your nvidia driver is not being loaded, so you can forget about prime… post output from:
inxi -xG
and logs:
journalctl -b0 -p5 --no-pager
sudo dmesg | grep -E 'nvidia|NVRM|nvrm'
inxi -xG ✔
Device-1: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: Lenovo
driver: nvidia v: 525.89.02 arch: Turing bus-ID: 01:00.0
Device-2: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5
bus-ID: 05:00.0 temp: 41.0 C
Device-3: Syntek Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-3:3
Display: x11 server: X.Org v: 21.1.7 driver: X: loaded: amdgpu,nvidia
unloaded: modesetting,nouveau dri: radeonsi gpu: amdgpu
resolution: 1920x1080~120Hz
API: OpenGL v: 4.6 Mesa 22.3.5 renderer: AMD Radeon Graphics (renoir LLVM
15.0.7 DRM 3.49 6.1.19-1-MANJARO) direct-render: Yes
journalctl -b0 -p5 --no-pager ✔
Mar 29 19:33:30 Manjaro kernel: Linux version 6.1.19-1-MANJARO (builduser@fv-az334-393) (gcc (GCC) 12.2.1 20230201, GNU ld (GNU Binutils) 2.40) #1 SMP PREEMPT_DYNAMIC Mon Mar 13 12:59:35 UTC 2023
Mar 29 19:33:30 Manjaro kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.1-x86_64 root=UUID=6149227b-bf85-45a8-9b63-ab8dd29b4a33 rw quiet splash udev.log_priority=3
Mar 29 19:33:30 Manjaro kernel: Unknown kernel command line parameters "splash BOOT_IMAGE=/boot/vmlinuz-6.1-x86_64", will be passed to user space.
Mar 29 19:33:30 Manjaro kernel: random: crng init done
Mar 29 19:33:30 Manjaro kernel: #2 #3 #4 #5 #6
Mar 29 19:33:30 Manjaro kernel: TSC synchronization [CPU#0 -> CPU#6]:
Mar 29 19:33:30 Manjaro kernel: Measured 4650 cycles TSC warp between CPUs, turning off TSC clock.
Mar 29 19:33:30 Manjaro kernel: #7 #8 #9 #10 #11
Mar 29 19:33:30 Manjaro kernel: audit: type=2000 audit(1680111202.156:1): state=initialized audit_enabled=0 res=1
Mar 29 19:33:30 Manjaro kernel: ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
Mar 29 19:33:30 Manjaro kernel: SCSI subsystem initialized
Mar 29 19:33:30 Manjaro kernel: VFS: Disk quotas dquot_6.6.0
Mar 29 19:33:30 Manjaro kernel: pci 0000:00:00.2: can't derive routing for PCI INT A
Mar 29 19:33:30 Manjaro kernel: pci 0000:00:00.2: PCI INT A: not connected
Mar 29 19:33:30 Manjaro kernel: Initialise system trusted keyrings
Mar 29 19:33:30 Manjaro kernel: Key type blacklist registered
Mar 29 19:33:30 Manjaro kernel: integrity: Platform Keyring initialized
Mar 29 19:33:30 Manjaro kernel: integrity: Machine keyring initialized
Mar 29 19:33:30 Manjaro kernel: Key type asymmetric registered
Mar 29 19:33:30 Manjaro kernel: Asymmetric key parser 'x509' registered
Mar 29 19:33:30 Manjaro kernel: ACPI: FW issue: working around C-state latencies out of order
Mar 29 19:33:30 Manjaro kernel: tpm tpm0: AMD fTPM version 0x3002f00000005 causes system stutter; hwrng disabled
Mar 29 19:33:30 Manjaro kernel: Loading compiled-in X.509 certificates
Mar 29 19:33:30 Manjaro kernel: Loaded X.509 cert 'Build time autogenerated kernel key: 31444bb7e6e17bb69ca9ad3ba00426f4041a030d'
Mar 29 19:33:30 Manjaro kernel: Key type .fscrypt registered
Mar 29 19:33:30 Manjaro kernel: Key type fscrypt-provisioning registered
Mar 29 19:33:30 Manjaro kernel: integrity: Loaded X.509 cert 'Microsoft Windows Production PCA 2011: a92902398e16c49778cd90f99e4f9ae17c55af53'
Mar 29 19:33:30 Manjaro kernel: integrity: Loaded X.509 cert 'Microsoft Corporation UEFI CA 2011: 13adbf4309bd82709c8cd54f316ed522988a1bd4'
Mar 29 19:33:30 Manjaro kernel: integrity: Loaded X.509 cert 'OK Certificate: c8c73a37546046ab495c33f4d0856052'
Mar 29 19:33:30 Manjaro kernel: integrity: Problem loading X.509 certificate -65
Mar 29 19:33:30 Manjaro kernel: integrity: Loaded X.509 cert 'EUJinn: 2d9ec14a26c9fcae420ef406a6e9492b'
Mar 29 19:33:30 Manjaro kernel: Unstable clock detected, switching default tracing clock to "global"
If you want to keep using the local clock, then add:
"trace_clock=local"
on the kernel command line
Mar 29 19:33:30 Manjaro kernel: scsi 0:0:0:0: Direct-Access ATA WDC WD10SPSX-08A 1A01 PQ: 0 ANSI: 5
Mar 29 19:33:30 Manjaro kernel: sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
Mar 29 19:33:30 Manjaro kernel: sd 0:0:0:0: [sda] 4096-byte physical blocks
Mar 29 19:33:30 Manjaro kernel: sd 0:0:0:0: [sda] Write Protect is off
Mar 29 19:33:30 Manjaro kernel: sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Mar 29 19:33:30 Manjaro kernel: sd 0:0:0:0: [sda] Attached SCSI disk
Mar 29 19:33:30 Manjaro kernel: nvidia: loading out-of-tree module taints kernel.
