Hi
my touchpad works fine except that I am not able to perform tasks on vertical 3/4 fingers swipe or pinch gestures.
3/4 fingers horizontal swipes work fine.
Already tried : fusuma, touchegg, gesture. Always the same problem. So I think I’ll stick with ‘gesture’ unless imperious reasons.
“libinput debug-gui” show the gestures are recognised.
First what I’m playing with :
[jaco@Lclodo ~]$ inxi -Fazy
Kernel: 6.9.0-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.9-x86_64
root=UUID=a6712c84-a233-4860-8285-3fc63b997dbb rw quiet splash apparmor=1
security=apparmor resume=UUID=9accaba2-c78f-424b-9edd-436a1dab5ac9
udev.log_priority=3
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 wm: xfwm4 v: 4.18.0
with: xfce4-panel tools: xfce4-screensaver vt: 7 dm: LightDM v: 1.32.0
Type: Laptop System: LENOVO product: 20FMS0SR00 v: ThinkPad T460
Mobo: LENOVO model: 20FMS0SR00 v: SDK0J40705 WIN
serial: <superuser required>
part-nu: LENOVO_MT_20FM_BU_Think_FM_ThinkPad T460
uuid: <superuser required> UEFI: LENOVO v: R06ET67W (1.41 )
date: 05/07/2019
ID-1: BAT1 charge: 66.8 Wh (97.7%) condition: 68.4/71.3 Wh (96.0%)
power: 7.3 W volts: 12.1 min: 10.8 model: SANYO 45N1777 type: Li-ion
serial: <filter> status: discharging
Info: model: Intel Core i5-6300U bits: 64 type: MT MCP arch: Skylake
gen: core 6 level: v3 note: check built: 2015 process: Intel 14nm family: 6
model-id: 0x4E (78) stepping: 3 microcode: 0xF0
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 895 high: 900 min/max: 400/3000 scaling:
driver: intel_pstate governor: powersave cores: 1: 882 2: 900 3: 900 4: 900
bogomips: 20004
Type: gather_data_sampling status: Vulnerable: No microcode
vulnerable
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Lenovo driver: i915
v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports: active: eDP-1
empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:1916
class-ID: 0300
Device-2: Bison ThinkPad P50 Integrated Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-10:4 chip-ID: 5986:0706
class-ID: 0e02
Display: x11 server: X.org v: 1.21.1.13 compositor: xfwm4 v: 4.18.0 driver:
X: loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 s-size: <missing: xdpyinfo>
Monitor-1: eDP-1 model: AU Optronics 0x2e3c built: 2013 res: 1366x768
hz: 60 dpi: 112 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9")
ratio: 16:9 modes: 1366x768
device: 1 drv: swrast surfaceless: drv: iris x11: drv: iris
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.6-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 520 (SKL GT2)
device-ID: 8086:1916 memory: 7.44 GiB unified: yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_soc_avs
bus-ID: 00:1f.3 chip-ID: 8086:9d70 class-ID: 0403
API: ALSA v: k6.9.0-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.5 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I219-LM vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:156f class-ID: 0200
IF: enp0s31f6 state: down mac: <filter>
Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:24f3 class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:3 chip-ID: 8087:0a2b
class-ID: e001
Local Storage: total: 238.47 GiB used: 12.72 GiB (5.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SD7TB6S256G1001
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 1201 scheme: GPT
ID-1: / raw-size: 229.37 GiB size: 224.71 GiB (97.97%) used: 12.72 GiB (5.7%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2
used: 296 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 41.0 C pch: 38.5 C mobo: N/A
Fan Speeds (rpm): fan-1: 0
Memory: total: 8 GiB available: 7.62 GiB used: 2.69 GiB (35.3%)
Processes: 226 Power: uptime: 8m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 3.03 GiB services: upowerd,xfce4-power-manager
Init: systemd v: 255 default: graphical tool: systemctl
Packages: 1091 pm: pacman pkgs: 1077 libs: 339 tools: pamac pm: flatpak
pkgs: 6 pm: snap pkgs: 8 Compilers: N/A Shell: Bash v: 5.2.26
running-in: xfce4-terminal inxi: 3.3.34
Then the damned touchpad
[jaco@Lclodo ~]$ libinput list-devices
Device: SynPS/2 Synaptics TouchPad
Kernel: /dev/input/event7
Group: 6
Seat: seat0, default
Capabilities: pointer gesture
Tap-to-click: disabled
Tap-and-drag: enabled
Tap drag lock: disabled
Left-handed: disabled
Nat.scrolling: disabled
Middle emulation: disabled
Calibration: n/a
Scroll methods: *two-finger edge
Click methods: *button-areas clickfinger
