TP-Link TL-WN722N slow connection
inxi -Fxxxza --no-host:
  Kernel: 5.15.49-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
    root=UUID=231ca8af-6402-4a5e-8faa-828dd52024af rw quiet apparmor=1
  Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.5 info: latte-dock
    wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
  Type: Desktop Mobo: Gigabyte model: B450 AORUS ELITE v: x.x
    serial: <superuser required> UEFI: American Megatrends v: F31
    date: 04/15/2019
  Info: model: AMD Ryzen 7 1700 bits: 64 type: MT MCP arch: Zen
    built: 2017-19 process: GF 14nm family: 0x17 (23) model-id: 1 stepping: 1
    microcode: 0x8001137
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 768 KiB desc: d-8x32 KiB; i-8x64 KiB L2: 4 MiB desc: 8x512 KiB
    L3: 16 MiB desc: 2x8 MiB
  Speed (MHz): avg: 1688 high: 2627 min/max: 1550/3000 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2627 2: 1295
    3: 1488 4: 1834 5: 1375 6: 1375 7: 1375 8: 1375 9: 2494 10: 1294 11: 2593
    12: 2395 13: 1375 14: 1375 15: 1375 16: 1375 bogomips: 95849
  Type: spectre_v2
    mitigation: Retpolines, IBPB: conditional, STIBP: disabled, RSB filling
  Device-1: NVIDIA TU116 [GeForce GTX 1660] vendor: Gigabyte driver: nvidia
    v: 515.48.07 alternate: nouveau,nvidia_drm non-free: 515.xx+
    status: current (as of 2022-06) arch: Turing process: TSMC 12nm
    built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 07:00.0
    chip-ID: 10de:2184 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.3 compositor: kwin_x11 driver: X:
    loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 93 s-size: 524x292mm (20.63x11.50")
    s-diag: 600mm (23.62")
  Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 94
    size: 521x293mm (20.51x11.54") diag: 598mm (23.53") modes: N/A
  OpenGL: renderer: NVIDIA GeForce GTX 1660/PCIe/SSE2
    v: 4.6.0 NVIDIA 515.48.07 direct render: Yes
  Device-1: NVIDIA TU116 High Definition Audio vendor: Gigabyte
    driver: snd_hda_intel bus-ID: 5-3:3 v: kernel pcie: chip-ID: 3299:4e4a
    class-ID: 0300 gen: 3 speed: 8 GT/s serial: <filter> lanes: 16
    bus-ID: 07:00.1 chip-ID: 10de:1aeb class-ID: 0403
  Device-2: AMD Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 09:00.3
    chip-ID: 1022:1457 class-ID: 0403
  Device-3: Solid State System SPC Gear Viro USB 7.1 Sound type: USB
    driver: hid-generic,snd-usb-audio,usbhid
  Sound Server-1: ALSA v: k5.15.49-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.52 running: yes
    lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Device-2: TP-Link TL-WN722N v2/v3 [Realtek RTL8188EUS] type: USB
    driver: r8188eu bus-ID: 1-5:2 chip-ID: 2357:010c class-ID: 0000
    serial: <filter>
  IF: wlp2s0f0u5 state: up mac: <filter>
  Local Storage: total: 1.14 TiB used: 100.69 GiB (8.6%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Patriot model: Scorch M2
    size: 238.47 GiB block-size: physical: 512 B logical: 512 B
    speed: 15.8 Gb/s lanes: 2 type: SSD serial: <filter> rev: E8FM12.0
    temp: 36.9 C scheme: MBR
  ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: HDWD110
    size: 931.51 GiB block-size: physical: 4096 B logical: 512 B
    speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: A8R0
    scheme: GPT
  ID-1: / raw-size: 237.98 GiB size: 233.18 GiB (97.99%)
    used: 13.43 GiB (5.8%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-2: /boot/efi raw-size: 500.1 MiB size: 499.1 MiB (99.80%)
    used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-3: /home raw-size: 931.51 GiB size: 915.82 GiB (98.31%)
    used: 87.27 GiB (9.5%) fs: ext4 dev: /dev/sda1 maj-min: 8:1
  System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 52 C
  Processes: 377 Uptime: 3h 5m wakeups: 0 Memory: 11.63 GiB
  used: 4.63 GiB (39.8%) Init: systemd v: 251 default: graphical
  tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: 1320
  pacman: 1309 lib: 337 flatpak: 4 snap: 7 Shell: Zsh v: 5.9
  running-in: konsole inxi: 3.3.19
lsusb:
Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 005 Device 004: ID 1532:0241 Razer USA, Ltd BlackWidow (2019)
Bus 005 Device 003: ID 3299:4e4a Solid State System Co.,Ltd. SPC Gear Viro USB 7.1 Sound
Bus 005 Device 002: ID 258a:0036 SINOWEALTH Wired Gaming Mouse
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 14cd:1212 Super Top microSD card reader (SY-T18)
Bus 001 Device 005: ID 2357:010c TP-Link TL-WN722N v2/v3 [Realtek RTL8188EUS]
Everything works, but it’s very slow. I did some speedtests (from speedtest net) one on my pc, second on my dad’s laptop. My download was 6-7 times slower than on his Win10 device. What I should do?
you could try the 5.18 kernel and see if it improves the speed
rt or normal?
the normal one
It didn’t helped :confused: Upload is only 3 Mbps difference, but download over 60 Mbps. Have you got any new solutions?
yes, installing dkms drivers could help, but first post output from:
mhwd-kernel -li
here it is
Currently running: 5.18.6-1-MANJARO (linux518)
   * linux515
   * linux518
so create this file:
sudo nano /etc/modprobe.d/blacklist.conf
inside it put this line:
blacklist r8188eu
then press ctrl+x to save the file
install headers:
sudo pacman -S linux515-headers linux518-headers
install driver:
pamac build 8188eu-dkms-git
reboot and test wifi
Good news! Upload is +/- same and the download rised from 10 to 20 Mbps but its nothing compared to around 70 on laptop. Are there any next steps?
provide output from:
inxi -xn
    vendor: Gigabyte driver: r8169 v: kernel port: f000 bus-ID: 04:00.0
  IF: eno1 state: down mac: b4:2e:99:44:20:ad
    driver: rtl8188eu bus-ID: 1-6:2
  IF: wlp2s0f0u6 state: up mac: d0:37:45:09:b5:b6
Dev1 is unused, I’m 100% sure of that
Btw I did some more speedtesting, download is 30 Mbps!
output from this:
lspci -k | grep 8188
none
 ✘ pepee@manjaro  ~  lspci -k | grep 8188
ok so lets try different driver, remove this one:
pamac remove 8188eu-dkms-git
install this:
pamac build 8188eu-aircrack-dkms-git
reboot and test
After changing kernel back to 5.15 (lack of this driver for 5.18) download can hit 45 Mbps and system tray wifi icon have 4 lines, it just works. Thanks!
5.18 is just not working well with some wifi adapters and has not for a good minute now.
