Been going on for about 6 weeks. Only recently looked for errors in journal (see below). Happens with all kernels from 6.7 to as far back as 5.15; didn’t check any further back.
Jan 22 09:30:06 tom-pc systemd-modules-load[195]: Failed to insert module 'tp_smapi': Exec format error
Jan 22 09:30:06 tom-pc systemd[1]: Failed to start Load Kernel Modules.
░░ Subject: A start job for unit systemd-modules-load.service has failed
░░ Defined-By: systemd
░░ A start job for unit systemd-modules-load.service has finished with a failure.
░░ The job identifier is 5 and the job result is failed.
Jan 22 09:30:09 tom-pc systemd-modules-load[533]: Failed to insert module 'tp_smapi': Exec format error
Jan 22 09:30:09 tom-pc systemd[1]: Failed to start Load Kernel Modules.
░░ The job identifier is 150 and the job result is failed.
Jan 22 09:30:10 tom-pc systemd-modules-load[592]: Failed to insert module 'tp_smapi': Exec format error
Jan 22 09:30:10 tom-pc systemd[1]: Failed to start Load Kernel Modules.
░░ The job identifier is 233 and the job result is failed.
One of the purposes of the package is to activate & utilize the battery charging limits. I now run my laptop without the battery to prevent damage by constantly charging to maximum.
Some weeks ago i run into the same problem on an old Thinkpad X201. It seems that these precompiled modules in the Manjaro extra repository are broken. I then tested the tp_smapi-dkms package from AUR, which solves the problem for me.
Your solution does work, thanks again. I hope they “fix” the modules in the extra repository so I don’t have to do this every time I run a different kernel. Another temporary fix to remember.
FYI - The solution offered by TheInvisible does work so I suspect he’s right about the tp_smapi kernel modules in the extra repository being the problem. Most people affected by this may not even realize they have a problem because their system is working. Thanks for your help.
Same here. I have a fleet of Thinkpad T410, gradually moving them over to manjaro. I chose this distro due to its tailored setup for thinkpads.
It would be great if the tp_smapi packages could be fixed!
The workaround with tp_smapi-dkms worked, after I installed the linux-headers (not in the default setup obviously)
