Touchpad not working on Thinkpad X1 Extreme gen 3
I recently made a risky purchase, and received a used Thinkpad X1 Extreme gen 3 (instead of the advertised X1 Carbon gen 9). Whoops! Anyway, the fun started then. A new install of Plasma…
/etc/X11/xorg.conf.d/30-touchpad.conf
Section "InputClass"
  MatchIsPointer "on"
  MatchDevicePath "/dev/input/event12"
  Identifier "touchpad"
  Driver "libinput"
  Option "Tapping" "on"
  Option "TappingDrag" "on"
  Option "DisableWhileTyping" "on"
  Option "ScrollMethod" "twofinger"
  Option "NaturalScrolling" "on"
EndSection
libinput list-devices #Touchpad only
Device:           PS/2 Synaptics TouchPad
Kernel:           /dev/input/event12
Group:            6
Seat:             seat0, default
Capabilities:     pointer
Tap-to-click:     n/a
Tap-and-drag:     n/a
Tap drag lock:    n/a
Left-handed:      disabled
Nat.scrolling:    disabled
Middle emulation: disabled
Calibration:      n/a
Scroll methods:   *button
Click methods:    none
Disable-w-typing: n/a
Disable-w-trackpointing: n/a
Accel profiles:   flat *adaptive custom
Rotation:         0.0
grep -i touch /var/log/Xorg.0.conf
[     4.942] Kernel command line: BOOT_IMAGE=/@/boot/vmlinuz-6.10-x86_64 root=UUID=67c949db-bc00-450f-9711-78195bd22e6b rw rootflags=subvol=@ quiet nosplash udev.log_priority=3 plymouth.enable=0 disablehooks=plymouth psmouse.synaptics_intertouch=1 acpi_osi=! "acpi_osi=Windows 2015" i915.enable_psr=0
[     5.632] (II) config/udev: Adding input device PS/2 Synaptics TouchPad (/dev/input/event12)
[     5.632] (**) PS/2 Synaptics TouchPad: Applying InputClass "evdev pointer catchall"
[     5.632] (**) PS/2 Synaptics TouchPad: Applying InputClass "libinput pointer catchall"
[     5.632] (**) PS/2 Synaptics TouchPad: Applying InputClass "touchpad"
[     5.632] (II) Using input driver 'libinput' for 'PS/2 Synaptics TouchPad'
[     5.632] (**) PS/2 Synaptics TouchPad: always reports core events
[     5.633] (II) event12 - PS/2 Synaptics TouchPad: is tagged by udev as: Mouse
[     5.634] (II) event12 - PS/2 Synaptics TouchPad: device is a pointer
[     5.634] (II) event12 - PS/2 Synaptics TouchPad: device removed
[     5.700] (II) libinput: PS/2 Synaptics TouchPad: Step value 0 was provided, libinput Fallback acceleration function is used.
[     5.700] (II) XINPUT: Adding extended input device "PS/2 Synaptics TouchPad" (type: MOUSE, id 11)
[     5.700] (EE) libinput: PS/2 Synaptics TouchPad: Failed to set scroll to twofinger
[     5.700] (**) PS/2 Synaptics TouchPad: (accel) selected scheme none/0
[     5.700] (**) PS/2 Synaptics TouchPad: (accel) acceleration factor: 2.000
[     5.700] (**) PS/2 Synaptics TouchPad: (accel) acceleration threshold: 4
[     5.702] (II) event12 - PS/2 Synaptics TouchPad: is tagged by udev as: Mouse
[     5.703] (II) event12 - PS/2 Synaptics TouchPad: device is a pointer
[     5.703] (EE) libinput: PS/2 Synaptics TouchPad: Failed to set scroll to twofinger
[     5.704] (II) config/udev: Adding input device PS/2 Synaptics TouchPad (/dev/input/mouse0)
[    13.183] (II) event12 - PS/2 Synaptics TouchPad: device removed
inxi -v8Fz
  Kernel: 6.10.3-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.10-x86_64
  Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.4.0
  Type: Laptop System: LENOVO product: 20TK001GUS v: ThinkPad X1 Extreme Gen 3
  Mobo: LENOVO model: 20TK001GUS v: SDK0J40697 WIN
    serial: <superuser required> part-nu: LENOVO_MT_20TK_BU_Think_FM_ThinkPad
    X1 Extreme Gen 3 uuid: <superuser required> UEFI: LENOVO
    v: N2VET46W (1.31 ) date: 11/13/2023
  ID-1: BAT0 charge: 56.1 Wh (83.9%) condition: 66.9/80.0 Wh (83.6%)
    volts: 16.2 min: 15.4 model: Celxpert 5B10X19050 type: Li-poly
    serial: <filter> status: not charging cycles: 278
  System RAM: total: 32 GiB available: 30.98 GiB used: 4.58 GiB (14.8%)
  Array-1: capacity: 32 GiB slots: 2 modules: 1 EC: None
  Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous size: 32 GiB