Mar 29 19:33:30 Manjaro kernel: nvidia: module license 'NVIDIA' taints kernel.
Mar 29 19:33:30 Manjaro kernel: Disabling lock debugging due to kernel taint
Mar 29 19:33:30 Manjaro kernel: nvidia: module verification failed: signature and/or required key missing - tainting kernel
Mar 29 19:33:30 Manjaro kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 525.89.02 Wed Feb 1 23:23:25 UTC 2023
Mar 29 19:33:30 Manjaro kernel: ATPX version 1, functions 0x00000001
Mar 29 19:33:30 Manjaro kernel: ATPX Hybrid Graphics
Mar 29 19:33:30 Manjaro kernel: amdgpu 0000:05:00.0: amdgpu: PSP runtime database doesn't exist
Mar 29 19:33:30 Manjaro kernel: [drm] psp gfx command LOAD_TA(0x1) failed and response status is (0x7)
Mar 29 19:33:30 Manjaro kernel: [drm] psp gfx command INVOKE_CMD(0x3) failed and response status is (0x4)
Mar 29 19:33:30 Manjaro kernel: amdgpu 0000:05:00.0: amdgpu: Secure display: Generic Failure.
Mar 29 19:33:30 Manjaro kernel: amdgpu 0000:05:00.0: amdgpu: SECUREDISPLAY: query securedisplay TA failed. ret 0x0
Mar 29 19:33:30 Manjaro kernel: amdgpu: SRAT table not found
Mar 29 19:33:30 Manjaro kernel: nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
Mar 29 19:33:30 Manjaro kernel: i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
Mar 29 19:33:30 Manjaro kernel: nvme nvme0: missing or invalid SUBNQN field.
Mar 29 19:33:30 Manjaro kernel: audit: type=1130 audit(1680111210.093:2): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 19:33:29 Manjaro systemd-vconsole-setup[365]: KD_FONT_OP_GET failed while trying to get the font metadata: Invalid argument
Mar 29 19:33:29 Manjaro systemd-vconsole-setup[365]: Fonts will not be copied to remaining consoles
Mar 29 19:33:30 Manjaro kernel: audit: type=1130 audit(1680111210.113:3): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 19:33:30 Manjaro kernel: audit: type=1130 audit(1680111210.149:4): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=plymouth-start comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 19:33:30 Manjaro kernel: ccp 0000:05:00.2: ccp: unable to access the device: you might be running a broken BIOS.
Mar 29 19:33:30 Manjaro kernel: ccp 0000:05:00.2: tee enabled
Mar 29 19:33:30 Manjaro kernel: ccp 0000:05:00.2: psp enabled
Mar 29 19:33:30 Manjaro kernel: audit: type=1130 audit(1680111210.309:5): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-backlight@backlight:amdgpu_bl0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 19:33:30 Manjaro kernel: cfg80211: Loading compiled-in X.509 certificates for regulatory database
Mar 29 19:33:30 Manjaro kernel: cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
Mar 29 19:33:30 Manjaro kernel: audit: type=1130 audit(1680111210.339:6): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-fsck@dev-disk-by\x2duuid-A29E\x2dC755 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 19:33:30 Manjaro kernel: iwlwifi 0000:04:00.0: api flags index 2 larger than supported by driver
Mar 29 19:33:30 Manjaro kernel: audit: type=1130 audit(1680111210.389:7): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 19:33:30 Manjaro kernel: thermal thermal_zone0: failed to read out thermal zone (-61)
Mar 29 19:33:30 Manjaro kernel: audit: type=1130 audit(1680111210.516:8): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 19:33:30 Manjaro kernel: audit: type=1130 audit(1680111210.583:9): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=plymouth-read-write comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 19:33:30 Manjaro kernel: audit: type=1130 audit(1680111210.656:10): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 19:33:30 Manjaro kernel: audit: type=1127 audit(1680111210.696:11): pid=571 uid=0 auid=4294967295 ses=4294967295 msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
Mar 29 19:33:30 Manjaro bluetoothd[583]: profiles/audio/vcp.c:vcp_init() D-Bus experimental not enabled
Mar 29 19:33:30 Manjaro bluetoothd[583]: src/plugin.c:plugin_init() Failed to init vcp plugin
Mar 29 19:33:30 Manjaro bluetoothd[583]: profiles/audio/mcp.c:mcp_init() D-Bus experimental not enabled
Mar 29 19:33:30 Manjaro bluetoothd[583]: src/plugin.c:plugin_init() Failed to init mcp plugin
Mar 29 19:33:30 Manjaro bluetoothd[583]: profiles/audio/bap.c:bap_init() D-Bus experimental not enabled
Mar 29 19:33:30 Manjaro bluetoothd[583]: src/plugin.c:plugin_init() Failed to init bap plugin
Mar 29 19:33:30 Manjaro polkitd[586]: Loading rules from directory /etc/polkit-1/rules.d
Mar 29 19:33:30 Manjaro polkitd[586]: Loading rules from directory /usr/share/polkit-1/rules.d
Mar 29 19:33:30 Manjaro polkitd[586]: Finished loading, compiling and executing 7 rules
Mar 29 19:33:30 Manjaro polkitd[586]: Acquired the name org.freedesktop.PolicyKit1 on the system bus
Mar 29 19:33:30 Manjaro bluetoothd[583]: Failed to set mode: Failed (0x03)
Mar 29 19:33:31 Manjaro kernel: ACPI: \: failed to evaluate _DSM bf0212f2-788f-c64d-a5b3-1f738e285ade (0x1001)
Mar 29 19:33:31 Manjaro wpa_supplicant[647]: Successfully initialized wpa_supplicant
Mar 29 19:33:31 Manjaro NetworkManager[602]: <warn> [1680111211.8080] device (wlp4s0): wifi-scan: active scanning for networks due to profiles with wifi.hidden=yes. This makes you trackable
Mar 29 19:33:35 Manjaro wpa_supplicant[647]: wlp4s0: CTRL-EVENT-REGDOM-CHANGE init=DRIVER type=COUNTRY alpha2=EG
Mar 29 19:33:35 Manjaro wpa_supplicant[647]: wlp4s0: SME: Trying to authenticate with b4:f5:8e:e0:6c:58 (SSID='~' freq=2412 MHz)
Mar 29 19:33:35 Manjaro kernel: ACPI Warning: \_SB.PCI0.GPP0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20220331/nsarguments-61)
