Transition to new mirror structure
Hi all.
I just wanted to let all of you know, that Manjaro ARM is transitioning to a Boxit Server, which requires a new mirror structure.
So I have uploaded a new pacman-mirrorlist package to the repo, which contains mirrors with this new structure:
sudo pacman -U http://ftp-osl.osuosl.org/pub/manjaro-arm/repo/stable/aarch64/core/pacman-mirrorlist-20200211-1-any.pkg.tar.xz
This does however mean, that it's likely you will begin to see some 404 errors from the mirror you are connected to, prior to this package update.
Don't be alarmed about it. Just install the pacman-mirrorlist update.
This should put you on the new mirrors.
This also means that, going forward, we have branches, just like Manjaro x64.
Current and new installs will be set to Stable branch by default, so updates will happen in batches, just like on Manjaro x64.
If you want to help out testing the packages before they hit Stable, we recommend you switch branch to testing. If you like living on the edge and get packages without testing, you can switch to unstable branch. :slight_smile:
Hi,
I update C2 And N2, something go wrong with the lsb-release
error: validation of the transaction failed (file conflict)
lsb-release: / etc / lsb-release is already present in the file system (belonging to manjaro-release)
Errors have occurred, no package has been updated
[nicolas@nls-pc ~]$ ssh nlc2@x.x.x.x
nlc2@x.x.x.x's password:
Welcome to Manjaro-ARM
~~Website: https://manjaro.org
~~Forum:   https://forum.manjaro.org/c/manjaro-arm
~~IRC:     #manjaro-arm on irc.freenode.net
~~Matrix:  #manjaro-arm-public:matrix.org
Last login: Tue Feb 11 11:21:52 2020 from x.x.x.x
[nlc2@c2 ~]$ sudo pacman -Syu
[sudo] Mot de passe de nlc2 :
:: Synchronisation des bases de données de paquets…
erreur : échec de récupération du fichier « core.db » depuis manjaro-arm.moson.org : The requested URL returned error: 404
erreur : échec de récupération du fichier « core.db » depuis smail.net.pl : The requested URL returned error: 404
erreur : échec de récupération du fichier « core.db » depuis manjaro-arm.moson.eu : The requested URL returned error: 404
erreur : échec de récupération du fichier « core.db » depuis natrox.jp : The requested URL returned error: 404
 core                                219,4 KiB   708 KiB/s 00:00 [####################################] 100%
erreur : échec de récupération du fichier « extra.db » depuis manjaro-arm.moson.org : The requested URL returned error: 404
erreur : échec de récupération du fichier « extra.db » depuis smail.net.pl : The requested URL returned error: 404
erreur : échec de récupération du fichier « extra.db » depuis manjaro-arm.moson.eu : The requested URL returned error: 404
erreur : échec de récupération du fichier « extra.db » depuis natrox.jp : The requested URL returned error: 404
 extra est Ă  jour
erreur : échec de récupération du fichier « community.db » depuis manjaro-arm.moson.org : The requested URL returned error: 404
erreur : échec de récupération du fichier « community.db » depuis smail.net.pl : The requested URL returned error: 404
erreur : échec de récupération du fichier « community.db » depuis manjaro-arm.moson.eu : The requested URL returned error: 404
erreur : échec de récupération du fichier « community.db » depuis natrox.jp : The requested URL returned error: 404
 community est Ă  jour
:: Début de la mise à jour complète du système…
avertissement : lilv : la version locale (0.24.6-2) est plus récente que extra (0.22.0-2)
avertissement : serd : la version locale (0.30.2-1) est plus récente que extra (0.22.0-1)
avertissement : sord : la version locale (0.16.4-1) est plus récente que extra (0.14.0-1)
avertissement : sratom : la version locale (0.6.4-1) est plus récente que extra (0.4.6-1)
