Hi all
im totally new with Linux. fits time i did install Manjaro and touchpad not detected doesn’t work.
i did tried to install drivers but noting.
Gnome version 3.36.6
Windows system X11
Can someone help me please ? Thank you
Please post the output of inxi -Fazy
, ls -l /sys/bus/acpi/devices/
, ls -l /sys/bus/i2c/devices/
, and ls -l /dev/input/*/
. Also install evtest
, then run it in a terminal and see if you can select your touchpad.
System: Kernel: 5.8.16-2-MANJARO x86_64 bits: 64 compiler: N/A parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64 root=UUID=99b038a2-53d6-4caa-9562-b0ff7342f6f2 rw quiet apparmor=1 security=apparmor udev.log_priority=3 Desktop: GNOME 3.36.6 tk: GTK 3.24.23 wm: gnome-shell dm: GDM 3.36.3 Distro: Manjaro Linux Machine: Type: Laptop System: Acer product: Aspire ES1-521 v: V1.06 serial: <filter> Chassis: type: 9 serial: <filter> Mobo: Acer model: BELLEMERE_BE v: V1.06 serial: <filter> UEFI: Insyde v: 1.06 date: 08/11/2015 Battery: ID-1: BAT1 charge: 29.8 Wh condition: 29.8/37.8 Wh (79%) volts: 12.7/11.4 model: COMPAL PABAS0241231 type: Li-ion serial: <filter> status: Full CPU: Topology: Quad Core model: AMD A6-6310 APU with AMD Radeon R4 Graphics bits: 64 type: MCP arch: Puma family: 16 (22) model-id: 30 (48) stepping: 1 microcode: 7030105 L2 cache: 2048 KiB flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 14379 Speed: 1086 MHz min/max: 1000/1800 MHz boost: enabled Core speeds (MHz): 1: 1183 2: 1090 3: 1334 4: 1050 Vulnerabilities: Type: itlb_multihit status: Not affected Type: l1tf status: Not affected Type: mds status: Not affected Type: meltdown status: Not affected Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via prctl and seccomp Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer sanitization Type: spectre_v2 mitigation: Full AMD retpoline, STIBP: disabled, RSB filling Type: srbds status: Not affected Type: tsx_async_abort status: Not affected Graphics: Device-1: AMD Mullins [Radeon R4/R5 Graphics] vendor: Acer Incorporated ALI driver: radeon v: kernel alternate: amdgpu bus ID: 00:01.0 chip ID: 1002:9851 Device-2: Realtek Acer 640 × 480 laptop camera type: USB driver: uvcvideo bus ID: 1-1.4:5 chip ID: 0bda:57b3 serial: <filter> Display: x11 server: X.org 1.20.9 compositor: gnome-shell driver: ati,radeon unloaded: modesetting alternate: fbdev,vesa resolution: <xdpyinfo missing> OpenGL: renderer: AMD KABINI (DRM 2.50.0 5.8.16-2-MANJARO LLVM 10.0.1) v: 4.5 Mesa 20.1.8 direct render: Yes Audio: Device-1: AMD Kabini HDMI/DP Audio vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel bus ID: 00:01.1 chip ID: 1002:9840 Device-2: AMD FCH Azalia vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel bus ID: 00:14.2 chip ID: 1022:780d Sound Server: ALSA v: k5.8.16-2-MANJARO Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 2000 bus ID: 01:00.0 chip ID: 10ec:8168 IF: enp1s0 state: down mac: <filter> Device-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter vendor: Lite-On driver: ath9k v: kernel port: 2000 bus ID: 02:00.0 chip ID: 168c:0036 IF: wlp2s0 state: up mac: <filter> Device-3: Lite-On Atheros AR3012 Bluetooth type: USB driver: btusb bus ID: 1-1.3:6 chip ID: 04ca:300b Drives: Local Storage: total: 476.94 GiB used: 8.51 GiB (1.8%) SMART Message: Required tool smartctl not installed. Check --recommends ID-1: /dev/sda vendor: Foresee model: 512GB SSD size: 476.94 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: 117B scheme: GPT Partition: ID-1: / raw size: 476.64 GiB size: 468.16 GiB (98.22%) used: 8.51 GiB (1.8%) fs: ext4 dev: /dev/sda2 Swap: Alert: No Swap data was found. Sensors: System Temperatures: cpu: 57.2 C mobo: N/A gpu: radeon temp: 52 C Fan Speeds (RPM): N/A Info: Processes: 208 Uptime: 47m Memory: 4.78 GiB used: 1.54 GiB (32.1%) Init: systemd v: 246 Compilers: gcc: 10.2.0 clang: 10.0.1 Packages: pacman: 1201 lib: 314 flatpak: 0 Shell: Zsh v: 5.8 running in: gnome-terminal inxi: 3.1.05
