A few months ago, an update changed something in the rendering of Transmission (dark theme) on my old Manjaro Cinnamon install. The hover popups are now written in white on yellow background, which is almost impossible for me to read.
Now I have no idea if that’s because I’m using an old (up-to-date) install or if it’s something I have broken somehow.
Could anyone using Manjaro Cinnamon tell me if it’s working for them? Thank you.
I’ve tried transmission-qt and both qgnomeplatform with no luck.
I then changed my theme from Mint-Y-Dark-Teal to something else and it worked. It seems that all Mint-Y-Dark give me this white/yellow color on popups.
I’ve found where the background color is set: /usr/share/themes/Mint-Y-Dark-Teal/gtk-4.0/gtk.css
The tooltip background is yellow and the front color is supposed to be dark grey, but in Transmission the front color is white (probably not using the tooltip front color at all).
I’ve swapped both colors and now it works: Transmission’s tooltips are white on dark grey background and I guess it will be yellow on grey for the other apps, which is fine.
Actually, I just installed Transmission on my system and it does the same thing, it would appear to be a bug in transmission. I personally use deluge-gtk, may be an alternative for you.
Sorry, I haven’t seen your previous message in time.
That wasn’t clear for me.
Here are the two relevant blocks in gtk.css
Line #1
.background {
color: rgba(255, 255, 255, 0.87); // <-- this is the text color used in Transmission
background-color: rgba(56, 56, 56, 0.999); }
and (line #2876)
tooltip {
color: #4a4a4a;
border-radius: 2px;
border: 1px solid #d0d0d0; }
tooltip.background {
background-color: #fbeaa0; // <-- This is the background color used in Transmission
background-clip: padding-box; }
tooltip.background label {
padding: 4px; }
The front and back colors are taken from different blocks, so I guess it’s only “luck” if it works with another theme. I may still be wrong but I don’t think it hurts asking the devs about it.
