I have installed Manjaro, Ubuntu and Win11 in that order on my system.
Grub bootloader correctly shows all three OS, I can load into any of them so everything is working fine.
It’s just irking me to change the order of appearance in the menu, it is currently as follows:
Manjaro
(Manjaro advanced options)
Windows
Ubuntu
(Ubuntu advanced options)
memtest
Is there any way I can edit /boot/grub/grub.cfg so that I can move Windows to a different location on the list? I am not comfortable using vi which is the only way I can open the file on KDE Plasma. I saw what I need to change in the file, I just do not know how to actually edit it as the file is locked.
I suspect it is because of alphabetical order in efi partition - Manjaro, Microsoft, Ubuntu
I tried efibootmgr --bootorder but still no effect
for no reapply all week…
create a pacman hook as mkinitcpio ?
(model : /usr/share/libalpm/hooks/90-mkinitcpio-install.hook)
etc/pacman.d/hooks/91-grub-modif.hook
