Touchscreen stopped working after switching to `unstable` branch
Hi. I have an HP Pavilion x360 Convertible 14m-dw1xxx laptop with manjaro-gnome[wayland] and windows 10 dual-booted.
About a week ago I switched to the unstable branch to receive updates for a specific package and after restarting, my touchscreen stopped working completely. I switched branched manually by editing /etc/pacman.d/mirrorlist.
My touchscreen was and still works normally on my windows 10 so the problem is not related to hardware. I have been using the touchscreen on manjaro in the last year so it’s not like it’s incompatible with manjaro.
Also when using the 360 capability on the laptop (folding the screen to the back), the external keyboard and keyboard backlight automatically gets disabled. Unlike the touchscreen itself, this is not broken.
Things I Have Tried
After a couple days and not finding anything related on the internet and in journal, I switched back to the stable branch using instructions on the wiki. But surprisingly nothing changed.
I am currently on kenel linux619 but I have 612, 617 and 618 also installed and I tried all four and nothing changed.
The output of less /proc/bus/input/devices shows 16 entries where none of them are related to a touchscreen (which should mean the problem is related to the kernel and the driver right?). The output is posted below.
What should I do?
Thanks in advance.
N: Name="Lid Switch"
P: Phys=PNP0C0D/button/input0
S: Sysfs=/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:01/input/input0
U: Uniq=
H: Handlers=event0
B: PROP=0
B: EV=21
B: SW=1
I: Bus=0019 Vendor=0000 Product=0001 Version=0000
N: Name="Power Button"
P: Phys=PNP0C0C/button/input0
S: Sysfs=/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
U: Uniq=
H: Handlers=kbd event1
B: PROP=0
B: EV=3
B: KEY=8000 10000000000000 0
P: Phys=LNXPWRBN/button/input0
S: Sysfs=/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
U: Uniq=
H: Handlers=kbd event2
B: PROP=0
B: EV=3
I: Bus=0011 Vendor=0001 Product=0001 Version=ab83
N: Name="AT Translated Set 2 keyboard"
P: Phys=isa0060/serio0/input0
S: Sysfs=/devices/platform/i8042/serio0/input/input3
U: Uniq=
H: Handlers=sysrq kbd leds event3 rfkill
B: PROP=0
B: EV=120013
B: KEY=180000 20000 4000000000000020 0 0 10500f02140007 ff803078f900d401 feffffdfffcfffff fffffffffffffffe
B: MSC=10
B: LED=7
I: Bus=0019 Vendor=0000 Product=0006 Version=0000
N: Name="Video Bus"
P: Phys=LNXVIDEO/video/input0
S: Sysfs=/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input4
U: Uniq=
H: Handlers=kbd event4
B: PROP=0
B: EV=3
B: KEY=3e000b00000000 0 0 0
I: Bus=0019 Vendor=0000 Product=0000 Version=0000
N: Name="Wireless hotkeys"
P: Phys=HPQ6001/input0
S: Sysfs=/devices/virtual/input/input5
U: Uniq=
H: Handlers=kbd event5 rfkill
B: PROP=0
B: EV=3
B: KEY=80000000000000 0 0 0
N: Name="Intel HID events"
P: Phys=
S: Sysfs=/devices/platform/INT33D5:00/input/input6
U: Uniq=
H: Handlers=kbd event6 rfkill
B: PROP=0
B: EV=13
B: KEY=81000300000000 5000004000 1e294000000020 0
B: MSC=10
N: Name="Intel HID 5 button array"
P: Phys=
S: Sysfs=/devices/platform/INT33D5:00/input/input7
U: Uniq=
H: Handlers=kbd event7
B: PROP=0
B: EV=13
B: KEY=2000000000000 0 0 0 0 1000000000000 0 201c000000000000 0
B: MSC=10
I: Bus=0010 Vendor=001f Product=0001 Version=0100
N: Name="PC Speaker"
P: Phys=isa0061/input0
S: Sysfs=/devices/platform/pcspkr/input/input8
U: Uniq=
H: Handlers=kbd event8
B: PROP=0
B: EV=40001
B: SND=6
I: Bus=0018 Vendor=04f3 Product=3139 Version=0100
N: Name="ELAN0722:00 04F3:3139 Mouse"
P: Phys=i2c-ELAN0722:00