Mar 29 19:33:35 Manjaro wpa_supplicant[647]: wlp4s0: Trying to associate with b4:f5:8e:e0:6c:58 (SSID='~' freq=2412 MHz)
Mar 29 19:33:35 Manjaro wpa_supplicant[647]: wlp4s0: Associated with b4:f5:8e:e0:6c:58
Mar 29 19:33:35 Manjaro wpa_supplicant[647]: wlp4s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Mar 29 19:33:35 Manjaro kernel: kauditd_printk_skb: 24 callbacks suppressed
Mar 29 19:33:35 Manjaro kernel: audit: type=1131 audit(1680111215.816:36): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 19:33:35 Manjaro wpa_supplicant[647]: wlp4s0: WPA: Key negotiation completed with b4:f5:8e:e0:6c:58 [PTK=CCMP GTK=TKIP]
Mar 29 19:33:35 Manjaro wpa_supplicant[647]: wlp4s0: CTRL-EVENT-CONNECTED - Connection to b4:f5:8e:e0:6c:58 completed [id=0 id_str=]
Mar 29 19:33:35 Manjaro wpa_supplicant[647]: wlp4s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-65 noise=9999 txrate=18000
Mar 29 19:33:36 Manjaro kernel: audit: type=1130 audit(1680111216.749:37): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-backlight@backlight:nvidia_0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 19:33:37 Manjaro kernel: audit: type=1100 audit(1680111217.623:38): pid=688 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Mar 29 19:33:37 Manjaro kernel: audit: type=1101 audit(1680111217.623:39): pid=688 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Mar 29 19:33:37 Manjaro kernel: audit: type=1103 audit(1680111217.623:40): pid=688 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Mar 29 19:33:37 Manjaro kernel: audit: type=1130 audit(1680111217.726:41): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@964 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 19:33:37 Manjaro systemd[690]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[sddm] ruser=[<unknown>] rhost=[<unknown>]
Mar 29 19:33:37 Manjaro kernel: audit: type=1101 audit(1680111217.733:42): pid=690 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 19:33:37 Manjaro kernel: audit: type=1103 audit(1680111217.733:43): pid=690 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=? acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Mar 29 19:33:37 Manjaro kernel: audit: type=1006 audit(1680111217.733:44): pid=690 uid=0 old-auid=4294967295 auid=964 tty=(none) old-ses=4294967295 ses=1 res=1
Mar 29 19:33:37 Manjaro kernel: audit: type=1300 audit(1680111217.733:44): arch=c000003e syscall=1 success=yes exit=3 a0=9 a1=7fff09d909a0 a2=3 a3=0 items=0 ppid=1 pid=690 auid=964 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/usr/lib/systemd/systemd" key=(null)
Mar 29 19:33:37 Manjaro systemd[690]: xdg-user-dirs-update.service: Main process exited, code=exited, status=1/FAILURE
Mar 29 19:33:37 Manjaro systemd[690]: xdg-user-dirs-update.service: Failed with result 'exit-code'.
Mar 29 19:33:37 Manjaro systemd[690]: Failed to start Update XDG user dir configuration.
Mar 29 19:33:37 Manjaro sddm-greeter[699]: QFont::fromString: Invalid description '(empty)'
Mar 29 19:33:38 Manjaro sddm-greeter[699]: QObject: Cannot create children for a parent that is in a different thread.
(Parent is QGuiApplication(0x7ffde6e739c0), parent's thread is QThread(0x55ee67e10430), current thread is QThread(0x55ee67f67a50)
Mar 29 19:33:38 Manjaro sddm-greeter[699]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
Mar 29 19:33:38 Manjaro udisksd[711]: udisks daemon version 2.9.4 starting
Mar 29 19:33:39 Manjaro udisksd[711]: Acquired the name org.freedesktop.UDisks2 on the system message bus
Mar 29 19:33:39 Manjaro sddm-greeter[699]: file:///usr/share/sddm/themes/breath/components/VirtualKeyboard.qml:11:1: Type InputPanel unavailable
Mar 29 19:33:39 Manjaro sddm-greeter[699]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:138:5: Type Keyboard unavailable
Mar 29 19:33:39 Manjaro sddm-greeter[699]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
Mar 29 19:33:39 Manjaro sddm-greeter[699]: file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assign [undefined] to QUrl
Mar 29 19:33:39 Manjaro sddm-greeter[699]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.20'
Mar 29 19:33:40 Manjaro wpa_supplicant[647]: wlp4s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-64 noise=9999 txrate=18000
Mar 29 19:33:40 Manjaro kernel: kauditd_printk_skb: 8 callbacks suppressed
Mar 29 19:33:40 Manjaro kernel: audit: type=1131 audit(1680111220.993:52): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 19:33:41 Manjaro kernel: audit: type=1100 audit(1680111221.746:53): pid=737 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="juba" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Mar 29 19:33:41 Manjaro kernel: audit: type=1101 audit(1680111221.746:54): pid=737 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="juba" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Mar 29 19:33:41 Manjaro kernel: audit: type=1103 audit(1680111221.749:55): pid=737 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="juba" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Mar 29 19:33:41 Manjaro kernel: audit: type=1006 audit(1680111221.749:56): pid=737 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
Mar 29 19:33:41 Manjaro kernel: audit: type=1300 audit(1680111221.749:56): arch=c000003e syscall=1 success=yes exit=4 a0=8 a1=7ffd9bb9aae0 a2=4 a3=0 items=0 ppid=650 pid=737 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=2 comm="sddm-helper" exe="/usr/lib/sddm/sddm-helper" key=(null)