>>> ls -l /sys/bus/acpi/devices/ [130] total 0 lrwxrwxrwx 1 root root 0 Oct 31 15:39 10250759:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:21/10250759:00 lrwxrwxrwx 1 root root 0 Oct 31 15:39 ACPI0003:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:21/ACPI0003:00 lrwxrwxrwx 1 root root 0 Oct 31 15:39 ACPI0003:01 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/ACPI0003:01 lrwxrwxrwx 1 root root 0 Oct 31 15:39 device:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/device:00 lrwxrwxrwx 1 root root 0 Oct 31 15:39 device:01 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:01 lrwxrwxrwx 1 root root 0 Oct 31 15:39 device:02 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:01/device:02 lrwxrwxrwx 1 root root 0 Oct 31 15:39 device:03 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:03 lrwxrwxrwx 1 root root 0 Oct 31 15:39 device:04 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:03/device:04 lrwxrwxrwx 1 root root 0 Oct 31 15:39 device:05 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:05 lrwxrwxrwx 1 root root 0 Oct 31 15:39 device:06 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:05/device:06 lrwxrwxrwx 1 root root 0 Oct 31 15:39 device:07 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:07 lrwxrwxrwx 1 root root 0 Oct 31 15:39 device:08 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:07/device:08 lrwxrwxrwx 1 root root 0 Oct 31 15:39 device:09 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:09 lrwxrwxrwx 1 root root 0 Oct 31 15:39 device:0a -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:09/LNXVIDEO:01/device:0a lrwxrwxrwx 1 root root 0 Oct 31 15:39 device:0b -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:09/device:0b lrwxrwxrwx 1 root root 0 Oct 31 15:39 device:0c -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0c lrwxrwxrwx 1 root root 0 Oct 31 15:39 device:0d -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0d lrwxrwxrwx 1 root root 0 Oct 31 15:39 device:0e -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0d/device:0e lrwxrwxrwx 1 root root 0 Oct 31 15:39 device:0f -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0d/device:0e/device:0f lrwxrwxrwx 1 root root 0 Oct 31 15:39 device:10 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0d/device:0e/device:0f/device:10 lrwxrwxrwx 1 root root 0 Oct 31 15:39 device:11 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0d/device:0e/device:0f/device:11 lrwxrwxrwx 1 root root 0 Oct 31 15:39 device:12 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0d/device:0e/device:0f/device:11/device:12 lrwxrwxrwx 1 root root 0 Oct 31 15:39 device:13 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:13 lrwxrwxrwx 1 root root 0 Oct 31 15:39 device:14 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:13/device:14 lrwxrwxrwx 1 root root 0 Oct 31 15:39 device:15 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:13/device:14/device:15 lrwxrwxrwx 1 root root 0 Oct 31 15:39 device:16 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:13/device:14/device:15/device:16 lrwxrwxrwx 1 root root 0 Oct 31 15:39 device:17 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:13/device:14/device:15/device:17 lrwxrwxrwx 1 root root 0 Oct 31 