avertissement : suil : la version locale (0.10.6-2) est plus récente que extra (0.8.2-2)
résolution des dépendances…
recherche des conflits entre paquets…
Paquet (1)              Ancienne version  Nouvelle version  Changement net  Taille du téléchargement
core/pacman-mirrorlist  20200128-1        20200211-1              0,00 MiB                  0,03 MiB
Taille totale du téléchargement :  0,03 MiB
Taille totale installée :        0,09 MiB
Taille de mise Ă  jour nette :    0,00 MiB
:: Procéder à l’installation ? [O/n] o
:: Récupération des paquets…
erreur : échec de récupération du fichier « pacman-mirrorlist-20200211-1-any.pkg.tar.xz » depuis manjaro-arm.moson.org : The requested URL returned error: 404
erreur : échec de récupération du fichier « pacman-mirrorlist-20200211-1-any.pkg.tar.xz » depuis smail.net.pl : The requested URL returned error: 404
erreur : échec de récupération du fichier « pacman-mirrorlist-20200211-1-any.pkg.tar.xz » depuis manjaro-arm.moson.eu : The requested URL returned error: 404
erreur : échec de récupération du fichier « pacman-mirrorlist-20200211-1-any.pkg.tar.xz » depuis natrox.jp : The requested URL returned error: 404
 pacman-mirrorlist-20200211-1-any     33,7 KiB   841 KiB/s 00:00 [####################################] 100%
(1/1) vérification des clés dans le trousseau                    [####################################] 100%
(1/1) vérification de l’intégrité des paquets                    [####################################] 100%
(1/1) chargement des fichiers des paquets                        [####################################] 100%
(1/1) analyse des conflits entre fichiers                        [####################################] 100%
(1/1) vérification de l’espace disque disponible                 [####################################] 100%
:: Traitement des changements du paquet…
(1/1) mise Ă  jour de pacman-mirrorlist                           [####################################] 100%
:: Querying servers, this may take some time...
Australia
Denmark
-> 0.213 https://mirrors.dotsrc.org/manjaro-arm/stable/$repo/$arch
Germany
-> 0.194 https://manjaro-arm.moson.eu/stable/$repo/$arch
-> 0.185 https://smail.net.pl/manjaro-arm/stable/$repo/$arch
-> 0.252 https://manjaro-arm.moson.org/stable/$repo/$arch
Japan
Switzerland
United_States
-> 0.703 https://manjaro-arm.ericlay.online/stable/$repo/$arch
:: Generated and saved '/etc/pacman.d/mirrorlist' mirrorlist.
hint: use `pacman-mirrors` to generate and update your pacman mirrorlist.
:: Exécution des crochets de post-transaction…
(1/1) Arming ConditionNeedsUpdate...
 core est Ă  jour
 extra                                 2,3 MiB  2037 KiB/s 00:01 [####################################] 100%
 community                             4,9 MiB  2,08 MiB/s 00:02 [####################################] 100%
avertissement : nombre de colonnes disponibles insuffisant pour afficher la table
Paquets (77) attica-5.67.0-1  audacity-1:2.3.3-2  baloo-5.67.0-1  bluez-qt-5.67.0-1  breeze-icons-5.67.0-1
             frameworkintegration-5.67.0-1  kactivities-5.67.0-1  kactivities-stats-5.67.0-1
             karchive-5.67.0-1  kauth-5.67.0-1  kbookmarks-5.67.0-1  kcmutils-5.67.0-1  kcodecs-5.67.0-1
             kcompletion-5.67.0-1  kconfig-5.67.0-1  kconfigwidgets-5.67.0-2  kcoreaddons-5.67.0-1
             kcrash-5.67.0-1  kdbusaddons-5.67.0-1  kdeclarative-5.67.0-1  kded-5.67.0-1
             kdelibs4support-5.67.0-2  kdesu-5.67.0-1  kdnssd-5.67.0-1  kemoticons-5.67.0-1
             kfilemetadata-5.67.0-1  kglobalaccel-5.67.0-1  kguiaddons-5.67.0-1  kholidays-1:5.67.0-1
             ki18n-5.67.0-1  kiconthemes-5.67.0-1  kidletime-5.67.0-1  kinit-5.67.0-1  kio-5.67.0-1
