I decided to dual boot my HP 15S-eq1023np that has an Elan touchpad with Manjaro 21.2.6 Kernel 5.15 and Windows 10.
Before, I was using Manjaro in a VM testing it out and it was going fine. When I decided to install Manjaro, the installation process was going flawless and the touchpad was working. But when I restarted the machine in Manjaro the touchpad was not working anymore.
I already reinstalled the system 3 times and confirmed that it only works on live usb and the kernel versions are the same.
Also tried to change GRUB and added i8042 parameters among a lot of other things.
Xinput in live usb shows elan touchpad but in native OS it doesn’t. After tinkering with GRUB it was listed as PS/2 Generic Mouse.
After adding other i8042 options to GRUB it now lists as an ‘ETPS/2 Elantech Touchpad’ but still no move. I followed the links you sent and installed synaptics driver. Since I had a file named 30-touchpad.conf with libinput and 10-synaptics.conf the touchpad was using libinput, but after renaming it to 70-synaptics.conf now it is using synaptics driver.
Just a quick update: I tried installing Endeavour OS and openSUSE and none of them work as well. Same result, it work on the installation process but not in the native OS.
Another update: apparently I need to press F9 to select the boot device every time it boots and select Grub but I don’t know if there is any other solution that doesn’t involve that.
