Touchpad not recognized anymore
Hey folks,
my touchpad stopped working, most likely after plugging my laptop into a docking-station which had a bluetooth remote keyboard+touchpad connected. Not working means it doesn’t recognize any input and the corresponding config section disappeared from the gnome config GUI. However, running a live system shows, that it’s not the hardware. Plugging out both docking-station and/or bluetooth dongle, or rebooting in those states didn’t show any effect. I’d be very happy if someone had an idea what to try next…
  Kernel: 6.1.31-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    root=UUID=3575f631-146f-4fed-88cc-fa82d150d517 rw quiet splash apparmor=1
  Desktop: GNOME v: 44.1 tk: GTK v: 3.24.37 wm: gnome-shell dm: GDM v: 44.1
  Type: Laptop System: FUJITSU product: LIFEBOOK E752 v: 10601115935
    serial: <superuser required> Chassis: type: 10 v: LIFEBOOK E752
  Mobo: FUJITSU model: FJNB252 v: M3 serial: <superuser required>
    UEFI: FUJITSU // Phoenix v: Version 2.11 date: 11/10/2014
  ID-1: CMB1 charge: 52.6 Wh (84.0%) condition: 62.6/62.6 Wh (100.0%)
    volts: 12.3 min: 10.8 model: Fujitsu CP689834-01 type: Li-ion
    serial: <filter> status: charging
  Info: model: Intel Core i7-3612QM bits: 64 type: MT MCP arch: Ivy Bridge
    gen: core 3 level: v2 built: 2012-15 process: Intel 22nm family: 6
    model-id: 0x3A (58) stepping: 9 microcode: 0x21
    L3: 6 MiB desc: 1x6 MiB
  Speed (MHz): avg: 1290 high: 1927 min/max: 1200/3100 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 1200 2: 1200 3: 1200
    4: 1200 5: 1927 6: 1200 7: 1200 8: 1200 bogomips: 33536
  Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
    vulnerable
    STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
  Type: srbds status: Vulnerable: No microcode
  Device-1: Intel 3rd Gen Core processor Graphics
    vendor: Fujitsu . LIFEBOOK E752 driver: i915 v: kernel arch: Gen-7
    process: Intel 22nm built: 2012-13 ports: active: HDMI-A-3,LVDS-1
    empty: DP-1, DP-2, DP-3, HDMI-A-1, HDMI-A-2, VGA-1 bus-ID: 00:02.0
    chip-ID: 8086:0166 class-ID: 0300
  Device-2: Chicony FJ Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.6:5 chip-ID: 04f2:b2fc
    class-ID: 0e02
  Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.1
    compositor: gnome-shell driver: gpu: i915 display-ID: 0
  Monitor-1: HDMI-A-3 model: LG (GoldStar) PROJECTOR serial: <filter>
    built: 2018 res: 1920x1080 dpi: 30 gamma: 1.2 size: 1600x900mm (62.99x35.43")
    diag: 1836mm (72.3") ratio: 16:9 modes: max: 1920x1080 min: 720x400
  Monitor-2: LVDS-1 model: Lenovo 0x40b1 built: 2009 res: 1600x900 dpi: 118
    gamma: 1.2 size: 345x194mm (13.58x7.64") diag: 396mm (15.6") ratio: 16:9
    modes: 1600x900
  API: OpenGL v: 4.2 Mesa 23.0.4 renderer: Mesa Intel HD Graphics 4000 (IVB
    GT2) direct-render: Yes
  Device-1: Intel 7 Series/C216 Family High Definition Audio
    vendor: Fujitsu . LIFEBOOK E752 driver: snd_hda_intel v: kernel
    bus-ID: 00:1b.0 chip-ID: 8086:1e20 class-ID: 0403
  API: ALSA v: k6.1.31-2-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.70 status: off tools: pw-cli
  Device-1: Intel 82579V Gigabit Network vendor: Fujitsu . LIFEBOOK E752
    driver: e1000e v: kernel port: 4080 bus-ID: 00:19.0 chip-ID: 8086:1503
    class-ID: 0200
  IF: enp0s25 state: down mac: <filter>
  Device-2: Intel Centrino Advanced-N 6205 [Taylor Peak] driver: iwlwifi
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 0a:00.0
    chip-ID: 8086:0082 class-ID: 0280
  IF: wlp10s0 state: up mac: <filter>
  Device-1: Foxconn / Hon Hai BCM20702A0 driver: btusb v: 0.8 type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1.3:4 chip-ID: 0489:e052
