading aiohappyeyeballs-2.7.1-py3-none-any.whl.metadata (5.9 kB)
Collecting aiosignal>=1.4.0 (from aiohttp>=3.11.8->-r /opt/comfyui/requirements.txt (line 13))
Downloading aiosignal-1.4.0-py3-none-any.whl.metadata (3.7 kB)
Collecting attrs>=17.3.0 (from aiohttp>=3.11.8->-r /opt/comfyui/requirements.txt (line 13))
Downloading attrs-26.1.0-py3-none-any.whl.metadata (8.8 kB)
Collecting frozenlist>=1.1.1 (from aiohttp>=3.11.8->-r /opt/comfyui/requirements.txt (line 13))
Downloading frozenlist-1.8.0-cp314-cp314-manylinux1_x86_64.manylinux_2_28_x86_64.manylinux_2_5_x86_64.whl.metadata (20 kB)
Collecting multidict<8.0,>=4.5 (from aiohttp>=3.11.8->-r /opt/comfyui/requirements.txt (line 13))
Downloading multidict-7.2.1-cp314-cp314-manylinux2014_x86_64.manylinux_2_17_x86_64.manylinux_2_28_x86_64.whl.metadata (6.1 kB)
Collecting propcache>=0.2.0 (from aiohttp>=3.11.8->-r /opt/comfyui/requirements.txt (line 13))
Downloading propcache-0.5.4-cp314-cp314-manylinux2014_x86_64.manylinux_2_17_x86_64.manylinux_2_28_x86_64.whl.metadata (25 kB)
Collecting Mako (from alembic->-r /opt/comfyui/requirements.txt (line 20))
Downloading mako-1.4.3-py3-none-any.whl.metadata (2.9 kB)
Collecting charset_normalizer<4,>=2 (from requests->-r /opt/comfyui/requirements.txt (line 26))
Downloading charset_normalizer-3.5.2-cp314-cp314-manylinux2014_x86_64.manylinux_2_17_x86_64.manylinux_2_28_x86_64.whl.metadata (46 kB)
Collecting urllib3<3,>=1.26 (from requests->-r /opt/comfyui/requirements.txt (line 26))
Downloading urllib3-2.8.0-py3-none-any.whl.metadata (7.4 kB)
Collecting certifi>=2023.5.7 (from requests->-r /opt/comfyui/requirements.txt (line 26))
Downloading certifi-2026.10.23-py3-none-any.whl.metadata (2.5 kB)
Collecting kornia-rs>=0.2.0 (from kornia>=0.7.1->-r /opt/comfyui/requirements.txt (line 31))
Downloading kornia_rs-0.2.0-cp314-cp314-manylinux_2_17_x86_64.manylinux2014_x86_64.whl.metadata (19 kB)
Requirement already satisfied: mpmath<1.4,>=1.1.0 in ./opt/comfyui/venv/lib/python3.14/site-packages (from sympy>=1.13.3->torch->-r /opt/comfyui/requirements.txt (line 4)) (1.3.0)
Requirement already satisfied: MarkupSafe>=2.0 in ./opt/comfyui/venv/lib/python3.14/site-packages (from jinja2->torch->-r /opt/comfyui/requirements.txt (line 4)) (3.0.3)
Collecting shellingham>=1.3.0 (from typer->transformers>=4.50.3->-r /opt/comfyui/requirements.txt (line 9))
Downloading shellingham-1.5.4-py2.py3-none-any.whl.metadata (3.5 kB)
Collecting rich>=13.8.0 (from typer->transformers>=4.50.3->-r /opt/comfyui/requirements.txt (line 9))
Downloading rich-15.0.0-py3-none-any.whl.metadata (18 kB)
Collecting annotated-doc>=0.0.2 (from typer->transformers>=4.50.3->-r /opt/comfyui/requirements.txt (line 9))
Downloading annotated_doc-0.0.7-py3-none-any.whl.metadata (6.4 kB)
Collecting markdown-it-py>=2.2.0 (from rich>=13.8.0->typer->transformers>=4.50.3->-r /opt/comfyui/requirements.txt (line 9))
Downloading markdown_it_py-4.3.0-py3-none-any.whl.metadata (7.9 kB)
Collecting pygments<3.0.0,>=2.13.0 (from rich>=13.8.0->typer->transformers>=4.50.3->-r /opt/comfyui/requirements.txt (line 9))
Downloading pygments-2.21.0-py3-none-any.whl.metadata (2.5 kB)
Collecting mdurl~=0.1 (from markdown-it-py>=2.2.0->rich>=13.8.0->typer->transformers>=4.50.3->-r /opt/comfyui/requirements.txt (line 9))
Downloading mdurl-0.1.2-py3-none-any.whl.metadata (1.6 kB)
Downloading comfyui_frontend_package-1.58.5-py3-none-any.whl (29.4 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 29.4/29.4 MB 11.0 MB/s 0:00:02