Disable-w-typing: enabled
Disable-w-trackpointing: enabled
Accel profiles: flat *adaptive custom
Rotation: n/a
And its complete prop :
[jaco@Lclodo ~]$ xinput --list-props "SynPS/2 Synaptics TouchPad"
Device 'SynPS/2 Synaptics TouchPad':
Device Enabled (184): 1
Coordinate Transformation Matrix (186): 1.000000, 0.000000, 0.000000, 0.000000, 1.000000, 0.000000, 0.000000, 0.000000, 1.000000
libinput Tapping Enabled (316): 1
libinput Tapping Enabled Default (317): 0
libinput Tapping Drag Enabled (318): 1
libinput Tapping Drag Enabled Default (319): 1
libinput Tapping Drag Lock Enabled (320): 0
libinput Tapping Drag Lock Enabled Default (321): 0
libinput Tapping Button Mapping Enabled (322): 1, 0
libinput Tapping Button Mapping Default (323): 1, 0
libinput Natural Scrolling Enabled (324): 1
libinput Natural Scrolling Enabled Default (325): 0
libinput Disable While Typing Enabled (326): 1
libinput Disable While Typing Enabled Default (327): 1
libinput Scroll Methods Available (328): 1, 1, 0
libinput Scroll Method Enabled (329): 1, 0, 0
libinput Scroll Method Enabled Default (330): 1, 0, 0
libinput Click Methods Available (331): 1, 1
libinput Click Method Enabled (332): 1, 0
libinput Click Method Enabled Default (333): 1, 0
libinput Middle Emulation Enabled (334): 0
libinput Middle Emulation Enabled Default (335): 0
libinput Accel Speed (336): 0.460000
libinput Accel Speed Default (337): 0.000000
libinput Accel Profiles Available (338): 1, 1, 1
libinput Accel Profile Enabled (339): 1, 0, 0
libinput Accel Profile Enabled Default (340): 1, 0, 0
libinput Accel Custom Fallback Points (341): <no items>
libinput Accel Custom Fallback Step (342): 0.000000
libinput Accel Custom Motion Points (343): <no items>
libinput Accel Custom Motion Step (344): 0.000000
libinput Accel Custom Scroll Points (345): <no items>
libinput Accel Custom Scroll Step (346): 0.000000
libinput Left Handed Enabled (347): 0
libinput Left Handed Enabled Default (348): 0
libinput Send Events Modes Available (301): 1, 1
libinput Send Events Mode Enabled (302): 0, 0
libinput Send Events Mode Enabled Default (303): 0, 0
Device Node (304): "/dev/input/event7"
Device Product ID (305): 2, 7
libinput Drag Lock Buttons (349): <no items>
libinput Horizontal Scroll Enabled (350): 1
libinput Scrolling Pixel Distance (351): 15
libinput Scrolling Pixel Distance Default (352): 15
libinput High Resolution Wheel Scroll Enabled (353): 1
Here is the libinput debug-events : first swipe 3fingers horizontal (that works fine), second swipe 3 fingers vertical that does nohting
[jaco@Lclodo ~]$ libinput debug-events
-event2 DEVICE_ADDED Power Button seat0 default group1 cap:k
-event4 DEVICE_ADDED Video Bus seat0 default group2 cap:k
-event0 DEVICE_ADDED Lid Switch seat0 default group3 cap:S
-event1 DEVICE_ADDED Sleep Button seat0 default group4 cap:k
-event3 DEVICE_ADDED AT Translated Set 2 keyboard seat0 default group5 cap:k
-event7 DEVICE_ADDED SynPS/2 Synaptics TouchPad seat0 default group6 cap:pg size 100x58mm tap(dl off) left scroll-nat scroll-2fg-edge click-buttonareas-clickfinger dwt-on dwtp-on
-event15 DEVICE_ADDED TPPS/2 IBM TrackPoint seat0 default group7 cap:p left scroll-nat scroll-button
-event6 DEVICE_ADDED ThinkPad Extra Buttons seat0 default group8 cap:k
-event7 GESTURE_HOLD_BEGIN +0.040s 2
event7 GESTURE_HOLD_END +0.142s 2 cancelled
event7 GESTURE_SWIPE_BEGIN +0.158s 3
event7 GESTURE_SWIPE_UPDATE +0.158s 3 -0.89/-3.82 (-1.43/-6.15 unaccelerated)
event7 GESTURE_SWIPE_UPDATE +0.178s 3 0.00/-6.70 ( 0.00/-6.80 unaccelerated)
event7 GESTURE_SWIPE_UPDATE +0.197s 3 0.00/-9.39 ( 0.00/-9.39 unaccelerated)
event7 GESTURE_SWIPE_UPDATE +0.216s 3 -0.96/-11.33 (-0.96/-11.33 unaccelerated)
event7 GESTURE_SWIPE_UPDATE +0.236s 3 -1.91/-14.25 (-1.91/-14.25 unaccelerated)
event7 GESTURE_SWIPE_UPDATE +0.255s 3 -1.43/-17.81 (-1.43/-17.81 unaccelerated)
event7 GESTURE_SWIPE_UPDATE +0.275s 3 -1.43/-17.48 (-1.43/-17.48 unaccelerated)
event7 GESTURE_SWIPE_UPDATE +0.293s 3 -1.43/-14.57 (-1.43/-14.57 unaccelerated)
event7 GESTURE_SWIPE_UPDATE +0.313s 3 -1.43/-13.60 (-1.43/-13.60 unaccelerated)
event7 GESTURE_SWIPE_UPDATE +0.332s 3 -1.43/-12.63 (-1.43/-12.63 unaccelerated)
event7 GESTURE_SWIPE_UPDATE +0.351s 3 -0.48/-10.68 (-0.48/-10.68 unaccelerated)
event7 GESTURE_SWIPE_END +0.380s 3
^[event7 - SynPS/2 Synaptics TouchPad: kernel bug: Touch jump detected and discarded.