15:39 device:18 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:13/device:14/device:15/device:18 lrwxrwxrwx 1 root root 0 Oct 31 15:39 device:19 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:19 lrwxrwxrwx 1 root root 0 Oct 31 15:39 device:1a -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1a lrwxrwxrwx 1 root root 0 Oct 31 15:39 device:1b -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1a/device:1b lrwxrwxrwx 1 root root 0 Oct 31 15:39 device:1c -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1a/device:1b/device:1c lrwxrwxrwx 1 root root 0 Oct 31 15:39 device:1d -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1a/device:1b/device:1d lrwxrwxrwx 1 root root 0 Oct 31 15:39 device:1e -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1a/device:1b/device:1e lrwxrwxrwx 1 root root 0 Oct 31 15:39 device:1f -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1a/device:1b/device:1f lrwxrwxrwx 1 root root 0 Oct 31 15:39 device:20 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:20 lrwxrwxrwx 1 root root 0 Oct 31 15:39 device:21 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:21 lrwxrwxrwx 1 root root 0 Oct 31 15:39 device:22 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:22 lrwxrwxrwx 1 root root 0 Oct 31 15:39 device:23 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:22/device:23 lrwxrwxrwx 1 root root 0 Oct 31 15:39 device:24 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:22/device:23/device:24 lrwxrwxrwx 1 root root 0 Oct 31 15:39 device:25 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:22/device:23/device:25 lrwxrwxrwx 1 root root 0 Oct 31 15:39 device:26 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:22/device:26 lrwxrwxrwx 1 root root 0 Oct 31 15:39 device:27 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:22/device:26/device:27 lrwxrwxrwx 1 root root 0 Oct 31 15:39 device:28 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:22/device:26/device:28 lrwxrwxrwx 1 root root 0 Oct 31 15:39 device:29 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:29 lrwxrwxrwx 1 root root 0 Oct 31 15:39 device:2a -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:29/device:2a lrwxrwxrwx 1 root root 0 Oct 31 15:39 device:2b -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:29/device:2a/device:2b lrwxrwxrwx 1 root root 0 Oct 31 15:39 device:2c -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:29/device:2a/device:2c lrwxrwxrwx 1 root root 0 Oct 31 15:39 device:2d -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:29/device:2d lrwxrwxrwx 1 root root 0 Oct 31 15:39 device:2e -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:29/device:2d/device:2e lrwxrwxrwx 1 root root 0 Oct 31 15:39 device:2f -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:29/device:2d/device:2f lrwxrwxrwx 1 root root 0 Oct 31 15:39 device:30 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:30 lrwxrwxrwx 1 root root 0 Oct 31 15:39 ELAN0501:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/ENE0300:00/ELAN0501:00 lrwxrwxrwx 1 root root 0 Oct 31 15:39 ENE0300:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/ENE0300:00 lrwxrwxrwx 1 root root 0 Oct 31 15:39 ETD0502:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:21/ETD0502:00 lrwxrwxrwx 1 root root 0 Oct 31 15:39 LNXCPU:00 -> ../../../devices/LNXSYSTM:00/LNXCPU:00 lrwxrwxrwx 1 root root 0 Oct 31 15:39 LNXCPU:01 -> ../../../devices/LNXSYSTM:00/LNXCPU:01 lrwxrwxrwx 1 root root 0 Oct 31 15:39 LNXCPU:02 -> ../../../devices/LNXSYSTM:00/LNXCPU:02 lrwxrwxrwx 1 root root 0 Oct 31 15:39 LNXCPU:03 -> ../../../devices/LNXSYSTM:00/LNXCPU:03 lrwxrwxrwx 1 root root 0 Oct 31 15:39 LNXPWRBN:00 -> ../../../devices/LNXSYSTM:00/LNXPWRBN:00 lrwxrwxrwx 1 root root 0 Oct 31 15:39 LNXSYBUS:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00 lrwxrwxrwx 1 root root 0 Oct 31 15:39 LNXSYBUS:01 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:01 lrwxrwxrwx 1 root root 0 Oct 31 15:39 LNXSYSTM:00 -> ../../../devices/LNXSYSTM:00 lrwxrwxrwx 1 root root 0 Oct 31 15:39 LNXVIDEO:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00 lrwxrwxrwx 1 root root 0 Oct 31 15:39 LNXVIDEO:01 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:09/LNXVIDEO:01 lrwxrwxrwx 1 root root 0 Oct 31 15:39 PNP0000:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:21/PNP0000:00 lrwxrwxrwx 1 root root 0 Oct 31 15:39 PNP0100:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:21/PNP0100:00 lrwxrwxrwx 1 root root 0 Oct 31 15:39 PNP0103:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/PNP0103:00 lrwxrwxrwx 1 root root 0 Oct 31 15:39 PNP0200:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:21/PNP0200:00 lrwxrwxrwx 1 root root 0 Oct 31 15:39 PNP0800:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:21/PNP0800:00 lrwxrwxrwx 1 root root 0 Oct 31 15:39 PNP0A08:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00 lrwxrwxrwx 1 root root 0 Oct 31 15:39 PNP0B00:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:21/PNP0B00:00 lrwxrwxrwx 1 root root 0 Oct 31 15:39 PNP0C01:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:21/PNP0C01:00 lrwxrwxrwx 1 root root 0 Oct 31 15:39 PNP0C02:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/PNP0C02:00 lrwxrwxrwx 1 root root 0 Oct 31 15:39 PNP0C02:01 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:21/PNP0C02:01 lrwxrwxrwx 1 root root 0 Oct 31 15:39 PNP0C02:02 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C02:02 lrwxrwxrwx 1 root root 0 Oct 31 15:39 PNP0C02:03 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C02:02/PNP0C02:03 lrwxrwxrwx 1 root root 0 Oct 31 15:39 PNP0C02:04 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C02:02/PNP0C02:04 lrwxrwxrwx 1 root root 0 Oct 31 15:39 PNP0C02:05 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C02:02/PNP0C02:05 lrwxrwxrwx 1 root root 0 Oct 31 15:39 PNP0C02:06 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C02:02/PNP0C02:06 lrwxrwxrwx 1 root root 0 Oct 31 15:39 PNP0C02:07 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C02:02/PNP0C02:07 lrwxrwxrwx 1 root root 0 Oct 31 15:39 PNP0C04:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:21/PNP0C04:00 lrwxrwxrwx 1 root root 0 Oct 31 15:39 PNP0C09:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:21/PNP0C09:00 lrwxrwxrwx 1 root root 0 Oct 31 15:39 PNP0C0A:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0A:00 lrwxrwxrwx 1 root root 0 Oct 31 15:39 PNP0C0C:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00 lrwxrwxrwx 1 root root 0 Oct 31 15:39 PNP0C0D:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00 lrwxrwxrwx 1 root root 0 Oct 31 15:39 PNP0C0E:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00 lrwxrwxrwx 1 root root 0 Oct 31 15:39 PNP0C0F:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0F:00 lrwxrwxrwx 1 root root 0 Oct 31 15:39 PNP0C0F:01 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0F:01 lrwxrwxrwx 1 root root 0 Oct 31 15:39 PNP0C0F:02 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0F:02 lrwxrwxrwx 1 root root 0 Oct 31 15:39 PNP0C0F:03 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0F:03 lrwxrwxrwx 1 root root 0 Oct 31 15:39 PNP0C0F:04 