Mar 29 19:33:41 Manjaro kernel: audit: type=1327 audit(1680111221.749:56): proctitle=2F7573722F6C69622F7364646D2F7364646D2D68656C706572002D2D736F636B6574002F746D702F7364646D2D6175746837666533393232352D643934352D343137642D386161342D616432323530666430363332002D2D69640031002D2D7374617274002F7573722F62696E2F7374617274706C61736D612D783131002D2D
Mar 29 19:33:41 Manjaro kernel: audit: type=1106 audit(1680111221.833:57): pid=688 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:session_close grantors=pam_unix,pam_systemd acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=:0 res=success'
Mar 29 19:33:41 Manjaro kernel: audit: type=1104 audit(1680111221.833:58): pid=688 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=:0 res=success'
Mar 29 19:33:41 Manjaro kernel: audit: type=1130 audit(1680111221.883:59): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 19:33:41 Manjaro systemd[739]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[juba] ruser=[<unknown>] rhost=[<unknown>]
Mar 29 19:33:42 Manjaro ksplashqml[767]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath-dark.desktop/contents/splash/Splash.qml:49: ReferenceError: maxWidth is not defined
Mar 29 19:33:42 Manjaro ksplashqml[767]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath-dark.desktop/contents/splash/Splash.qml:82:29: Unable to assign int to QEasingCurve
Mar 29 19:33:42 Manjaro ksmserver[827]: Qt: Session management error: networkIdsList argument is NULL
Mar 29 19:33:42 Manjaro kwin_x11[830]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
Mar 29 19:33:42 Manjaro kwin_x11[830]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
Mar 29 19:33:43 Manjaro ksmserver[827]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.16'
Mar 29 19:33:43 Manjaro plasmashell[881]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Mar 29 19:33:43 Manjaro plasmashell[881]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Mar 29 19:33:43 Manjaro polkitd[586]: Registered Authentication Agent for unix-session:2 (system bus name :1.41 [/usr/lib/polkit-kde-authentication-agent-1], object path /org/kde/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8)
Mar 29 19:33:43 Manjaro org_kde_powerdevil[900]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Mar 29 19:33:43 Manjaro pipewire[956]: mod.rt: Can't find org.freedesktop.portal.Desktop. Is xdg-desktop-portal running?
Mar 29 19:33:43 Manjaro pipewire[956]: mod.rt: found session bus but no portal
Mar 29 19:33:43 Manjaro wireplumber[976]: Can't find org.freedesktop.portal.Desktop. Is xdg-desktop-portal running?
Mar 29 19:33:43 Manjaro wireplumber[976]: found session bus but no portal
Mar 29 19:33:43 Manjaro wireplumber[976]: Failed to set scheduler settings: Operation not permitted
Mar 29 19:33:43 Manjaro wireplumber[976]: SPA handle 'api.alsa.enum.udev' could not be loaded; is it installed?
Mar 29 19:33:43 Manjaro wireplumber[976]: PipeWire's SPA ALSA udev plugin("api.alsa.enum.udev")missing or broken. Sound Cards cannot be enumerated
Mar 29 19:33:43 Manjaro wireplumber[976]: SPA handle 'api.bluez5.enum.dbus' could not be loaded; is it installed?
Mar 29 19:33:43 Manjaro wireplumber[976]: PipeWire's BlueZ SPA missing or broken. Bluetooth not supported.
Mar 29 19:33:43 Manjaro kded5[829]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.16'
Mar 29 19:33:43 Manjaro wireplumber[976]: <WpNode:0x55a4e2fea780> Object activation aborted: PipeWire proxy destroyed
Mar 29 19:33:43 Manjaro wireplumber[976]: <WpPortalPermissionStorePlugin:0x55a4e2f84600> Failed to call Lookup: GDBus.Error:org.freedesktop.portal.Error.NotFound: No entry for camera
Mar 29 19:33:43 Manjaro org_kde_powerdevil[900]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Mar 29 19:33:43 Manjaro pamac-tray-plas[1051]: updates_checker.vala:71: check updates
Mar 29 19:33:44 Manjaro plasmashell[881]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Mar 29 19:33:44 Manjaro plasmashell[881]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:534:9: QML Label: Binding loop detected for property "height"
Mar 29 19:33:44 Manjaro plasmashell[881]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:499:13: QML Label: Binding loop detected for property "height"
Mar 29 19:33:44 Manjaro plasmashell[881]: Trying to use rootObject before initialization is completed, whilst using setInitializationDelayed. Forcing completion
Mar 29 19:33:44 Manjaro plasmashell[881]: org.kde.plasma.kicker: Entry is not valid "org.kde.kontact.desktop" QSharedPointer(0x5590c4eb7430)
Mar 29 19:33:44 Manjaro plasmashell[881]: org.kde.plasma.kicker: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x5590c4e76430)
Mar 29 19:33:44 Manjaro plasmashell[881]: org.kde.plasma.kicker: Entry is not valid "org.kde.discover.desktop" QSharedPointer(0x5590c4ebc9c0)
Mar 29 19:33:44 Manjaro plasmashell[881]: org.kde.plasma.kicker: Entry is not valid "org.kde.kontact.desktop" QSharedPointer(0x5590c4ebc870)
Mar 29 19:33:44 Manjaro plasmashell[881]: org.kde.plasma.kicker: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x5590c4ebc870)
Mar 29 19:33:44 Manjaro plasmashell[881]: org.kde.plasma.kicker: Entry is not valid "org.kde.discover.desktop" QSharedPointer(0x5590c4eb7430)
Mar 29 19:33:44 Manjaro plasmashell[881]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:556:5: QML Label: Binding loop detected for property "height"
Mar 29 19:33:44 Manjaro plasmashell[881]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
Mar 29 19:33:44 Manjaro plasmashell[881]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/ThumbnailStrip.qml"
Mar 29 19:33:44 Manjaro pulseaudio[1129]: The decibel volume range for element 'PCM' (-2837 dB - -6 dB) has negative maximum. Disabling the decibel range.