See https://wayland.freedesktop.org/libinput/doc/1.25.0/touchpad-jumping-cursors.html for details
event7 GESTURE_SWIPE_BEGIN +3.514s 3
event7 GESTURE_SWIPE_UPDATE +3.514s 3 0.00/ 0.59 ( 0.00/ 0.65 unaccelerated)
event7 GESTURE_SWIPE_END +3.736s 3
event7 GESTURE_SWIPE_BEGIN +4.848s 4
event7 GESTURE_SWIPE_UPDATE +4.848s 4 -9.22/ 0.59 (-10.04/ 0.65 unaccelerated)
event7 GESTURE_SWIPE_UPDATE +4.867s 4 -19.13/ 3.89 (-19.13/ 3.89 unaccelerated)
event7 GESTURE_SWIPE_UPDATE +4.887s 4 -20.57/ 3.89 (-20.57/ 3.89 unaccelerated)
event7 GESTURE_SWIPE_UPDATE +4.906s 4 -24.39/ 3.89 (-24.39/ 3.89 unaccelerated)
event7 GESTURE_SWIPE_UPDATE +4.926s 4 -24.87/ 3.56 (-24.87/ 3.56 unaccelerated)
event7 GESTURE_SWIPE_UPDATE +4.944s 4 -24.87/ 2.27 (-24.87/ 2.27 unaccelerated)
event7 GESTURE_SWIPE_UPDATE +4.964s 4 -23.44/ 2.59 (-23.44/ 2.59 unaccelerated)
event7 GESTURE_SWIPE_UPDATE +4.983s 4 -22.48/ 1.62 (-22.48/ 1.62 unaccelerated)
event7 GESTURE_SWIPE_END +5.022s 4
-event3 KEYBOARD_KEY +9.531s *** (-1) pressed
event3 KEYBOARD_KEY +9.730s *** (-1) pressed
^C
And finally my config
[jaco@Lclodo ~]$ libinput-gestures -l
libinput-gestures: session xfce+x11 on Linux-6.9.0-1-MANJARO-x86_64-with-glibc2.39, python 3.12.3, libinput 1.25.0
Hash: 1e084483b086645ffe79e86f3b59961d
Gestures configured in ~/.config/libinput-gestures.conf:
swipe left 3 xdotool key Alt+Right
swipe right 3 xdotool key Alt+Left
swipe left 4 xdotool key Ctrl+Alt+Right
swipe right 4 xdotool key Ctrl+Alt+Left
swipe up 3 xdotool key Ctrl+Alt+D
libinput-gestures: device /dev/input/by-path/platform-i8042-serio-1-event-mouse(event7): SynPS/2 Synaptics TouchPad
libinput-gestures is installed.
libinput-gestures is set up as a desktop application.
libinput-gestures is currently running as a desktop application.
libinput-gestures is set to autostart as a desktop application.
libinput-gestures is using custom configuration file.
The faulty touch jump error is annoying but I understand that one have to live with what one can do nothing about.
On the libinput-gesture github page there is talk of _internal command instead of xdotool. I have wmctrl installed, but the “_internal” syntax is completely alien to me.
Then, dunno if it’s related, here is what happens when I hit enter on “xinput list-props 10 | grep Capabilities” command :
Hope I’ve been thorough, first post ever.
Thanks for all guys, you all saved me from a lot of tight spot. But that particular issue I am unable to solve with all there is here or on arch forum.
Hope someone got an idea.
CHeers