             kirigami2-5.67.1-1  kitemmodels-5.67.0-1  kitemviews-5.67.0-1  kjobwidgets-5.67.0-1
             kjs-5.67.0-1  knewstuff-5.67.0-1  knotifications-5.67.0-1  knotifyconfig-5.67.0-1
             kpackage-5.67.0-1  kparts-5.67.0-1  kpeople-5.67.0-1  kpmcore-4.1.0-1  kpty-5.67.0-1
             krunner-5.67.0-1  kservice-5.67.0-1  ktexteditor-5.67.0-1  ktextwidgets-5.67.0-1
             kunitconversion-5.67.0-1  kwallet-5.67.0-1  kwayland-5.67.0-1  kwidgetsaddons-5.67.0-1
             kwindowsystem-5.67.0-1  kxmlgui-5.67.0-1  libinput-1.15.1-1  libusbmuxd-2.0.1-1
             lsb-release-1.4-15  modemmanager-qt-5.67.0-1  ncdu-1.14.2-1  networkmanager-qt-5.67.0-1
             pango-1:1.44.7+11+g73b46b04-1  partitionmanager-4.1.0-1  plasma-framework-5.67.0-1
             prison-5.67.0-1  purpose-5.67.0-1  qqc2-desktop-style-5.67.1-1  qt5-base-5.14.1-2
             sane-1.0.29-1  solid-5.67.0-1  sonnet-5.67.0-1  syntax-highlighting-5.67.0-1
             threadweaver-5.67.0-1  tlp-1.3.1-2  xf86-video-fbturbo-git-199.f9a6ed7-4.1
Taille totale du téléchargement :   90,56 MiB
Taille totale installée :        397,96 MiB
Taille de mise Ă  jour nette :      2,33 MiB
 libinput-1.15.1-1-aarch64           232,0 KiB  1657 KiB/s 00:00 [####################################] 100%
 qt5-base-5.14.1-2-aarch64            12,0 MiB  2,07 MiB/s 00:06 [####################################] 100%
 attica-5.67.0-1-aarch64             540,3 KiB  2,03 MiB/s 00:00 [####################################] 100%
 pango-1:1.44.7+11+g73b46b04-1-...   507,1 KiB  2029 KiB/s 00:00 [####################################] 100%
 ki18n-5.67.0-1-aarch64             1384,7 KiB  2,05 MiB/s 00:01 [####################################] 100%
 karchive-5.67.0-1-aarch64           361,3 KiB  2007 KiB/s 00:00 [####################################] 100%
 kconfig-5.67.0-1-aarch64            923,4 KiB  2007 KiB/s 00:00 [####################################] 100%
 kcoreaddons-5.67.0-1-aarch64       1157,3 KiB  2,02 MiB/s 00:01 [####################################] 100%
 kfilemetadata-5.67.0-1-aarch64      363,0 KiB  2017 KiB/s 00:00 [####################################] 100%
 kidletime-5.67.0-1-aarch64          130,7 KiB  2,13 MiB/s 00:00 [####################################] 100%
 libusbmuxd-2.0.1-1-aarch64           25,8 KiB  2,52 MiB/s 00:00 [####################################] 100%
 solid-5.67.0-1-aarch64              811,6 KiB  2,03 MiB/s 00:00 [####################################] 100%
 kwidgetsaddons-5.67.0-1-aarch64       4,4 MiB  2,07 MiB/s 00:02 [####################################] 100%
 kjobwidgets-5.67.0-1-aarch64        284,7 KiB  2034 KiB/s 00:00 [####################################] 100%
 kdbusaddons-5.67.0-1-aarch64        208,5 KiB  1896 KiB/s 00:00 [####################################] 100%
 kwindowsystem-5.67.0-1-aarch64      721,8 KiB  2,07 MiB/s 00:00 [####################################] 100%
 kcrash-5.67.0-1-aarch64             112,1 KiB  1602 KiB/s 00:00 [####################################] 100%
 kglobalaccel-5.67.0-1-aarch64       238,8 KiB  2,12 MiB/s 00:00 [####################################] 100%
 kauth-5.67.0-1-aarch64              306,1 KiB  1801 KiB/s 00:00 [####################################] 100%
 kcodecs-5.67.0-1-aarch64            332,1 KiB  1954 KiB/s 00:00 [####################################] 100%
 kguiaddons-5.67.0-1-aarch64         252,0 KiB  1938 KiB/s 00:00 [####################################] 100%
 kconfigwidgets-5.67.0-2-aarch64     938,2 KiB  2,08 MiB/s 00:00 [####################################] 100%
 kitemviews-5.67.0-1-aarch64         560,2 KiB  2,03 MiB/s 00:00 [####################################] 100%
 kiconthemes-5.67.0-1-aarch64        483,8 KiB  2016 KiB/s 00:00 [####################################] 100%
