Hi guys,
I’m struggling with a touchpad problem with my ‘Thinkpad L13 Yoga’ - probably since day 1 after installing Manjaro KDE half a year ago. Since I usually use an external mouse, I rarely use the touchpad and have therefore hardly noticed the problem:
My touchpad is too sensitive!
Unlike other touchpad related problems, my Elan touchpad is detected correctly and the pointer movement is as I would like it to be. What I’m talking about is the pressure threshold when a click is detected (with the option “tap to click” enabled). It’s too sensitive, so the movement of the pointer is interpreted as dragging in half the time.
Can someone help me fix this?
The system settings didn’t help me in any way. I will gladly give additional information from my side
`inxi -Fxz`
System: Kernel: 5.8.6-1-MANJARO x86_64 bits: 64 compiler: N/A Desktop: KDE Plasma 5.19.5 Distro: Manjaro Linux
Machine: Type: Convertible System: LENOVO product: 20R6S00800 v: ThinkPad L13 Yoga serial: <filter>
Mobo: LENOVO model: 20R6S00800 serial: <filter> UEFI: LENOVO v: R15ET25W (1.05 ) date: 10/15/2019
Battery: ID-1: BAT0 charge: 38.4 Wh condition: 39.4/46.0 Wh (86%) model: Celxpert 02DL031 status: Discharging
CPU: Topology: Quad Core model: Intel Core i5-10210U bits: 64 type: MT MCP arch: Kaby Lake rev: C L2 cache: 6144 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 33615
Speed: 783 MHz min/max: 400/4200 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800
Graphics: Device-1: Intel UHD Graphics vendor: Lenovo driver: i915 v: kernel bus ID: 00:02.0
Device-2: Chicony ThinkPad T490 Webcam type: USB driver: uvcvideo bus ID: 1-5:3
Device-3: Chicony Integrated 5M Camera type: USB driver: uvcvideo bus ID: 1-9:7
Display: x11 server: X.Org 1.20.8 driver: modesetting resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 20.1.7 direct render: Yes
Audio: Device-1: Intel vendor: Lenovo driver: snd_hda_intel v: kernel bus ID: 00:1f.3
Sound Server: ALSA v: k5.8.6-1-MANJARO
Network: Device-1: Intel Wireless-AC 9462 driver: iwlwifi v: kernel port: 2000 bus ID: 00:14.3
Device-2: Intel Ethernet I219-V vendor: Lenovo driver: e1000e v: 3.2.6-k port: efa0 bus ID: 00:1f.6
IF: enp0s31f6 state: down mac: <filter>
IF-ID-1: vpn0 state: down mac: N/A
Drives: Local Storage: total: 476.94 GiB used: 95.74 GiB (20.1%)
ID-1: /dev/nvme0n1 vendor: Toshiba model: N/A size: 476.94 GiB
Partition: ID-1: / size: 468.16 GiB used: 95.74 GiB (20.4%) fs: ext4 dev: /dev/nvme0n1p2
Swap: Alert: No Swap data was found.
Sensors: System Temperatures: cpu: 41.0 C mobo: 1.0 C
Fan Speeds (RPM): cpu: 0
Info: Processes: 287 Uptime: 8d 18h 07m Memory: 15.36 GiB used: 3.73 GiB (24.3%) Init: systemd Compilers: gcc: 10.2.0
Packages: 1719 Shell: Bash v: 5.0.18 inxi: 3.1.05
