Trouble in Second Monitor
Hi
I install Manjaro on Acer Aspire A715, When I want to connect the second monitor via HDMI I faced a problem with the resolution. I removed video-modesetting and install video-hybrid-intel-nvidia-450xx-prime and then I can’t set the second display’s resolution to it’s recommended on Display setting, when I do it the screen becomes black.
I was a problem to install Manjaro on SSD because of Intel Rapid Storage’s technology which was installed on this device, when I change SATA mode to AHCI then I can install Manjaro to SSD but I faced to multiple errors on Manjaro KDE. Now I install Manjaro on HDD.
Please Help me.
:+1: Welcome to Manjaro! :+1:
Please read this:
and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
An inxi --admin --verbosity=7 --filter --no-host would be the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
:innocent:
tanks for you reply. You are right sorry.
this this out of inxi --admin --verbosity=7 --filter --no-host command
Kernel: 5.8.6-1-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=5bc60ba7-65f9-4fd7-9ed7-02ed3575a08f rw quiet apparmor=1
Desktop: GNOME 3.36.6 tk: GTK 3.24.23 wm: gnome-shell dm: LightDM 1.30.0
Distro: Manjaro Linux
Type: Laptop System: Acer product: Aspire A715-74G v: V1.29
serial: <filter>
Mobo: CFL model: Pidgey_CFS v: V1.29 serial: <filter> UEFI: Insyde v: 1.29
date: 04/09/2020
ID-1: BAT1 charge: 25.9 Wh condition: 57.0/57.5 Wh (99%) volts: 14.8/15.4
model: LGC AP18E8M type: Li-ion serial: <filter> status: Discharging
RAM: total: 15.48 GiB used: 4.07 GiB (26.3%)
RAM Report:
Topology: 6-Core model: Intel Core i7-9750H bits: 64 type: MT MCP
arch: Kaby Lake family: 6 model-id: 9E (158) stepping: A (10)
microcode: D6 L2 cache: 12.0 MiB bogomips: 62431
Speed: 800 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 800 2: 800
3: 800 4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm
lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae
pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti
pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel UHD Graphics 630 vendor: Acer Incorporated ALI
driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:3e9b
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q]
vendor: Acer Incorporated ALI driver: nouveau v: kernel bus ID: 01:00.0
chip ID: 10de:1f91
Device-3: Quanta HD User Facing type: USB driver: uvcvideo bus ID: 1-5:3
chip ID: 0408:a061
Display: x11 server: X.org 1.20.8 compositor: gnome-shell
driver: intel,modesetting,nouveau alternate: fbdev,nv,vesa
resolution: <xdpyinfo missing>
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 20.1.7
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci
bus ID: 00:1f.3 chip ID: 8086:a348
Device-2: NVIDIA vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
bus ID: 01:00.1 chip ID: 10de:10fa
Sound Server: ALSA v: k5.8.6-1-MANJARO
vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 3000
bus ID: 07:00.0 chip ID: 10ec:8168
IF: enp7s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: 3000
bus ID: 08:00.0 chip ID: 8086:2723
IF: wlp8s0 state: down mac: <filter>
IP v4: <filter> type: noprefixroute scope: global
IP v6: <filter> virtual: stable-privacy scope: link
Local Storage: total: 1.14 TiB used: 19.03 GiB (1.6%)
ID-1: /dev/nvme0n1 vendor: Kingston model: RBUSNS8154P3256GJ1
size: 238.47 GiB block size: physical: 512 B logical: 512 B
speed: 15.8 Gb/s lanes: 2 serial: <filter> rev: E8FK12.3 scheme: GPT
ID-2: /dev/sda vendor: Western Digital model: WD10SPZX-21Z10T0
size: 931.51 GiB block size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter> rev: 1A02 scheme: GPT
ID-1: / raw size: 238.17 GiB size: 233.43 GiB (98.01%)
used: 18.95 GiB (8.1%) fs: ext4 dev: /dev/nvme0n1p2 label: N/A
uuid: 5bc60ba7-65f9-4fd7-9ed7-02ed3575a08f
ID-2: /boot/efi raw size: 300.0 MiB size: 299.4 MiB (99.80%)
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 label: N/A
uuid: BB87-3029
ID-3: /mnt/2FBFD0AC525CC105 raw size: 279.59 GiB
size: 279.59 GiB (100.00%) used: 73.2 MiB (0.0%) fs: ntfs dev: /dev/sda1
label: Files uuid: 2FBFD0AC525CC105
Hub: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
speed: 480 Mb/s chip ID: 1d6b:0002
Device-1: 1-3:2
info: SHARKOON 2.4GHz Wireless rechargeable vertical mouse [More&Better]
type: Mouse driver: hid-generic,usbhid interfaces: 1 rev: 1.1
speed: 12 Mb/s chip ID: 1ea7:0064
Device-2: 1-5:3 info: Quanta HD User Facing type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s chip ID: 0408:a061
Device-3: 1-8:4 info: LighTuning EgisTec Touch Fingerprint Sensor
type: <vendor specific> driver: N/A interfaces: 1 rev: 1.1 speed: 12 Mb/s
chip ID: 1c7a:0570 serial: <filter>
Device-4: 1-14:5 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s chip ID: 8087:0029
Hub: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.1 speed: 10 Gb/s
chip ID: 1d6b:0003
System Temperatures: cpu: 49.0 C mobo: N/A gpu: nouveau temp: 25 C
Processes: 320 Uptime: 1h 37m Init: systemd v: 246 Compilers: gcc: 10.2.0
Packages: pacman: 1182 lib: 309 flatpak: 0 Shell: Zsh v: 5.8
running in: gnome-terminal inxi: 3.1.05
