Trouble after 2026-05-02 stable update
Hi,
Following yesterday’s update, I am completely lost. I rebooted the computer right after, everything looked usual. This morning, after booting, appears on the monitor the overview of all running applications - upper left corner icon view - and with the dock at the bottom with big icons of low resolution. When I click the upper left corner icon, I do not see the dock and some icons - home, update - are missing on the right side of the top bar.
Which information should I provide to help?
Sorry, I am not an expert.
bilem
I do not know the Gnome environment so probably can’t help here, but it will likely be beneficial to those who can if you provide some system information:
inxi -zv8
Please remember to use proper code formatting. :slight_smile:
Mini How-To for code formatting
Select and copy all the text in the Terminal window, then paste the output in between two lines containing three backticks ``` or three tildes ~~~ (or paste then highlight the text and click the </> button at the top of the reply window, easier for smaller outputs).
inxi -zv8
  Kernel: 6.1.170-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=69e87da4-2969-48e1-a3e0-0ebaa56168f4 rw quiet splash apparmor=1
  Desktop: GNOME v: 50.1 tk: GTK v: 3.24.52 wm: gnome-shell
    tools: gsd-screensaver-proxy dm: GDM v: 50.0 Distro: Manjaro
    base: Arch Linux
  Type: Desktop System: Gigabyte product: B760M AORUS ELITE AX v: N/A
    serial: <superuser required>
  Mobo: Gigabyte model: B760M AORUS ELITE AX v: x.x
    serial: <superuser required> uuid: <superuser required> Firmware: UEFI
    vendor: American Megatrends LLC. v: F3 date: 03/07/2023
  Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard serial: <filter>
    charge: 55% (should be ignored) rechargeable: yes status: discharging
  System RAM: total: 32 GiB available: 31.12 GiB used: 4.67 GiB (15.0%)
  Device-1: Controller0-ChannelA-DIMM0 type: no module installed
  Device-2: Controller0-ChannelA-DIMM1 type: DDR5 detail: synchronous
    size: 16 GiB speed: 5600 MT/s volts: curr: 1.25 min: 1 max: 1.25
    width (bits): data: 64 total: 64 manufacturer: Corsair
    part-no: CMK32GX5M2B5600C36 serial: N/A
  Device-3: Controller1-ChannelA-DIMM0 type: no module installed
  Device-4: Controller1-ChannelA-DIMM1 type: DDR5 detail: synchronous
  Info: model: 13th Gen Intel Core i5-13400 bits: 64 type: MST AMCP
    arch: Raptor Lake gen: core 13 level: v3 note: check built: 2022+
    process: Intel 7 (10nm) family: 6 model-id: 0xBF (191) stepping: 2
    microcode: 0x3E
  Topology: cpus: 1x dies: 1 clusters: 7 cores: 10 threads: 16 mt: 6 tpc: 2
    st: 4 smt: enabled cache: L1: 864 KiB desc: d-4x32 KiB, 6x48 KiB; i-6x32
    KiB, 4x64 KiB L2: 9.5 MiB desc: 6x1.2 MiB, 1x2 MiB L3: 20 MiB
    desc: 1x20 MiB
  Speed (MHz): avg: 800 min/max: 800/4600:3300 scaling: driver: intel_pstate
    governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
    8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800 15: 800 16: 800
    bogomips: 79888
    de ds_cpl dtes64 dtherm dts ept ept_ad erms est f16c flexpriority
    hwp_epp hwp_notify hwp_pkg_req ibpb ibpb_exit_to_user ibrs ibrs_enhanced
    ibt ida intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx
    monitor movbe movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae
    pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36
    pts rdpid rdrand rdseed rdtscp rep_good sdbg sep serialize sha_ni smap
    smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
    tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
    vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave xsavec xsaveopt xsaves
    xtopology xtpr
    conditional; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
  Device-1: Intel Alder Lake-S GT1 [UHD Graphics 730] vendor: Gigabyte
    driver: i915 v: kernel arch: Xe process: Intel 10nm built: 2020-21 ports:
    active: DP-1 empty: HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:4682
    class-ID: 0300
  Device-2: Microsoft LifeCam VX-2000 driver: snd-usb-audio,uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-10.1:7
    chip-ID: 045e:0761 class-ID: 0102
    compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris gpu: i915 display-ID: 0
  Monitor-1: DP-1 model: NEC EA244WMi serial: <filter> built: 2015
    res: 1920x1200 dpi: 94 gamma: 1.2 chroma: red: x: 0.655 y: 0.333 green:
    x: 0.302 y: 0.635 blue: x: 0.149 y: 0.063 white: x: 0.314 y: 0.329
    size: 519x324mm (20.43x12.76") diag: 612mm (24.1") ratio: 16:10
    modes: 1920x1200, 1920x1080, 1680x1050, 1400x1050, 1280x1024, 1440x900,
    1280x960, 1280x800, 1280x720, 1024x768, 800x600, 720x480, 640x480
    drv: iris x11: drv: iris
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 26.0.6-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 730 (ADL-S
    GT1) device-ID: 8086:4682 memory: 30.39 GiB unified: yes display-ID: :0.0
  Info: Tools: api: eglinfo,glxinfo x11: xprop,xrandr
  Device-1: Intel Raptor Lake High Definition Audio vendor: Gigabyte
    driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
    bus-ID: 00:1f.3 chip-ID: 8086:7a50 class-ID: 0403
  API: ALSA v: k6.1.170-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.6.4 status: active with: 1: pipewire-pulse
  Device-1: Intel 700 Series CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:7a70 class-ID: 0280
  Device-2: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0
  Info: services: httpd, mld, NetworkManager, nfsd, systemd-timesyncd,
    wpa_supplicant
  Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:10 chip-ID: 8087:0033