    speed: spec: 3200 MT/s actual: 2933 MT/s volts: curr: 1 width (bits):
    data: 64 total: 64 manufacturer: Samsung part-no: M471A4G43AB1-CWE
    serial: <filter>
  Device-2: ChannelB-DIMM0 type: no module installed
  Info: model: Intel Core i7-10850H bits: 64 type: MT MCP arch: Comet Lake
    gen: core 10 level: v3 note: check built: 2020 process: Intel 14nm family: 6
    model-id: 0xA5 (165) stepping: 2 microcode: 0xFA
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
    L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 808 high: 900 min/max: 800/5100 scaling:
    driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 800
    5: 800 6: 800 7: 800 8: 900 9: 800 10: 800 11: 800 12: 800 bogomips: 64821
    fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
    ibrs_enhanced ida intel_pt invpcid lahf_lm lm mca mce md_clear mmx
    monitor movbe mpx msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid
    pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdrand
    rdseed rdtscp rep_good sdbg sep sgx sgx_lc smap smep smx ss ssbd sse sse2
    xsaves xtopology xtpr
  Type: retbleed mitigation: Enhanced IBRS
    conditional; RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW
    loop
  Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Lenovo driver: i915
    v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
    active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:9bc4
    class-ID: 0300
  Device-2: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: Lenovo
    driver: N/A alternate: nouveau, nvidia_drm, nvidia non-free: 550.xx+
    status: current (as of 2024-06; EOL~2026-12-xx) arch: Turing code: TUxxx
    process: TSMC 12nm FF built: 2018-2022 pcie: speed: Unknown lanes: 63
    link-max: gen: 6 speed: 64 GT/s bus-ID: 01:00.0 chip-ID: 10de:1f95
    class-ID: 0300
  Device-3: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:2 chip-ID: 04f2:b6cb
  Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.1
    alternate: fbdev,vesa dri: iris gpu: i915 display-ID: 0
  Monitor-1: eDP-1 res: 1707x960 size: N/A modes: N/A
    drv: iris x11: drv: iris
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.1.5-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (CML GT2)
    device-ID: 8086:9bc4 memory: 15.13 GiB unified: yes display-ID: :1.0
  Device-1: Intel Comet Lake PCH cAVS vendor: Lenovo
    driver: sof-audio-pci-intel-cnl alternate: snd_hda_intel, snd_soc_skl,
    snd_soc_avs, snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:06c8
    class-ID: 0401
  Device-2: NVIDIA vendor: Lenovo driver: snd_hda_intel v: kernel pcie:
    speed: Unknown lanes: 63 link-max: gen: 6 speed: 64 GT/s bus-ID: 01:00.1
    chip-ID: 10de:10fa class-ID: 0403
  API: ALSA v: k6.10.3-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.2 status: active with: 1: pipewire-pulse
  Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
  IF-ID-1: virbr0 state: down mac: <filter>
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:4 chip-ID: 8087:0026
    class-ID: e001
  Local Storage: total: 953.87 GiB used: 262.02 GiB (27.5%)
    model: MZVLB1T0HBLR-000L7 size: 953.87 GiB block-size: physical: 512 B
    fw-rev: 5M2QEXF7 temp: 29.9 C scheme: GPT
  ID-1: / raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
    used: 262.02 GiB (27.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: 67c949db-bc00-450f-9711-78195bd22e6b
    used: 584 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: A0D0-9C44
  ID-3: /home raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
  ID-4: /var/cache raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
  ID-5: /var/lib/libvirt/images raw-size: 953.57 GiB
    size: 953.57 GiB (100.00%) used: 262.02 GiB (27.5%) fs: btrfs
    dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
  ID-6: /var/log raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
  Device-1: 1-8:2 info: Chicony Integrated Camera type: video
    driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 04f2:b6cb class-ID: fe01
