Trouble installing Brother hl l2320d printer via usb
When I search for printers, it doesn’t show. All of the search options for manually setting it up seem to suggest networked printers. Am I missing something I need to install? Any help will be greatly appreciated.
Running KDE version of Manjaro, latest.
The driver is available via the AUR. Make sure that you have the base-devel package installed and AUR support enabled in Pamac.
It can be installed via Pamac GUI or in terminal:
pamac build brother-hll2320d
Additional reading:
brother-hll2320d 3.2.0_1-1 [Installed]
Thanks. Apparently, I installed that (forgot about it) but that doesn’t seem to help. I still get this dialog:
Never mind! It was a bad USB port. On a brand new machine. Very annoying. Anyway, thanks for the suggestion!