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0F:04 lrwxrwxrwx 1 root root 0 Oct 31 15:39 PNP0C0F:05 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0F:05 lrwxrwxrwx 1 root root 0 Oct 31 15:39 PNP0C0F:06 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0F:06 lrwxrwxrwx 1 root root 0 Oct 31 15:39 PNP0C0F:07 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0F:07 lrwxrwxrwx 1 root root 0 Oct 31 15:39 PNP0C14:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C14:00 lrwxrwxrwx 1 root root 0 Oct 31 15:39 PNP0C14:01 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C14:01 lrwxrwxrwx 1 root root 0 Oct 31 15:39 SYN1B7E:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:21/SYN1B7E:00 lrwxrwxrwx 1 root root 0 Oct 31 15:39 SYN1B7E:01 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/ENE0300:00/SYN1B7E:01 ~ >>>
~ >>> ls -l /sys/bus/i2c/devices/ [130] total 0 lrwxrwxrwx 1 root root 0 Oct 31 16:11 i2c-0 -> ../../../devices/pci0000:00/0000:00:01.0/i2c-0 lrwxrwxrwx 1 root root 0 Oct 31 16:11 i2c-1 -> ../../../devices/pci0000:00/0000:00:01.0/i2c-1 lrwxrwxrwx 1 root root 0 Oct 31 16:11 i2c-2 -> ../../../devices/pci0000:00/0000:00:01.0/i2c-2 lrwxrwxrwx 1 root root 0 Oct 31 16:11 i2c-3 -> ../../../devices/pci0000:00/0000:00:01.0/i2c-3 lrwxrwxrwx 1 root root 0 Oct 31 16:11 i2c-4 -> ../../../devices/pci0000:00/0000:00:01.0/i2c-4 lrwxrwxrwx 1 root root 0 Oct 31 16:11 i2c-5 -> ../../../devices/pci0000:00/0000:00:01.0/i2c-5 lrwxrwxrwx 1 root root 0 Oct 31 16:11 i2c-6 -> ../../../devices/pci0000:00/0000:00:01.0/i2c-6 lrwxrwxrwx 1 root root 0 Oct 31 16:11 i2c-7 -> ../../../devices/pci0000:00/0000:00:01.0/i2c-7 lrwxrwxrwx 1 root root 0 Oct 31 16:11 i2c-8 -> ../../../devices/pci0000:00/0000:00:01.0/drm/card0/card0-eDP-1/i2c-8 ~ >>>
/dev/input/by-path/: total 0 lrwxrwxrwx 1 root root 10 Oct 31 16:28 pci-0000:00:12.0-usb-0:1.2:1.1-event-kbd -> ../event12 lrwxrwxrwx 1 root root 10 Oct 31 16:28 pci-0000:00:12.0-usb-0:1.2:1.1-event-mouse -> ../event13 lrwxrwxrwx 1 root root 9 Oct 31 16:28 pci-0000:00:12.0-usb-0:1.2:1.1-mouse -> ../mouse0 lrwxrwxrwx 1 root root 10 Oct 31 15:40 pci-0000:00:12.0-usb-0:1.4:1.0-event -> ../event11 lrwxrwxrwx 1 root root 9 Oct 31 15:39 platform-i8042-serio-0-event-kbd -> ../event5 lrwxrwxrwx 1 root root 9 Oct 31 15:39 platform-pcspkr-event-spkr -> ../event6 ~ >>>
>>> evtest No device specified, trying to scan all of /dev/input/event* Not running as root, no devices may be available. Available devices: /dev/input/event0: Power Button /dev/input/event1: Sleep Button /dev/input/event2: Lid Switch /dev/input/event3: Power Button /dev/input/event4: Video Bus /dev/input/event5: AT Translated Set 2 keyboard /dev/input/event6: PC Speaker /dev/input/event7: HDA ATI HDMI HDMI/DP,pcm=3 /dev/input/event8: HDA Digital PCBeep /dev/input/event9: HD-Audio Generic Headphone /dev/input/event10: Acer WMI hotkeys /dev/input/event11: VGA Webcam: VGA Webcam /dev/input/event12: Logitech Wireless Keyboard PID:4023 /dev/input/event13: Logitech Wireless Mouse Select the device event number [0-13]:
Please run cat /sys/bus/acpi/devices/ELAN0501:00/status
~ >>> cat /sys/bus/acpi/devices/ELAN0501:00/status 15 ~ >>>
Any solution please?
i just put back hdd with Windows 10 and Touchpad works no problem.
Perfect support
Disappointed
I found solution… Bios settings, touchpad was in advance mode i change it to basic and it works now.
Hey, thanks MEEM! I just installed Manjaro yesterday, and this solved my touchpad as well.
That’s work in my case. Thanks for sharing!
To use the Advanced Touchpad features, you’ll need to revert to Windows 10.