    serial: <filter>
  Device-2: 1-9:8 info: Synaptics Prometheus MIS Touch Fingerprint Reader
    type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0
    chip-ID: 06cb:00bd class-ID: ff00 serial: <filter>
  Device-3: 1-14:4 info: Intel AX201 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0026 class-ID: e001
  Hub-2: 2-0:1 info: super-speed hub ports: 10 rev: 3.1
  System Temperatures: cpu: 29.0 C pch: 38.0 C mobo: N/A
  Fan Speeds (rpm): fan-1: 2780 fan-2: 2511
  Packages: pm: pacman pkgs: 1290 libs: 365 tools: pamac pm: flatpak pkgs: 0
    1: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    2: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    3: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
    4: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    5: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    6: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    7: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    8: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 312
  1: cpu: 300% command: ps pid: 48444 mem: 3.57 MiB (0.0%)
  2: cpu: 0.3% command: firefox pid: 1568 mem: 821.8 MiB (2.5%)
  3: cpu: 0.3% command: firefox pid: 48360 mem: 80.6 MiB (0.2%)
  4: cpu: 0.1% command: kwin_wayland pid: 875 mem: 403.0 MiB (1.2%)
  5: cpu: 0.1% command: firefox pid: 48038 mem: 103.9 MiB (0.3%)
  Memory top: 5 of 312
  1: mem: 821.8 MiB (2.5%) command: firefox pid: 1568 cpu: 0.3%
  2: mem: 666.6 MiB (2.1%) command: plasmashell pid: 1071 cpu: 0.0%
  3: mem: 403.0 MiB (1.2%) command: kwin_wayland pid: 875 cpu: 0.1%
  4: mem: 355.1 MiB (1.1%) command: firefox pid: 1710 cpu: 0.0%
  5: mem: 274.1 MiB (0.8%) command: konsole pid: 1394 cpu: 0.0%
  Processes: 312 Power: uptime: 2d 20h 38m states: freeze,mem,disk
    suspend: s2idle avail: deep wakeups: 5 hibernate: platform avail: shutdown,
    reboot, suspend, test_resume image: 12.36 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Compilers: N/A Shell: Zsh v: 5.9 default: Bash v: 5.2.26
    running-in: konsole inxi: 3.3.35
journalctl -b -1 | grep -iE 'touchpad|input9|ps/2'
Aug 13 15:30:53 tpad kernel: i8042: PNP: PS/2 Controller [PNP0303:KBD,PNP0f13:MOU] at 0x60,0x64 irq 1,12
Aug 13 15:30:55 tpad kernel: input: PS/2 Synaptics TouchPad as /devices/platform/i8042/serio1/input/input9
Aug 13 15:30:55 tpad kernel: mousedev: PS/2 mouse device common for all mice
Aug 13 15:31:07 tpad kcminit_startup[879]: Initializing  "/usr/lib/qt6/plugins/plasma/kcms/systemsettings/kcm_touchpad.so"
About 100 hours later with over half spent such on getting the touchpad to work properly. (And this is probably my 12th Thinkpad.) I have never had this much trouble with a Synaptics touchpad. The touchpad works a mouse, barely. The only gesture that works, is a single tap (and constant palm misclicks). Plasma settings says no touchpad found.
Everything I’ve read, is saying the old xf86-input Synaptics package/module is obsolete with Wayland, and everything is done through libinput. Is this correct?
I have tried many ways to Match* the device, and I think I’ve done it 4+ different ways through device types and paths successfully. But it is not accepting these setttings as udev lablelled it is a mouse, and libinput refuses any touchpad related setting I try? Or am I way off here?
Yes.
And really synaptics has been deprecated for a long while. It is no longer updated.
Its also true that libinput works differently.
This looks funny to me. A basic structure for a touchpad would look something like this:
    Driver "libinput"
    MatchIsTouchpad "on"
    Option "DisableWhileTyping" "0"
EndSection
Besides the order and path etc, yours is also specifically using ‘MatchIsPointer’ which means a trackpoint … the little eraser-head ball thing.
https://wiki.archlinux.org/title/Libinput
That file has been changed hundreds of times. I only need one touchpad related setting to throw errors. But Xorg config values take “True”, “on”, “1”, etc. (and their counterparts).
