Hello can you help me with some drivers for my wifi adapter?I cant find any good solutions yet…
Hello,
Most likely you need this package from AUR
https://aur.archlinux.org/packages/rtl8822bu-git/
From terminal:
sudo pacman -Syyu base-devel
and then run
pamac build rtl8822bu-git
and once that is done, reboot and test your WiFi.
It might be helpful to visit linux-hardware.org and look up the device by its PCI/USB/etc. identifier, and see what drivers others use. Then there’s a very high chance that those drivers are available in the AUR.