Downloading comfyui_workflow_templates-0.11.105-py3-none-any.whl (11 kB)
Downloading comfyui_embedded_docs-0.5.16-py3-none-any.whl (24.6 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 24.6/24.6 MB 10.0 MB/s 0:00:02
Downloading comfy_aimdo-0.6.0-cp39-abi3-manylinux2014_x86_64.manylinux_2_17_x86_64.whl (442 kB)
Downloading comfy_kitchen-0.2.41-cp312-abi3-manylinux_2_27_x86_64.manylinux_2_28_x86_64.whl (69.2 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 69.2/69.2 MB 11.1 MB/s 0:00:06
Downloading comfyui_workflow_templates_core-0.3.396-py3-none-any.whl (89 kB)
Downloading comfyui_workflow_templates_json-0.1.131-py3-none-any.whl (4.4 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 4.4/4.4 MB 11.1 MB/s 0:00:00
Downloading comfyui_workflow_templates_media_api-0.3.84-py3-none-any.whl (100.1 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 100.1/100.1 MB 11.1 MB/s 0:00:08
Downloading comfyui_workflow_templates_media_assets_01-0.1.48-py3-none-any.whl (94.2 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 94.2/94.2 MB 11.1 MB/s 0:00:08
Downloading comfyui_workflow_templates_media_assets_02-0.1.30-py3-none-any.whl (77.9 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 77.9/77.9 MB 10.9 MB/s 0:00:07
Downloading comfyui_workflow_templates_media_image-0.3.160-py3-none-any.whl (89.4 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 89.4/89.4 MB 11.1 MB/s 0:00:08
Downloading comfyui_workflow_templates_media_other-0.3.229-py3-none-any.whl (89.1 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 89.1/89.1 MB 11.1 MB/s 0:00:08
Downloading comfyui_workflow_templates_media_video-0.3.101-py3-none-any.whl (104.3 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 104.3/104.3 MB 11.1 MB/s 0:00:09
Downloading pydantic-2.14.4-py3-none-any.whl (494 kB)
Downloading pydantic_core-2.50.5-cp314-cp314-manylinux2014_x86_64.manylinux_2_17_x86_64.whl (2.3 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 2.3/2.3 MB 11.3 MB/s 0:00:00
Downloading pydantic_settings-2.16.3-py3-none-any.whl (82 kB)
Downloading torchsde-0.2.6-py3-none-any.whl (61 kB)
Downloading einops-0.8.2-py3-none-any.whl (65 kB)
Downloading transformers-5.23.0-py3-none-any.whl (13.3 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 13.3/13.3 MB 11.2 MB/s 0:00:01
Downloading tokenizers-0.23.3-cp310-abi3-manylinux_2_17_x86_64.manylinux2014_x86_64.whl (3.4 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 3.4/3.4 MB 11.4 MB/s 0:00:00
Downloading huggingface_hub-2.4.0-py3-none-any.whl (857 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 857.0/857.0 kB 12.5 MB/s 0:00:00
Downloading click-8.5.1-py3-none-any.whl (126 kB)
Downloading hf_xet-1.8.0-cp38-abi3-manylinux2014_x86_64.manylinux_2_17_x86_64.whl (4.3 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 4.3/4.3 MB 11.4 MB/s 0:00:00
Downloading httpx2-2.16.2-py3-none-any.whl (97 kB)
Downloading httpcore2-2.16.2-py3-none-any.whl (85 kB)
Downloading sentencepiece-0.2.3-cp314-cp314-manylinux_2_27_x86_64.manylinux_2_28_x86_64.whl (1.7 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 1.7/1.7 MB 11.7 MB/s 0:00:00
Downloading safetensors-0.8.0-cp310-abi3-manylinux_2_17_x86_64.manylinux2014_x86_64.whl (516 kB)
Downloading aiohttp-3.14.5-cp314-cp314-manylinux2014_x86_64.manylinux_2_17_x86_64.manylinux_2_28_x86_64.whl (1.9 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 1.9/1.9 MB 11.5 MB/s 0:00:00
