I have installed Manjaro gnome for a few weeks
everything works very well
I come from using linuxmint cinnamon for several years and it turned out to be a very nice delicacy
I have problems with the touchpad, I have tried several lts kernels but the problem continues
when starting the system with wayland, everything works perfectly, with two fingers the scroll, with three fingers the desktop is passed, all very well
the problem is when closing the lid and resuming the work, it is no longer good
the two fingers do not scroll and if you scroll with three fingers in kernel 5.15
with kernel 5.10 I can’t work anything on the touchpad
is this because it requires some configuration that I have to do separately?
I leave you the information of my hardware
Kernel: 5.15.21-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
Desktop: GNOME 41.3 tk: GTK 3.24.31 wm: gnome-shell dm: GDM
Type: Laptop System: LENOVO product: 20AMA2EJAR v: ThinkPad X240
Mobo: LENOVO model: 20AMA2EJAR v: SDK0E50510 PRO
serial: <superuser required> UEFI-[Legacy]: LENOVO v: GIET87WW (2.37 )
date: 09/13/2016
ID-1: BAT1 charge: 20.2 Wh (87.8%) condition: 23.0/47.5 Wh (48.4%)
volts: 11.9 min: 10.8 model: LGC 45N1735 serial: <filter>
status: Discharging
Info: dual core model: Intel Core i5-4300U bits: 64 type: MT MCP
arch: Haswell rev: 1 cache: L1: 128 KiB L2: 512 KiB L3: 3 MiB
Speed (MHz): avg: 1515 high: 1898 min/max: 800/2900 cores: 1: 1895
2: 1323 3: 946 4: 1898 bogomips: 19961
Device-1: Intel Haswell-ULT Integrated Graphics
vendor: Lenovo ThinkPad X240 driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:0a16
Display: wayland server: X.Org 1.21.1.4 compositor: gnome-shell driver:
loaded: modesetting alternate: fbdev,vesa resolution: 1366x768~60Hz
s-dpi: 96
Device-1: Intel Haswell-ULT HD Audio vendor: Lenovo ThinkPad X240
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:0a0c
Device-2: Intel 8 Series HD Audio vendor: Lenovo ThinkPad X240
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9c20
Sound Server-1: ALSA v: k5.15.21-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.45 running: yes
Device-1: Intel Ethernet I218-LM vendor: Lenovo ThinkPad X240
driver: e1000e v: kernel port: 3080 bus-ID: 00:19.0 chip-ID: 8086:155a
IF: enp0s25 state: down mac: <filter>
Device-2: Intel Wireless 7260 driver: iwlwifi v: kernel bus-ID: 03:00.0
chip-ID: 8086:08b2
Local Storage: total: 223.57 GiB used: 76.3 GiB (34.1%)
ID-1: /dev/sda vendor: Kingston model: SA400S37240G size: 223.57 GiB
speed: 6.0 Gb/s serial: <filter>
ID-1: / size: 210.34 GiB used: 76.3 GiB (36.3%) fs: ext4 dev: /dev/sda1
dev: /dev/sda2
System Temperatures: cpu: 43.0 C mobo: N/A
Fan Speeds (RPM): fan-1: 3068
Packages: 1586 pacman: 1553 flatpak: 33
1: http://manjaro.dcc.uchile.cl/stable/$repo/$arch
2: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
3: https://mirrors.manjaro.org/repo/stable/$repo/$arch
4: http://manjaro.grena.ge/stable/$repo/$arch
5: http://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
6: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
7: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
8: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
Processes: 239 Uptime: 3h 12m Memory: 7.46 GiB used: 2.37 GiB (31.7%)
Init: systemd v: 250 Compilers: gcc: 11.1.0 clang: 13.0.1 Shell: Zsh v: 5.8
running-in: gnome-terminal inxi: 3.3.12
