after today system upgrade i cannot work with tradingview anymore. its crashed all the time…
never heard of it - if it is a thirdparty tool installed using a custom script - rebuild the package using your custom script.
uh, it’s from AUR and precompiled binaries… i see today electron is upgrade so ill try do downgrade this packages
[2024-10-10T08:51:18+0200] [ALPM] upgraded electron30 (30.5.0-1 → 30.5.1-1)
[2024-10-10T08:51:19+0200] [ALPM] upgraded electron32 (32.0.2-1 → 32.1.0-1)
but no packages to downgrade
(there are not in local cache also)
sudo pacman -S electron30=30.5.0-1 electron32=32.0.1-1
error: package electron30=30.5.0-1 not found
error: package electron32=32.0.1-1 not found
not only TV crashes…
systemd-coredump[3742]: Process 1917 (vivaldi-bin) of user 1000 terminated abnormally with signal 11/SEGV, processing…
It may still need rebuilding as it has dependencies that are not included with the binary: (electron30 gcc-libs glib2 glibc libsecret). As at least one of those dependencies has been updated (electron) the binary may need to be rebuilt on your system.
pamac info tradingview ✔
Version : 2.9.2-1
Description : A charting platform for traders and investors
URL : https://www.tradingview.com/desktop/
Licenses : LicenseRef-TradingView
Repository : AUR
Groups : --
Depends On : electron30 gcc-libs glib2 glibc libsecret
Optional Dependencies : libappindicator-gtk3 [Installed]
Make Dependencies : links
Check Dependencies : --
Provides : --
Replaces : --
Conflicts With : --
Maintainer : inetol
First Submitted : Sat 19 Nov 2022 07:45:58
Last Modified : Mon 07 Oct 2024 21:21:14
Votes : 28
Out of Date : --
yeah, so i’ll report this to TV support and i’ll wait for new version.
