BeOS
1
Hi all,
My tray icons look a bit maligned:
I think the Caffeine icon is the culprit. How can I choose an alternative pair of icons for Caffeine that have the same height for different states?
Also is there an option to make all system tray icons rendered in monochrome/grayscale?
Thanks.
Replacing Gnome Extension’s icon is hard.
I would search the extension’s source code and confirm it uses icon standard and loads icon from /usr/share/icons/....
and then copy them over ~/.local/share/icons/... and modify them there. Might work
but also might not depends how the extension is made.
There might be a pixel off
Have you tried disabling extensions one by one, see if that influences the way tray looks? Also, are you on Wayland or X11 ?
BeOS
4
X11. A few of them are off by 1 pixel. The network icon has the same problem. When seen cannot be unseen!