S: Sysfs=/devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-1/i2c-ELAN0722:00/0018:04F3:3139.0001/input/input12
U: Uniq=
H: Handlers=event9 mouse0
B: PROP=0
B: EV=17
B: KEY=30000 0 0 0 0
B: REL=3
B: MSC=10
N: Name="ELAN0722:00 04F3:3139 Touchpad"
S: Sysfs=/devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-1/i2c-ELAN0722:00/0018:04F3:3139.0001/input/input14
U: Uniq=
H: Handlers=event10 mouse1
B: PROP=5
B: EV=1b
B: KEY=e520 10000 0 0 0 0
B: ABS=2e0800000000003
B: MSC=20
N: Name="HP WMI hotkeys"
P: Phys=wmi/input0
S: Sysfs=/devices/virtual/input/input15
U: Uniq=
H: Handlers=kbd event11
B: PROP=0
B: EV=33
B: KEY=180000 20000 0 4000000000 0 101000700000000 2302400 0 0
B: MSC=10
B: SW=22
I: Bus=0000 Vendor=0000 Product=0000 Version=0000
N: Name="sof-hda-dsp Mic"
P: Phys=ALSA
S: Sysfs=/devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0/input16
U: Uniq=
H: Handlers=event12
B: PROP=0
B: EV=21
B: SW=10
N: Name="sof-hda-dsp Headphone"
P: Phys=ALSA
S: Sysfs=/devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0/input17
U: Uniq=
H: Handlers=event13
B: PROP=0
B: EV=21
B: SW=4
N: Name="sof-hda-dsp HDMI/DP,pcm=3"
P: Phys=ALSA
S: Sysfs=/devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0/input18
U: Uniq=
H: Handlers=event14
B: PROP=0
B: EV=21
B: SW=140
N: Name="sof-hda-dsp HDMI/DP,pcm=4"
P: Phys=ALSA
S: Sysfs=/devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0/input19
U: Uniq=
H: Handlers=event15
B: PROP=0
B: EV=21
B: SW=140
N: Name="sof-hda-dsp HDMI/DP,pcm=5"
P: Phys=ALSA
S: Sysfs=/devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0/input20
U: Uniq=
H: Handlers=event16
B: PROP=0
B: EV=21
B: SW=140
So to clarify: your touchscreen was working before switching to unstable from stable in the first place, but now attempting to switching back to stable no longer helps making it work again?
That is not how you switch branches, idk the behind mechanics but I’m sure there’s a reason for how to do it properly on the wiki. Anyways, seems You already found this when you switched back to stable but I think it’s too late now.
Chances are when you manually edited the sources and did an upgrade, some critical packages got removed due to wrongly configurating the branches and corresponding repos.
If you have backup (timeshift + btrfs snapshot or whatever else) try undoing your action to a point in time before you did the branch switch.
If you dont have any backups, then just try wiggling around branches by that guide, in order to put things back where they belong. If I were you, and being currently on unstable, then I’d do it in multiple steps, like, going testing first, do an allowing to downgrade (sudo pacman -Syuu), then lastly back to stable, and again allowing to downgrade.
If all fails, I know it hurts but: fresh reinstall.
Welcome to the forum! :waving_hand:
What package? :thinking:
Please help us help you:
While switching from stable to unstable, lots of packages where upgraded (unfortunately I didn’t take note of which) but I was specifically looking to update tor.
Thanks for responding. Yes you understood me correctly.
Yeah it’s probably where I messed up. Later when switching back I found it in the wiki but at first I just found the branch url and manually copied it.
Unfortunately I don’t have backups so I’m trying my best to avoid a fresh install.
The surprising thing for me is that the touchscreen is not recognized by the kernel at all. There’s no trace of any touchscreen in journalctl -b or anywhere else which indicates that the issue is related to the kernel.
You’re welcome. But we will need your system info, in order to help
Post output of inxi -zv8
output of inxi -zv8:
  Kernel: 6.19.0-rc1-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.19-x86_64
    root=UUID=60dc2a4d-cdf0-48b5-bdb9-531010324ac4 rw quiet splash
    udev.log_priority=3
  Desktop: GNOME v: 49.2 tk: GTK v: 3.24.51 wm: gnome-shell
    tools: gsd-screensaver-proxy avail: light-locker dm: 1: GDM v: 49.2
    2: LightDM v: 1.32.0 note: stopped Distro: Manjaro base: Arch Linux
  Type: Convertible System: HP product: HP Pavilion x360 Convertible
    14m-dw1xxx v: N/A serial: <filter> Chassis: type: 31 serial: <filter>
  Mobo: HP model: 87F4 v: 39.32 serial: <filter> part-nu: 1F4W5UA#ABA
    uuid: 51067a20-f52e-9947-ad2a-e19825aada4d Firmware: UEFI vendor: AMI
    v: F.41 date: 04/06/2022
  ID-1: BAT0 charge: 11 Wh (31.5%) condition: 34.9/34.9 Wh (100%)
    power: 11.1 W volts: 10.89 min: 11.55 model: Hewlett-Packard Primary
    type: Li-ion serial: <filter> charging: status: discharging cycles: 575
  System RAM: total: 8 GiB available: 7.4 GiB used: 2.64 GiB (35.7%)
    igpu: 60 MiB
  Device-1: Bottom - Slot 1 (left) type: DDR4 detail: synchronous
    size: 4 GiB speed: 3200 MT/s volts: curr: 1.2 min: 1.2 max: 1.2
    width (bits): data: 64 total: 64 manufacturer: Samsung
    part-no: M471A5244CB0-CWE serial: <filter>
  Device-2: Bottom - Slot 2 (right) type: DDR4 detail: synchronous
  Slot: 0 type: PCIe status: in use info: J6B2 length: long volts: 3.3
    bus-ID: 00:01.0
  Info: model: 11th Gen Intel Core i5-1135G7 socket: U3E1 bits: 64
    type: MT MCP arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
    process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
    microcode: 0xBC
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
    smt: enabled cache: L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB
    desc: 4x1.2 MiB L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 1002 min/max: 400/4200 base/boost: 2400/4200 scaling:
    driver: intel_pstate governor: powersave volts: 0.7 V ext-clock: 100 MHz
    cores: 1: 1002 2: 1002 3: 1002 4: 1002 5: 1002 6: 1002 7: 1002 8: 1002
    bogomips: 38707
    arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
    avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
    cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
    cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
    hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt invpcid
    lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b movdiri msr mtrr
    nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs
    pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdt_a rdtscp
    rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd sse sse2
    tsc_deadline_timer tsc_known_freq umip user_shstk vaes vme vmx vnmi
    vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology
    xtpr
  Type: indirect_target_selection mitigation: Aligned branch/return thunks
    conditional; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
  Type: vmscape status: Not affected
  Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Hewlett-Packard
    driver: i915 v: kernel alternate: xe arch: Xe process: Intel 10nm
    built: 2020-21 ports: active: eDP-1 empty: DP-1, DP-2, DP-3, HDMI-A-1,
    HDMI-A-2 bus-ID: 0000:00:02.0 chip-ID: 8086:9a49 class-ID: 0300
  Device-2: Quanta HP Wide Vision HD Camera driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-6:2 chip-ID: 0408:5423
  Display: unspecified server: X.org v: 1.21.1.21 with: Xwayland v: 24.1.9
    compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris gpu: i915 display-ID: :0 note: <missing: xdpyinfo/xrandr>
  Monitor-1: eDP-1 model: AU Optronics 0x403d built: 2019 res: 1920x1080
    dpi: 158 gamma: 1.2 chroma: red: x: 0.573 y: 0.337 green: x: 0.349 y: 0.565
    blue: x: 0.161 y: 0.125 white: x: 0.314 y: 0.329
    size: 309x174mm (12.17x6.85") diag: 355mm (14") ratio: 16:9
    modes: 1920x1080
  EDID-Warnings: 1: parse_edid: unknown flag 2
    device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
    inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.3.1-arch1.2
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Iris Xe Graphics (TGL
    GT2) device-ID: 8086:9a49 memory: 7.23 GiB unified: yes
  API: Vulkan v: 1.4.335 layers: 2 device: 0 type: integrated-gpu name: Intel
    Iris Xe Graphics (TGL GT2) driver: mesa intel v: 25.3.1-arch1.2
    device-ID: 8086:9a49 surfaces: N/A
  Info: Tools: api: eglinfo, glxinfo, vulkaninfo wl: wayland-info x11: xprop
  Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Hewlett-Packard
    driver: sof-audio-pci-intel-tgl alternate: snd_soc_avs,
    snd_sof_pci_intel_tgl, snd_hda_intel bus-ID: 0000:00:1f.3
    chip-ID: 8086:a0c8 class-ID: 0401
  API: ALSA v: k6.19.0-rc1-1-MANJARO status: kernel-api
  Server-2: PipeWire v: 1.4.9 status: n/a (root, process) with:
  Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 0000:00:14.3
    chip-ID: 8086:a0f0 class-ID: 0280
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 8087:0026
    class-ID: e001
  Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
    v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
  Local Storage: total: 238.47 GiB used: 108.09 GiB (45.3%)
    model: MZVLQ256HAJD-000H1 size: 238.47 GiB block-size: physical: 512 B
    fw-rev: HPS4NFXV temp: 40.9 C scheme: GPT
  SMART: yes health: PASSED on: 229d 4h cycles: 1,421
    read-units: 51,150,759 [26.1 TB] written-units: 31,216,888 [15.9 TB]
  ID-1: / raw-size: 50 GiB size: 48.91 GiB (97.83%) used: 23.06 GiB (47.1%)
    fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
    uuid: 60dc2a4d-cdf0-48b5-bdb9-531010324ac4
  ID-2: /boot/efi raw-size: 3 GiB size: 2.99 GiB (99.80%)
    used: 292 KiB (0.0%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p4
    maj-min: 259:4 label: N/A uuid: 068C-F69B
  ID-3: /mnt/personal raw-size: 115.2 GiB size: 115.2 GiB (100.00%)
    used: 85.03 GiB (73.8%) fs: ntfs block-size: 4096 B dev: /dev/nvme0n1p6
    maj-min: 259:6 label: N/A uuid: 48A45877A4586988
  ID-1: swap-1 type: partition size: 15 GiB used: 4 KiB (0.0%) priority: -1
    dev: /dev/nvme0n1p7 maj-min: 259:7 label: N/A
    uuid: b507ee39-fae3-4728-aef2-af1e1aa840ad
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 260 MiB fs: vfat label: SYSTEM
    uuid: D28F-37AE
  ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: N/A label: N/A
    uuid: N/A
  ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 55 GiB fs: ntfs label: Windows
    uuid: 106490FD6490E72E
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 3-6:2 info: Quanta HP Wide Vision HD Camera type: video
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 0408:5423 class-ID: 0e02
    serial: <filter>
  Device-2: 3-7:3 info: Elan Micro ELAN:ARM-M4 type: <vendor specific>
    driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 100mA chip-ID: 04f3:0c00 class-ID: 0000
  Device-3: 3-10:4 info: Intel AX201 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0026 class-ID: e001
  System Temperatures: cpu: 36.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: pm: dpkg pkgs: 0 pm: pacman pkgs: 1439 libs: 376 tools: yay
    1: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    2: https://mirrors2.manjaro.org/stable/$repo/$arch
    3: https://mirrors.manjaro.org/repo/stable/$repo/$arch
Processes:
  CPU top: 5 of 270
  1: cpu: 28.0% command: firefox pid: 22398 mem: 546.5 MiB (7.2%)
  2: cpu: 14.4% command: firefox pid: 22770 mem: 344.8 MiB (4.5%)
  3: cpu: 3.3% command: com.github.amezin.ddterm started-by: gjs pid: 23176
    mem: 94.0 MiB (1.2%)
  4: cpu: 2.6% command: firefox pid: 22665 mem: 229.5 MiB (3.0%)
  5: cpu: 2.0% command: gnome-shell pid: 1873 mem: 307.0 MiB (4.0%)
  Memory top: 5 of 270
  1: mem: 546.5 MiB (7.2%) command: firefox pid: 22398 cpu: 28.0%
  2: mem: 344.8 MiB (4.5%) command: firefox pid: 22770 cpu: 14.4%
  3: mem: 307.0 MiB (4.0%) command: gnome-shell pid: 1873 cpu: 2.0%
  4: mem: 229.5 MiB (3.0%) command: firefox pid: 22665 cpu: 2.6%
  5: mem: 183.9 MiB (2.4%) command: firefox pid: 22602 cpu: 0.8%
  Processes: 270 Power: uptime: 7h 5m states: freeze,mem,disk suspend: s2idle
    avail: deep wakeups: 2 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 2.94 GiB services: gsd-power,
    power-profiles-daemon, upowerd Init: systemd v: 258 default: graphical
    tool: systemctl
  Compilers: clang: 21.1.6 gcc: 15.2.1 Shell: Sudo (sudo) v: 1.9.17p2
    default: Bash v: 5.3.9 running-in: gjs inxi: 3.3.40