Mar 29 19:33:45 Manjaro plasmashell[881]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Mar 29 19:33:45 Manjaro pulseaudio[1129]: stat('/etc/pulse/default.pa.d'): No such file or directory
Mar 29 19:33:45 Manjaro pulseaudio[1129]: Could not find org.bluez.BatteryProviderManager1.RegisterBatteryProvider(), is bluetoothd started with experimental features enabled (-E flag)?
Mar 29 19:33:46 Manjaro plasmashell[881]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Mar 29 19:33:46 Manjaro plasmashell[881]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x5590c5e96300) QQmlContext(0x5590c51b9fc0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Mar 29 19:33:46 Manjaro plasmashell[881]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Mar 29 19:33:46 Manjaro plasmashell[881]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Mar 29 19:33:46 Manjaro pamac-tray-plas[1051]: updates_checker.vala:101: 2 updates found
Mar 29 19:33:46 Manjaro plasmashell[881]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:433: Unable to assign [undefined] to QString
Mar 29 19:33:46 Manjaro konsole[1159]: kf.xmlgui: Shortcut for action "" "Show SSH Manager" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
Mar 29 19:33:46 Manjaro konsole[1159]: kf.xmlgui: Shortcut for action "" "Show Quick Commands" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
Mar 29 19:33:47 Manjaro plasmashell[881]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Mar 29 19:33:48 Manjaro plasmashell[881]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Mar 29 19:33:48 Manjaro kernel: kauditd_printk_skb: 10 callbacks suppressed
Mar 29 19:33:48 Manjaro kernel: audit: type=1131 audit(1680111228.669:68): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 19:33:49 Manjaro plasmashell[881]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Mar 29 19:33:49 Manjaro plasmashell[881]: file:///usr/lib/qt/qml/org/kde/plasma/workspace/calendar/InfiniteList.qml:43:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Mar 29 19:33:49 Manjaro plasmashell[881]: file:///usr/lib/qt/qml/org/kde/plasma/workspace/calendar/MonthView.qml:381: TypeError: Cannot read property 'cellHeight' of null
Mar 29 19:33:50 Manjaro plasmashell[881]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Mar 29 19:33:52 Manjaro systemd[691]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[sddm] ruser=[<unknown>] rhost=[<unknown>]
Mar 29 19:33:52 Manjaro kernel: audit: type=1131 audit(1680111232.286:69): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@964 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 19:33:52 Manjaro kernel: audit: type=1131 audit(1680111232.419:70): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@964 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 19:33:53 Manjaro wpa_supplicant[647]: wlp4s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-68 noise=9999 txrate=18000
Mar 29 19:34:00 Manjaro kernel: audit: type=1131 audit(1680111240.959:71): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 19:34:01 Manjaro kernel: audit: type=1334 audit(1680111241.039:72): prog-id=34 op=UNLOAD
Mar 29 19:34:01 Manjaro kernel: audit: type=1334 audit(1680111241.039:73): prog-id=33 op=UNLOAD
Mar 29 19:34:01 Manjaro kernel: audit: type=1334 audit(1680111241.039:74): prog-id=32 op=UNLOAD
Mar 29 19:34:01 Manjaro plasmashell[881]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:433: Unable to assign [undefined] to QString
Mar 29 19:34:15 Manjaro plasmashell[881]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Mar 29 19:35:54 Manjaro kwin_x11[830]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Mar 29 19:36:48 Manjaro plasmashell[881]: kf.sonnet.core: No language dictionaries for the language: "en_US"
Mar 29 19:36:48 Manjaro plasmashell[881]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Mar 29 19:36:48 Manjaro plasmashell[881]: libpng warning: iCCP: known incorrect sRGB profile
Mar 29 19:36:49 Manjaro kwin_x11[830]: libpng warning: iCCP: known incorrect sRGB profile
Mar 29 19:36:49 Manjaro nvidia-settings[1837]: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Mar 29 19:37:00 Manjaro wpa_supplicant[647]: wlp4s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-72 noise=9999 txrate=36000
Mar 29 19:37:03 Manjaro wpa_supplicant[647]: wlp4s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-60 noise=9999 txrate=36000
Mar 29 19:37:27 Manjaro wpa_supplicant[647]: wlp4s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-69 noise=9999 txrate=54000
Mar 29 19:37:30 Manjaro wpa_supplicant[647]: wlp4s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-71 noise=9999 txrate=54000
Mar 29 19:37:37 Manjaro plasmashell[881]: file:///usr/share/plasma/plasmoids/org.kde.plasma.mediacontroller/contents/ui/CompactRepresentation.qml:77: TypeError: Cannot read property 'implicitWidth' of null
Mar 29 19:37:41 Manjaro wpa_supplicant[647]: wlp4s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-67 noise=9999 txrate=54000
Mar 29 19:38:32 Manjaro wpa_supplicant[647]: wlp4s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-69 noise=9999 txrate=54000
Mar 29 19:38:40 Manjaro wpa_supplicant[647]: wlp4s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-68 noise=9999 txrate=54000
Mar 29 19:39:02 Manjaro wpa_supplicant[647]: wlp4s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-68 noise=9999 txrate=48000
Mar 29 19:39:06 Manjaro wpa_supplicant[647]: wlp4s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-77 noise=9999 txrate=54000
Mar 29 19:39:35 Manjaro wpa_supplicant[647]: wlp4s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-66 noise=9999 txrate=48000
Mar 29 19:39:45 Manjaro wpa_supplicant[647]: wlp4s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-67 noise=9999 txrate=54000
sudo dmesg | grep -E 'nvidia|NVRM|nvrm' ✔
[sudo] password for juba:
[ 2.148476] nvidia: loading out-of-tree module taints kernel.