Downloading yarl-1.25.1-cp314-cp314-manylinux2014_x86_64.manylinux_2_17_x86_64.manylinux_2_28_x86_64.whl (117 kB)
Downloading multidict-7.2.1-cp314-cp314-manylinux2014_x86_64.manylinux_2_17_x86_64.manylinux_2_28_x86_64.whl (506 kB)
Downloading pyyaml-6.0.3-cp314-cp314-manylinux2014_x86_64.manylinux_2_17_x86_64.manylinux_2_28_x86_64.whl (794 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 794.2/794.2 kB 11.8 MB/s 0:00:00
Downloading scipy-1.18.1-cp314-cp314-manylinux_2_27_x86_64.manylinux_2_28_x86_64.whl (35.3 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 35.3/35.3 MB 11.2 MB/s 0:00:03
Downloading tqdm-4.70.1-py3-none-any.whl (80 kB)
Downloading psutil-7.2.2-cp36-abi3-manylinux2010_x86_64.manylinux_2_12_x86_64.manylinux_2_28_x86_64.whl (155 kB)
Downloading alembic-1.20.1-py3-none-any.whl (270 kB)
Downloading sqlalchemy-2.1.9-cp314-cp314-manylinux2014_x86_64.manylinux_2_17_x86_64.manylinux_2_28_x86_64.whl (4.6 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 4.6/4.6 MB 11.2 MB/s 0:00:00
Downloading av-19.0.2-cp312-abi3-manylinux_2_28_x86_64.whl (35.0 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 35.0/35.0 MB 11.2 MB/s 0:00:03
Downloading requests-2.34.2-py3-none-any.whl (73 kB)
Downloading charset_normalizer-3.5.2-cp314-cp314-manylinux2014_x86_64.manylinux_2_17_x86_64.manylinux_2_28_x86_64.whl (255 kB)
Downloading idna-3.20-py3-none-any.whl (69 kB)
Downloading urllib3-2.8.0-py3-none-any.whl (135 kB)
Downloading simpleeval-1.0.8-py3-none-any.whl (18 kB)
Downloading blake3-1.0.11-cp314-cp314-manylinux_2_17_x86_64.manylinux2014_x86_64.whl (382 kB)
Downloading kornia-0.9.2-py3-none-any.whl (2.2 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 2.2/2.2 MB 11.4 MB/s 0:00:00
Downloading spandrel-0.4.2-py3-none-any.whl (320 kB)
Downloading pyopengl-3.1.10-py3-none-any.whl (3.2 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 3.2/3.2 MB 11.3 MB/s 0:00:00
Downloading comfy_angle-0.1.1-py3-none-manylinux_2_28_x86_64.whl (5.1 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 5.1/5.1 MB 11.3 MB/s 0:00:00
Downloading aiohappyeyeballs-2.7.1-py3-none-any.whl (15 kB)
Downloading aiosignal-1.4.0-py3-none-any.whl (7.5 kB)
Downloading annotated_types-0.8.0-py3-none-any.whl (13 kB)
Downloading anyio-4.16.0-py3-none-any.whl (134 kB)
Downloading attrs-26.1.0-py3-none-any.whl (67 kB)
Downloading certifi-2026.10.23-py3-none-any.whl (135 kB)
Downloading frozenlist-1.8.0-cp314-cp314-manylinux1_x86_64.manylinux_2_28_x86_64.manylinux_2_5_x86_64.whl (231 kB)
Downloading h11-0.16.0-py3-none-any.whl (37 kB)
Downloading kornia_rs-0.2.0-cp314-cp314-manylinux_2_17_x86_64.manylinux2014_x86_64.whl (5.3 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 5.3/5.3 MB 11.3 MB/s 0:00:00
Downloading packaging-26.3-py3-none-any.whl (129 kB)
Downloading propcache-0.5.4-cp314-cp314-manylinux2014_x86_64.manylinux_2_17_x86_64.manylinux_2_28_x86_64.whl (232 kB)
Downloading python_dotenv-1.2.4-py3-none-any.whl (23 kB)
Downloading regex-2026.11.19-cp314-cp314-manylinux2014_x86_64.manylinux_2_17_x86_64.manylinux_2_28_x86_64.whl (808 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 808.5/808.5 kB 11.5 MB/s 0:00:00
Downloading trampoline-0.1.2-py3-none-any.whl (5.2 kB)
Downloading truststore-0.10.5-py3-none-any.whl (19 kB)
Downloading typing_inspection-0.4.5-py3-none-any.whl (14 kB)
Downloading mako-1.4.3-py3-none-any.whl (80 kB)
