Transmission-gtk crashes within a minute of starting it
Transmission (gtk) crashes after within a minute of starting it. Nothing in the log files… gdb shows this
Thread 7 "transmission-gt" received signal SIGPIPE, Broken pipe.
[Switching to Thread 0x7fffe89ba6c0 (LWP 5960)]
0x00007ffff5b2810b in writev () from /usr/lib/libc.so.6
(gdb) bt
#0  0x00007ffff5b2810b in writev () from /usr/lib/libc.so.6
#1  0x00007ffff7f03847 in evbuffer_write_iovec (buffer=buffer@entry=0x7fffd2c9e790, fd=fd@entry=125, howmuch=0, howmuch@entry=318)
    at /usr/src/debug/libevent/libevent-2.1.12-stable/buffer.c:2460
#2  0x00007ffff7f08173 in evbuffer_write_atmost (buffer=0x7fffd2c9e790, fd=125, howmuch=318)
    at /usr/src/debug/libevent/libevent-2.1.12-stable/buffer.c:2546
#3  0x00005555556cd0a0 in libtransmission::Buffer::to_socket (this=0x7fffd2c9e498, sockfd=125, n_bytes=318, error=0x7fffe89b3058)
    at /usr/src/debug/transmission/transmission-4.0.6/libtransmission/tr-buffer.h:272
#4  tr_peer_socket::try_write (this=0x7fffd2c9e188, buf=..., max=318, error=0x7fffe89b3058)
    at /usr/src/debug/transmission/transmission-4.0.6/libtransmission/peer-socket.cc:82
#5  tr_peerIo::try_write (this=0x7fffd2c9df20, max=318) at /usr/src/debug/transmission/transmission-4.0.6/libtransmission/peer-io.cc:290
#6  0x00005555556c08d2 in tr_peerIo::flush (limit=3000, this=<optimized out>, dir=TR_CLIENT_TO_PEER)
    at /usr/src/debug/transmission/transmission-4.0.6/libtransmission/peer-io.cc:539
#7  tr_bandwidth::phaseOne (peers=..., dir=<optimized out>)
    at /usr/src/debug/transmission/transmission-4.0.6/libtransmission/bandwidth.cc:188
#8  0x00005555556dbacf in tr_bandwidth::allocate (period_msec=500, this=<optimized out>)
    at /usr/src/debug/transmission/transmission-4.0.6/libtransmission/bandwidth.cc:245
#9  tr_peerMgr::bandwidthPulse (this=0x555555a92d30) at /usr/src/debug/transmission/transmission-4.0.6/libtransmission/peer-mgr.cc:2231
#10 tr_peerMgr::tr_peerMgr(tr_session*)::{lambda()#1}::operator()() const (__closure=<optimized out>)
    at /usr/src/debug/transmission/transmission-4.0.6/libtransmission/peer-mgr.cc:689
#11 std::__invoke_impl<void, tr_peerMgr::tr_peerMgr(tr_session*)::{lambda()#1}&>(std::__invoke_other, tr_peerMgr::tr_peerMgr(tr_session*)::{lambda()#1}&) (__f=...) at /usr/include/c++/14.1.1/bits/invoke.h:61
#12 std::__invoke_r<void, tr_peerMgr::tr_peerMgr(tr_session*)::{lambda()#1}&>(tr_peerMgr::tr_peerMgr(tr_session*)::{lambda()#1}&) (
    __fn=...) at /usr/include/c++/14.1.1/bits/invoke.h:111
--Type <RET> for more, q to quit, c to continue without paging--
#13 std::_Function_handler<void (), tr_peerMgr::tr_peerMgr(tr_session*)::{lambda()#1}>::_M_invoke(std::_Any_data const&) (__functor=...)
    at /usr/include/c++/14.1.1/bits/std_function.h:290
#14 0x00007ffff7f17c45 in event_persist_closure (ev=<optimized out>, base=0x555555b416e0)
    at /usr/src/debug/libevent/libevent-2.1.12-stable/event.c:1623
#15 event_process_active_single_queue (base=base@entry=0x555555b416e0, activeq=0x555555b56790,
    max_to_process=max_to_process@entry=2147483647, endtime=endtime@entry=0x0)
    at /usr/src/debug/libevent/libevent-2.1.12-stable/event.c:1682
#16 0x00007ffff7f193af in event_process_active (base=0x555555b416e0) at /usr/src/debug/libevent/libevent-2.1.12-stable/event.c:1783
#17 event_base_loop (base=0x555555b416e0, flags=4) at /usr/src/debug/libevent/libevent-2.1.12-stable/event.c:2006
#18 0x00005555556f2b5e in tr_session_thread_impl::sessionThreadFunc (this=0x555555a8e8a0, evbase=0x555555b416e0)
    at /usr/src/debug/transmission/transmission-4.0.6/libtransmission/session-thread.cc:245
#19 0x00007ffff5ce1cf4 in std::execute_native_thread_routine (__p=0x555555b4c8e0)
    at /usr/src/debug/gcc/gcc/libstdc++-v3/src/c++11/thread.cc:104
#20 0x00007ffff5aa339d in ?? () from /usr/lib/libc.so.6
#21 0x00007ffff5b2849c in ?? () from /usr/lib/libc.so.6
(gdb) quit
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
Arch patched curl to fix this this a few days ago. 8.9.1-2 is only available on Manjaro unstable branch right now.
When I couldn’t find a journal or log entry, or even a terminal output I was a bit lost till I found this post. Just installed gdb, but it doesn’t seem to get recognized by the system (command not found, didn’t try a reboot yet). Do you have a good resource on how to use gdb?
So what is the turnover time, when might we see the patch in stable? Is there a way to install a single package from unstable?
gdb needs debug symbols
all the “normal” packages are stripped - even if they where initially compiled with debug info.
no chance using it
you would need to build the software yourself - and allow and/or keep the debug info
no one else has got this problem - it’s not a problem with the software
rather it is with your machine setup and/or configuration
I never understood the trouble people have understanding the implications of deliberately holding back updates (Manjaro stable) vs just using the original (Arch or Manjaro unstable).
I’m sure this is fixable, but when I’ve to compile the source to use it I might not use it.
I don’t have a problem that packages get tested before being put into stable. That is the main reason I use Manjaro and not Arch. My question was what the turnover time is. I thought about 2 weeks, but I’m not sure.
:man_shrugging:
Simply downloading the package and installing it will work. In general don’t do this but it’s safe to do in this particular case.
https://ftp.halifax.rwth-aachen.de/manjaro/unstable/core/x86_64/curl-8.9.1-2-x86_64.pkg.tar.zst
Nice, simple, temporary fix! Thank you!
Will help anybody hoe is looking for an answer in this particular case and for those who don’t have the time to fumble around for hours.
curl 8.9.1-2 has been released to Testing branch - [Testing Update] 2024-08-16