[ 2.148488] nvidia: module license 'NVIDIA' taints kernel.
[ 2.182464] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ 2.567375] nvidia-nvlink: Nvlink Core is being initialized, major device number 235
[ 2.568822] nvidia 0000:01:00.0: enabling device (0000 -> 0003)
[ 2.568958] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
[ 2.617210] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 525.89.02 Wed Feb 1 23:23:25 UTC 2023
[ 3.812888] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 525.89.02 Wed Feb 1 23:09:40 UTC 2023
[ 3.815270] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[ 3.815277] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 1
[ 4.790072] nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
[ 4.903963] nvidia-uvm: Loaded the UVM driver, major device number 510.
[ 13.654731] audit: type=1130 audit(1680111216.749:37): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-backlight@backlight:nvidia_0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
I think it’s loaded, I can run application using it
driver: nvidia v: 525.89.02 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2023-02) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1f95
class-ID: 0300
code: Vega process: GF 14nm built: 2017-20 pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: eDP-1 empty: none bus-ID: 05:00.0
chip-ID: 1002:1636 class-ID: 0300 temp: 38.0 C
Device-3: Syntek Integrated Camera type: USB driver: uvcvideo bus-ID: 1-3:3
chip-ID: 174f:244c class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.7 compositor: kwin_x11 driver: X:
loaded: amdgpu,nvidia unloaded: modesetting,nouveau alternate: fbdev,nv,vesa
dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x08e8 built: 2019
res: 1920x1080 hz: 120 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
prime-run glxinfo | grep "OpenGL renderer"
OpenGL renderer string: NVIDIA GeForce GTX 1650 Ti/PCIe/SSE2
ok so the driver is being loaded…
so install again optimus:
edit your sddm.conf:
kate /etc/sddm.conf
and put a #
before the line starting with DisplayCommand
and the one starting with DisplayStopCommand
- you may not have this display command lines there, so proceed with install:
sudo pacman -S optimus-manager optimus-manager-plasma
dont install any dependencies, only these 2 packages;
reboot
- I was having many problem with connecting an external monitor via HDMI cable, I reinstalled manjaro because there mess in many configuration files.
- the external monitor does not work out of the box in manjaro.
- I want someone guide me step by step what I can do to enable the monitor because I spent too much time and I can’t do it, please.
- my laptop has AMD integrated GPU and Nvidia Discrete GPU, the HDMI cable is connected to the Nvidia GPU my laptop is Lenovo legion 5 15arh05h
Edit for future context: This post and the following 4 posts were part of a different thread, and were merged into this one by a moderator.
Please do not make duplicate threads about the same topic, instead continue the discussion on the old one.
I’m sorry, but it’s not duplicated.
I removed the whole system, So I want a help with the new one, and to make sure that everyone can help will help
I understand wanting to increase the visibility of your issue to try to find more help on it, however doing this creates clutter on the forum and makes it more difficult to help everyone. While you did reinstall your system, you are still facing the same issue, which means that it’s still the same topic.
you are right, Should I delete this ?
I am not sure if you are able to delete threads, even your own. But if you can, it’s probably for the best. Good luck on resolving your issue
After installing optimus manager and reboot, the monitor does not work with integrated mode or any other mode, the monitor goes into powersave mode after connecting to the laptop.
[8] INFO: # Xorg pre-start hook
[8] INFO: Previous state was: {'type': 'pending_pre_xorg_start', 'requested_mode': 'integrated', 'current_mode': None}
[8] INFO: Requested mode is: integrated
[32] INFO: Available modules: ['nouveau', 'nvidia', 'nvidia_drm', 'nvidia_modeset', 'nvidia_uvm']
[33] INFO: Unloading modules ['nvidia_drm', 'nvidia_modeset', 'nvidia_uvm', 'nvidia'] (if loaded)
[226] INFO: switching=none, nothing to do
[259] INFO: Found MHWD-generated Xorg config file at /etc/X11/xorg.conf.d/90-mhwd.conf. Removing.
[259] INFO: Writing to /etc/X11/xorg.conf.d/10-optimus-manager.conf
[259] INFO: Writing state {'type': 'pending_post_xorg_start', 'switch_id': '20230329T195157', 'requested_mode': 'integrated'}
[259] INFO: Xorg pre-start hook completed successfully.
[7] INFO: # Xorg post-start hook
[36] INFO: Running /etc/optimus-manager/xsetup-integrated.sh
[45] INFO: Writing state {'type': 'done', 'switch_id': '20230329T195157', 'current_mode': 'integrated'}
[45] INFO: Xorg post-start hook completed successfully.
[33] INFO: Unloading modules [‘nvidia_drm’, ‘nvidia_modeset’, ‘nvidia_uvm’, ‘nvidia’] (if loaded)
I think optimus manager unload the modules we added earlier.