Downloading typer-0.29.2-py3-none-any.whl (121 kB)
Downloading annotated_doc-0.0.7-py3-none-any.whl (5.3 kB)
Downloading rich-15.0.0-py3-none-any.whl (310 kB)
Downloading pygments-2.21.0-py3-none-any.whl (1.3 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 1.3/1.3 MB 12.1 MB/s 0:00:00
Downloading markdown_it_py-4.3.0-py3-none-any.whl (96 kB)
Downloading mdurl-0.1.2-py3-none-any.whl (10.0 kB)
Downloading shellingham-1.5.4-py2.py3-none-any.whl (9.8 kB)
Installing collected packages: trampoline, PyOpenGL, urllib3, typing-inspection, truststore, tqdm, SQLAlchemy, simpleeval, shellingham, sentencepiece, scipy, safetensors, regex, pyyaml, python-dotenv, pygments, pydantic-core, psutil, propcache, packaging, multidict, mdurl, Mako, kornia-rs, idna, hf-xet, h11, frozenlist, einops, comfyui-workflow-templates-media-video, comfyui-workflow-templates-media-other, comfyui-workflow-templates-media-image, comfyui-workflow-templates-media-assets-02, comfyui-workflow-templates-media-assets-01, comfyui-workflow-templates-media-api, comfyui-workflow-templates-json, comfyui-workflow-templates-core, comfyui-frontend-package, comfyui-embedded-docs, comfy-kitchen, comfy-angle, comfy-aimdo, click, charset_normalizer, certifi, blake3, av, attrs, annotated-types, annotated-doc, aiohappyeyeballs, yarl, requests, pydantic, markdown-it-py, httpcore2, comfyui-workflow-templates, anyio, alembic, aiosignal, torchsde, rich, pydantic-settings, kornia, httpx2, aiohttp, typer, spandrel, huggingface-hub, tokenizers, transformers
Successfully installed Mako-1.4.3 PyOpenGL-3.1.10 SQLAlchemy-2.1.9 aiohappyeyeballs-2.7.1 aiohttp-3.14.5 aiosignal-1.4.0 alembic-1.20.1 annotated-doc-0.0.7 annotated-types-0.8.0 anyio-4.16.0 attrs-26.1.0 av-19.0.2 blake3-1.0.11 certifi-2026.10.23 charset_normalizer-3.5.2 click-8.5.1 comfy-aimdo-0.6.0 comfy-angle-0.1.1 comfy-kitchen-0.2.41 comfyui-embedded-docs-0.5.16 comfyui-frontend-package-1.58.5 comfyui-workflow-templates-0.11.105 comfyui-workflow-templates-core-0.3.396 comfyui-workflow-templates-json-0.1.131 comfyui-workflow-templates-media-api-0.3.84 comfyui-workflow-templates-media-assets-01-0.1.48 comfyui-workflow-templates-media-assets-02-0.1.30 comfyui-workflow-templates-media-image-0.3.160 comfyui-workflow-templates-media-other-0.3.229 comfyui-workflow-templates-media-video-0.3.101 einops-0.8.2 frozenlist-1.8.0 h11-0.16.0 hf-xet-1.8.0 httpcore2-2.16.2 httpx2-2.16.2 huggingface-hub-2.4.0 idna-3.20 kornia-0.9.2 kornia-rs-0.2.0 markdown-it-py-4.3.0 mdurl-0.1.2 multidict-7.2.1 packaging-26.3 propcache-0.5.4 psutil-7.2.2 pydantic-2.14.4 pydantic-core-2.50.5 pydantic-settings-2.16.3 pygments-2.21.0 python-dotenv-1.2.4 pyyaml-6.0.3 regex-2026.11.19 requests-2.34.2 rich-15.0.0 safetensors-0.8.0 scipy-1.18.1 sentencepiece-0.2.3 shellingham-1.5.4 simpleeval-1.0.8 spandrel-0.4.2 tokenizers-0.23.3 torchsde-0.2.6 tqdm-4.70.1 trampoline-0.1.2 transformers-5.23.0 truststore-0.10.5 typer-0.29.2 typing-inspection-0.4.5 urllib3-2.8.0 yarl-1.25.1
[notice] A new release of pip is available: 26.2.1 -> 26.3
[notice] To update, run: /opt/comfyui/venv/bin/python -m pip install --upgrade pip
:: Setting ownership to comfy:comfy...
:: ComfyUI upgraded successfully.
Starte Post-Transaction-Hooks...
Creating system user accounts... [1/5]
Creating temporary files... [2/5]
Reloading system manager configuration... [3/5]
Enqueuing marked services... [4/5]
Arming ConditionNeedsUpdate... [5/5]