 kxmlgui-5.67.0-1-aarch64           1519,5 KiB  2,01 MiB/s 00:01 [####################################] 100%
 kbookmarks-5.67.0-1-aarch64         472,0 KiB  2,10 MiB/s 00:00 [####################################] 100%
 knotifications-5.67.0-1-aarch64     400,9 KiB  2,06 MiB/s 00:00 [####################################] 100%
 kservice-5.67.0-1-aarch64           658,5 KiB  1995 KiB/s 00:00 [####################################] 100%
 kwallet-5.67.0-1-aarch64            469,7 KiB  2,08 MiB/s 00:00 [####################################] 100%
 kcompletion-5.67.0-1-aarch64        648,2 KiB  2,11 MiB/s 00:00 [####################################] 100%
 sonnet-5.67.0-1-aarch64             587,4 KiB  2025 KiB/s 00:00 [####################################] 100%
 ktextwidgets-5.67.0-1-aarch64       764,6 KiB  2,07 MiB/s 00:00 [####################################] 100%
 kio-5.67.0-1-aarch64                  6,7 MiB  2,06 MiB/s 00:03 [####################################] 100%
 baloo-5.67.0-1-aarch64              581,8 KiB  1939 KiB/s 00:00 [####################################] 100%
 bluez-qt-5.67.0-1-aarch64           829,0 KiB  2022 KiB/s 00:00 [####################################] 100%
 breeze-icons-5.67.0-1-any             9,8 MiB  2,07 MiB/s 00:05 [####################################] 100%
 kpackage-5.67.0-1-aarch64           336,4 KiB  2,05 MiB/s 00:00 [####################################] 100%
 knewstuff-5.67.0-1-aarch64         1588,3 KiB  2,07 MiB/s 00:01 [####################################] 100%
 frameworkintegration-5.67.0-1-...  1582,3 KiB  2,03 MiB/s 00:01 [####################################] 100%
 kactivities-5.67.0-1-aarch64        305,9 KiB  2040 KiB/s 00:00 [####################################] 100%
 kactivities-stats-5.67.0-1-aarch64  272,8 KiB  2,05 MiB/s 00:00 [####################################] 100%
 kdeclarative-5.67.0-1-aarch64       459,1 KiB  1913 KiB/s 00:00 [####################################] 100%
 kcmutils-5.67.0-1-aarch64           627,2 KiB  2023 KiB/s 00:00 [####################################] 100%
 kded-5.67.0-1-aarch64                53,9 KiB  1796 KiB/s 00:00 [####################################] 100%
 kunitconversion-5.67.0-1-aarch64    879,0 KiB  2,04 MiB/s 00:00 [####################################] 100%
 kitemmodels-5.67.0-1-aarch64        661,7 KiB  2,08 MiB/s 00:00 [####################################] 100%
 kemoticons-5.67.0-1-aarch64        1848,4 KiB  2,07 MiB/s 00:01 [####################################] 100%
 kparts-5.67.0-1-aarch64             917,6 KiB  2,04 MiB/s 00:00 [####################################] 100%
 kdelibs4support-5.67.0-2-aarch64      3,1 MiB  2,08 MiB/s 00:02 [####################################] 100%
 kpty-5.67.0-1-aarch64               196,9 KiB  2,14 MiB/s 00:00 [####################################] 100%
 kdesu-5.67.0-1-aarch64              225,1 KiB  2047 KiB/s 00:00 [####################################] 100%
 kdnssd-5.67.0-1-aarch64             306,0 KiB  2,13 MiB/s 00:00 [####################################] 100%
 kholidays-1:5.67.0-1-aarch64        347,5 KiB  2044 KiB/s 00:00 [####################################] 100%
 kinit-5.67.0-1-aarch64              125,0 KiB  2,03 MiB/s 00:00 [####################################] 100%
 kirigami2-5.67.1-1-aarch64          321,0 KiB  2006 KiB/s 00:00 [####################################] 100%
 kjs-5.67.0-1-aarch64                355,5 KiB  1975 KiB/s 00:00 [####################################] 100%
 knotifyconfig-5.67.0-1-aarch64      199,1 KiB  1991 KiB/s 00:00 [####################################] 100%
 kpeople-5.67.0-1-aarch64            370,2 KiB  1948 KiB/s 00:00 [####################################] 100%
 kwayland-5.67.0-1-aarch64             2,7 MiB  2,07 MiB/s 00:01 [####################################] 100%