- I started to think of the cable it self, it’s DVI-D to HDMI cable, but it was working and I purchased it a weak ago, (I tried it on my old laptop and I works fine, the laptop does not have hybrid graphics)
first rerun update since its a fresh install:
sudo pacman-mirrors --fasttrack 5 && sudo pacman -Syyu
reboot;
then install optimus as instructed, and reboot
@brahma I watched some videos and I found that I should install nvidia
package (proprietary drivers) to make optimus manager work, I’m using video-hybrid-amd-nvidia-prime
not the proprietary drivers
nvidia drivers are included in the video hybrid drivers, so you are using proprietary drivers…
so did you installed optimus, edited the sddm.conf, reboot and it didnt helped?
if not, click on the optimus tray icon, and switch to nvidia, and see if it works
I edited /etc/sddm.conf and installed optimus manager and it’s system tray, switching to Nvidia mode and hybrid mode does not make the monitor work, I have windows 11 dual boot and the monitor works fine, so it’s not a hardware issue
switch to the 5.15 kernel, install it from system settings, reboot and in grub menu/ advanced options select it and see if that helps
Finally, After using Linux 5.15 and optimus manager hybrid mode the monitor worked for I second and then turned off, I reconnected the cable and it’s working fine now, I booted the laptop again but using 6.1 this time to see what will happen, the monitor works fine also but KDE have some problem with the font and the dock (these problems with the hybrid mode, but in the integrated mode everything is fine but I can’t connect the monitor).
What do you suggest, should I remove 6.1 and use 5.15?
if everything is working fine on the 5.15, use that…
you can try add these parameters:
kate /etc/default/grub
and in the following line: GRUB_CMDLINE_LINUX_DEFAULT, inside the quotes, add these parameters:
acpi_osi=! acpi_osi='Windows 2018'
dont remove anything from there, add them to existing parameters, save the file and update grub:
sudo update-grub
reboot;
and test with the 6.1 kernel
@brahma
Today Linux 6.1 working fine with out any changes, I slept before doing the last changes you suggest and now it’s working without rendering or font issues, I think it will not last much like before.
EDIT
after adding ACPI parameter to grub and updating grub the laptop does not boot neither using the normal mode nor fallback mode in both kernels, after changes:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash udev.log_priority=3 acpi_osi=! acpi_osi='Windows 2018'"
- I don’t know what to do, if I undo the changed how could I update grub, I’m using live usb now
EDIT 2
I found this guide GRUB/Restore the GRUB Bootloader - Manjaro, following the instruction I successfully fixed grub and booted to the system again.
the monitor is working properly with Linux 6.1
I should not say that the problem is solved I will test it further more
- btw, should I revert the changes in
/etc/mkinitcpio.conf
@brahma, the problem still exists.
I started installing my programs to use the laptop, but the laptop rebooted because I installed VirtualBox (and some other packages), and the monitor is not working now
pamac history
[2023-03-30T05:54:05+0200] [ALPM] installed sublime-text-4 (4.4143-4)
[2023-03-30T05:54:05+0200] [ALPM] installed neovim (0.8.3-1)
[2023-03-30T05:54:05+0200] [ALPM] installed tree-sitter (0.20.7-1)
[2023-03-30T05:54:05+0200] [ALPM] installed libluv (1.44.2_1-2)
[2023-03-30T05:54:05+0200] [ALPM] installed luajit (2.1.0.beta3.r467.gd0e88930-1)
[2023-03-30T05:54:05+0200] [ALPM] installed libvterm (0.3-1)
[2023-03-30T05:54:05+0200] [ALPM] installed msgpack-c (5.0.0-1)
[2023-03-30T05:54:05+0200] [ALPM] installed libtermkey (0.22-2)
[2023-03-30T05:54:05+0200] [ALPM] installed unibilium (2.1.1-1)
[2023-03-30T05:51:11+0200] [ALPM] installed bash-completion (2.11-3)
[2023-03-30T05:51:11+0200] [ALPM] installed code (1.75.1-1)
[2023-03-30T05:51:11+0200] [ALPM] installed ripgrep (13.0.0-3)
[2023-03-30T05:51:11+0200] [ALPM] installed electron19 (19.1.9-4)
[2023-03-30T05:46:57+0200] [ALPM] installed terminator (2.1.2-2)
[2023-03-30T05:46:57+0200] [ALPM] installed python-psutil (5.9.4-1)
[2023-03-30T05:46:57+0200] [ALPM] installed python-configobj (5.0.6.r110.g3e2f4cc-3)
[2023-03-30T05:46:57+0200] [ALPM] installed python-six (1.16.0-6)
[2023-03-30T05:46:57+0200] [ALPM] installed libkeybinder3 (0.3.2-4)
[2023-03-30T05:41:27+0200] [ALPM] installed ticktick-nativefier (2021.04.30-3)
[2023-03-30T05:40:28+0200] [ALPM] installed nodejs-nativefier (50.0.1-1)
[2023-03-30T05:39:24+0200] [ALPM] installed telegram-desktop (4.6.2-2)
[2023-03-30T05:39:24+0200] [ALPM] installed abseil-cpp (20220623.1-1)
[2023-03-30T05:39:24+0200] [ALPM] installed jemalloc (1:5.3.0-1)
[2023-03-30T05:39:24+0200] [ALPM] installed glibmm-2.68 (2.74.0-1)