  Local Storage: total: 465.76 GiB used: 90.93 GiB (19.5%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 500GB
    tech: SSD serial: <filter> fw-rev: 1B6Q scheme: GPT
  ID-1: / raw-size: 465.46 GiB size: 457.09 GiB (98.20%)
    used: 90.93 GiB (19.9%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
    used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
  System Temperatures: cpu: 52.0 C mobo: N/A
  Processes: 263 Uptime: 1h 0m wakeups: 1 Memory: available: 7.62 GiB
  used: 3.91 GiB (51.3%) Init: systemd v: 253 default: graphical
  tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: 1611
  pm: pacman pkgs: 1580 libs: 385 tools: gnome-software,pamac,yay pm: flatpak
  pkgs: 31 Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.27
The MS Nano Tranceiver entries seem to be related to the remote keyboard/touchpad (dissapear when disconnected):
I: Bus=0019 Vendor=0000 Product=0005 Version=0000
N: Name="Lid Switch"
P: Phys=PNP0C0D/button/input0
S: Sysfs=/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input0
U: Uniq=
H: Handlers=event0
B: PROP=0
B: EV=21
B: SW=1
I: Bus=0019 Vendor=0000 Product=0001 Version=0000
N: Name="Power Button"
P: Phys=PNP0C0C/button/input0
S: Sysfs=/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
U: Uniq=
H: Handlers=kbd event1
B: PROP=0
B: EV=3
B: KEY=10000000000000 0
I: Bus=0019 Vendor=0000 Product=0003 Version=0000
N: Name="Sleep Button"
P: Phys=PNP0C0E/button/input0
S: Sysfs=/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input2
U: Uniq=
H: Handlers=kbd event2
B: PROP=0
B: EV=3
B: KEY=4000 0 0
I: Bus=0011 Vendor=0001 Product=0001 Version=ab54
N: Name="AT Translated Set 2 keyboard"
P: Phys=isa0060/serio0/input0
S: Sysfs=/devices/platform/i8042/serio0/input/input3
U: Uniq=
H: Handlers=sysrq kbd leds event3
B: PROP=0
B: EV=120013
B: KEY=402000000 3803078f800d001 feffffdfffefffff fffffffffffffffe
B: MSC=10
B: LED=7
I: Bus=0010 Vendor=001f Product=0001 Version=0100
N: Name="PC Speaker"
P: Phys=isa0061/input0
S: Sysfs=/devices/platform/pcspkr/input/input14
U: Uniq=
H: Handlers=kbd event9
B: PROP=0
B: EV=40001
B: SND=6
I: Bus=0019 Vendor=0000 Product=0000 Version=0000
N: Name="Fujitsu FUJ02E3"
P: Phys=FUJ02E3/input0
S: Sysfs=/devices/LNXSYSTM:00/LNXSYBUS:00/FUJ02E3:00/input/input15
U: Uniq=
H: Handlers=kbd event10 rfkill
B: PROP=0
B: EV=13
B: KEY=40000 0 0 0 0 181000000000c00 300000 0 0
B: MSC=10
I: Bus=0003 Vendor=04f2 Product=b2fc Version=9783
N: Name="FJ Camera : FJ Camera "
P: Phys=usb-0000:00:1a.0-1.6/button
S: Sysfs=/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.6/1-1.6:1.0/input/input20
U: Uniq=
H: Handlers=kbd event11
B: PROP=0
B: EV=3
B: KEY=100000 0 0 0
I: Bus=0019 Vendor=0000 Product=0006 Version=0000
N: Name="Video Bus"
P: Phys=LNXVIDEO/video/input0
S: Sysfs=/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input21
U: Uniq=
H: Handlers=kbd event12
B: PROP=0
B: EV=3
B: KEY=3e000b00000000 0 0 0
I: Bus=0011 Vendor=0002 Product=0007 Version=01b1
N: Name="SynPS/2 Synaptics TouchPad"
P: Phys=isa0060/serio4/input0
S: Sysfs=/devices/platform/i8042/serio4/input/input19
U: Uniq=
H: Handlers=event13 mouse1
B: PROP=9
B: EV=b
B: KEY=6420 30003 0 0 0 0
B: ABS=260800011000003
I: Bus=0000 Vendor=0000 Product=0000 Version=0000
N: Name="HDA Intel PCH Mic"
P: Phys=ALSA
S: Sysfs=/devices/pci0000:00/0000:00:1b.0/sound/card0/input23
U: Uniq=
H: Handlers=event14
B: PROP=0
B: EV=21
B: SW=10
N: Name="HDA Intel PCH Dock Mic"
P: Phys=ALSA
S: Sysfs=/devices/pci0000:00/0000:00:1b.0/sound/card0/input24
U: Uniq=
H: Handlers=event15
B: PROP=0
B: EV=21
B: SW=10
N: Name="HDA Intel PCH Dock Headphone"
P: Phys=ALSA
S: Sysfs=/devices/pci0000:00/0000:00:1b.0/sound/card0/input25
U: Uniq=
H: Handlers=event16
B: PROP=0
B: EV=21
B: SW=4
N: Name="HDA Intel PCH Front Headphone"
P: Phys=ALSA
