I just got done building an entirely new computer and wanted to stay with the Manjaro line. Trying to get the 5.1 surround audio to work. I have a Blue/Green/Orange audio plug setup on a Gigabyte A520I board with a new Ryzen 5 5600G setup. Under audio in Settings it is only showing the two front speakers. On my gaming system I actually have a config button to change it to 5.1 but for some reason this build doesn’t have that setting currently.
It is trying to put the Orange into the “input” area instead of configuring for an “output” so as to run it properly. I have all the jacks plugged into the correct lines.
Kernel: 5.15.32-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=40c5582b-9861-4f1d-bac1-bf3fec98488a rw quiet splash apparmor=1
Desktop: GNOME v: 41.5 tk: GTK v: 3.24.33 wm: gnome-shell dm: GDM v: 41.3
Type: Desktop Mobo: Gigabyte model: A520I AC v: x.x
serial: <superuser required> UEFI: American Megatrends LLC. v: F13
date: 07/08/2021
Info: model: AMD Ryzen 5 5600G with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 family: 0x19 (25) model-id: 0x50 (80) stepping: 0
microcode: 0xA50000C
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 2810 high: 3435 min/max: 1400/4464 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3435 2: 2994
3: 2395 4: 2395 5: 2394 6: 2993 7: 2884 8: 3053 9: 2625 10: 2395 11: 3165
12: 2994 bogomips: 93456
STIBP: always-on, RSB filling
Device-1: AMD Cezanne vendor: Gigabyte driver: amdgpu v: kernel pcie:
gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
active: HDMI-A-2 empty: DP-1,HDMI-A-1 bus-ID: 06:00.0 chip-ID: 1002:1638
class-ID: 0300
Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.1
compositor: gnome-shell driver: gpu: amdgpu display-ID: 0
Monitor-1: HDMI-A-2 model: Samsung built: 2011 res: 1920x1080 dpi: 305
gamma: 1.2 size: 160x90mm (6.3x3.54") diag: 184mm (7.2") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
OpenGL: renderer: AMD RENOIR (DRM 3.42.0 5.15.32-1-MANJARO LLVM 13.0.1)
v: 4.6 Mesa 21.3.8 direct render: Yes
Device-1: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 06:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD Family 17h/19h HD Audio vendor: Gigabyte
link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.6 chip-ID: 1022:15e3
class-ID: 0403
Sound Server-1: ALSA v: k5.15.32-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.49 running: no
Device-1: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0
chip-ID: 8086:24fb class-ID: 0280
IF: wlp3s0 state: down mac: <filter>
lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-8:3 chip-ID: 8087:0aa7 class-ID: e001
Local Storage: total: 238.47 GiB used: 12.67 GiB (5.3%)
model: MZVLB256HBHQ-000L7 size: 238.47 GiB block-size: physical: 512 B
rev: 5M2QEXH7 temp: 32.9 C scheme: GPT
ID-1: / raw-size: 238.17 GiB size: 233.38 GiB (97.99%)
used: 12.67 GiB (5.4%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 16.8 C mobo: N/A gpu: amdgpu temp: 27.0 C
Processes: 306 Uptime: 0m wakeups: 0 Memory: 15.08 GiB
used: 1.13 GiB (7.5%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1147 lib: 304 flatpak: 0
Shell: Zsh v: 5.8.1 running-in: gnome-terminal inxi: 3.3.15