[2023-03-30T05:39:24+0200] [ALPM] installed ttf-opensans (1.101-2)
[2023-03-30T05:39:24+0200] [ALPM] installed obsidian (1.1.9-3)
[2023-03-30T05:39:24+0200] [ALPM] installed electron21 (21.3.5-2)
[2023-03-30T05:39:24+0200] [ALPM] installed libdispatch (5.5.0-1)
[2023-03-30T05:39:24+0200] [ALPM] installed virtualbox (7.0.6-1)
[2023-03-30T05:39:23+0200] [ALPM] installed liblzf (3.6-3)
[2023-03-30T05:39:23+0200] [ALPM] installed qt6-5compat (6.4.2-1)
[2023-03-30T05:39:23+0200] [ALPM] installed qt6-imageformats (6.4.2-1)
[2023-03-30T05:39:23+0200] [ALPM] installed qt6-svg (6.4.2-1)
[2023-03-30T05:39:23+0200] [ALPM] installed discord (0.0.25-1)
[2023-03-30T05:39:23+0200] [ALPM] installed libsigc++-3.0 (3.4.0-1)
[2023-03-30T05:39:23+0200] [ALPM] installed npm (8.19.2-1)
[2023-03-30T05:39:23+0200] [ALPM] installed node-gyp (9.3.1-1)
[2023-03-30T05:39:23+0200] [ALPM] installed nodejs-nopt (7.0.0-1)
[2023-03-30T05:39:23+0200] [ALPM] installed openssl-1.1 (1.1.1.t-1)
[2023-03-30T05:39:23+0200] [ALPM] installed latte-dock (0.10.9-1)
[2023-03-30T05:39:23+0200] [ALPM] installed rnnoise (0.4.1-1)
[2023-03-30T05:39:23+0200] [ALPM] installed semver (7.3.8-1)
[2023-03-30T05:39:23+0200] [ALPM] installed nodejs (19.6.0-1)
[2023-03-30T05:39:23+0200] [ALPM] installed sdl12-compat (1.2.60-1)
[2023-03-30T05:39:23+0200] [ALPM] installed unzip (6.0-19)
[2023-03-30T05:39:14+0200] [ALPM] installed linux515-virtualbox-host-modules (7.0.6-16)
[2023-03-30T05:39:11+0200] [ALPM] installed linux61-virtualbox-host-modules (7.0.6-17)
[2023-03-30T05:39:11+0200] [ALPM] installed libtpms (0.9.5-2)
[2023-03-30T05:39:11+0200] [ALPM] installed qt6-wayland (6.4.2-1)
[2023-03-30T05:39:11+0200] [ALPM] installed electron (22.0.3-2)
[2023-03-30T05:39:10+0200] [ALPM] installed jsoncpp (1.9.5-2)
[2023-03-30T05:39:10+0200] [ALPM] installed c-ares (1.19.0-1)
[2023-03-30T05:39:10+0200] [ALPM] installed webkit2gtk (2.38.4-1)
[2023-03-30T05:39:10+0200] [ALPM] installed woff2 (1.0.2-4)
[2023-03-30T05:39:10+0200] [ALPM] installed libmanette (0.2.6-3)
[2023-03-30T05:39:10+0200] [ALPM] installed hyphen (2.8.8-5)
[2023-03-30T05:39:10+0200] [ALPM] installed harfbuzz-icu (7.0.0-1)
[2023-03-30T05:39:10+0200] [ALPM] installed enchant (2.3.3-2)
[2023-03-30T05:39:10+0200] [ALPM] installed jq (1.6-4)
[2023-03-30T05:39:10+0200] [ALPM] installed oniguruma (6.9.8-1)
[2023-03-30T05:39:10+0200] [ALPM] installed libuv (1.44.2-1)
[2023-03-30T05:39:10+0200] [ALPM] installed wpebackend-fdo (1.14.0-1)
[2023-03-30T05:39:10+0200] [ALPM] installed libwpe (1.14.1-1)
[2023-03-30T05:39:10+0200] [ALPM] upgraded onlyoffice-desktopeditors (7.3.0-1 -> 7.3.3-1)
[2023-03-30T07:31:08+0200] [ALPM] installed google-chrome (111.0.5563.146-1)
[2023-03-30T07:29:35+0200] [ALPM] installed autoconf (2.71-1)
[2023-03-30T07:29:35+0200] [ALPM] installed bison (3.8.2-4)
[2023-03-30T07:29:35+0200] [ALPM] installed automake (1.16.5-1)
[2023-03-30T07:29:35+0200] [ALPM] installed debugedit (5.0-4)
[2023-03-30T07:29:35+0200] [ALPM] installed flex (2.6.4-4)
[2023-03-30T07:29:35+0200] [ALPM] installed m4 (1.4.19-2)
[2023-03-30T07:29:35+0200] [ALPM] installed pkgconf (1.8.0-1)
[2023-03-30T07:29:35+0200] [ALPM] installed make (4.4-1)
[2023-03-30T07:29:35+0200] [ALPM] installed guile (3.0.9-1)
[2023-03-30T07:29:35+0200] [ALPM] installed gc (8.2.2-1)
EDIT
I removed VirtualBox, assuming that its host modules were the problem and the monitor is working fine, I installed VirtualBox again, but this time I selected 5.15 linux virtualbox not 6.1 (although pamac installed 6.1 too), rebooting the laptop and everything is fine.
[2023-03-30T06:07:30+0200] [ALPM] installed virtualbox-guest-iso (7.0.6-1)
[2023-03-30T06:07:30+0200] [ALPM] installed virtualbox-sdk (7.0.6-1)
[2023-03-30T06:07:30+0200] [ALPM] installed vde2 (2.3.3-3)
[2023-03-30T06:07:30+0200] [ALPM] installed virtualbox-ext-vnc (7.0.6-1)
[2023-03-30T06:07:30+0200] [ALPM] installed libvncserver (0.9.14-2)
[2023-03-30T06:07:30+0200] [ALPM] installed virtualbox (7.0.6-1)
[2023-03-30T06:07:25+0200] [ALPM] installed linux61-virtualbox-host-modules (7.0.6-17)
[2023-03-30T06:07:17+0200] [ALPM] installed linux515-virtualbox-host-modules (7.0.6-16)
[2023-03-30T06:07:17+0200] [ALPM] installed wolfssl (5.5.4-1)
[2023-03-30T06:02:15+0200] [ALPM] removed linux515-virtualbox-host-modules (7.0.6-16)
[2023-03-30T06:02:11+0200] [ALPM] removed linux61-virtualbox-host-modules (7.0.6-17)
[2023-03-30T06:01:32+0200] [ALPM] removed virtualbox (7.0.6-1)
for future you dont have to boot into live usb, just in the grub menu press ‘E’ and locate the parameters for the kernel you want to boot with, for example the 6.1:
and just remove them, save it and boot with the 6.1 kernel and then just remove them from the grub config, and update grub to make it permanent…
no keep those changes, since you need early loading of the drivers…
so everything is now ok on the 6.1 kernel?
