Hi!
I’ve tried searchigf the forums and the general web, but to no avail. I got myslef a USB Wi-Fi adapter, TP-Link AX1800, and installed this AUR package AUR (en) - rtl8852au-dkms-git
The adapter works, but is much slower than expected. Its download speed on my 1Gb optical fibre net is about 100-120 Mb/s (the upload speed is much higher, 300-400 Mb/s), whereas on my mobile at the same spot the download speed is easily 300+ Mb/s and another PC in the room with a different card has about 500 Mb/s.
I tried kernels 6.6.65 and 6.12.4, but it doesn’t seem to make a difference.
My inxi -Fazy output (network section) is below. I’m surprised the adapter’s speed is listed as 480, because it’s connected via a USB 3.0 and supposedly supports that, but I don’t think this has anything to do with my problem, because I’m not nearing that speed anyway.
Yes, sorry if I wasn’t clear, but I connected the wi-fi adapter via a USB 3.0 cable to a USB 3.2 slot. I don’t understand why inxi thinks it’s 2.0. I tried another USB 3.2 slot and it was the same.
Indeed, it looks like it’s reported as 2.0, too. Confusing.
Bus 003 Device 002: ID 2357:013f TP-Link 802.11ac WLAN Adapter
Couldn't open device, some information will be missing
Negotiated speed: High Speed (480Mbps)
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 0 [unknown]
bDeviceSubClass 0 [unknown]
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x2357 TP-Link
idProduct 0x013f 802.11ac WLAN Adapter
bcdDevice 0.00
iManufacturer 1 Realtek
iProduct 2 802.11ac WLAN Adapter
iSerial 3 00e04c000001
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 0x004a
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 500mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 8
bInterfaceClass 255 Vendor Specific Class
bInterfaceSubClass 255 Vendor Specific Subclass
bInterfaceProtocol 255 Vendor Specific Protocol
iInterface 2
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x84 EP 4 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0200 1x 512 bytes
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x05 EP 5 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x06 EP 6 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x07 EP 7 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x09 EP 9 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x0a EP 10 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x0b EP 11 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x0c EP 12 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
But when I connected an external USB disk to the same slot, it does report it as 3.0, so it must be something with the adapter or the cable that was packaged with it, I think? Or could it be that the drivers are the cause somehow?
Bus 004 Device 002: ID 1058:0837 Western Digital Technologies, Inc. My Passport Ultra (WDBBKD)
Negotiated speed: SuperSpeed (5Gbps)
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 3.00