S: Sysfs=/devices/pci0000:00/0000:00:1b.0/sound/card0/input26
U: Uniq=
H: Handlers=event17
B: PROP=0
B: EV=21
B: SW=4
N: Name="HDA Intel PCH HDMI/DP,pcm=3"
P: Phys=ALSA
S: Sysfs=/devices/pci0000:00/0000:00:1b.0/sound/card0/input27
U: Uniq=
H: Handlers=event18
B: PROP=0
B: EV=21
B: SW=140
N: Name="HDA Intel PCH HDMI/DP,pcm=7"
P: Phys=ALSA
S: Sysfs=/devices/pci0000:00/0000:00:1b.0/sound/card0/input28
U: Uniq=
H: Handlers=event19
B: PROP=0
B: EV=21
B: SW=140
I: Bus=0003 Vendor=045e Product=0800 Version=0111
N: Name="Microsoft Microsoft® Nano Transceiver v2.0"
P: Phys=usb-0000:00:14.0-3/input0
S: Sysfs=/devices/pci0000:00/0000:00:14.0/usb3/3-3/3-3:1.0/0003:045E:0800.0004/input/input29
U: Uniq=
H: Handlers=sysrq kbd leds event4
B: PROP=0
B: EV=120013
B: KEY=1000000000007 ff800000000007ff febeffdff3cfffff fffffffffffffffe
B: MSC=10
B: LED=7
N: Name="Microsoft Microsoft® Nano Transceiver v2.0 Mouse"
P: Phys=usb-0000:00:14.0-3/input1
S: Sysfs=/devices/pci0000:00/0000:00:14.0/usb3/3-3/3-3:1.1/0003:045E:0800.0005/input/input30
U: Uniq=
H: Handlers=event5 mouse0
B: PROP=0
B: EV=17
B: KEY=1f0000 0 0 0 0
B: REL=1943
B: MSC=10
N: Name="Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control"
S: Sysfs=/devices/pci0000:00/0000:00:14.0/usb3/3-3/3-3:1.1/0003:045E:0800.0005/input/input31
U: Uniq=
H: Handlers=event6
B: PROP=0
B: EV=5
B: REL=1040
P: Phys=usb-0000:00:14.0-3/input2
S: Sysfs=/devices/pci0000:00/0000:00:14.0/usb3/3-3/3-3:1.2/0003:045E:0800.0006/input/input32
U: Uniq=
H: Handlers=sysrq kbd event7
B: PROP=0
B: EV=10001f
B: KEY=3f000307ff 0 0 483ffff17aff32d bfd4444600000000 1 130ff38b17d007 ffff7bfad9415fff ffbeffdfffefffff fffffffffffffffe
B: REL=1040
B: ABS=100000000
B: MSC=10
N: Name="Microsoft Microsoft® Nano Transceiver v2.0 System Control"
S: Sysfs=/devices/pci0000:00/0000:00:14.0/usb3/3-3/3-3:1.2/0003:045E:0800.0006/input/input34
U: Uniq=
H: Handlers=kbd event8
B: PROP=0
B: EV=1b
B: KEY=40000001000000 1200000000 0 100000800000000 40000010cc00 10168000000000 0
B: ABS=10000000000
B: MSC=10
Find your touchpad id in:
$ xinput list
then:
$ xinput list-props <touchpad id>
ensure Device Enabled (<note this number>) has value 1, if not:
$ xinput set-prop <touchpad id> <that noted number or "Device Enabled", yes in quotes> 1
Thanks a lot for your reply. I checked the props for all listed devices via ‘xinput list’, starting with pointers but also for the keyboard entries (id 2-9). All of them have value 1 for the “device enabled” property.
Please excuse, I’m not very experienced with client-side Linux, especially not with Arch-based systems, but I was wondering a bit, why in xinput the devices seem to use wayland driver, but for libinput -list-devices the pointer/touchpad seems to be a Synaptics device (see first post). Don’t know if that’s relevant at all, but somehow feels this could be conflicting…
Output of xinput list:
WARNING: running xinput against an Xwayland server. See the xinput man page for details.
⎡ Virtual core pointer                    	id=2	[master pointer  (3)]
⎜   ↳ Virtual core XTEST pointer              	id=4	[slave  pointer  (2)]
⎜   ↳ xwayland-pointer:16                     	id=6	[slave  pointer  (2)]
⎜   ↳ xwayland-relative-pointer:16            	id=7	[slave  pointer  (2)]
⎜   ↳ xwayland-pointer-gestures:16            	id=8	[slave  pointer  (2)]
⎣ Virtual core keyboard                   	id=3	[master keyboard (2)]
    ↳ Virtual core XTEST keyboard             	id=5	[slave  keyboard (3)]
    ↳ xwayland-keyboard:16                    	id=9	[slave  keyboard (3)]
Edit: I just tried the libinput debug-gui tool and surprisingly there (and only there) the touchpad behaves as expected :face_with_monocle:
SOLUTION:
https://wiki.archlinux.org/title/Libinput#Touchpad_not_working_in_GNOME