    class-ID: e001
  Local Storage: total: 2.05 TiB used: 625.93 GiB (29.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 250GB
    size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QGXA7 temp: 32.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT2000BX500SSD1
    size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 061 scheme: GPT
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GH24NSD5 rev: LV00
    dev-links: cdrom
  Features: speed: 12 multisession: yes audio: yes dvd: yes
  ID-1: / raw-size: 232.59 GiB size: 227.88 GiB (97.98%)
    used: 138.55 GiB (60.8%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: 69e87da4-2969-48e1-a3e0-0ebaa56168f4
    used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: F1AE-DD88
  ID-3: /srv/nfs/data raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
    used: 487.38 GiB (26.6%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: data
    uuid: 9f9c8be8-cbd6-4e1f-bf8f-c02b8e6b7d9c
  Hub-2: 1-6:2 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 1-6.4:4 info: Canon CanoScan LiDE 110 type: <vendor specific>
    driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 500mA chip-ID: 04a9:1909 class-ID: ff00
  Hub-3: 1-9:3 info: Realtek RTS5411 Hub ports: 4 rev: 2.1
    chip-ID: 0bda:5411 class-ID: 0900
  Hub-4: 1-10:5 info: Microchip (formerly SMSC) USB 2.0 Hub ports: 4
    rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 2mA
    chip-ID: 0424:2514 class-ID: 0900
  Device-1: 1-10.1:7 info: Microsoft LifeCam VX-2000 type: video,audio
  Device-2: 1-10.3:9 info: Logitech Nano Receiver type: keyboard,mouse
    driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0
    chip-ID: 046d:c534 class-ID: 0301
  Device-3: 1-11:6 info: Integrated Express RGB LED Controller type: HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:5702 class-ID: 0300
  Device-4: 1-14:10 info: Intel AX211 Bluetooth type: bluetooth
    mode: 1.1 power: 100mA chip-ID: 8087:0033 class-ID: e001
  Hub-5: 2-0:1 info: super-speed hub ports: 9 rev: 3.1
  Hub-6: 2-8:2 info: Realtek Hub ports: 4 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 96mA
    chip-ID: 0bda:0411 class-ID: 0900
  System Temperatures: cpu: 33.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: 1846 pm: pacman pkgs: 1837 libs: 449
    tools: gnome-software,pamac,yay pm: flatpak pkgs: 9
    1: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    2: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    3: https://manjaro.ynh.ovh/stable/$repo/$arch
    4: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    5: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    6: https://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    7: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
    8: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 402
  1: cpu: 9.8% command: firefox pid: 5347 mem: 703.7 MiB (2.2%)
  2: cpu: 6.0% command: gnome-shell pid: 3328 mem: 270.2 MiB (0.8%)
  3: cpu: 4.5% command: firefox pid: 6458 mem: 322.6 MiB (1.0%)
  4: cpu: 4.0% command: firefox pid: 6149 mem: 324.7 MiB (1.0%)
  5: cpu: 3.6% command: firefox pid: 5791 mem: 117.9 MiB (0.3%)
  Memory top: 5 of 402
  1: mem: 703.7 MiB (2.2%) command: firefox pid: 5347 cpu: 9.8%
  2: mem: 632.6 MiB (1.9%) command: thunderbird pid: 3558 cpu: 1.0%
  3: mem: 324.7 MiB (1.0%) command: firefox pid: 6149 cpu: 4.0%
  4: mem: 322.6 MiB (1.0%) command: firefox pid: 6458 cpu: 4.5%
  5: mem: 270.2 MiB (0.8%) command: gnome-shell pid: 3328 cpu: 6.0%
  Processes: 402 Power: uptime: 52m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.4 GiB services: gsd-power,
    power-profiles-daemon, upowerd Init: systemd v: 260 default: graphical
    tool: systemctl
  Compilers: clang: 22.1.3 gcc: 15.2.1 alt: 14 Shell: Bash v: 5.3.9
    default: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.40
The inxi does not indicate a system issue to me (besides the usual no swap default install)
Can you elaborate what usual is for you.
  • Have you stuck with the defaults after installation?
  • Installed extra extensions?
  • Does the layout-switcher work and can you get back to a default?
To keep in mind:
  • Gnome updated to 50 and some extensions are not updated yet.
Thanks Hanzel for your answer.
Usually I see the desktop and the dock - right hand side.
As I mentionned the first reboot was ok. I observed the issue only the second time.
I didn’t install anything. Should I?
If the layout-switcher is the upper left button, it works but… I don’t see the dock and I have to use the layout-switcher again and again.
Well, maybe I just need to be patient.
In fact I saw after typing gnome-extensions-app that ALL extensions were inactivated - no idea why… Resetting dash to dock I was able to see the dock again.
The only issue left is that booting leads to the overview of all programs open. I have then to click the icon left of the top bar or press ESC. I can survive…
No, just asking.
It is a separate program that offer a few different way’s to use gnome with some extensions eg:
It seems to me that starting the computer with an empty session might help. Someone will no doubt explain how to do that; :eyes:
I’m in macOS currently, and don’t recall specifically where the setting to change lives.
Clearing the cache might also help:
  1. Logout
  2. Enter a TTY – Ctrl+Alt+F2 ↔ F7
  3. Login with your username and password
  4. Issue the following command to delete the ~./cache folder:
    rm -rf .cache
  5. Reboot your machine immediately: sudo reboot.
This is a safe action – any Cache content will rebuild itself as you continue use your computer.