 plasma-framework-5.67.0-1-aarch64     3,8 MiB  2,07 MiB/s 00:02 [####################################] 100%
 threadweaver-5.67.0-1-aarch64       446,1 KiB  2,07 MiB/s 00:00 [####################################] 100%
 krunner-5.67.0-1-aarch64            310,4 KiB  2,17 MiB/s 00:00 [####################################] 100%
 syntax-highlighting-5.67.0-1-a...  1176,1 KiB  2,09 MiB/s 00:01 [####################################] 100%
 ktexteditor-5.67.0-1-aarch64          3,1 MiB  2034 KiB/s 00:02 [####################################] 100%
 modemmanager-qt-5.67.0-1-aarch64    549,9 KiB  2036 KiB/s 00:00 [####################################] 100%
 networkmanager-qt-5.67.0-1-aarch64 1732,8 KiB  2,06 MiB/s 00:01 [####################################] 100%
 prison-5.67.0-1-aarch64             139,4 KiB  1992 KiB/s 00:00 [####################################] 100%
 purpose-5.67.0-1-aarch64            311,4 KiB  1946 KiB/s 00:00 [####################################] 100%
 qqc2-desktop-style-5.67.1-1-aa...    63,7 KiB  2,07 MiB/s 00:00 [####################################] 100%
 sane-1.0.29-1-aarch64                 3,4 MiB  2,05 MiB/s 00:02 [####################################] 100%
 audacity-1:2.3.3-2-aarch64            5,5 MiB  2,08 MiB/s 00:03 [####################################] 100%
 kpmcore-4.1.0-1-aarch64             554,3 KiB  2,08 MiB/s 00:00 [####################################] 100%
 lsb-release-1.4-15-any                8,1 KiB   809 KiB/s 00:00 [####################################] 100%
 ncdu-1.14.2-1-aarch64                39,6 KiB  1982 KiB/s 00:00 [####################################] 100%
 partitionmanager-4.1.0-1-aarch64   1522,3 KiB  2030 KiB/s 00:01 [####################################] 100%
 tlp-1.3.1-2-any                      62,5 KiB  2,03 MiB/s 00:00 [####################################] 100%
 xf86-video-fbturbo-git-199.f9a...    25,9 KiB  2,53 MiB/s 00:00 [####################################] 100%
(77/77) vérification des clés dans le trousseau                  [####################################] 100%
(77/77) vérification de l’intégrité des paquets                  [####################################] 100%
(77/77) chargement des fichiers des paquets                      [####################################] 100%
(77/77) analyse des conflits entre fichiers                      [####################################] 100%
erreur : la validation de la transaction a échoué (conflit de fichiers)
lsb-release : /etc/lsb-release est déjà présent dans le système de fichiers (appartenant à manjaro-release)
Des erreurs se sont produites, aucun paquet n’a été mis à jour
Yeah. The lsb-release package update should be ignored. We supply the lsb-release files as part of the manjaro-release package. It just slipped through to the new mirrors.
Thanks for your message, what is the solution to solve this issue ?
It's ok, I uninstalled the lsb package, the update is now working well :slight_smile:
Hopefully I will manage to get it right in the repo at some point. :wink:
If for whatever reason, you've managed to mangle the mirrorlist package before getting the updated version (cough, cleared the cache, cough), here is a direct link: http://ftp-osl.osuosl.org/pub/manjaro-arm/repo/stable/aarch64/core/pacman-mirrorlist-20200211-1-any.pkg.tar.xz
Install, update the mirrors (in my case for unstable) and just wait for the packages to be updated :smile:
Thanks, @Strit!
To make it a little more obvious you can use
The mirrorlist package seems to have moved since this post:
https://ftp-osl.osuosl.org/pub/manjaro-arm/repo/stable/core/aarch64/pacman-mirrorlist-20200213-2-any.pkg.tar.xz
Yeah. The OSL mirror has also now updated to the new structure. :slight_smile:
