I have a fresh install of Manjaro but for some reason my touchscreen does not work at all, and based on the xinput list, it’s not detected at all. I have gotten it to briefly work after reinstalling the xf86-input-evdev driver but no luck since then, and doesn’t seem to work since then.
What shows up when I run the command 'xinput list --long'
⎡ Virtual core pointer id=2 [master pointer (3)]
Reporting 7 classes:
Class originated from: 9. Type: XIButtonClass
Buttons supported: 10
Button labels: "Button Left" "Button Middle" "Button Right" "Button Wheel Up" "Button Wheel Down" "Button Horiz Wheel Left" "Button Horiz Wheel Right" None None None
Button state:
Class originated from: 9. Type: XIValuatorClass
Detail for Valuator 0:
Label: Rel X
Range: -1.000000 - -1.000000
Resolution: 0 units/m
Mode: relative
Detail for Valuator 1:
Label: Rel Y
Mode: relative
Detail for Valuator 2:
Label: Rel Horiz Scroll
Mode: relative
Detail for Valuator 3:
Label: Rel Vert Scroll
Mode: relative
Class originated from: 9. Type: XIScrollClass
Scroll info for Valuator 2
type: 2 (horizontal)
increment: 120.000000
flags: 0x0
Scroll info for Valuator 3
type: 1 (vertical)
flags: 0x0
⎜ ↳ Virtual core XTEST pointer id=4 [slave pointer (2)]
Reporting 3 classes:
Class originated from: 4. Type: XIButtonClass
Button state:
Class originated from: 4. Type: XIValuatorClass
Label: Rel X
Mode: relative
Label: Rel Y
Mode: relative
⎜ ↳ MSFT0001:01 04F3:3138 Mouse id=10 [slave pointer (2)]
Class originated from: 10. Type: XIButtonClass
Buttons supported: 7
Button state:
Class originated from: 10. Type: XIValuatorClass
Label: Rel X
Mode: relative
Label: Rel Y
Mode: relative
Mode: relative
Mode: relative
Class originated from: 10. Type: XIScrollClass
flags: 0x0
type: 1 (vertical)
flags: 0x0
⎜ ↳ MSFT0001:01 04F3:3138 Touchpad id=9 [slave pointer (2)]
Button state:
Label: Rel X
Mode: relative
Label: Rel Y
Mode: relative
Mode: relative
Mode: relative
flags: 0x0
type: 1 (vertical)
flags: 0x0
⎣ Virtual core keyboard id=3 [master keyboard (2)]
Reporting 1 classes:
Class originated from: 12. Type: XIKeyClass
Keycodes supported: 248
↳ Virtual core XTEST keyboard id=5 [slave keyboard (3)]
Class originated from: 5. Type: XIKeyClass
↳ Video Bus id=6 [slave keyboard (3)]
Class originated from: 6. Type: XIKeyClass
↳ Power Button id=7 [slave keyboard (3)]
Class originated from: 7. Type: XIKeyClass
↳ Integrated Camera: Integrated C id=8 [slave keyboard (3)]
Class originated from: 8. Type: XIKeyClass
↳ Ideapad extra buttons id=11 [slave keyboard (3)]
Class originated from: 11. Type: XIKeyClass
↳ AT Translated Set 2 keyboard id=12 [slave keyboard (3)]
System specs - 'inxi --admin --verbosity=7 --filter --width'
Kernel: 6.1.23-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=7b33fa44-40da-420c-9157-3fc9c7ea05d7 rw quiet
cryptdevice=UUID=14f6da74-4f88-4055-a726-2e7df0094149:luks-14f6da74-4f88-4055-a726-2e7df0094149
root=/dev/mapper/luks-14f6da74-4f88-4055-a726-2e7df0094149 splash
udev.log_priority=3 acpi_backlight=native
Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Convertible System: LENOVO product: 82BH v: Yoga 7 14ITL5
serial: <superuser required> Chassis: type: 31 v: Yoga 7 14ITL5
Mobo: LENOVO model: LNVNB161216 v: SDK0T76463 WIN
serial: <superuser required> UEFI: LENOVO v: F5CN59WW date: 11/25/2022
ID-1: BAT0 charge: 46.2 Wh (72.6%) condition: 63.6/71.0 Wh (89.5%)
volts: 16.0 min: 15.4 model: SMP L19M4PDC type: Li-poly serial: <filter>
status: discharging cycles: 279
RAM: total: 15.43 GiB used: 2.33 GiB (15.1%)
Info: model: 11th Gen Intel Core i7-1165G7 bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
microcode: 0xA6
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 12 MiB
desc: 1x12 MiB
Speed (MHz): avg: 2340 high: 2800 min/max: 400/4700 scaling:
driver: intel_pstate governor: powersave cores: 1: 932 2: 2800 3: 2800
4: 2800 5: 988 6: 2800 7: 2800 8: 2800 bogomips: 44864
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b
movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
rdt_a rdtscp rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd
sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Lenovo
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1, HDMI-A-2,
HDMI-A-3, HDMI-A-4 bus-ID: 0000:00:02.0 chip-ID: 8086:9a49 class-ID: 0300
Device-2: Bison Integrated Camera type: USB driver: uvcvideo bus-ID: 3-8:2
chip-ID: 5986:212a class-ID: 0e02
Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0
screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: ChiMei InnoLux 0x1432 built: 2020 res: 1920x1080
hz: 60 dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 23.0.2 renderer: Mesa Intel Xe Graphics (TGL GT2)
direct-render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Lenovo
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
chip-ID: 8086:a0c8 class-ID: 0401
API: ALSA v: k6.1.23-1-MANJARO status: kernel-api with: aoss
type: oss-emulator tools: alsamixer,amixer
Server-2: PipeWire v: 0.3.68 status: off with: wireplumber status: active
tools: pw-cli,wpctl
Server-3: PulseAudio v: 16.1 status: active tools: pacat,pactl
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 0000:00:14.3
chip-ID: 8086:a0f0 class-ID: 0280
Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-10:4
chip-ID: 8087:0026 class-ID: e001
Device-1: luks-14f6da74-4f88-4055-a726-2e7df0094149 maj-min: 254:0
type: LUKS dm: dm-0 size: 400.39 GiB
Components:
p-1: nvme0n1p4 maj-min: 259:4 size: 400.39 GiB
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
Local Storage: total: 476.94 GiB used: 14.13 GiB (3.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: TeamGroup model: TM8FP4512G
lanes: 4 type: SSD serial: <filter> rev: ECFM12.3 temp: 29.9 C scheme: GPT
ID-1: / raw-size: 400.39 GiB size: 393.03 GiB (98.16%) used: 14.11 GiB (3.6%)
fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-14f6da74-4f88-4055-a726-2e7df0094149 label: N/A
uuid: 7b33fa44-40da-420c-9157-3fc9c7ea05d7
used: 29.5 MiB (30.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 8073-63E3
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 75.82 GiB fs: ntfs label: N/A
uuid: FC1A74171A73CCE0
ID-3: /dev/nvme0n1p5 maj-min: 259:5 size: 625 MiB fs: ntfs label: N/A
uuid: 96FC6FA2FC6F7AFF
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-8:2 info: Bison Integrated Camera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 5986:212a
class-ID: 0e02
Device-2: 3-9:3 info: LighTuning EgisTec EH576 type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 100mA
chip-ID: 1c7a:0576 class-ID: ff00 serial: <filter>
Device-3: 3-10:4 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
class-ID: e001
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 41.0 C mobo: N/A
Processes: 233 Uptime: 11m wakeups: 1670 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
Packages: 1202 pm: pacman pkgs: 1196 libs: 332 tools: pamac pm: flatpak
pkgs: 6 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.26