That was one of the first places of course. Then going back to it dozens of times.
Why does udev make it a mouse, then libinput will not do anything with it, unless it is a setting for mice only?
I guess you’ve tried different kernels? My T440 (albeit much older) was having trackpad issues with certain HWE kernels (and, initially, the later LTS ones).
For example I frequently had to issue sudo modprobe -r psmouse && sudo modprobe -a psmouse after the first resume from suspend. If the trackpad worked at all.
I tried 4 kernels, two LTS, and 6.9 (before its EOL), and 6.10.
I tried about 10 things with the psmouse module, and giving it parameters in desperation as well. (All which did nothing.)
I dont think you gathered the main point - you have it set to trackpoint. either that file is having no impact on your touchpad or it is effectively turning it into the little eraser nib - meaning something like 2-finger would be impossible.
The TrackPoint? It works fine on another device. Are you meaning with the MatchIsPointer "on" line?
That was left over from troubleshooting, I have tried many combinations of settings before posting this. I took it out just now, and same thing.
Or what are you suggesting I do? (Most of the Match* type lines I’ve tried seem to work fine. I can match it a few ways.)
https://wiki.archlinux.org/title/Libinput#Via_Xorg_configuration_file
But also … if using wayland this is moot.
With wayland it depends on your desktops support.
(Or possibly udev rules as outlined at the wiki)
I actually thought it meant the pointer InputClass. But I’ve tried it without before, and removed it just now. (Same results.)
Yeah, I just keep it in 30-touchpad.conf to combine with all the /etc/X11/xorg.conf.d/*.conf files. I did make it 30, but I’ve tried it highest and lowest. I do remember the one massive Xorg config file days. No thanks.
Yes, this was all to try and get it working in Wayland. My conclusion was I have to go back to X11, well configure X11, as it installed with Wayland. (Which is still newish to me.) I didn’t say outright, but it’s in the inxi.
So just no touchpad in Wayland? (Many sources actually even say this, but the majority are pretty dated.) But I find that hard to believe after all this time?
My desktop’s support? KDE 6.0.5? It says, “No touchpad found.”
This is where I thought the problem lies, but my knowledge is lacking. How and where does udev label this as a pointer, before libinput gets to it.
That’s what I’ve ended up using, just running it as a service after sleep:
[Unit]
Description=Synaptics Touchpad Sleep Fix
After=suspend.target hibernate.target hybrid-sleep.target
[Service]
User=root
Type=oneshot
ExecStart=/usr/local/bin/touchpad_fix.sh
TimeoutSec=0
[Install]
WantedBy=multi-user.target suspend.target hibernate.target hybrid-sleep.target
Thanks for posting this, very helpful! I’ve bookmarked it for future reference. :smile_cat:
Unfortunately, for me it happened on boot, and any state.
Even if it was related, you didn’t say what you are doing:
So you do what right after it wakes?
After about 2 months, I gave up. I dd’d Win 11 back, and gave the laptop away.
It was supposed be to an X1 Carbon anyway. This Extreme line is garbage. There were more issues, but a basic touchpad was kind of a deal breaker.
The script is just what was recommended before, it’s a dumb fix but so far seems to work for me:
#!/bin/bash
It should be called whenever resuming from any type of sleep/suspend state. I haven’t seen it randomly happen yet but I wouldn’t be surprised.
Hello all, just dropping a note that a separate script is probably not necessary.
You could use something like this;
File:
/etc/systemd/system/restart-touchpad.service
Contents:
[Unit]
Description=Restart Touchpad
After=basic.target suspend.target hibernate.target
[Service]
user=root
Type=oneshot
ExecStart=/usr/bin/bash -c '\
/usr/bin/rmmod psmouse; \
/usr/bin/modprobe psmouse'
[Install]
WantedBy=basic.target suspend.target hibernate.target
Enable service:
systemctl enable restart-touchpad.service --now
But I will also note that psmouse is maybe an odd module for a touchpad.
So, as written, it may or may not be applicable.
i2c_hid is a likely candidate (or something related like i2c_hid_acpi).
Did you identify the correct module already?
