Hello to all lovers of computer hardware and codes. I am a regular user who has decided to change from Windows to Linux. I have a serious problem: I cannot configure hibernation. This applies both to the swapfile I tried to use and the partition that I already created automatically. After all the attempts, I chose to install the system with automatic disk partitioning. In this case, you can turn on the ready-made hibernation. It happens to me like this: when I turn it off for verification, the system is restored without problems. For a short time, a few hours, too, no problem. If I turn it off until the next day, a black screen and a stationary cursor appear, Caps Lock may blink at the same time. We have to cut down the laptop with the power button.
Here’s what I have:
/etc/default/grub
GRUB_CMDLINE_LINUX_DEFAULT = “quiet apparmor = 1 security = apparmor resume = UUID = a1c1057d-8a94-4068-a828-20733fce823c udev.log_priority = 3”
/etc/mkinitcpio.conf:
HOOKS = “base udev autodetect modconf block keyboard keymap resume filesystems”
/ etc / fstab:
UUID = a1c1057d-8a94-4068-a828-20733fce823c swap swap defaults, noatime 0 2
$ inxi --full --admin --verbosity=7 --filter --no-host
System: Kernel: 5.8.16-2-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64 root=UUID=26ba52d4-2296-436e-9b31-4fe7b1c0fd7f
rw quiet apparmor=1 security=apparmor resume=UUID=a1c1057d-8a94-4068-a828-20733fce823c
udev.log_priority=3
Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.1 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Laptop System: Dell product: G5 5590 v: N/A serial: Chassis: type: 10
serial:
Mobo: Dell model: 0KW84T v: A01 serial: UEFI: Dell v: 1.11.1 date: 11/11/2019
Battery: ID-1: BAT0 charge: 27.7 Wh condition: 56.6/60.0 Wh (94%) volts: 14.7/15.2
model: BYD DELL HYWXJ02 type: Li-poly serial: status: Discharging
Memory: RAM: total: 7.59 GiB used: 3.08 GiB (40.6%)
CPU: Topology: 6-Core model: Intel Core i7-9750H bits: 64 type: MT MCP arch: Kaby Lake family: 6
model-id: 9E (158) stepping: A (10) microcode: D6 L2 cache: 12.0 MiB bogomips: 62431
Speed: 800 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800 5: 800
6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art avx avx2 bmi1 bmi2
bts clflush clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm
dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp
hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm mca
mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq
pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep
smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust
tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology
xtpr
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
Type: spectre_v2
mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: Intel UHD Graphics 630 vendor: Dell driver: i915 v: kernel bus ID: 00:02.0
chip ID: 8086:3e9b
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: Dell driver: nouveau
v: kernel bus ID: 01:00.0 chip ID: 10de:1f91
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo bus ID: 1-5:2
chip ID: 0c45:671f
Display: x11 server: X.Org 1.20.9 compositor: kwin_x11 driver: intel,modesetting,nouveau
alternate: fbdev,nv,vesa display ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.0x11.2") s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143 size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 20.1.8 direct render: Yes
Audio: Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3 chip ID: 8086:a348
Device-2: NVIDIA vendor: Dell driver: snd_hda_intel v: kernel bus ID: 01:00.1
chip ID: 10de:10fa
Sound Server: ALSA v: k5.8.16-2-MANJARO
Network: Device-1: Intel Wireless-AC 9560 [Jefferson Peak] driver: iwlwifi v: kernel port: 5000
bus ID: 00:14.3 chip ID: 8086:a370
IF: wlo1 state: up mac:
IP v4: type: dynamic noprefixroute scope: global broadcast:
IP v6: type: noprefixroute scope: link
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Dell driver: r8169
v: kernel port: 3000 bus ID: 03:00.0 chip ID: 10ec:8168
IF: enp3s0 state: down mac:
WAN IP:
Argument “fuse.gocryptfs” isn’t numeric in numeric eq (==) at /usr/bin/inxi line 12906.
Drives: Local Storage: total: 238.47 GiB used: 177.83 GiB (74.6%)
ID-1: /dev/nvme0n1 vendor: A-Data model: IM2P33F3 NVMe ADATA 256GB size: 238.47 GiB
block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 serial:
rev: 91002105 scheme: GPT
RAID: Message: No RAID data was found.
Partition: ID-1: / raw size: 230.00 GiB size: 225.39 GiB (98.00%) used: 177.83 GiB (78.9%) fs: ext4
dev: /dev/nvme0n1p2 label: N/A uuid: 26ba52d4-2296-436e-9b31-4fe7b1c0fd7f
ID-2: /boot/efi raw size: 300.0 MiB size: 299.4 MiB (99.80%) used: 312 KiB (0.1%) fs: vfat
dev: /dev/nvme0n1p1 label: N/A uuid: 9613-4811
Swap: Kernel: swappiness: 60 (default) cache pressure: 100 (default)
ID-1: swap-1 type: partition size: 4.00 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 label: N/A uuid: a1c1057d-8a94-4068-a828-20733fce823c
Unmounted: Message: No unmounted partitions found.
USB: Hub: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0 speed: 480 Mb/s
chip ID: 1d6b:0002
Device-1: 1-5:2 info: Microdia Integrated_Webcam_HD type: Video driver: uvcvideo interfaces: 2
rev: 2.0 speed: 480 Mb/s chip ID: 0c45:671f
Device-2: 1-14:3 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: Bluetooth
driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s chip ID: 8087:0aaa
Hub: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.1 speed: 10 Gb/s chip ID: 1d6b:0003
Sensors: System Temperatures: cpu: 35.0 C mobo: N/A gpu: nouveau temp: 28 C
Info: Processes: 290 Uptime: 1h 18m Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages:
pacman: 1240 lib: 349 flatpak: 0 Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.05
I would be grateful for your help, because the problem is critical for me. I’ll have to ditch Manjaro if it doesn’t fix it. It’s a pity the time spent on mastering the system, especially since I like it.
I apologize for the automatic translation if something is not clear.
